PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 [99] 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Supertech SPR-H1002D valve springs with Toda Spec B?
  2. 96spec EK's ls/vtec build
  3. yet another ls/vtec build
  4. What caused this?
  5. anr header - final input?
  6. Helie coil (sp?)
  7. B20 Block
  8. crank balancing...
  9. MA State Emissions on a B16 - Which cams would pass? ITR? Skunk2 S1?
  10. Give me advice on my B18C Type-R build
  11. lsvtec pics and problems...
  12. Where do you see the Honda All Motor scene 2 years from now?
  13. Cam Gears?
  14. Do i need larger injectors?
  15. AN-R Header right for me?
  16. received type r cams and need help...!!
  17. Another LS/Vtec Build
  18. which stock air box? searched.
  19. whp estimate.........
  20. gsr rods
  21. cams and cam gears
  22. passing smog (state Ref) California
  23. Race preped crank VS stock
  24. Built NA B18b LS block VS Built NA 89mm stroke B18c GSR
  25. OT: Need help with ticket(Modified Emissions)
  26. All motor GSR?
  27. b20/vtec injector suggestion..
  28. How much clearnace do ITBs need to breathe? From trumpet to firewall.
  29. dealing with pressure and ventilation when using itbs
  30. Je vs JDM
  31. filling the injector cut out on head (twm itb)
  32. 2.0 motor build
  33. B20 all motor build
  34. ctr valvetrain
  35. engine code 22
  36. a few pics of cars at a drag meet in Antigua
  37. i need little help with exhaust?
  38. question about header heat
  39. Best piston & rod combo for b16?
  40. searching for feed back on passward jdm c-f cai
  41. what pistons do u recomend? ive searched a long time
  42. The infamous NA is best! sticker
  43. Valve Clearance Question>>>??
  44. spring compressor YA8845
  45. UPDATE: fuel tank and Straight beam axle pics
  46. question about fuel presure gauge
  47. CTR cams...worth the money??
  48. new skunk2 pro manifold...possibly rebuilt???
  49. thottle body size?
  50. Better gas mileage
  51. To engine Builders, Cam shaft Holder question
  52. b18 crx
  53. Minor engine build, ECU options and inspection questions
  54. need some info
  55. got a question for any one with a streetlite act flywheel for 90 integra
  56. Turbo F22
  57. Camshaft ?'s
  58. toda gasket question
  59. HELP VTEC TROUBLE
  60. -- Rocker Arms -- Any secrets behind them?
  61. LS/V-TEC W/ OF W/OUT BLOCK GUARD
  62. valve to piston clearance?
  63. d16z6 block, zc pistons z6 head, what comp ratio !
  64. piston help
  65. 5zigen HEADER how good is it compared to TODA SMSP ect???
  66. Del Sol D15B7
  67. B18A1 Vs B20B block
  68. a few questions
  69. phearable.net 2 step launch
  70. Which velocity stack is better?
  71. DH-Racing Billet Throttle Body
  72. Weird idle & power loss
  73. Trouble with intake monifold
  74. new bold fab header
  75. Bearing question
  76. Blox Type B
  77. OEM rings or other?
  78. Need help reading the degrees on the JG engine dynamics gears
  79. ls-vtec block guard(searched)
  80. J's racing header?
  81. ECU question!!!
  82. Skunk2 pro2 or buddy club spec IV cams??
  83. Should I use the Skunk2 Pro Series Manifold for my B20Vtec?
  84. Compression ratio calculating FYI
  85. B18A/B and B20B
  86. Where can I find ITR LMA's?
  87. CTR piston, safe in b18c??
  88. Bearing Shells
  89. Installing ARP head studs-Help...
  90. best swap build for a obd-1 95 teg ls
  91. SKUNK2 stuff and 92-95 Civic 2door stuff in SAN DIEGO
  92. Soarer front clip?
  93. YAY, another ECU question...
  94. Why cam timing matters... Picture of King Motorsports Dummy Motor
  95. k20a2 dyno
  96. Synthetic Motor Oil
  97. Do I even need a catch can?
  98. Eagle Rods
  99. cams
  100. pistons question
  101. Whats a good header?
  102. 226.86whp 157.65tq thanks to Redzone Performance.
  103. JDM b16/ how much should it be making and how to get more
  104. DD Setup?
  105. wat optoins do i have with a d17
  106. Im wondering wat cam should I use on my New B20V build?
  107. ITR valves
  108. Heard of XS Cams/Valvetrain ?? Need Info!
  109. tune for break in period
  110. input on cam choice
  111. Pressing in wrist pins...
  112. rebuilding a D16Z6. got a few questions
  113. F20B clearance using H22 Crower Stage 3 cams
  114. which cams to buy
  115. B18C1 almost build time (advice needed)
  116. ZERO-1000 Power Chamber intake system
  117. white smoke out of my exhaust?
  118. I'm wanting to rebuild...
  119. megan or dc headers?
  120. Who has honed there own cylinder walls?(insight D.I.Yer's) Please comment images
  121. have some questions and need some info!
  122. Last Minute Camshaft Change
  123. ARP Rod Bolts
  124. Moroso Oil Pan question
  125. CTR Cams
  126. Poor mans type R
  127. NON-VTEC cams/valvesprings/valvetrain thread...give advice/comments
  128. Why Do Bigger Ports / Runners Make More Power
  129. Need help with cams!!!!
  130. Best online place to buy Toda Springs
  131. ARC intake dealers
  132. can itr pistons take the abuse?
  133. A Quick b20 vtec question
  134. How to find how much much material has been removed from head?
  135. Buy parts from Fox Race Co and this is what you get......
  136. Quick Question...your input is appreciated!
  137. question about my new lsvtec setup...
  138. D15B help....
  139. which valves??
  140. IM manifold for b20v
  141. Bearing Colors Arent Matching Bearing Chart?!?!?!Please Help!!
  142. Hayward Performance for Port & Polish?
  143. who can i get to install GE sleeves in b20 and will i need them?
  144. Fezzie's makin progress!!!
  145. Crank machining
  146. Cam gears not lining up... need help!!!
  147. Arias Custom H22 High Comp Pistons..... check these out!
  148. F1spec has a header?
  149. Where are the Cam Cards??
  150. out of the three which would u build
  151. k-series exhaust size
  152. buildin my B16a2 heaad and need to know some advice?????
  153. ports and valve sizes
  154. rear main seal
  155. Checking the condition of pistons after a 4 months use
  156. Headlight Intake
  157. Revving b18b to 9000+
  158. Skunk2 Pro 1's???
  159. about my k20a2
  160. b16a swap
  161. B20 VTEC need advice on selecting cams, manifold, t/b
  162. whats next??
  163. Hey guys, school me.
  164. Difference in CAM GEARS
  165. D16B5 piston dome size?
  166. What pistons should I install?
  167. What model AEM intake do i order for EG with JDM ITR ??
  168. whats wrong with this?
  169. What happends to the b16 when using an LS tranny?
  170. skunk stage 2 cams or crower stage 2's
  171. racing flywheel
  172. F22B2; 97 Accord
  173. using a d16y8 intake man on a d15b head????
  174. itr tb??? and sparky headers???
  175. B18c1 Set up from import builders
  176. Video from HondaClub Spain
  177. Which B series for more Power With a Built head?
  178. loses power
  179. toda valve springs and retainers with skunk2 pro 2's>?
  180. dc type r 4-1 header?
  181. Installing Ls crank into a GSR
  182. LS crank/GSR block
  183. Skunk pro stg1 cams
  184. Skunk pro stg1 cams
  185. hydro or cable??
  186. jasma header
  187. d16 stuttering in lower rpm's
  188. itr bearring color chart
  189. ll sec?
  190. Skunk2 Pro 64mm Manifold w/ 64mm throttle body (maxbored)
  191. LS/VTEC Dyno
  192. B16B pistons.. a bad idea?
  193. would you recommend this for an all motor build?
  194. need help - white smoke
  195. !!!00 JDM ITR in to a 98 Civic: No check engine light and still wont start!!!
  196. Rough Idle At Start-up during cold.....
  197. My simple B20
  198. KTeller Tri-Y Header??? Anyone use it?
  199. new problem with my B16
  200. Ebay Pistons and rings?
  201. Inlet port divider: location
  202. All motor single cam non vtec d15b?
  203. ke Toda Timing Belt
  204. HUUUUUGE PROBLEM V-TEEEEEEEC
  205. K20/K24 Exhaust size
  206. bogging issues plz help
  207. Dry Sump
  208. Most reliable valvetrain for h22
  209. JUN stage 2 or 00 Civic R cams
  210. ported neon head and manifold i did
  211. Cams
  212. Stockblock B20vtec Problems?. A little help..All Motor Heads
  213. BOTTOM END BUILD
  214. Exhaust Mods
  215. timing belt broke. Need help SO CAL
  216. hmmm...about arp head and main studs??
  217. Max power with use of a exedy stage 1 cable clutch kit???
  218. UBERDATA
  219. Crome tuner in San Diego??
  220. Suggestions/Opinions needed
  221. P1-TUNER Blox Cams
  222. help
  223. What numbers will this make ?
  224. help or any suggestions
  225. My B20VTEC Dyno
  226. Better header worth it for my setup?
  227. Topline Pistons?
  228. Piston Slap and broken rings, please help--
  229. To TWM ITB or NOT ? 2.0l Motor
  230. headpower
  231. what afr's should i be aiming for?
  232. Brian Crower Crank Jammed My Motor!
  233. Adding Molybdenum Disulfide to Engine Oil ? Good or Bad?
  234. would this work, anybody running this setup ??
  235. obd-0... what are my tuning possiblities..
  236. reliability of the type-r oil pump...
  237. whp #'s?
  238. Max port
  239. need help on info of displacement
  240. Part number for ls/b20 arp rod bolts?
  241. ? About the BLOX Dual Valve Springs
  242. JUN type 3 cam lobes spec
  243. USING BDL 70MM TB, WHERE TO PUT THE IACV LINE NOW?!?!?!
  244. Golden Eagle Ls-v kit
  245. Flow benches in CA
  246. Wrong intkae manifold gasket? Fucking eBay..
  247. question..
  248. BLOX IM, what bolts/studs do I need?
  249. engine help!!
  250. Anyone have trouble with RM retainers fitting their SL springs?
