PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. blox cams
  2. wat oil u recommend
  3. loud knocking sound from fresh ls/vtec build
  4. how much whp does an all stock ls/vtec make
  5. all motor h22, need help
  6. b16 trans into a 1994 gsr
  7. noob... but question on aem adj cams
  8. Itb
  9. All Motor Type R
  10. valve job question with new valves
  11. Need to know.
  12. Vtec Head Plug Question
  13. my new toy.......exciting!
  14. 2" collector with 70mm exhaust?
  15. need engine builder shop in so cal
  16. ingridients for a quik @$$ ls
  17. ITR valve springs with 11.9mm lift cam?
  18. *Ultimate Bolt On Shoot Out!*... many choices
  19. *Ultimate Bolt On Shoot Out!*... many choices
  20. toda spec b valve clearances.
  21. problems on my build
  22. rmf replica vs hytech replica?
  23. Need some Feedback!!!!
  24. Big cams + direct port 100 shot? good idea or no? lmk guys
  25. GSR Header
  26. I need help asap
  27. Big throttle body
  28. H22A: stock valves with JUN cams??
  29. Whats the maximum rev I can run SAFELY on ITR motor
  30. OEM ITR 4-1 vs Ebay 4-1 Headers
  31. 70mm TB am I losing power?
  32. Engine builders needed
  33. z6 head with y7 block, timing problems
  34. starting my g23 build
  35. a little stroker shopping
  36. Played with some E85 on a JDM ITR in a "less-obvious" chassis today...
  37. B17 Cams Vs B16 ..need help
  38. Super D!!!!
  39. Brian Crower oops?
  40. Having trouble finding PR3 Pistons at the Honda Stealership. Help!!
  41. Header question
  42. Is it wierd that my cam timing is untouched?
  43. Crankcase Pressure Help!!
  44. I want to increase my horsepower
  45. RMF replica h22, anyone tried it
  46. Wats da best header out on da market
  47. Zero Deck height B18C1
  48. H22 throttle body
  49. GSR piston squirter causing problems?
  50. any one knows what a gsr 20 over would b
  51. Sad Day. (Dyno #'s)
  52. Skunk2 MegaPower Header?
  53. Bronze guides: guide v. seat wear
  54. Exotic Piston & Rod Combo: Update with Pics of Prototypes
  55. PR3 Heads
  56. oil usage
  57. YAY or NYAY..k24 dyno inside
  58. Roller killer cams - video
  59. Notched GSR Block?
  60. need help with my motor
  61. oil pressure question
  62. pro 1 timing belt jumpin off vibrant tension good idea?
  63. b16 advice did some research found nothing
  64. B18c1 block with CTR pistons with B16 Head.
  65. b20b intake
  66. S2000 F20c inside
  67. Spring and retainer question for GSR and ITR cam combo
  68. blowen headgasket I think
  69. what kind a piston is this pls. look
  70. 2 layer Headgasket
  71. 93 delsol Si wire diagram?
  72. Is there a knock sensor for the b20b block?
  73. Are arp flywheel bolts a must?
  74. Mix & matching rockers
  75. HELP before Tune
  76. B20b vtec problem!!
  77. CTR pulley on b17. Heard that I shouldn't use it (vibrations=oil pump failure?)
  78. d15b8 intake mani on a d16y8 head?
  79. LS with a little umph, quick question.
  80. HG question
  81. Best Advice: Engine Assembly
  82. question about oil ring
  83. What size shim did you end up with?
  84. P73 question type r help!!
  85. my new jdm h22a swap
  86. I need help with my H22 w/ Stage 2 Crower cams
  87. spark plug question
  88. advice please, jdm b18c rebuild
  89. need help onrebuilding gsr block
  90. B17 Build, advice on pistons?? Rings all same for b-series vtec??
  91. Top Line Automotive Engineering Valves
  92. a few "mini me" questions
  93. Couple build questions
  94. Type-r vs. B20V
  95. pe width tolerances?
  96. My Ls/V Build recommend girdle?
  97. Bisimoto 9 sec all motor rev/idle vid
  98. Anybody heard of or tried the BWR Intake Manifold???
  99. Idle question.
  100. B16A2 valvetrain / head update
  101. who likes your all motor ls? non-vtec.
  102. greddy timing belt issues
  103. running different intake than the one I tuned with, how much does it matter?
  104. blox type a on stock compression gsr
  105. B20-V vs. b16
  106. need help on head studs
  107. obd1 gsr keeps dying
  108. what clutch kit for lsvtec
  109. blox intake cause missfire?
  110. should i get this header??
  111. gaskets ?
  112. good quality hytech/tri y replica? where?
  113. Price???
  114. Camshaft centerline VS peak lift
  115. Compression Ratio Question - Not a calculator
  116. B18C Brian Crower Stroker Kit
  117. Can I use a CTR Piston on a forged rod?
  118. stock LS motor with Hytech replica, yes.. no?
  119. Mostly new to tuning and have questions please answer nicely lol :)
  120. found very good cam info!!!!
  121. Gsr head help please
  122. poor man type r or lsvtec need help???lost??
  123. valve-to-valve click
  124. Deck height and milling question (searched already)
  125. Help on cam tuning
  126. b- series ques??? please help
  127. b18c gsr skunk2 header vs toda
  128. 1000 cc injectors big enough
  129. Plug,main bearing bridge
  130. Hydrolocked my ITR
  131. Will 81 mm itr pistons fit on a 81.5mm bore block?
  132. Camshafts?????
  133. Need help identifying these cams**ASAP
  134. h22a1 with type s pistons
  135. B20Z2/ VTEC need some help!
  136. Questions about tuning?
  137. Oil Squirter Block-offs?? Any advantages??
  138. turbo?
  139. cam degeeing and dyno tuning
  140. noob ITR build
  141. LS/V doenst want to start up
  142. another LS-VTEC build!!
  143. Basic All Motor LS vs. Basic "unreliable" ls/vtec?
  144. Degreeing cam issue with Crower3(63403) cams and Mugen .47 two layer head gasket.
  145. b16 with b17 guts
  146. D16y8 non vtec
  147. b head type lma washer for spring type and lma rebuild
  148. Need help to decide what stage 1 cams for DD/street b18c1
  149. Fully Built Motor - Break In Questions...
  150. b18a head on b16 block???
  151. More vibration after flywheel install
  152. Should i get it tunned?
  153. Piston to valve measurement, with headgasket or not?
  154. skunk2 pro series in h22 ej coupe?
  155. mini swapp
  156. My stock sleeve b20vtec build
  157. spark plugs?
  158. GSR flat face valves dont sit flush
  159. stupid noob question?
  160. Best/Non raspy clean exhausts for civic?
  161. b18b dizzy on b18 a
  162. is it safe to spray with this setup??
  163. b18b1 w/ITR pistons/rods
  164. Coolant leak at front passenger side or head
  165. wiseco pistons ?
  166. Block has Hair Line crack ...HELP!
  167. 97 spec Type R flywheel in Cable Tranny?
  168. help me identify these cams
  169. D16z2 (also known as D16a6) Mini me..
  170. jdm euro r accord h22a engine build
  171. skunk2 valve springs and retainers????
  172. Piston to deck height with LS crank/rods in a GSR block-
  173. b18b intake on a b18a head
  174. skunk2 stage 2
  175. B17 or ls-vtec what would you build
  176. cams???
  177. Myth busted or plausible: stock ls/vtec with valve clearance issues?
  178. B16A2 Head Problems
  179. Loosing coolant NEED HELP!!!!
  180. Reusing piston??
  181. pmtr bottom end
  182. Mugen Twinloop Exhaust
  183. piston-to-deck height for B18B?
  184. Header options for 2.25"
  185. Anyone using those f1 racing clutch flywheel kits from ebay?
  186. Crazy frankie build up idea....
  187. Question on Skunk2 cams
  188. Purchasing Engine Parts in Japan?
  189. jumping ilde car shakes under load
  190. header bolts stripped
  191. Catch Can question
  192. running lean...maybe a misfire
  193. VP Q16 Race fuel for All Motor
  194. what flywheel for my b20v all motor build
  195. will my motor run
  196. b20b + b16head hp ?
  197. b16 head help
  198. s2000 Header
  199. B20vtec build; help me choose my components
  200. Best Guestimate w/ new TB?
  201. Type R cams
  202. K20 rockers on b18c?
  203. What setup do u recommend?
  204. crower stage 1 and supertech springs TIPS
  205. Need help. Need an S300 .slk file/base map to help start my car.
  206. help with all motor b16 setup
  207. Brian Crower crankshaft needed ASAP
  208. K24a4 any different from an a2?
  209. b16 head flow
  210. Gude Performance
  211. help decide what motor
  212. What clutch kit to get
  213. b20 cams in a b18?
  214. All motor b20v build
  215. will valves clear gsr block gsr rods ctr pistons b16 head
  216. OEM Rebuild B18C1
  217. ECU Woes...
  218. My ls/vtec build...how much hp?
  219. 84mm b16
  220. all motor noob questions.......
  221. Rod Bearings Help
  222. Cat back question.
  223. will pistons fit rods???
  224. Jdm d15b p08 rings?
  225. Mini Me Swap HElP!!! PLEASEEE
  226. B20 vtec build
  227. help me choose a new header
  228. blox type C too big for stock itr?
  229. what motor is this b18c type r or gsr
  230. should i run open header??
  231. engine bore
  232. D16z6 HELP
  233. Buddy Club K Series Spec II & III camshafts
  234. ls/vtec build
  235. B-series starters, interchangable?
  236. b series bare block build up
  237. GSR cams on B16A2
  238. Is it worth it?
  239. LS VTEC HP Predictions
  240. exhaust suggestions
  241. b serious
  242. What blasting equipment for heads and IM's?
  243. Cams and Piston Combination
  244. GSR Rocker Shafts
  245. b16a2 Need advise please
  246. Question about motul oil
  247. Going from 103 to 110 octane
  248. Is it possible to repair this camshaft ?
  249. Leakdown tester
  250. Had my head rebuilt- Does this look normal?
