PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 [113] 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. buddy club spec II?
  2. how to read casting dates?
  3. Anyone tried this header??
  4. Does this seem right? Dynoed my GsR/EG
  5. Throtthel body for my EJ2 swap b16a2
  6. pr3s or ctrs. in ls/vtec.
  7. Valve clearance...
  8. Idle on sk2 pro 2's ?
  9. Identify these pistons
  10. buddy club iv tried search
  11. before i make a mistake...
  12. toda timing belt and cam gears question
  13. i have a question
  14. HOGAN INTAKE MANIFOLDS
  15. JDM automatic p30 ecu- Hondata S100
  16. b16a2 99 si build
  17. z6 crankshaft the same as a6?
  18. CR-VTEC ??????
  19. Post your HP TQ estimates for my setup
  20. All Motor K series in DA
  21. what exactly is it?
  22. how to tune partial throttle on a dynapack?
  23. this realy isnt on subject but its about this thred/forum or whatever
  24. b18c5 rebuild
  25. camshaft choices
  26. Single layer HG??
  27. Need Help identifying Skunk 2 stage 3 cams
  28. Perfect Intake manifold?? OPINIONS NEEDED!!!
  29. im stuck need help cam problem
  30. From Pro1 to??? Need help choosing a new cam BC4 or JUN 3?
  31. b20 dipstick
  32. what kinda power would a built jdm type-r put out??
  33. Is there any physical differances between BC3 Vs BC4?
  34. just started up the new motor!! vid inside! .. same motor with 1" deck.
  35. Which valve springs, Rocket gen 1 or gen 2
  36. help with my Ls v-tech
  37. CTR pistons in b16a2 block with Type R head questions......
  38. cam cap bolts dont go all the way down?
  39. Pics of my H22 build
  40. B20 vtec Trans?
  41. Brian Crower products ?
  42. Need advice b16 n/a
  43. The REAL B series engines...
  44. Dyno'd my setup- What should I change?
  45. JDM/USDM B18C5
  46. h22 del sol rebuild
  47. blox cams:competition series vs tuner series?
  48. Dyno Testing - BPi Flow Stack & Injen Velocity Stack Filter
  49. b16a or b18c head?
  50. 83mm safe?
  51. Header Question
  52. What intake to use for a b-series engine, in an eh hatch, with an edlebrock victor manifold?
  53. broken cam
  54. Will running 12.5:1 Pistons be Safe?
  55. whats the best compression for........
  56. any such thing as a true 2.5 prebuilt exhaust that sounds good?
  57. sleeve question
  58. Ls Vtec
  59. I actualy bought and installed the xs power cams and valve train!!
  60. my ls/vtec build?
  61. tell me what i am geting myself into with my set up
  62. gsr cams into a b16a?
  63. What motor you use?
  64. ok i need some help here
  65. LS crank/rods RELIABILITY in GSR bottom end
  66. weird stalling problem on built gsr motor.
  67. msd cap which one
  68. Jerking problem
  69. My Future Built head - Do I have everything right - Help me from disaster!
  70. why wont my car start??? details inside. !!!!!!
  71. Custom header
  72. B20/VTEC CAMSHAFT???
  73. Should I be making more power than this???
  74. Safe RPMs on my ls/vtec setup???
  75. valves necessary?
  76. valvetrain?...
  77. Need help- Head was wet on the inside?? Normal-
  78. 9200 rpm shift on stock b16a2
  79. Dual Valve Springs with CTR Cams
  80. head gasket
  81. fueling
  82. f20b cam question
  83. Spoon Camshafts
  84. 99 accord
  85. wings west lip
  86. Building a B20
  87. question about blox cams for h22a
  88. How bad is it to drive with my valves clicking?
  89. The car stumbles during acceleration after engine rebuild...Please Help
  90. Compression ratio of 10.5:1 and 91 octane???
  91. Throttle Body... is bigger always better ?
  92. big bore stock sleeves
  93. crane stg 2 cams
  94. b16b and b18C5 weight difference?
  95. Axle popped out...
  96. clickin noise
  97. CROWER (K24) STROKER KIT...ANYONE HAVE IT???
  98. about high compression and pump gas?
  99. Skunk2 Pro+2
  100. MSD ignition?
  101. 90-93 LS water pump same as 94+????
  102. a6 head gasket equivalent
  103. help me pick a cam!
  104. Anyone in SoCal have P8R B20 Head Laying Around???
  105. breaking in motor. synthetic or regular oil?
  106. need help asap
  107. Need Help on a B17a1
  108. H22 Prelude N/A questions
  109. Detail skunk2 pro series manifold installation
  110. 96 GSR swap w/ITR cams
  111. B18C4 Rods vs Revs
  112. what's best?!
  113. BUMP got his B16A2 tuned
  114. anyone skunk2 IM on stock ls?
  115. JDM B16: Which 4-2-1 header?
  116. B20 Debate
  117. CAM INSTALL
  118. Making my first N/A motor need hlp
  119. Budget LS-V hits the dyno. Finally cracked 200whp.
  120. jdm 96 spec itr crank rods w/new rs 84mm 11;5 pistons IN A B20B???/!!!
  121. comptech header question
  122. B16a mild build info needed
  123. motor purchase question
  124. Cracked spark plug - Heat range too hot?
  125. Blox H22 Cams
  126. Whats a GOOD Header for H series
  127. Thoughts on my B18 build plans
  128. help me find this thread!!!! it was in the all motor section i think
  129. Finally took the all motor ef to the track...
  130. ITR valve springs with aftermarket cams???
  131. b16b valve springs
  132. b18c1 block n' b16a2 head
  133. INVIDIA HEADER?!
  134. Back from the track LOOK INSIDE (ls/vtec)
  135. Good n/a GSR build for a daily driver/autox?
  136. Fuel pressure GAUGE question
  137. 99 jdm b20b dyno
  138. hondata s300 b16 map?????
  139. Need a link to the cheapest source of B18A bearings available
  140. in progress of building poor man's type r
  141. ecu and power potential question
  142. REPUTABLE Valve Adjustment shops IN BAY AREA?
  143. My B20/vtec build up
  144. Any good machine shops in cleveland ohio area for LS VTEC machine work?
  145. evo 8 fuel pump
  146. arc air box
  147. strength of stock b18a rods....
  148. B20 Post your set up.
  149. header Q
  150. that jg or skunk 2 intake manifold?
  151. 200whp lsvtec??
  152. b16a2 setup
  153. ls/vtech question
  154. Question that i need answered
  155. stupid question...
  156. 8lbs or 12lbs????
  157. got a question
  158. Volumetric Proficiency by Combustion Contraption... 85x89 Build
  159. My B16A2 build officially started tonight....
  160. piston to valve clearance
  161. Dyno/Engine Sim?
  162. GEO B16a swap?
  163. which headgasket
  164. Suggestion to my setup?
  165. B16b Build up
  166. What Cams for my set up?
  167. ignition timing question
  168. Stock Tachs are EXTREMELY INNACCURATE!!
  169. zealautowerks.com CR calcualtor
  170. Dyno Numbers after changing electric water pump & individual coils.
  171. question about crankshaft
  172. B16a6 + BuddyClub Spec III+ Help
  173. how many hp?...and after tune?
  174. Buddy Club III and portflow inner valve springs?
  175. ? what is the most aggresive stock d-series cam ?
  176. velocity stack for j's/passwordjdm/memoryfab, etc style intake?
  177. Need B16 rear block view. Questions
  178. any truth to omni power ITB's
  179. Honda Crx Si motor
  180. Blox A ob B cams? 10.6:1 JDM GSR
  181. HELP WITH MY SETUP!!!
  182. Need answer quick- TPS Sensor Swap
  183. Where would i go about getting my computer chipped?
  184. what do you think about toda timing belt?
  185. What do you think about these cams?
  186. pv clearance ?'s
  187. what will a chipped p28 ecu do?
  188. Curved airhorns for itbs?
  189. Mini-me + what = 180 hp?
  190. What size Injectors should I use.
  191. i need info please!!!!
  192. 2.0 GSR build with track video
  193. ITB's...is it worth the money??
  194. Need advice on DC5 Type R cams on my FG2
  195. LS/VTEC Build Questions. i have searched.
  196. Horn used as nitrous activation??
  197. a6 pistons, y8 head, z6 block
  198. need help asap please
  199. Honestly is there any difference between Hondata and Uberdata?
  200. 1.8 liter ls/vtec dyno
  201. frankenstein motors
  202. buying a b16 to go all motor
  203. engine pic
  204. I'm in a delima
  205. Built SOHC OR B20.
  206. RLZ/SPEED INNOVATIONS Build
  207. ALL MOTOR NON VTEC's CHECK IN!
  208. k20 & Icebox ??
  209. Question's on a p61 ecu & a obd1 p72 on a jdm gsr motor with bolt on's
  210. what cams to get?!
  211. .9mm rod length difference?
  212. Stroking B16b.....? inside
  213. what needs to be done to fully rebuild a head?
  214. Dynamic Compression Discussion
  215. Setup to achieve 150+ horse on a y8?
  216. b16a2 all motor
  217. Whats a good camshaft for a d16y8?
  218. took pics of my motor in my car finally!! 1"deckplate....my hoods gettin right hacked up lol...
  219. do i really need an expensive header?
  220. Injector Question
  221. Blox Type B cams for DD???
  222. how much does a melted cat affect performance
  223. 12.6:1, No port! 1834cc b18c1- Skunk2 Pro2 Yes or No
  224. Toda Spec C Cams in CTR head
  225. ?????? What to do with jdm ITR BLocK at machine shop ??????
  226. Whats with the peak power hard-on people?
  227. 00' Integra B18c1type r pistons
  228. Honda's First CORR Win
  229. What cams and header for 1.8l lsvtec setup
  230. taiho and daido oem bearings.. difference??
  231. do you use a short shifter on your NA cars?
  232. Puting an integra radiator into a civic?
  233. Can I run aftermarket rods on P29 pistons?
  234. Dyno'd my almost stock B16 today. Check it out
  235. Type R Camshafts on Stock Valve Springs and Retainers
  236. ITR Camshafts in an SiR-II B16a
  237. Advice on a 200whp Build?
  238. OIL PUMP QUESTION B18C1 and B16A
  239. safe to run on stock ecu for breakin
  240. Buddy Club Spec III+ Powered B16
  241. Cam choice
  242. Black wet soot on floor during warm-up
  243. piston/valvetrain or tranny upgrade?
  244. Do you guys believe in an oil cooler and catch can?
  245. Need help on buying a head!
  246. custom intake?
  247. RPM Services 72-70mm TB and IB ITR IM questions...
  248. Endyn Crank Case breather.. Is it setup properly?
  249. All Motor ?
  250. motor basics
