- AEM EMS tuning question
- F22 Head Buildup
- Build Up the Top Or Bottom End First?
- I need a built block
- Buddy Club Racing Spec III VS. skunk 2 stage 2
- Out with the Old, in with the New.......
- K20A2 guys what are you putting out?
- help me please oil leak
- what would have a better 1/4 time ........
- EGR problem
- Skunk 2 Valve Springs for SOHC.... Suck Balls!!!!
- B16a from 94' del sol in 89'hatch --ideles stuck at 3000 gs
- put itb's on today now i got a question
- Need help with oem tach
- B20 vtec?
- Headers??
- For those who do/have done their own tuning ...
- with LSD, the steering knock?
- del sol swap?
- Individual Throttle Bodies?
- Integra 2gen lsvtec tims
- Anyone ever heard of RPM in New York? for head work
- 2K to spend on All motor project..
- Integra Engine Question
- ITR 9k safe?
- Headers
- Ractive
- gsr crank question(searched)
- OBX Headers
- Short vid of the Tuned B18C R hatch
- Pistons hitting spark plugs!!
- can i run 11:1 je pistons on a b18c1 without any problems?
- Arias Flat Top Pistons = 10.1:1 CR... What's the best way to get it up to 11:1?
- B20 Vtec Upgrade
- Odd setting for fuel?
- Help with my radiator
- STR cam gear problem?
- Kamikaze Headers
- size of b20 valve grooves?
- what can we expect? think its time for some tuning..
- Whats the most miles anyone has got out of a 200+ hp setup?
- Jun 2's 160ttw WTF
- Making something good better...
- Steps on ITB
- Finally started building the H22
- ls/vtec suggestions?
- Twm jumps on board.
- Port head or Build block?
- stock honda muffler
- Coolant in Oil I need some help!
- loud sound at 6500
- all motor h23 dyno results (kinda sad)
- LS internals In B18C1?
- h22 pistons into an h23.
- will gsr acl bearings fit in b18b block
- Where to get new b18b1 block?
- Allmotor Shirt!!!
- The Build: Internals
- I need cam help!
- swapped JDM b16a in eg, having some problems, PLEASE HELP
- Stock b18c1 motor in my EG 13.8@100.65 (timeslip pic and video)
- ATTN ITB AMIGOS (FUEL FUEL FUEL!!!!!!!!)
- VTEC activation trouble
- Mystery Cams - Please Help Identify
- swapped b16.... what to do with map sensor?
- ANYONE USING OBX VTEC CAMS???
- Is porting and polishing necessary to make power?
- 2.5" collector 2.25" exhaust
- what mufflers have a 2.5" inlet?
- OBX camshafts
- b18c7 ??
- Racing B-Pipe
- does honing mess up the way your engine seals?
- Individual Coils
- LS/VTEC boggs and stutters useing a JDM b16a ECU?????
- Is 87 octane ok for 9:1 compression
- EAGLE RODS WONT FIT...NEED HELP!!!
- ZC twin cam : mugen 10/40 cams and valve spring
- Which spark plugs do I need?
- ATS 4.9 for my all motor b16?
- jdm h22a valve clearances
- help rad question
- Just installed a Toda header on my b16b swap WOW!!
- Looking LS\vtec builder in Ontario, Canada
- super problems, need ideas!!! thanks
- sohc vtec cams
- itb filtering
- pic ID - ITR Valvesprings
- arp rod bolts
- daily driven 404's?
- Valve adjustment specs??
- ctr pistons and skunk2 cam ?
- hp differences between pump gas and race fuel and open header and exhaust?????
- Looking for a machine shop in DFW to shave small ends of a set of rods I have..
- how much compression do i have?
- I REALLY NEED SOME HELP!!!!!!!
- how much $ does it take to carb a b-series
- Throttle body ques?
- Engine Building Advice??
- just a little question about a website
- obx cams
- jdm header on ebay?
- Is Hondata worth it with my setup?????
- SuperTec valves
- i love to buy stuff
- help i need info on my acura
- Cylinder head modification (exhaust port discussion)
- I need new cams.
- for everybody who's dyno'd thier all motor b-series.
- header flange (pics inside)
- oil line screw thing broke and its stuck in my block!! need lsvtec help
- IACV Spade Connectors for mini me?
- Hondata ?
- JUNIII w/ CTR Pistons
- which injectors?
- newbie to all-motor setup...how much power?
- MSD 5A vs 6A ignition....??~!!
- Update on my AN-R header
- ecu chip for my motor
- High CR.. do i need to upgrade the starter?
- losing power on H22 help!!!
- used pistons, yes/no ?
- piston swap.....legal
- stock b20 vtec..what is the most hp anobody has gotten
- type s swap
- Oil Pump Oil Seal Installation????
- Need help with ls/vtec bigtime
- WHICH PISTONS SHOULD I GET
- Pipercross Viper Intake
- b20z throttle body size?
- rasing compression in b16a2 ?
- b16 q's
- Injector sizes
- help need more power
- OBX LSD, anyone heard anything about this?
- better cam for autox/track jun or toda
- gsr exhaust camshaft identification
- B16 head getting milled
- Constant/Fixed RPM and Synthetic Motor Oil
- spoon sports quality
- power difference between b16 and built ls/vtec
- TrueRace K20 Header and stuff
- found most of the miss.
- how much smoke is normal during break in?
- fitting ctr pistons to b16a rod bolts ?
- spark plug problem...
- jun 3, which valves ?
- TWM Itb in LS/VTEC 1.8 whp dyno.
- Skunk2 Stage 2 Cams/Springs/Retainers - B16A2 - Do I need the Valves?
- World fastest all-motor accord wagon (daily driven)
- ecu question help???
- How to get power out of a D15B7?
- tune up
- hondata ecu
- B-series swap
- best header for b16a
- head work on my rs integ?
- milling the head
- How high can you rev an H22 on stock bottom end?
- b16 pistons in 81.25 or 81.50 ??
- omni power (omni man) VS. RM(ef-1)
- removal of stock rods from pistons
- Please help, acceleration problem
- Doing b20 swap
- Higher compression b18c1 and stock ECU?
- HP AND BOOST LIMIT QUESTION
- 200 whp
- Check this setup out!!!!
- All Motor Ls VS Turbo Ls
- Integra LS (B18B) N/A Setup's PLEASE....?
- rev limit for B18C5 with skunk2 valve train?
- just got dyno results
- crane stage 2 cams & valvetrain
- Is this real??!?!
- How can you measure the C/R
- b18c5 or Toda Race header?
- whats the first thing to break on a b series?
- WTF is on my rod cap? (56k prolly handle it)
- looking for input on z10 engineering's machine shop
- aebs sleeves?
- Whats more important--compression or crank pressure?
- Best race Header Jun, Smsp, Toda, An-R, Spoon. . . .
- b18c1 head milled .020 what cams? Will i have clearance issues?
- What rods for fuily built lsvtec
- what do you think about different intake cam than exhaust cam?
- Edelbrock Intake manifold?over skunk 2
- Any dyno tuners in WA or Canada using free devices? (Uberdata, Crome, etc.)
- Piston Choice?
- Oil line help for vtec??
- Does anyone have any resonable info on an H23 block on an h22 head?
- B18C5 stock comp. 10.6 what would be better....9:1 or 11.5:1??????
- ls/vtech
- Race gas on 13:1 or higher
- Big cams high compression!
- reving to 9500 ls vtec
- 9.5k RPM all motor, should i upgrade alternator?
- Want to run LOW 13 sec. quarters in street trim 98 EK hatch
- Bolting down a B16A head...
- How high can you rev a stock JDM GSR bottom end?
- Love Fab H22 Headers
- questions on small N/A build
- good newbie all-motor setup? need opinion..
- from Turbo to all motor. thinking of joining the club
- Engine management, confused as hell!
- B18C1 or B20 build up?
- short 1/8th mile video
- Cometic Head gasket question
- Buddy Club cam quality?
- anybody seen a fast 4 door before?
- Intake Piping Shortened
- Tired of the msd switch how do i do it right ???
- tb coolant bypass on an eg ? tell me how and what gains to expect?
- Is that true Spoon 2.0 L stroker kit using B20A crank???
- First NA build: Wanna comment on my setup?
- ITB Builders... I need help with a couple of questions... ?
- Civic Hatch b16 Suggestion Setup Please
- b16 All motor DYNO, Built stock stroke
- K20A2 Vs. K20R
- Need your guy'z help/opinions!! b16a2 build
- need help?!
- what are these cams comparable to?
- Anyone know where to buy a valve spring compressor for a B18C1?
- B20 Sleeves
- LDL pics from LV TnT 7/09 **56K warning**, Drag strip debut
- Looking for the post that has all the different measurments and misc info on headers.
- Mini-Mase-a-palooza South Carolina Tour
- engine weight???
- help how to make my aerodeck 3 gen with A20A1 engine make faster
- Walbro Fuel pump 190 LPH
- Questions for b20 vtec build.
- Greddy SS 4-2-1 Collector Size
- Which pistons for b20/vtec?
- Location for wideband o2 bung on header?
- How to tell how type r head??
- itr fd in a 99-00 SI tranny and where to buy synchros?
- Need opinions to get 170+ WHP
- pics of my new NA block
- anyone tried out the golden eagle/ hp racing intake manifold??
- check this all motor set-up B18C5............
- GSR INTAKE Valve springs, and ITR exaust springs are the same?
- Gsr with jun cams... Valve lash??
- Mugen head gasket
- what kind of grease is used to torque the head bolts down?
- Which Pistons???
- New AllMotor piston available off the shelf with 13.4-1 C/R
- h22 or b18?
- increasing torque
- alternator belt problem
- port and polish b16a2... what kind of gains?
