- Breather fitting on valve cover?
- What car should I buy K24 out of?
- my car so far
- NEED HELP BAD!!! Broke something!!!!
- BLEW 4TH MOTOR!!! WTF IS WRONG???
- Cams LSVTEC
- which head?
- Full Race ls/vtec kit Is this all?????
- swapped H22. cranks but wont start. fuel pump not priming. help!! *searched and did everything*
- dsm 450cc inj on a build lsvtec
- Bought a B-series monster cheap... here's the story!
- H22a Allmotor Build Up??
- DOHC ZC vs Type R
- fitting itr cams?
- Engine Shops/Builders in SoCali
- b18c5 w cams and bolt on's.
- TODA B cams + supertech springs ?
- Alcohol / Methanol Injection - Detonation Band-Aid?
- ls vtec cams
- help!!
- Pics of NEW PARTS (SSR header and S2 cams) but i do have another problem......
- What are the gains on Thermal Barrier coating the piston, combustion chamber, valves and exhaust por
- Non Honda Motor Need Build - Up advice
- Bearing Clearance Measurement
- Stroker setup
- GSR Rod bearings
- ecu question
- catch can question
- Fuel upgrades? Searched
- h22 cams
- Pro Fab Tri Y header???
- oil weight
- scratches in crank? need new one?
- Motor boggs out HELP!!!!
- valve adjustment specs for crower stage 3 in h22
- How quick is an eg hatch with a stock B18c swap??
- piston???
- suggested settings
- b series in eg. help.. asap
- b20 swap ecu question
- exhaust camshaft intsall problem
- What should I do? Main bearing problems
- ZC / D16A1 DOHC, can a SOHC VTEC head be fitted to it?
- Wiring tps on twm itb's
- Interesting...Blue Top H23A beware:(pic intensive)
- Best Base for NA?
- h23a1 n/a prelude?
- How safe is an 8600rpm Redline??? (k20z3 - si)
- e-85
- best cam for a z6 motor build?
- searched: found very little, long first gear
- gauge hook-up
- DD N/A GSR plans
- HOW CAN I MAKE MORE POWER
- running rich
- using used pistons - what to check?
- What is match port-
- Can a kind person review my setup to see if theres something missing???
- Buddy club?
- 2.25 or 2.5 exhaust
- Help me identify these D16Z6 pistons SOHC high compression
- experiencing bogging with 1/4 tank of gas?
- B16a w/ gsr crank?
- dowel pin???help ASAP...
- what is the difference between b18c1(us) and (jdm)b18c??
- Impact of Piston Weights
- Arias Pistons dealers...
- Autometer A/F ratio guage
- Fuel pressure regulator required?
- K-series RMF header???
- Piston coated - PR3
- building all motor b16 help please?
- skunk2 question...
- MY fresh build continues to be a pain** LSV**
- Gs-R pistons
- need help ASAP! pr3 throwing code 68!????
- Best Valve Springs???
- H22A Port & Polish - Expert Feedback Needed
- 64mm to 68mm throttle body
- how much will this N/A make?
- Will weather Temperature affect Horsepower.
- ITR cam owners...
- any help msd
- b20 nonvtec build... input?
- anyone know anything about a b18C4???
- B18A1 tries but wont start
- B16B + Buddy Club 4's? (BC4)....
- Which GE sleeved block for my build - B18c1 or B20?
- PLX iMFD (simply amazing)
- Had colder plugs for nitrous, now N/A
- skunk pro series question
- Stainless Steel Header Options Under $700
- explain to me what this means : piston dome cc vs. compression
- certified JDM b18c motor in cali?
- open header question..
- ls crank in a type r block???
- Built CRVTEC power curve problem, dyno sheets inside, any ideas.
- ARP main stud choice???
- build finally done!
- Fuel Pump
- pro1 users-how far have you advanced your intake cam?
- MSD rpm activated switch for IAB?
- camshaft compairison?
- obx cam specs for d16z6
- best mid-range header
- LS power
- Advice before I go back to the dyno PLZ
- questions about gsr pistons
- Rage & Profab?
- blox cams
- BPi Flow Stack!!!
- "middle of the road headers"
- which pistons for lsvtec with s2p2 cams in a (street car)
- EPROM chip problem...broken prongs
- 92mm stroked motor
- 9sec all motor crx
- compression ratio affect smog?
- how to rebuid (aftermartket)???????
- Bad/Bent Valve? Noise from upper half!
- obdII----->obdI
- question about gsr headers
- How to calculate cam lift?
- crower 62403 vs 62403-2 ls
- type r lsd
- Why Better cams wont push more power for me??? Also Help me find out what Cams these are!?
- If I have a 1.6 L non vtech engine and i want to put an Integra 1.8 LS motor.....
- mugen cams
- All Motor SOHC
- Timing Belt
- Knock sensor and 02 sensors needed?
- Engine Starting problem
- clutch and flywheel help
- Price comparrison ITB vs Coldair intatake, TB, IM (& reworked)
- need advice on setup
- Not resurfacing a flywheel...any major effects?
- HELP!!!!! Dyno Results b18b
- PR3 rod mod delimma
- re use main cap bolts?
- post your BIG bore HIG comp NA builds...!!!!!!!!!!
- light weight flywheel ????????
- What header will be a good relation between price and useful power?
- NEED Help Quick....How to identify Skunk2 Stage 1 Cams For B-Series VTEC
- cams and valvetrain combo
- What cams are these ?
- Ignition Tuning. Hondata Basemaps too much timing????
- A few questions about my 82mm bore and pistons
- OBD-1 VS OBD-2A/B
- D16Y8 MODS
- Itake system and hp gains
- TUNING MY H22, WHERE IN THE BAY AREA IS THE BEST?
- ACL Race bearings
- Need Help!!!!! Oil Pressure down to 10 psi
- Pics of my new customised CF ITB airhorns....
- h22 electrics
- am i likey to lose power here? or posibly gain a lil?
- cams on 00 si
- 89 crx engine problem
- gsr compression at 230psi across, will 100 octane bennefit?
- Is my head ported and polished?
- for discussion: anybody done an E85 conversion and tune yet?
- inspections
- questions before i start the swap.....
- take a look, omni power VS RM valves (read)
- How to tune the Ecu of my civic?
- supertech springs/retainers/flat valves with skunk 2 stage 1 pro's
- b17 with b16 rods/custom pistons all motor build Q's
- could help identify my jun 2 intake cam?valve adjustment???specs
- Need help please ................ thanks
- b16 build up help needed
- XS Power Stg. 2 Cams
- car is boging?need assistance
- Where to buy bearings?
- Mods for my b18c5, appriciate the input
- Help LS V-TECH turbo injector problem
- cam question
- polishing intake ports..... any gains?
- can a stock b20b pass smog?
- What do I do...crankshaft journal has a tiny knick....
- HELP Injectors question
- JDM H22 Back from the dyno
- my plans for a C1 daily driven street motor..need a few suggestions please.
- B18C5 Lawnmower
- Preventive maintenance?::: Aftermarket Valvesprings and Ti Retainers
- Just for discussion: This guy's site says 30% smaller ports make more power
- !!!!___I think i my Motor is done for_____ HELP
- H23 vtec cam gear adjustment and spark plugs
- redoing the setup i need some cam advice
- what throttle body
- "piston soak?"
- Woke up to FedEx today.....
- JDM 4-1 header Exhaust Dounut Part# x-over to S2000
- n00b Q: TDC on cams and block
- buddy club spec III cams
- help - scoring marks on cylinder 3
- Which cams for an ITR?
- good shop in bay area
- RMF Header wait time?
- Are my cams, valvesprings, and retainers stock?
- Head Stud?
- DC header for itr
- Walboro 255 fuel pump
- B20B parts on B18A1 block?????
- with my settup
- Ebay Vtec Controller?
- injector whaaat
- TDF header for TSX K24 , the domestic import motor
- damn b18c type-r
- Main/rod bearing size choice HELP?!?!
- Engine pros, please help
- B20 destroked?
- Is it absolutely critical for me to tune my car?
- Question about the strength of OEM bottom end parts
- my SMSP header finally came
- all motor b16 issues
- Getting tranny cryoed and rebuilt.
- Skunk2 stg 1 cams w/ hondata???
- Blown B16
- Head Stud help!
- supertech valvesprings SPR-H1002D or SPR-H100DR
- Guys, let me know: How do I put power down in a stock GSR?
- LSVTEC QUESTION??
- help with axle seals
- my car cranks but wont start! *searched* HELP!!
- Golden Eagle sleeved H22A4 block *pictures*
- B20z Question....Dumb but I'm in a bind
- Who can program an All Motor program on an Eprom chip?
- Which Header for my set-up'
- Dual springs and retainers
- timing belt tension
- quick exhaust question.
- Leaking oil AGAIN?!?!?
- Shitty Tuning or What? Need help !!
- cams for b16 street driven WTB
- Good price for a k20?
- Weak igniton?
- Comptech intake question
- ERL Performance Newest Tech Brief!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- XS engineering b series cams stage 2
- tuning a big issue for i/h/e?
- Fresh build and now throwing SMOKE!
- Standard or Big-Tube?
- Z6 intake mani??
- Rebuild H22
- GSR block B16a Head
- Can't decide can you guys HELP?
- integra gs engine??
- Rebuilding the motor
- Whats left besides the H22?
