- i hate do do this but i need help
- HELP HELP HELP!!
- i need help with a short block, bent rods?????/ warped deck??????
- Compression Check...??
- built ls-vtec,how high can i rev it?
- why is everyone so hung up up on "CFM"??
- Anyone happen to have a CROME bin for a b16 w/ jun 3's?
- Passing smog with a ported head?
- b16a stroker kit
- Quick Question.. Type-R Head
- what piston is ?
- crx ls/vtec swap mount question
- Rebuilding a Sir-II B16a on a budget?
- dyno results
- b20vtec problems/questions
- AFR
- Manley Piston?
- can i save it
- Difference between H22a type S and H22a euro R?
- Stock B20z rebuild - Wrist pin and b18a head gasket questions
- Race Day Pics
- Valve Kepers on a B18C1 Build??
- Exhaust situation
- crazy Honda civic with b18c engine
- DIY Port and polish....
- headgasket?
- Engine build update (as posted in the ITR forum)
- B16 head on a JDMITR head
- lsvtec or b16/b18c1
- do i have a blown motor ?
- help my buddy out, car is not runnin... TPS issue
- Changing from fuel injection to carby on 16V SOHC VTEC 1500 cc
- need help with recently bought camshafts.
- 204 whp and 166 ft lbs of torque completely stock JDM H22A HMO I/H/E (Dyno Sheet Inside)
- Well my time has come....AGAIN!
- a few questions for finishing up a ls/v swap
- b20 build
- Finally got dyno tuned
- RC injector clips....
- skunk2 vs. omni valve train (and valve decision help)
- WILL H22A FIT IN 89 ACCORD?
- bent valves....?
- my b20 build project
- B20 VTEC
- B serie oil pump gears Q?
- question on high compression head gaskets
- anyone dyno this try-Y header yet??
- Open header???
- kinda of dumb question
- What do u think about the victor x manifold
- Rod Bolts Question
- New T1R 70mm catback vs T1R 65mm
- Omni valve train or supertech?
- gap my plugs/what plug?
- Honda Spools
- [B]Stock Fuel Pumps:[/B] Flows and Potential
- b18c5 head ...ebay find
- ITR T.B
- fight: odb2 b-series oil pump vs obd1 timing belt cover (we win/howto)
- acydphryck setup !!!
- b20 head gasket
- supertech springs SPR-H100DR too much on ITR with skunk stg2 cams?
- All Motor B20 Dyno Graph
- Problem after compression test
- JDM ITR Tranny 4.78. PROBLEMS with 4th gear.
- ArtieTuned or RD Tech?
- omni valve springs
- Here is motor setup... which cams?
- FS: Buddy Club stage IV (4) Cams shipped 310 $
- Tried search found no definite answers
- Another B20 vtec dyno chart
- is a b16a2 reffarieable?
- Car a few sessions of dyno run today, a few issues needs opinion and suggestions
- JE/SRP Pistons.....famous for oil leakage into combustion chamber???
- blox
- What compenents throughout the b series motors are the same
- how to make big horsepower on a b16?
- dyno comparos on specific parts
- Would Skunk2 stage2 cams be a good choice?
- Yet another header Question
- Engine modifications
- smaller oil filter to raise oil pressure
- Need help building high rev B16A
- Can stock valves handle a hard spring?
- ..:::something for the REAL street RACER or street class competitors:::...
- A weird situation, and question, All motor B18B1.
- what mods to hang with an E46 M3
- Ultimate LSvtec Build up Parts Price Thread
- Problems with DIY ITB setup, Cylinder does not fire - Help?
- k24/k20 high HP (what tranny?)
- ALL MOTOR speedometer videos
- Is 3" the best size exhause for an all motor H22?
- head CC
- Just dyno my car B18C5 today..
- OK...Need some help here. Fuel problems! EXPLOSIONS!
- B20 oil pickup question
- Thoughts on Power
- LSVtec 2.0L build
- B16 cam specs vs. GSR cam specs
- claying a motor
- b16 tranny on gsr
- Header Help...
- what cams for my set up
- will JDM GSR pistons/rods work with b18b block/crank (searched)
- stock or s2 IM?
- Endyn K-Series head magic - Leveraging into sponsored Racer setups
- Dyno'ed & Tuned my GSR
- d15 or 16 in md pa area
- power loss from a 4-1 header???
- How good are buddy club cams
- Blown head gasket..
- ls.v head choice (been researching forever)
- K-series head porting for k20 k20a k24 k24a - need info
- Quick question about dyno
- Skunk2 Pro3+ vs Buddu Club Racing Spec 6 vs Brian Crower N/a Spec 2
- oversized valves
- Buying a B16A head - have some questions regarding sensors etc...
- Which intake manifold is better...
- knock after 4th gear pull =(
- Team 1320's All Motor ITB K20/K24/k26 Eg Project
- NA OR FI
- GSR Cams poll
- How good are bc cams
- What is this ? TWM ITB Something ????
- Mahle Gold Series H22 Pistons - Couple ?'s
- Is anyone from reno or carson city, and what kinda time's are you running
- anyone here NOT running a resonator?? here is why...
- deck height difference between b16a and b16b
- will this really work???
- question for those with itb's?? where do you get your horns???
- b18b ls build, round 2!! what will it put down?
- Champion reads plugs for $5?
- Megan racing 421 header any good for gsr?
- ITR valve springs +skunk2 stage1's Rev Limit?
- replacement ignition coil
- Release bearing won't stay in flywheel? bad flywheel?
- Shop in Orange County???
- Expecerience with skunk2 intake manifold......weather to buy?
- The D16a6 Block is going to the Machine Shop What should I have Done to the Crank? Balanced and Blue
- .25 OS piston weights vs. std bore.
- Neptune Pregunta
- Should my Ls/vtec Feel Like this???
- are Spoon wires worth the money???
- compression...???
- difference between LS and GSR block?
- What throttle cable and bracket for Edelbrock Victor X Manifold for Type R?
- Best Cam Gears?
- Coming to the streets tomorrow
- Magnesium Retainers-Ferrea
- Stroked ITR-?????
- ls vtec smoking
- b16b.. ctr motor with itbs?
- what is some of your b18a1 builds
- whats the most you can mill a B-series head???
- Valvetrain removal - head in car?
- B18C3 with B16a2 Head.. What compression?
- To anyone who has experience with a dynojet
- Will this get me at least 200whp?
- Is B16a2 head, same as usdm integra type r head? And compression ratio???
- mahle pistons?
- All OEM all Motor hp?
- Look for 14.5 seconds from a b16
- DIY itb's or man up and buy a real set?
- J-K-Tuning
- My "1990 Honda Civic SI" Project,.
- itr pistons?
- can i use ACL rod and mains bearings std. size
- anyone heard anything about the buddy club stage 4 cams????
- what kinda numbers u think i should be putting down?
- Does Any Honda / Acura Vehicle use 2.25" Donut Gasket for Exhaust?
- COMPRESSION AND TUNERS
- How do you deal with your addiction?
- Gsr tranny or B16 ????
- How much power would i make???
- header
- Dart motor 327hp
- Does power really come from the fuel??
- What WHP Range Should I Shoot for? Built D series
- Stage 3 crower camshaft opinions
- Need Help With Compression On D16z6 w/ Jdm Sohc Vtec Head!!!
- Diff between Type S cams and Type R cams
- Jun3's on a JDM b16 w/ Mugen head gasket a bad idea?
- help identify these cams
- y7/y5 mini-me?
- CRAP i put the valve seal on the wrong side...how to remove safely!?
- h22 all motor build??
- Exedy organic clutch
- N/A Gurus needed
- Anyone who has ordered an RMF header, please come in.
- Main Bearing Problems
- No more KICK after installing Kenji's chipped ecu? LS/V
- B16A Throttle Body
- balance motor not
- my Ls vid: first time using movie maker be easy
- who's FAULT?
- crower 404 cams. whats the idle like?
- unknown itb's
- B18c1 block with a B16 head?
- need help building a motor
- 200 whp and 168 ft lbs of torque Stock Internal JDM H22A engine (dyno sheet inside)
- b20vtec cam timing???
- badasss civic
- Which cams are stronger GSR or B16 ???
- $2000... best way to "waste" it
- Timesert installation??
- EM1 All Motor project.
- My first port and polish/valve job!! 56k go bake a pie!
- Randy RMF, since you cannot be contacted on your mobile, i'm sure you can read this!!!
- k89EF Sleeved,Tucked,Shaved,2.0L NA LSVTEC Build
- ZEX/COMP 59300 cam, ignition timing?
- 310cc injectors... should i run stock or warlbro fuel pump?
- built b16a2 head with a pro 1 cams & stock gsr block! am i over camming my motor?
- what makes the sirII b16a higher compression?
- tuning all motor
- Whats the optimal A/F on a NA motor and a Wideband question
- ????????? About ls/vtec ????????
- Help! Problem with ITR throttle cable
- b16b track motor ...
- h22 all mtor
- can you tell if my timing is off (pics)
- ctr pistons and ls rods?
- Revs when cold
- rocket m22xx vs. the world
- New K series comes to life.
- B18c1 GSR question. Experienced engine builders please help with advice
- for sale eagle stroker kit for gsrb $450
- how do you clay an engine
- compression ratio and headgasket??????
- Non vtec turbo buildup advice
- Tuning Assistance
- BUDDY CLUB CAMS SPEC 3 MARKINGS****************************
- ls-Vtec project log
- Need suggestion for cam upgrade!
- 2.2L ITR all motor baby!
- anyone heard info on rmf lately???????
- skunk2 stage 1 vs stage 2's
- Should i upgrade fuel pump and injectors?
- not another bloody ls/vtec question!
- pro1's w/ stock bottom b16 pr3 slugs
- 1 layer head gasket
- For sale
- Cam Caps ...
- total timing on high compression NA builds
- JUST FINISHING THE FINAL TOUCHES............
- b16a2
- gsr compression
- can someone help me understand cam timing!!!
- To sleeve or not to sleeve????
- Bosal brospeed header?
- supertech valves, springs, retainers
