PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 [125] 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. which would be a better head for my lsvtec
  2. K20A2 swap in ep3.......
  3. What does this dyno graph mean?
  4. SI tranny?
  5. History of bad experience with ****** head work
  6. lsvtec/closed deck sleeved and bored to a 2.0l/b16 head/questions
  7. ctr pistons ls vtec numbers
  8. Bad experience with ****** poe
  9. What stock engine parts do I need to replace for an all motor H22 engine build?
  10. does any one have a tranny tooth count for all b series gears gsr, ls, type r ,b16
  11. Turbo Question?
  12. best car/engine for newbie?
  13. m22 too much for a build b16?
  14. stripped oil squirters
  15. DIY block
  16. BC4 + 12.8CR, IDLE tune almost there...Any last suggestions?
  17. Jdm itr pistons
  18. Idle/Acceleration Issue
  19. Jun3's or Pro1's in ITR
  20. B20Z2 build advice please
  21. b16 tranny or....?
  22. obd0 pr3 to run poor man's type R allmotor build?
  23. Profab vs. Virbant 4-2-1 ?????
  24. any1 has dyno graphs or numbers of STOCK or just bolt ons GSR or Type R?
  25. Tuning Questions..
  26. D15 Rebuild Kit?
  27. WHICH SHOP?
  28. Swap Question
  29. could this pcv setup be affecting my idle
  30. Stroked H22 header ????'s
  31. people who have owned TURBO AND ALL MOTOR cars, please come in....
  32. ADVISE to get my goal of 220whp on a B18C6
  33. Spark Plugs
  34. Difference between H22 and H22 Type-S
  35. Pulling the head
  36. an-r owners:need some info
  37. p06 to VTEC
  38. My B20v Build any suggestions?
  39. Is it safe to run a stock ECU with this build?
  40. Fuel componets
  41. P72 Head, P30's LS-VTEC. What cams for 200whp?
  42. try to build a b20vtec,where cani find "howto"
  43. lsvtec build: used pistons, new rings?
  44. Integra Type R Crankshaft
  45. ls/vtec build?
  46. Question concerning vtec controller
  47. blew my motor with this setup.. need help with next...
  48. need some realistic estimates
  49. HELP...What kinda engine is this?
  50. Dyno Sheets of Motors with Stock USDM ITR Block or GSR Block w/ USDM ITR Pistons
  51. recommended cams for this setup...
  52. i need some all motor input please
  53. B18B1 CBR 954 ITB's
  54. what size injectors?
  55. People w/ Hi-Comp LS-VTEC with no knock sensor, get up in hurr.
  56. AEBS GSR IM, where to buy?
  57. Intake Manifold vs. ITB's
  58. Dyno Day May13th@1320 performance
  59. What do you guys think of this header?
  60. What the hell is going on here?
  61. ls/vetc or gsr?
  62. Cam Degree Kit.... help!
  63. Looking to do an H22 type-s for my eg hatch.
  64. Toda Cam Spec B Or Skunk 2 Stage 2 ?
  65. need your oppinion
  66. b16 head advice
  67. new b here building b20 vtec need help
  68. p72 pistons in a B18A1
  69. header gasket leak....
  70. b16A or b16B?!?!
  71. Profab header quality???
  72. carnage at the track: details soon
  73. wat head to use
  74. Quick K-Series Question
  75. b16 biuld progress ?
  76. Proper Break In vs. Dyno Tuning
  77. Need to replace my H22a Alternator.... Don"t know which one to get
  78. wtk
  79. Searched Skunk Pro 2 Cams
  80. B16 Surge?
  81. b16 integra???
  82. OT: guy claims this is a 210whp n/a car .(i tihkn its boosted: vid)
  83. All In, but problem!! help please!!
  84. LsVtec with oil leak question????
  85. Is it okay to run crower steel retainers w/skunk2 springs
  86. Estimate My HP/TQ #s for me... And Maybe 1/4 mile times
  87. Spooned engine or b16
  88. Low dyno #'s with B16A2
  89. help with h22 build
  90. my all motor build (LOTS of pics)
  91. Skunk2 Stage 2 Cams in B16b
  92. My LSV Build
  93. *** dual engagement vtec question
  94. h22 with D series tranny?
  95. Size of AEM intakes?
  96. Rod length
  97. who can get me prices on cams on here???
  98. going for b20/vtec fully built! tell me the best setup?
  99. what header and exhaust?? built b20 vtec
  100. TWM itb problem
  101. Question about resizing rods with arp rod bolts
  102. All motor lude at the track
  103. the next step
  104. Buying' Used Cam's....
  105. planing a swap
  106. Finally got my Pro1s to idle Thanks Intec Racing
  107. Ignition Timing problem Wont reach 3 marks
  108. Fully built b20 vtec
  109. Custom Trans gear set
  110. crankcase breather system..
  111. header ??
  112. H22 Hatch, Went threw 3 batteries in a week
  113. Skunk2 Stage 1, Pro vs Non-Pro Camshaft's
  114. JDM B16A oil drain plug stripped help!!!!!!!!!!!
  115. H22 type s pistons?
  116. sir pistons?
  117. 310 injectors on a b16?
  118. need help with all motor gs-r motor
  119. How long should my runners be for a custom intake mani???
  120. Help with a future build
  121. im not in any sort of trouble or nothin, but i need some help for future
  122. Stock Bottom ITR w/ blox b's
  123. compression for pro1
  124. Vibrant header Jspec 4-2-1 or Jdm replica ss 4-1 ITR header
  125. What to do next????
  126. b16 head or GSR head
  127. what to do with a gsr???
  128. ACL or TOGA bearings?
  129. cam help
  130. clutch and fly wheel
  131. Cams for a stock bottom end itr motor.
  132. rocket motorsports valve springs and retainers
  133. Numbers to be expected TYPE R???
  134. Does The Fc comander make good horse power gains
  135. Best T/B Size for my setup...opinions??
  136. CTR pistons on a 97 B18C-R
  137. Need some opinions!!!!!
  138. jdm itr HELP
  139. 12.5 compression with milled head?
  140. What intake is better for performance?
  141. Question about Skunk 2 PRO 1's and how they idle
  142. Question about D series Pistons
  143. H2B People
  144. Milled Head?
  145. considering ebay header
  146. B16A Cam ??????
  147. 81mm or 81.50mm head gasket
  148. Stripped motor to find a spun rod bearing on piston #2
  149. What ecu is everyone using? Open Poll
  150. What to do??
  151. Does anybody here use an aftermarket timing belt?
  152. what header is this?
  153. itr water pump has no dowel pins?
  154. need your opinion on ls vtec set up
  155. cam help
  156. What do you think of the skunk2 pro1 cams
  157. CRV obd2 dist???
  158. 4.4 open diff Vs. 4.266 LSD
  159. stroker kit? for b16a
  160. BREAK IN a MUST ??
  161. ITB air box
  162. K20 cams
  163. ***Official H22 All-Motor Dynamometer Thread***
  164. short ram vs. cold air vs. Vstack
  165. more compression
  166. tell me what you think
  167. D16 rebuild tips read this before u laugh
  168. ITB for a b16
  169. B18C JDM - Code 3 & 6
  170. Mild b18c5 build. Got questions and need answers.
  171. Stock B16A with Buddy Club Spec 3+ (Dynoed)
  172. 81.5mm or 82mm bore?
  173. am i alright to run my ls pistons in my LS/vtec
  174. Spoon head gasket thickness
  175. Head gasket Choice
  176. Velocity Stack
  177. quick question about springs and retainers install
  178. stock b18b with b16 pistons, tuning issues?
  179. cant find thread
  180. power steering removal, using stock reservoir?
  181. buddy club 4 ???
  182. F22B DOHC head + F23 bottom end??
  183. Engine bolt Torque Specs (b18c)????
  184. Bolt doesn't tighten on the intake manifold..
  185. Rod bolt size in B16A2
  186. My new setup!
  187. Good d16a6 cam for my setup? (plus need other info)
  188. Quick Question:How Much to Bore
  189. question about my intake and the IATS
  190. RS-Machines pistons?
  191. What are your VAFC settings?
  192. mtf/gm sychromesh
  193. Help identifying possible JG D16Z6 cam?
  194. 265 whp 170 tq b20vtec
  195. **VIDEO** 1991 h22 accord vs. 2003 acura tl type-s
  196. intake manifold instructions
  197. Church's Tuned GSR, 214whp/155lbft...pics/video
  198. swap 91 civic engine for an 88 prelude, will it fit?
  199. ::Those who pride themselves at problem solving please click::
  200. LSVTEC QUESTIONS...
  201. proper radiator / surge tank / overflow tank setup? long rambling :/
  202. hacth back
  203. Dyno Predictions!!
  204. dohc zc in ef
  205. diy itb's
  206. b18b help needed!
  207. some basic b20vtec (stock bottom gsr head) questionsrelie
  208. All motor b18b non vtec worthless?
  209. Stupidity>Me
  210. What do you guys think of Ployurethane engine mounts?
  211. New header....200 here I come
  212. need info...
  213. buddy clubs IV's to big for my set up?
  214. Want to upgrade to a better Cam. need advice pls.
  215. camshafts for gsr
  216. COMMENTS PLEASE...
  217. Ok, listen up...
  218. My all motor LS Build Up
  219. oil cooler
  220. Suggestions for my setup...
  221. lsvtec build
  222. ANR street version header?
  223. K20A-R Swap into a Integra 2001
  224. help solve this idle problem (searched)
  225. B20 crank in P72 block?
  226. Switch? hondata stage2 to crome
  227. b16 main bearings
  228. 12:5 compression okay for daily driving?
  229. LS valvesprings
  230. Stroker H22 Intake Manifold RLZ style !!!!
  231. LS vtec tranny issues
  232. i got a ? about cams
  233. What IM and TB ???
  234. Crankcase/block vent for B20 Vtec (searched)
  235. b16 vs. b18 opinions
  236. B17 cams in b18c head??
  237. Is it ok to REUSE ARP rodbolts after spun bearing?
  238. Santa Isabel Performance Built
  239. is this header for 1.8L or 2.0L ??
  240. Slow Chicago'ins B16 CRX
  241. b20 bore
  242. The never-ending oil burning problem...UGH!!!
  243. Does it matter what oil pan i use on my LsVtec?
  244. anyone using Crower 62405A-2 cam on a b18/b20
  245. im throwing codes
  246. dont know how fast im going.
  247. blown head gasket ... or cracked sleeve maybe?
  248. WTB: .:Integra Type R Throttle Body, Virgin p28 or p72:.
  249. Eagle rods??? h22 build
  250. ProFab Headers...how to tell if it's replica or not???
