Suggestions Needed: B18C compression test results are in. Any recommendation?
Hello, I have do the compression test on my stock B18C engine
Cylinder 1 : 110 psi
Cylinder 2 : 150 psi
Cylinder 3 : 155 psi
Cylinder 4: 145 psi
I do it when coolant temper was 6X
the engine has oil consumption problem, and the engine little bit to start up when cold , i need to press the accerlation padel to start up.
Cylinder 4: 145 psi
re: Suggestions Needed: B18C compression test results are in. Any recommendation?
Based on those numbers, you are ready for a complete rebuild.
Re: Suggestions Needed: B18C compression test results are in. Any recommendation?
Cylinder 4: 145 psi
Cylinder 4: 145 psi
https://cimg8.ibsrv.net/gimg/honda-t...2268e20bcd.jpg
yes, Finally I found the obviously scratch in #1 cylinder wall.hope it is not a worst condition.
now going to measure how many need to honing and put in the oversize piston,
jmeyer99
10-02-2010 09:08 AM
