PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 [215] 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. what cams
  2. CTR pistons in ITR bottome end....
  3. bearing thickness
  4. Cam Profile in relation to Compression
  5. Thermal R&D or Tanabe Med. Racing?
  6. Difference between ITR and CTR/00-01 ITR cams?
  7. HELP! injector
  8. how to make a MTL flow better
  9. are throttle bodies worth the money?
  10. my goals
  11. Thoughts on HP for this setup
  12. help me calculate my compression :P
  13. Where to buy new OEM parts?
  14. Ericks Racing Spec D cams?
  15. spark plugs for all motor y8??
  16. WTP:JDM DC 4-1
  17. b20 and ls cylinder sleeve differences
  18. compression test
  19. installing gsr girdle and oil pump
  20. Rs Machines cams
  21. Can Skunk2 Stage 2 pass smog 2 in CA?
  22. whats good parts for engine internals for...........
  23. knock-knock problem
  24. skunk 2 IM for h22a released???
  25. Vafc
  26. all motor B18B opinions?
  27. Hayame-thinking of getting their cam gears & exhaust
  28. Regarding CTR Pistons and Nitrous
  29. 160-175 whp
  30. Smaller wrist pins - Pros & Cons?
  31. Underdrive Pulleys, Are they any good????
  32. k20 eg times?
  33. mill the dowel pins when you mill the head?
  34. Mjor tunners valve spring comparison.
  35. Crower H beam or Eagle H beam?
  36. Apexi VAFC ver1 v ver2
  37. Skunk2 Exhaust Piping Size???
  38. Opinion Needed on B20B4 w/ Type-R EX-ternals
  39. Are Y8's really more prone to Spinning Bearings???
  40. Who makes custom cranks... ??
  41. Race Prep Block rework oil Sytem , whats the deal ?
  42. check out my setup
  43. LS rods on GSR crank?
  44. Air Intake Recommendation
  45. CTR pistons on GSR rods ?
  46. Pics of new motor w/ITB's
  47. what DONT i need in my engine bay?
  48. ctr pistons and mugen head gasket installed...
  49. lightened crankpulley
  50. B20 help
  51. invidia catback good buy?
  52. what #`s do u think my b18c will yield
  53. 300 HP N/A Streetable on K's????
  54. JUN 2 vs ITR cams
  55. will the AIR CF IM (Endyne ) work on a N/A engine ?
  56. what size head gasket to lower compression?
  57. Can you do a valve adjustment to factory specs with aftermarket cams?????????
  58. great all motor sleeper muffler
  59. what would gain me more
  60. Mild LS setup
  61. 200whp on stock head ports?
  62. lhtperformance.net reviews/reputation??
  63. what to u guys think of my set up compare to the WHP?
  64. cams choice?
  65. im in CALI.los angeles..where can i go resurface b16 head???
  66. Next step?
  67. what pulleys to use on all motor setup?
  68. RS Machine
  69. My NA setup
  70. PRO FAB INTAKE GASKETS
  71. militec-1 metal conditioner
  72. toda c cams
  73. going all motor, which ecu to go with?
  74. what is my head lacking?
  75. dyno tuning around ohio??
  76. Vtec not engaging... Help troubleshoot?
  77. my 13.4 vid on street tires !!!!!
  78. experiences in wideband tuning...
  79. what is my compression?? ls vtec....what else can i do? all motor..
  80. Troubleshooting: What are the Signs of a Failing VTEC solenoid?
  81. What a/f is dangerously lean?
  82. GSR head/ SI head
  83. Thoughts on CTR n1 crank pulley
  84. In need of a rebuild
  85. whats good oil for LS VTEC n B16 n B18c???
  86. B16 .wich cams?
  87. help with numbers?
  88. m22 cams-how long of a wait??
  89. need help on installing apexi v-afc
  90. hondata for JUN ecu
  91. JDM ITR exhaust
  92. apex v-afc II
  93. Could you post the specs of your all motor h22?
  94. supertech valves
  95. How does this setup sound.
  96. Whats better for b18c1?? Pr3 Pistons/ITR pistons/.25 overbore ITR pistons
  97. Installing ARP rod bolts question.
  98. Have some questions about rebuilding a B18A.
  99. what cams to use with pr3 pistons in b18c1?
  100. anybody got any k series rumors?
  101. ef-1
  102. Getting poor fuel economy with LSVTEC
  103. advice on how to dyno tune
  104. 94 Vtec Accord?
  105. ?'s on b20 setup
  106. over 200mph?
  107. Toda B's?
  108. invidia catback w/ jdm dc 4-1 question
  109. necessary to change bearings???
  110. Skunk 2 Stage 2 Cam Clearance?
  111. All-motor LS build up???
  112. Boring a b18c?
  113. GSR head
  114. another lsvtec question--searched
  115. 62404's in b20
  116. piston to deck height prob.
  117. Rebuilding a B18B1.....What are the best parts?
  118. FRANKENSTEIN ALL MOTOR. WHICH BLOCK AND HEAD SHOULD MATE BEST?
  119. ITB's + Hondata = ???????
  120. compression for skunk2 stage 2's???
  121. Got money to spend, Help me decide on a set up
  122. b20 vtec help look!!
  123. arefor those of youwho have hit 200whp...
  124. piston install
  125. Whats the difference between Peak & Hold Injectors and Saturated Injectors ?
  126. New design Golden Eagle block
  127. Pics of my blown motor
  128. What you think this all motor combination?
  129. Opinions on this set up - 2.1 LS/VTEC
  130. jun 3, toda c, ef-1 m22/23 or s2 stg2
  131. anybody running carbs?
  132. BBK INTAKE MANIFOLD were and how much?
  133. One less B17A in the world :(
  134. Anyone using a sheet metal IM on NA?
  135. headertech headers
  136. ZC pm7 Pistons... what to do...
  137. need help with what compression to go with
  138. Who makes a nice sounding 2.5" exhaust
  139. Exospeed reputation and personal opinions
  140. attention OMNIMAN......
  141. Toda question
  142. JDM Tranny
  143. Winter problems?
  144. 4-7 final or other ? whats the best for all motor
  145. fuel delivery
  146. Skunk2 cam spec sheets
  147. K Vs. B head
  148. B16b rods in B16a?
  149. a cool pic i took the other day.
  150. Help with Type R's seemingly low dyno 164.1 hp at wheels tuned
  151. a few questions. . .
  152. cleaning cam caps, and other misc head pieces..
  153. b18 and b16 with deckplate question?
  154. Might be OT... Damn 3SI Owners....
  155. Question concerning block assembly. NEED ANSWER URGENTLY
  156. What's better in a b18c1?
  157. b18 with ctr pistons?
  158. b16 stroker help
  159. P30 pistons or Ctr?
  160. how to identify skunk2 stage 2 cams?
  161. will non OBD ecu work w/ ITR injectors?
  162. Know nothing help!!!!! [B]Me Stupid[/B]
  163. dc sports jdm type r header >?
  164. Best quiet high flow exhaust for a cx with b18c1?
  165. any info on jun stage 4 cams
  166. CTR cams/ valvetrain???
  167. Building a large primary, long-tube 4-2-1 header...
  168. skunk 2 im question
  169. Does anyone have dyno plots for a stock gsr and type r on the same chart?
  170. prev junIII users: why do their cams break?
  171. who is staying either B or H series for next year
  172. anyone know standard skunk2 cam specs..tried search
  173. In dire need of a rebuild on my b18c1
  174. dseries with mikuni's?
  175. y8 swap....which distributor?
  176. Can i put a cable b16 lsd on a hydro b16 tranny?
  177. Compression Test - Acceptable Spread (GSR)
  178. Leaving force induction goin all motor setup?
  179. How much compression is enough?
  180. Road Racing Setup
  181. Block Prep
  182. Compression Ratio for Gsr head/B20b block?
  183. Want to know what all motor engine will produce the most whp?????? and trq????
  184. JUN III's in stock b16a???????
  185. A1 tranny
  186. toda belt jump timing twice 10 bent valves/two heads is it the tensioner?
  187. What comp.?
  188. Kinda new to this, but I'm learning...
  189. allmotor buildup using an LS block?
  190. suggestions on fuel pressure
  191. I think I got scammed
  192. All motor nitrous....
  193. Need part # for ITR cam that is = to CTR Intake cam
  194. ARC induction box for ek
  195. b20 pistons
  196. K24 specs?
  197. help with compression ratio
  198. zex nitrous 55 shot what kind of plugs?
  199. Will V-tec or Dohc Valve Covers fits a stock integra 1995 rs?
  200. Copper Retaining Rings on Head Gasket Removal (c-speedracing.com picture)
  201. Tell me why too high octane could be useless?
  202. B16A timing belt
  203. What plugs are you guys running on your hi comp motors?
  204. Just finished Ls/vtec, now for a question?
  205. h22a p72 vs p13 graph
  206. Water Injection for NA? 13.5:1 on pump gas?
  207. Pics of My LS/VTEC Progress.
  208. Header for D series?
  209. m.a.h.l. pistions
  210. ls. vs. vtec
  211. Help, somethings wrong with my car.
  212. ringing pistons
  213. anyone ever broke skunk 2 cams
  214. machine shops
  215. ALL RIGHT ALL MOTOR ?
  216. what should i do about my tranny probs?
  217. DTR 2.0 liter HEADER
  218. B16 dyno....what #'s to expect?
  219. CTR Pistons with Skunk 2 stage 1 cams?
  220. Eg coupe with either GSR all-motor high compression or Low compression Turbo?
  221. b16b question
  222. code 17 and no vtec?
  223. hey does TODA make stuff for the d series engine? thx
  224. do i need to sleeve my motor for a high compression NA setup?
  225. Squeezing more from the B16B?
  226. valve sizes..
  227. Valve Size????
  228. Mugen or Tanabe exhaust
  229. any know this car??
  230. Exhaust cutout's and N/A cars....
  231. What gauges do you use?
  232. Skunk2 Stage 3 Cams
  233. Upgraded rods?
  234. ? D16Y8- Specs.
  235. wrist pin size?
  236. WD40 bad for valve Seals??????
  237. Is it worth getting injectors?
  238. Rebuild GSR tranny or buy ITR tranny ?
  239. Aftermarket block girdle, worth it?
  240. How much do you think this Will kill my whp?
  241. f22 or h22 in your accord.
  242. lsd??? i need help 2 built my b16
  243. Headgasket coating?
  244. JUN IV does any one have dyno #. want to change from JUN 3 to JUN IV
  245. Head Tech
  246. 300HP All Motor B16 - suggestions?
  247. problems w/ mugen headgasket n' timing?
  248. H22A Rods?
  249. Idle problem
  250. B20B PCV System
