PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. 82mm itr build
  2. ls vtec oil / water pump question
  3. Fitting Bosch Injectors to intake manifold.
  4. How to tell if valve seals or piston rings are bad??
  5. Need IM & TB advice for LSVtec
  6. B16A slow 0-60 speed
  7. Pitter patter knock?
  8. JDM D15B vtec selinoid gasket?
  9. NA H22A Crx the right slick pressure? the right RPM which to launch?
  10. My First Build, Dyno Results. Suggestions please.
  11. Piston To Valve Clearance/Headgasket/Compression ITR HELP!
  12. First ever motor build(LS/V pr3s)
  13. im having some problems
  14. hypothetical question
  15. What does changing the LMA do??
  16. How to build a Single cam 1.6 motor.?
  17. 87 accord diaphram pump (needle came out)
  18. question on low idle no Cel's checked everything, could it be the gas im using with 10%ethanol
  19. Question about speed sensor throwing a light plz Plz help
  20. tuner series springs wit pro cams
  21. putting H22 internals in H23
  22. LS Vtec Question??
  23. HELP!! ported head with oversized valves w/ jdm itr pistons??
  24. Fuel pressure
  25. ITR Sleeve??
  26. *NEW* B-Series LMA Info
  27. K-series Fuel Injectors on B16a?? Need help!
  28. port and polished b16 head/intake
  29. 95' b20b short block oil pump question.....
  30. JDM GSR BUILD UP
  31. Advantages/Disadvantages between STD size p30's and .25 overbore?
  32. SOHC VTEC- HEADER WRAP? HOW MUCH DO I NEED??
  33. USDM ITR dyno
  34. Skunk 2 B-Series Header *NEW* !
  35. crank question
  36. Question about ITR Valve Springs and Retainers???
  37. Will i be ok running buddy club stage 4 cams
  38. Started my LSVTEC and.......problems
  39. Washed my engine bay so now....
  40. Maching a stock crank pulley to single belt?
  41. Shotpeening(Ls/vtec build)
  42. b18c build help
  43. JDM B18C dyno results
  44. Everyday Header
  45. Cams too big for stock gsr??
  46. How do I identify skunk2 pro1??
  47. LS motor(b4 lsvtec), vtec water pump and vtec timing belt
  48. Sprak Plug Reading
  49. cam identification woes...
  50. LS/vtec 84mm setup.....what cams to use
  51. Will I Run Into Problems? Skunk2Stage2 w/ Supertech Valvetrain
  52. blox valvetrain
  53. noob question i really need help pls
  54. Help with Honda Challenge H2 B18C1 Build (Choosing correct valve parts, finding an engine builder, e
  55. part number for USDM "R" rods same as JDM B18C rods
  56. h22a w/ Jun 3s, dome top valves, head milling?
  57. AEM V2
  58. Confusing plastigauge results?
  59. Blox type C valve lash settings
  60. Tranny/Tire size and the Dyno
  61. 350hp All Motor Build for the Average Joe
  62. new injectors high idle. help!
  63. Motor Won't Start
  64. B16 crank in a B17 question..
  65. smoke from the exhaust and spark from valve cover grommet
  66. Okay to mount MSD ignition in the interior, rather than under hood? MSD says no.
  67. LS/VTEC going in a 00 GSR, Do I need to use the Fan Switch on the block or thermo housing?
  68. walbro 255 with completely stock motor and ECU...too much fuel?
  69. question on timing
  70. Valve Clearance, how do you like your valves, looser or tighter?
  71. Throttle body size?
  72. 2.0 poor man type r
  73. h22\f22 vtec problem
  74. What Kind of Heads can be put on an F22a1 Motor?
  75. will hydro b16 diff fit in cable b16 tranny?
  76. are supertech valve stems undersized?
  77. I tuned my CTR today....
  78. Camshaft Questions
  79. all motor gsr build
  80. Skunk2 Pro1 (b-series) users
  81. JE piston identifiaction
  82. GSR cam question
  83. Checking cam lift, and Valvetrain questions
  84. weird power lost problem...
  85. h22 dyno numbers what you think
  86. B17A1 NA build, CTR cams, p30 pistons. PLEASE HELP!
  87. Would you run these valves?
  88. What is the optimal outside air temperature when tuning a car?
  89. Interesting read on cam theory
  90. Which Spark Plugs: NGK BKR7EIX-11 or BKR6EIX-11
  91. Stock H2B Dyno Results 216/166
  92. Best CAMS!!!
  93. All-motor F22A4 setup questions
  94. JUN Cam Gears
  95. 12.1 cr on stock block
  96. cam help
  97. Great explanation of I-VTEC
  98. High Flow CAT's Universal Size?
  99. Increasing displacement?
  100. Please help!!!!!!!!!!!!!
  101. g23 cams what can i use
  102. Need suggestions on how to pick up some whp gains
  103. Open header question
  104. All motor custom exhaust?
  105. What kind??
  106. POOR MAN TYPE R BUILD
  107. k20 vs b-series mod prices...........
  108. someone with knowelge about skunk2 camshaft stage 2 help me !!
  109. LS/VTEC, what INNER timing belt cover do I use?
  110. b16 rods on ctr pistons
  111. stock gsr retainers w/ crower valve springs?
  112. Anyone have experience with this h22 header??
  113. H22 with injectors UNTUNED
  114. 98vtec's H23vtec - 215/178 - 13.43 @ 103
  115. 4-1 header runnig problem
  116. what cams are in my b16a2? take a look..?
  117. Big, Bigger, and Biggest.... Simple PED/QSD H22 stroker dyno results!!!
  118. DH-Racing Valvetrain?
  119. help searching: WD-40 shoot out
  120. B16 to B18C????
  121. fuel pump problem
  122. Dyno finally
  123. Exhaust help...
  124. Engine coatings are they worth the $$
  125. 89x84.5mm Injectors and displacement
  126. Motor Rebuild help.
  127. skunk2 TB problem
  128. 3" exhaust vs. 2.5" cutout
  129. CLUTCH WHINNING?? BAD PILOT BEARING??
  130. yonaka header
  131. 2.5 inch exhaust vs. Open header **DYNO**
  132. Need Help to Finish off LS-Vtec Build Caution NOOB!
  133. Mugen Oil
  134. changed back to n/a now having problems help.
  135. valve clearance question
  136. ROCKER LOCKERS BY KMS??????
  137. profetional product TB & bouncing idle
  138. Titanium Retainers Advice
  139. b20 with type r head...
  140. heavily worn skunk2 stage 2 pro series cams.
  141. B16a Timing help! (i searched, all i find is b18's?)
  142. Time for a rebuild
  143. Built B20vtec: Header choice
  144. What cams and header for me?
  145. H23 crank help???
  146. STILL dropping a cylinder
  147. Need guidance, shopping list to COMPLETELY convert cable to hydro on b16 in EF.
  148. Wiseco Piston End Gap Help.
  149. vTech Power Loss
  150. ecu question
  151. seized block
  152. Resized Rods = tighter clearances?
  153. whats cost on installing a factory sleeve?
  154. crower vs brian crower
  155. need help figuring out cams!!!
  156. S2 pro 1 vs Jun 3
  157. Low oil pressure with new oil cooler
  158. b18c1 or b18c5
  159. Dyno result of my 82mm built!!!
  160. 180whp
  161. Unknown Engine Problem - Please help! :(
  162. My LS/VTEC build using all OEM Parts - Goal 200whp
  163. torque specs on arp hardware
  164. Cam question
  165. fUNNY QUESTION, how to notch stock b20b/z pistons for bigger cams
  166. P73 JDM pistons or stay with P72 JDM pistons?
  167. Finally got a couple minutes to myself with my new toy... (Dyno inside)
  168. Poll: Stuck on what size TB. Searched but found nothing like my setup...
  169. Next Generation Rocker Arms - CNC Modular Units for BVTEC (Prototype Spy Shots)
  170. help on chosing pistons on my ALL MOTOR GSR !
  171. Help on a b16a1 Sir
  172. IM READY TO KILLL SOMEONE!!!!!!!
  173. b16 with itr pistons and ctr cams
  174. Anybody running stock bottom end ls/b20vtecs?
  175. Another Moroso Oil Pan........Yes I Already Searched!!
  176. Head Gasket question??
  177. skunk2 pro3+ cams on a gsr block???
  178. need more out of my gsr
  179. anyone have an idea.
  180. Help on a JDM B16a!
  181. broke a ring what do i do
  182. which cams for my b20vtec
  183. pulstar plugs and how they make power? according to them, need opions please
  184. Built my first all motor car! post feedback!
  185. gsr build. help a noobie out
  186. N/A engine build advice please??
  187. STORE BOUGHT HONE
  188. Intake manifolds vs ITB's
  189. Timing belt question
  190. My B20 vtec build
  191. rebuilt engine CTR pistons oil smoke
  192. My 85.5x92 build
  193. poor mans type r piston choice?
  194. Question about ring seal/valve stem seals
  195. Troubleshooting : overheating problem with 85x89 build
  196. Going with Bigger Cams! Help!!!!!1
  197. motor don gone retarded.!!!!! help from you all motor gurus
  198. Golden Eagle Crank
  199. after break in oil weight?
  200. Cheap, DIY Way of making your own Balancer shaft removal kit for H/F Motors
  201. My ls/vtec build up!!! (pr3's, pro2's, mfactory, obx diff)
  202. ARP rod bolts wont let cap come off!!
  203. whirring noise... water pump?
  204. need advice on gsr build(ctr pistons/skunk pro 2 cams)???
  205. just another LS/VTEC tune/dyno!
  206. Oil Magnet? Looks Interesting but I'm a Noob so please take a look...
  207. stage 3 cams or stage 2?
  208. type R manifold on a b16.. boggin,misfiring!! help
  209. itr dizzy and obd1 conversion
  210. hytech cat or test pipe?
  211. Removed head without setting engine to TDC: How to reset?
  212. Compression test: big cams
  213. built ls vtec smoking like crazy! please help!!!
  214. viton valve seal ???
  215. H22
  216. New K24A Race engine build
  217. How much will a 4.9 final drive help???
  218. intersting info on skunk2 stage 2 cams i like to share!!!!!!
  219. Skunk2 Fuel Rail
  220. lock tight or no lock tight
  221. My B20VTEC dyno w/ Skunk2 PRO2 cams
  222. stock gsr block built gsr head
  223. JDM B16A Stock Timing Map Same as USDM?
  224. Exhaust Fumes?!?!?!
  225. HELP!! broke head stud off in block
  226. Crankshaft question
  227. 95 civic ex problem
  228. whats a good cam
  229. Attarco motors good??
  230. TPS issue
  231. type R with skunk2
  232. Harness- d to b
  233. B20B - 84mm Block with B16A Head (81mm) - Squish
  234. valve guide?
  235. b16b pistons poor mans type r
  236. all motor build woes. need feedback on ITR block
  237. just degreed my cams... dissappointed
  238. Vtec Issues H22
  239. Is it safe to use ACETONE to clean valves?
  240. what type of cams
  241. D-SERIES WITH ITB...hp?......
  242. Stock internal b20 vtec's on 87 octane ? no im not kidding "Gas Price is Killing Me"
  243. Help with deciding on Pistons!!
  244. ignition timing need some help asap!!!!
  245. need more vacuum!
  246. ls header help???
  247. Project F/H Series - 87x97 F2B Street Machine
  248. KNOCKING please help
  249. parts questions
  250. super b16..
