- Neptune
- 89 D16A6 Block, with a 97 D16y8 Vtec Head, into a 90 civic dx
- omnipower valve ??'s
- 200+ whp in gsr
- EG with JDM ITR ,what cam setup for road racing
- Anyone running the buddy club titanium retainers with pvd black nitride?
- SRZ RACING Header Test PART II
- spark plugs for an 01' civic LX and 00' EX...
- Injectors Advice Please, NA H22A
- Alternator for a B-series including swap HELP ME PLEASE!!!
- aftermarket vtec rocker arms?
- just bought a b18b bare block...what internals to put in it???
- Question about 89 D16A6 Block, with a 97 D16y6 Vtec Head, into a 90 civic dx
- i need some wires to hook up my injector with resistor box, what wires can i use?
- B20VTEC, 230 whp / 151 tq
- Aluminum retainers worth using?
- Wow, I fell in love with my car again.
- Porstreet Products??
- H22+civic - best conversion for street setup(hasport,enjo,etc.)?
- can someone explain some header Q's i have
- Can i use b18c5 valvetrain in my y7 ?
- need help on my motor build up.piston conflict.
- need help on my all motor set up.pistons complications....
- After Market B20 Pistons? Need After Market Rods too?
- 1.8 guys what A:F did your built motors make the most power at??
- Cam Cap problem plz help
- Those running standalone, whats the optimal A/F ratio in partial throttle?
- Most cam with stock springs in b16a?
- D Series Exhaust Size
- kms valvetrain
- All Motor GSR Build... What are your thoughts?
- ls vtec or b16a stroked
- ANYONE INTRESTED IN DOING AN INTAKE MANIFOLD SHOOTOUT???
- my new crvtec crx setup, wanting suggestions
- P8R head
- what to do with F22B1 motor?? Need help what setup to go with??
- The other memory fab intake?
- Stroke b18c1 to 2.0 vs b18c1 bore to 84 mm???
- 85.5 GSR block
- Flow charts of my DIY head from RLZ!
- how much hp wit this setup?
- ls vtec head gasket
- turbo or all motor?
- idea for a sticky / please no flaming
- motor vs turbo ?
- DO U GO FASTER ??? after redline or after your power died ??
- Help me Identify this Throttle body
- Throttle body recommendations...
- Not too sure about my Type R???
- how good are swap shop racing valve springs?
- b20vtec all motor build-what header?
- K-series OBX LSD
- how do i know this is an ls crank?
- throttle body question
- hi-flow/test pipe sound on gsr?
- itb syncronizing
- What kind of retainers are these?
- d16y8 please help
- what to expect from this set up???
- b20vtec or stay gissr
- Dyno Plots of SMS 4-2-1 vs SMS 4-1 vs RMF 4-1 From DFE Enterprises
- where to pass emissions in NJ???
- My DA dyno vid!
- Reputable shop in the DC/MD/VA/PA Area
- MSD 6A Ignition Box Problem
- White Smoke....need help!!
- head trouble
- Looking for safe cam to run with .5 mm os valves
- TWM ITBS
- WHat bodies will an '04 Si motor swap into w/o Hasport mounts?
- 5Zigen Pro Racer A-Spec Exhaust??
- Help on motor build
- pr3 and pw0 chips interchangeable?
- <~~NEW STAINLESS HEADER DYNO TESTED HOOK-UPS~~>
- What fuel pressure should I be at b20vtec ? (walboro intank, B&M fpr, stock injectors, fuel rail)
- TWM ITB 50 vs 52mm ???
- anyone try carbs on a ls
- stock cams with upgraded valvetrain
- JDM ITR losing power after changing header
- ek hatch weight compared to crx si
- ZC motor problem
- b18a question
- E-manage Vs Hondata
- cheapest power chamber
- help buddy club 3's and 3+ info cam spec.'s please a.s.a.p
- cam question
- B18c5 rebuild... Help needed...
- i need a cam position sensor for a carbed, non ecu, b20b distributorless motor, any ideas?
- has anyone modified their rocker arms for more clearance of retainers (with high lift cams)?
- To tune or not to tune?
- compression tested, does #'s look good.
- How is my setup gonna be for street and reliablility>?
- GSR cams in a b16a worth it?
- Professional Head porters look in here!
- Modification to valve guides necessary for crower nonvtec 403's ?
- looking for CTR pistons
- What clutch from ACT ONLY will hold this......
- Quickest 1.8L ???
- k20a2 vs. k20A?
- acl bearings
- Removing piston from rods???
- Tuning Tips from Motec
- Itr cams and making power?
- b18c b16
- LS intake manifold
- how do i find out how much material was taken off the head and block ???
- Blox type-b cams
- Width of F22A1 sleeves?
- Just got a new head...need help (pics, 56k beware)
- KMS racing full valvetrain
- Donf,HAVE YOU MOVED
- Uncommon Hybrid 1.7L
- aebs
- egr valve or something else?
- head milling question.....searched but kind of a specific question *helo
- cp piston clearences
- uberdata/chrome/hondata/etc users help w/ xtronics romulator
- compression test results.......is my motor OK?
- ECU problems
- b20vtec powered integra gsr 13.6@100.mph
- Building A b16 block
- some IM and cam quatesions....(SOHC)
- Burnt valve. B18C5 head is comming off! Need valve info!
- Throttle Body Opinions?
- b16 cam reinstall ?
- Townsend Bros. H2B Adapter Plate... Its 6/1/05 are you shipping product????
- pr3 02 sensor question
- Skunk2 intake manifold vs stock JDM B16a2 I/M
- Can I use stock B16A2 retainers with aftermarket valvesprings?
- b16 with CTR pistons o.k with stock cams?
- b16 into ef specific header by hasport?
- Camshafts
- SMSP Dyno Graphs Requested
- few questions before i build..
- b20vtec oil pump? b16,gsr or type r?
- Pistons in my LS/vtec
- IceMan Ram air intake system...
- B18c1 BC3+ cams pistons?
- ctr piston in a ls block quest help???????
- Stock B16 rod bolts safe to 9300?
- HELP NEEDED: APB on Tim Hastings / ProFab Designs
- shops in miami...
- which rod to use between the two?
- what cams for my set up
- gsr crank and some other questions
- Has anyone ran 14's down the 1/4 with an LS tranny, & NON-VTEC?
- my b18c1 setup
- QICK QUSTION GSR EG, 2.25 OR 2.5 " Exhust ?
- header wrap?
- Attn cam experts, question about valve springs
- b16 tranny on an h22 ?????
- Will this work?
- TPR B16 headers test
- K-Series: the never-ending quest for more power
- BKR7E-11 spark plugs?
- Car not getting up to operating temp
- Cam Questions
- which header is better need opinions
- who has FAL molded glass on a street car?
- CR - B16A2 + .4mm head gasket
- update on stroker build (pics)
- p8r valve springs
- need HELP, which INTAKE MANIFOLD should i use for my all mota EG
- can i make 190whp?
- Let's see your 1.8L OEM Bottom-end, ALLMOTOR, 91 Octane Dynos
- HELP! B20 Vtec Parts list NEEDED! SEARCHED!!! my FIRST motor!
- 97 spec itr cams vs ctr cams worth the savings in my lsvtec ?
- Skunk2 Announces new Cams & Cam Gears for K series
- future engine project....could use your opinions
- streetability of a 6puck???
- b20 markings ( anyway to tell its a real b20 )
- i want to import a full engine swap to israel. (need advice)
- obd1 gsr motor in ek
- Omnipower USA Test Pipe fit t1r b pipe and toda header?
- Tuner performance mag says 6whp gain with Direct Hits, anyone believe this?
- Near Stock b20 dyno with gsr head itr cams
- Need Help w/ Cam Timing-- Crower Stage 3's.
- obd0 b16a wont go into vtec
- Individual throttle bodies, yes or no???
- pr3 ecu question
- ECU Problem
- BASIC QUESTION - How does an O2 sensor work?
- o2 sensor
- b17 or b20 all motor.
- Would 3" exhaust hurt performance on be b16 del sol.
- I have a set of weird ITR cams. Tried search and this is what i found
- golden eagle lsvtec conversion
- H22a H22 Dyno Stock i/h/e IM and basemap 197.7whp
- my lsvtec dyno. Look inside!@#$
- NEPTUNE TUNERS in SOCAL
- quick question for h22a in an integrga
- what happens if o2 sensor is not on while on dyno
- difference between y7 and y8 block....?????
- does anyone know how much power it gains when changing collector to 2.5 from 2
- rpms for itr valve train?
- Uberdata tunners in TN?
- what is better to tune with?
- b18c1 & b16a2 usdm vs. jdm
- s2s2 on CTR valvetrain?
- N/A GSR Piston - Valve Clearance & H/G
- intake manifold question..need help...
- Transmission ID question
- b20/vtec 12.5:1 dyno...
- problem with b16a2
- 2001 civic EX VTEC transmission *problem* need help***
- N/A B18C1 Build
- vafc on ls?
- My Planned setup
- should i upgrade to TWM itbs?? plz help setup inside..
- Anyone heard of "Zero Factory"(Tuner) Oshimo-a tuning shop in So Cal?
- Kooks custom headers
- Difference in intakes? short ram, cold air, and "fat tube"
- Mechanical differences between B16A generations???
- Engine Swaps: Non-Honda Motors
- best valve springs combo w/S2 Pro+ Cams
- Passport Waterpump Help - Any Honda Techs?
- cam timing settings on b16
- Ever Use the Golden Eagle Vtec Conversion Kit?
- 05 Odyssey Engine Issues: Need Help!
- info on omni mans new quicklutch master cylinder
- Allmotor crvtec fuel pressure question......
- My B20 Vtec Dyno result
- just dynoed, hoping for some comments on motor's potential..............
- Z6 and Y8 head differences.
- b18a or b18b?
- b20z2 vtec... but no vtec?
- going all motor b-series, need suggestions...
- need help! ls/vtec wiring issues!
- What is the BEST Octane Booster available ?
- just fired up the crvtec........big problem, need ideas
- Any Good Hondata Tuners in NORCAL????
- how much work is it to put a b18c in a 91 civic si?
- Buddy club spec3+ vs. Spec4
- skunk2 stage 3's ok with porflow valvetrain?
- why would anyone want to remove Vtec?
- Race Car Pics, finally got my camera :(
- SAFC-II post your fuel curve settings with your mods
- first motor build ls or ls/vtec (Searched but got even more confused)
- Question about torque
- any dynos of the blox hsl?
- zero compression on new build
- LS Tranny Y80 Question
- SRZ RACING stock block GSR build
- 2.2L b16 with deck plate!!!
- TCC lockup control
- jun2 enough compression?
- Piston to valve clearance on JDM ITR with Toda b ??
- another ls vtec question..
- compression?
- 95mm crank streetable???
