- b20 rev capabilities...
- Affects of not tuning a newly built motor right away
- ? on ITB
- arp studs still giving problems!
- missed a gear, possible underlying problems?
- Is going from 1.8 to 2.0 as impressive as 1.6 to 1.8?
- Questions about building a block... (b18c1)
- Ls integra header
- pressure plate?
- Need Advice On B18C All-Motor Rebuild
- ngk plug- gap size? 44 -vs- 38 -vs- 35
- Endyn Ported IM
- b18a cams on b20b
- Question bout S2000 Exhaust...
- open deck vs. closed deck sleeves
- CTR, ITR, or stock B16a crank pulley? harmonic balance
- B16 Performance Building---
- mixing and matching cams and valvetrain
- JDM engine codes
- ITR intake manifold and throttle body question
- JG Edelbrock "mild cams"
- what fuel pressure shoul i run
- right conditions for vtec to activate
- ATTN:ALL people running header-tech About to order... bolting questions
- my new setup in my eg in the shop again
- Fuel Pulsation Damper???
- would upgrading my oil and water pumps hurt my engine?
- zex cam question
- CRVTEC OIL PUMP
- obd1 prelude injectors into a 92 teg
- LS motor oil squirter questions
- Engine will not idle at all. B20 high c/r 404's.
- Engine Basics
- front mount intake
- ALL motor LS question.. am i nuts?
- vtec engagement at what rpm?
- higher compression same time??
- Toda spec C ... or Cheaper JUN type 3 for my Si???
- Feedback Needed (My Setup and what's next)
- itr cams inside a b16a, low power, do I need ecu chip/vafc/fpr?
- who's pumping high horsepower out of your modified 1.6L engine?(all motor only)
- my ls-vtec setup.
- hey guys wondering about Headgasket and clearance.....
- NGK PLUGS copper -vs- platium ???
- JUN, TODA, Crower, CRANE or SKUNK 2 cams......what to choose?
- D16A6 engine swap problem..
- when to use bronze valve guides
- Anyone do just a ls/vtec without other power mods?
- looking to buy a leakdown tester...is this the right one guys?
- yes I'm a noob at timing
- crower stroker kit?
- Pros & Cons... Spec B exhuast w/ Spec B Intake cam
- 8500 rpm on stock b18c1 valvetrain???
- Intercooler on an all-motor
- 14:1 on 93/94 octane....Controversial topic......
- D16y8
- Recommendations for a thinner Headgasket...
- Methanol guys, got a question..
- Which head DOHC VTEC head is best for power?
- How long do you crank for during a compression test?
- 2.5 collector header for sale on ebay
- spark plugs?
- possible hp out of this setup
- what grit sand paper to smooth out pistons?
- Degreeing in cams with engine out of car?
- lowering compression by using 2 headgaskets?
- compression and bore...
- h22a in a civic....please help......
- post ur times of b18a/b motor in a EG
- engine won't start
- Looking for skunk2 stage 1 or toda cams A. also cam gears as well.
- gap on spark plugs
- should i torque the clutch?
- parts for a b18a in a 92 si
- pinging
- Problem with type R trany from japan
- My friend's dyno chart with Skunk2 stage 1s...
- Fuel Press.
- How much timing can one run with stock compression and 93 octane?
- All motor Definitions....
- 2000 Honda Civic Type R
- Rebuilt motor, smokes but good compression
- pressed ARP rod bolts?
- Hey guys, can you help me out? Are these Skunk stg 2 cams?
- Need Help to Contact or Order Headers from an-r.com
- great az tuners?
- POST your motor SETUPS, times & dyno #'s as well (for reference use)
- should i use these high mileage ls rods?
- 96 Prelude vtec spark plug gap and spark plug wire help
- help with idle....already search plz
- machined B16 crank pulley - VS - ctr crank pulley-- dampener differences?
- Intake
- largest bore size on stock sleeves?
- Piston Rod Combo's for 85mm street motor...HELP!
- what kinda power am i making?
- Triple Step Header?
- what causes cams to break?
- Need Help Building 1.6 Stroker Block
- skunk 2 valves, high or standerd compression
- Type R motor with Skunk Stage 2???
- valve keepers for 1st gen b16a?
- Flat faced valves w/ CTR pistons?
- Bent valves shifting at 8K??? please help
- Need a little help with b18 setup.
- How do you "tune" an ALL Motor Hybrid?
- jdm type r headers whats size piping should i use?
- buying CTR pistons
- b16 rod hardware size? 9 millimeter?
- skunk 2 valvetain?
- what starter are you using on your high compression motor?
- turbo or all motor
- how much to mill head?
- Quick Clutch Question, will an ITR Disc + PP be enough for my all motor setup?
- motor swap
- what next for my all motor gsr
- Civic SI all motor project... ITR or GSR block???
- skunk 2 manifold on gsr
- has anyone ever got the gude head,throttle body,ecu,cam,intake manifold package
- Tools needed for engine build?
- MSD ignition or /fuel rail or regulator
- biggest bore size on stock sleaves?
- Need some advice on b18c1 block. A few questions.
- what fuel pump to get `
- ctr lma same as itr?
- MIDNIGHT PERFORMANCE DYNO DAY CONTEST AND BBQ
- integra ls vs 1990 accord
- Header for a custom built engine with a deck plate.
- HELP RYANE Motorsports lowering Steering Knuckle !!!!!
- a question about piston rings????
- replacing head gasket and manifold gasket
- Getting the most out of a B18c5 without removing the heads
- Cams for a type-r....
- Which throttle body size would you recommend?
- what would cause a valve guide to break / crack?
- I need some good advice
- Question about Supercharger kits
- Vote on the best Honda Head Porter
- ?'s for others running built 2l
- What size Mandrel Bent piping is best for All Motor?
- Can stock GSR handle 8400 RPM?
- PRO and CONS on dsm injectors on all motor setup and has anyone done this before????
- Do I need to take any special precautions with my new setup?
- IB blocks
- Anyone ever use JDM B16 pistons with a B18 block?
- Question on STR Block Guard
- how much to mill for OS pistons?
- Cleaning up some ports?
- b20vtec stock bottom end and ctr cams valve clearance?
- Need Cam timing Specs for TODA a cams
- will this cause a lean situation?
- Keepers
- Who will be the next guy to break into 9's NA
- anyone running rc injectors?
- max redline on stock ls bottom end
- RC 310cc injectors don't fit!!!
- need an ecu suggestion......gsr w/ jun3's obd1
- torque specs on flywheel?
- Best intake manifold?
- Anyone had trouble with their GE sleeve?
- compression?
- All motor monster!!!
- Cam question and help
- ALL MOTOR WITH ZEX 50 SHOT
- which clutch would you guys recommend?
- pistons for my poor man r
- ferrea or portflow ti retainers?
- Best exhaust size for 220whp setup
- Cable Tranny Aftermarket Gears
- How can we fool the weight scale at the track for N/A cars?
- d16z6 all motor
- ZEX cam??
- idling problems???
- Anyone Running a Test pipe in kentucky?
- gettin most out of b18a
- What to do next to a d16y8 all motor
- address to the top of the line headers?
- cel question that really needs help... please read :-(
- Best all motor cams for daily driver in a 00 itr
- jdm 4 to 1 headers on a first gen jdm b16a
- ef-1 cams
- Block girdle.
- SPEC clutches...and one have one? couple q's for ya
- most power for the $$$$
- need help!!!!
- broken cams!!!!
- PW0 worth modding...
- Final drive How does it affect your overal gears
- is it a good idea---used crower cams for sale
- What is Erick's Racing's Piston bore and Stroke?
- 84.5 bore GSR
- Who is the best of the best honda head porter?
- best all motor headers
- Another Civic Type R Piston Question
- timeslip from about a month ago. just thought id share
- flange to buy for test pipe to JDM 2.5in header??
- WOT and partial throttle tuning
- Whp Gains with Ctr pistons and JUn 3's???
- All motor LS is stuttering and bogging
- using plastigage for cam install
- cam condition - good or bad?
- compression gains for flat faced valves
- How much pressure can stock b20 sleeves take?
- ROD knocking... cranmk work needed?
- To Stroke Or Not To Stroke
- All motor build up suggestions on B16
- Spark Plugs
- mushroomed valve stems
- ZC Engine
- Pistons.
- rs machine sleeving
- d16a8 ( ZC ) engine obd1 - eg5 civic hatch
- sucking air thru the breather in the valve cover?
- RS Machine products???
- Rebuilding motor, Q's on assembling
- b 16a help n/a setup?s
- type r pistons 25 over?
- vafc vs hondata ??????
- All Motor Extreme Piston and Rod Combo
- toda b question
- 1800 to spend what would you buy next?
- ACT 6 puck and pro lite fly
- Will my DC 4-1 fit my LS-VTEC?
- question about piston rings
- lsvtec checklist.. help me out.
- Best All Motor Head Porters
- b16B crank+ forged rods +forged pistons+ b20b block sleeved
- Eagle Rods w/ CTR
- question about compression with gsr block and b16 head with stock gsr pistons and rods?
- Toda spec C idle
- compression
- Golden Eagle IM?
- ls-vtec is my moto good enuf...what else
- SWAP SHOPS IN NC???
- OBD1 fuel injectors vs OBD2 fuel injectors!!!
- Easy ?? for you guys about B16A
- What cams in my H22A?
- CTR cams vs. skunk2 stage I
- NA or FI Daily driver
- please help!
- Best Cams for a ...
- Titanium Retainers
- 86mm head gasket?
- Anybody know ...
- Crower Econo Rods, your opinions?
- i need you advice on some cams....
- mph gains
- LS/vtec setup
- piston and valve clearnace?
- Random N/A questions
- ecu for LS/vtec
