- what connecting rod is better?
- Machine Shops
- EK9 Pistons in EK4
- need help asap :(
- ls vs. b16 mani?
- Machinest fubared my block
- ExospeedAMcrx read inside...
- Review: "big tube" header from sublimnal
- cam help
- Sunnen VGS-20 machine for VJ
- Help! All motor LSV
- 3.0 vtec questions
- Crower 404 upgrade
- ITB
- b16a build
- Block stamp VT7??
- d-series where to start?
- Radiator refill once a week
- gsr crank in b20 questions
- Oil Catch Can with LS/VTEC?
- ///B20 VTEC Build - JUN, Wiseco, Omni Power///
- B16 - brown smoke at high rpms
- b20 vtec build questions
- rebuilding head with bent valve
- LSvtec
- JDM B18C (GSR) swap into EG5 Civic - major problems
- ls/vtec timing issue
- B16/17 build question
- compression
- open header for track?
- Rebuild Help
- skunkpro3 with b20 race engine onboard practice vid
- New Rod Bearings 1994 gsr possible to leave engine in car?
- D series Dry Sump
- Why Pro All Motor Guy Prefer B Series than a H22? (Just Curious)
- b16 swap question
- b16 vs ls questions
- piston question
- post smog legal setups
- JDM B18C can beat Nissan 350 Z?
- My Dyno Numbers, What u guys think
- lsvtec question
- hybrid b16 and a few q's
- poor man's type-r build, some Q's
- ITR crank vs. GSR crank?
- Exhaust pipe size for B20 Vtec
- need header opinions for a non-vtec build
- GSR motor Bogs out at 1500 rpm
- fully built engine making anoying ticking noises
- Piston Ring order always the same?
- B16 lack of power in low rpm
- Some info on my plugs?
- b20 vs. ls
- Help. White Corrosion On Valve Stem
- LOOKING TO BUYing GSR MOTOR, WHAT TO LOOK FOR?
- higher comp. for d16z6
- B20 block on Ls head
- Ported GSR head, need advice on this!
- what head to use basic motor build
- exhaust quesition..
- Need Help with this plug reading diagnosis
- stage 3 cams help
- flow rates on head swap
- Going For 200 on a B16
- h22 lma spacer
- ls head on gsr block?
- what pistons/rod/crank
- degreeing aftermarket vtec cam
- Dumb rebuild question
- valve cover studs on b18c
- Catch Can?
- compression question pls help
- intake cam stuck
- Cam question
- building a gsr
- New Semi Build
- Suggestion on cams for F20b?
- ARP headstud fitment
- freshly rebuilt gsr burning oil
- Need Help with crankshaft specs
- LS/vtec help
- Help on NA Build
- Can anyone figure out...
- badass custom intake manifold??????
- Recomendations for new Mufler
- poorman R low dyno numbers
- Need help which headstuds to use "ARP" LSvtec
- Skunk 2 Stage 1 Turbo Camshafts
- What Cams would u Run?
- MSD Questions
- Skunk2 manifold installed no runs like crap
- GSR in EJ1 issues!!
- b18a/b crankshaft specs needed please
- A few Valve Train Questions
- H23vtec bluetop H2B or b20vtec built
- Building a D16z6
- whats my weakpoint? / a few ?'s
- vafc2
- UGR Stage 2 Cams Info
- !!!BUILT B20 VTEC!!! HELP
- Aftermarket VS. OEM
- High Compression LS or B20?
- Should I NA build my b16a2?
- Build Almost Done, Have Questions, Need Answers
- Vteckidd comes out of retirement...........
- What Clutch for big build???
- performer x manifold fit question
- engine builders - question on measuring mains
- F20b Sir dyno
- B20V question
- JDM B18c type r
- what type of gains from port and polish head???
- valve adjustment specs for skunk2 stage 2 pro 2 cams? anyonE?
- How Do you put a k20 in a ITR
- advice on B16b
- cam gear question for b20vtec
- s2 pro3 cams + high compression pistons
- any gains with e85 for NA setup?
- b16 stock dual spring question
- 2.5" to 60mm
- Exhaust Piping
- Need help with throttle body
- stock rings
- i need help deciding
- b20z block w/ b18 head..no PVC valve??
- Cam Gears Timing GSR
- LSVTEC info needed **BUILD**
- B16 Intake cam
- noob questions on build of b16a2
- Rocket Cam broke!! RIP B20vtec :-(
- question about oil pumps. EDIT: nevermind
- slicks
- what vtec conversion kit should i use for my b20v
- Auto to Standard Help.
- Hayame adj. cam gear trouble...
- Can't decide what header to buy for my set up.
- H22 boring stones and past?
- These Darn Cams, Need Some Help
- What size throttle body?
- rbc on both accord R AND civic SI
- rod bearing color help
- PIC REQUEST GSR EXHAUST CAM
- help with all motor b16
- LEAN and COLD
- Not Happy with Dyno #'s help
- Wrist pin bushings
- Mild built ls/vtec overheating issue?
- hondata s100?
- Replica Tri-y header or replica RMF (*EK/b18c*)
- B Series head gasket
- dyno'd 1994 gsr
- Are EBAY torque wrenches accurate?
- Spark Racing Rods
- low power help please
- 171whp 94 GSR TUNED BY TODD @ MOTION LAB DYNO DYMANICS
- b18c5 build up! 2.0+?
- will ls high comp pistons interfer with b16 head/valves
- NA AEM RAM AIR INTAKE
- 1998 civic ex w/ 96 b18c1 needs a lil tlc?
- uneven compression....
- will a D series zc cam in a d15b2
- F22B2 piston to valve
- got my b16a3 dyno tuned on chrome!!! nothing crazy though....
- b16 block/gsr head.. or lsvtec with gsr head
- losing fuel pressure, leaning out
- lsd GSR vs. JDM b16
- b20v with gsr head?
- more oil pressure better
- What should i look for when buying a used longblock?
- will this cams still work crower cams s2
- chossing the right ls/vtec setup for me
- d15b7 mini me dyno
- Deglazing cylinder walls
- gsr crank and rods in ls block
- B18C5 From Scratch
- Built ITR exhaust question
- What seat pressure do I use for s2 pro1 cams??
- help f20b swap in 97 accord
- valve springs & retainers for s2p1 ls/vtec?
- LSVTEC oil pump loses prime over night???
- Supertech Dual Valve Springs and Retainers
- Buddy club spec 4 cams?
- b16a redline?
- s2p1 install
- what else can i do to make the most out of my LS/Vtec?
- What cams in your opinion? B16a used for road racing
- Rod Knock Problem...Need to rebuild or Just Swap
- Y7 to Y8
- help am running lean
- Those with H22 TypeS/ATR Pistons+S2P2 or S2S2 cams
- Confused about injector size...
- B18C1 head mill amounts
- Skun2 tuner2
- wrist pin/ gudgeon pin help.
- gapping plugs for more hp?
- ticking noise after installing itr cams in b16??? why
- Building my b20 vtec
- building poor mans type r!! good parts bad parts?
- nitrous on h22
- rmf header install question inside.
- Car won't start after it gets warm
- low vaccum
- what c/r to choose
- stock d16z6 blown head gasket help plz
- Rebuilding the B18c5, but I have a few Qs
- Stock LS connecting rod ????
- head gasket leaking oil?? !!HELP PLEASE!!
- problem with new build
- gsr with blox type a cams where should my vtec be
- Anyone run both spoolin header vs Toda Header?
- interchangeable mains??
- gsr build help
- b20 cylinder wall lubrication?
- hondata s300 b20 vtec 13.5:1 compression help
- H22 N/A rebuild...Good setup??
- Dynoed 85mmx89mm with M 24 camshaft
- Blew up h23/vtec (hybrid)
- cel 16 after injector install
- ls/vtec compression?!!PLEASE HELP!!
- what kind of hp gain with itr cams and tuned on chrome on b16???
- b18 c GSR motor question
- y7 dizzy work with z6 head?
- h22 budget build help
- CTR Cam Timing
- Questions about a mild build on a Bluetop H23A VTEC motor
- engine rebuild help????
- Del Sol B16 Simple!
- h22a arp cyl head torque specs
- puerto rico fastes street allmotor civic
- B20B bottom with B18C Head Question
- REMOVING THE CRANKSHAFT PULLEY...???
- EDM Accord Type-R powered by Skunk2 Pro1+
- Any suggestions for VALVE TRAIN SETUPS for B18b1 engine?
- h2b question
- Which Header would make more/better pwr on a stock H23A VTEC BlueTop H2B RMF or HYT..
- Piston to valve clearance issues? B20Vtec Qs.
- ls vtec b18c1 coversion
- B16a2 what will it take to put make it have a B18C1 block??
- Need help with obd1 conversion
- h22a
- got my head back from shop
- need help with timing belt
- Where to order JDM OEM Parts from Japan Dealership?
- Looking for somone to install a timing belt. PA
- h22 valvetrain option?
- H22 - Snapped timing belt
- S2 P2 cams and OS Valves
- B17A1 gaskets question.
- oil catch can b20vtec - oil plug fitting size??
- F20B with F22B2 DOHC non-VTEC head
