- help my B18C1 with b16 head
- Haw far can a non vtec B20 Bor Z be taken
- Opinions on my custom intake?
- nonvtec B20B
- usdm b18c1 vs jdm b16a2
- lowering compression on pinging motor
- lsvtec startup
- CTR Pistons with GSR.
- Gasmileage with a slightly built motor.
- Labor on headwork
- Toda spec C to B Q's
- b16 ECU's
- ACL Bearing Question
- what hondata setup for my setup
- Which would be best?
- does any one knoe a place in the mid west that can tune toda cams?
- Guess the whp??Going to the dyno today.
- 90-91 Teg throttle cable pt # 17910-sk7-a03 for my EF swap...
- omnimans gsr cranked 1932cc b20z vtec street motor dyno
- zex 59300 in y8 head-cam timing question
- Inner exhaust valvesprings
- oil catch can setup for Ls/Vtec
- Torque on a B16
- How the fuck do u use a TIG welder.......??????
- B20 Tranny Gearing
- need help with pinging GSR
- knock sensor code...
- B16a block with CTR psitons and GSR head
- B18c1 head V's B16a
- Final Mods, due to being dicked too many times....need some opinions/wisdom/info..
- Idle surging problem !!!
- B16 head question
- Only run I have on tape from this year. Spinning threw 1st and 2nd.
- are toda cams loud?
- Installed Spec B's TODAy
- b20/vtec guys Cams? jun3 specC valve/piston clearence ?
- ... rev limit question... gsr head, itr valvesprings, gsr cams...
- H22 in 97 EX ?
- ferrea valve springs for h22a???
- cam gears for a6
- B18B Head
- Help me choose a Header: Header Tech vs. AN-R
- B18C 94-95 (GSR) swap
- Projected WHP with this Setup! Need some insight!
- piston question
- Toda A's or Skunk 2 Stage 1's
- all motor reliability (sp)
- Question regarding port & polish
- Type R intake mani on b16?
- CTR Pistons in a Type R
- Opinions on Crower stroker kit on B18C5?
- Compression Ratios
- ITR or skunk2 for my setup?
- is a gsr block and type r head a good combo
- will 255 pump work in my 88 si?
- Which cam to go with...HELP???
- Does Hytech make a full header back exhasut for a crx with a swap?
- 189.7whp on my B16, Dyno inside
- A little misshap
- Oil Cooling - negligable or visible benefits on dyno
- do i have the compression?
- well the build-up has begun, starting to by my shizzz nit.
- How much HP with the DOHC ZC?
- plugs look lean but I'm running fuel at 45psi
- Final Drive and Slick Size Recommendation
- Ef1 Cams
- GSR cam identification
- LS/VTEC with CTR Cams & ITR Valvetrain...Rev Limit?
- Tell me what you think of these cam specs
- question about stage 3 cams???
- Post your allmotor 1/4 mile times.
- Skunk2 Springs and Retainers
- Anyone here sporting SOHC non-VTEC engines?
- Anybody got any pics of a H22 in a Ef? or Eg chasiss?
- Anyone heard of RS MOTORS in San Diego?
- Skunk2 Manifold, TB, Higher Redline?
- went to dyno today
- Skunk 2 ECU??
- SDS users?
- car takes long to start whenever i goto pump gas.!?
- B18c1 block, Pr3 head, and CTR pistons...
- Your feelings on converting to cable, in a hydro car, been searched...
- Questions and advice about cam choices.
- Got dynoed today.....brake horsepower?????
- ITR vs. GSR cam lift & duration???
- Anyone ever have AEBS do their headwork?
- Toda spec D's
- Putting cams back into head???
- ALL MOTOR EXHAUST
- What do you think this setup will hit???
- DC JDM 4-1 header, worth it?
- Pics of Some Head Work I Did
- valve job..3 angle vs 5 angle??
- Trying to learn about trannies and have a question.
- HELP...CAN YOU GET 200WHP FROM A STOCK ITR
- L'Natural 10.36 @ 130+mph... video link
- Hondata Stage2 PR3 problems again
- Block Guard for all motor?
- preferred piston rings- 11.5 comp daily driven B16
- valve adjustment questions...
- B16 or GSR motor?
- Satisfied with your N/A setup?
- Skunk2 manifold review (LINK)
- Best Pistons.... your comments...
- need help blue smoke !!!!!!!!!!!
- Japanese ITR final drive in an LS S80
- Multi-angle valve job
- HEAD PORTERS: K series
- b20 vtec or gsr
- ID these injectors, pics
- CTR pistons in ITR
- let me know what ya think about my ls/vtec setup
- price
- Why use a muffler on a race car like Pierre Kleinubing?
- Power Enterprise timing belt woes
- Skunk2 stage 2 aand 3 cams question
- Rpm Gauge
- any b16's using toda camshafts SPEC C?
- Can I mount the EGT here?
- dumb question, need cam specs
- uping compresson by use of a thinner head gasget
- asap need vafc th-point crossover settings for ls
- vtec hitting late and inconsistent...
- Quickest way to 9000 RPM
- Lets name all the 10 sec all motor cars
- what do u guys think about this header
- Ti Retainer wear
- wanted dyno graph
- motor breaking in
- which motor would you choose
- All about the block.
- Wanted: CTR Piston Dyno graph(s)
- b16 distributer help
- New turbo - check engine light after boost ?????????
- Length of Hytech header?
- H22/H23 Frankenstein.....
- d16z6 dc sports headers
- how difficult would be to get 200 whp .................
- so the car just decided not to turn on, not even a click
- whats wrong???????
- Who knows cams?
- Cam...
- AN-R headers
- power steering or no??
- Vtec help??
- windage tray ?
- compression and piston question?
- JG Edelbrock or DC?
- fastest 18c1 in a integra body?
- Power Enterprise belt too loose......
- do these things really make a difference
- what ecu program should i use for a p28
- what pistons should i do?
- NooB? Block gaurd on a B20Vtec
- ?LS Vtec piston to valve clearence W/ CTRpistons and Skunk2 stg2??
- LS Vtec compression? w/ .25 over bore CTR pistons??
- what will it take to hit mid to low 13's
- Much props to Leslie Durst!!!!
- Has anybody seen ericks' new Project Crx on his site? What do you guys think?
- B20b-vtec or B20b-Turbo? suggestions and feedback please.
- what companies make custom header for b-series motors?
- 185whp....can it be??
- Leslie Durst runs 10.3 to win NHRA Dallas
- few tunning questions untill i get to dyno
- UNIVERSAL MUFFLER?
- FUEL PRESSURE REG/UNREG
- stupid ls/vtec!! i need help??
- Stupid noob question,what does ITB mean?
- Kamikaze Header for NA?
- Standard or oversized p30's in an LS block?
- Comp and Web Cams
- Anyone With All Motor Use A NA Timer?
- Shorts Bad-Ass 00 ITR Pics
- 2 1/2" Collector w/ 2 1/4" Test Pipe ?
- 200 whp
- CTR Pistons and Intake Cam In B18C1. Is it reliable and streetable?
- conciquences of putting engine in and not wireing up vtec for now?
- my aem CAI is whistling???
- Spark plug Recommandation and GAP for High Compression Motors..
- All Motor h22 1/4 mile times?
- Engine for 93 civic
- V-AFC or Hondata
- which one should i get?
- spoon N1 muffler on eg
- CAT Cams any good?
- All motor setup
- CTR piston Part # for the .25mm overbore
- What would it take to get Jeff@IB back on the board?
- Best ECU?
- 97 itr tranny
- Q's about LS/Vtec build up *already searched*
- Help: Timing Belt
- Flywheel and Wheel HP Conversion Factors
- ZC DOHC Timing Belt tension.
- check out this vid
- is my compression to low????
- CTR pistons on GSR rods
- exhaust question?
- Endyn CF intake manifold for H22!
- Question ?? my setup vs power im putting out is good or bad????
- No car blues...
- Please Help ASAP
- Final Attempt to find a good tuner in Washington....
- total seal piston ring question
- 2 gen B16 rev/shift.....ahh just read it......
- Just wondering what 1/4 mile times and hp i might see...hmmmm.
- sohc vtec cam/valvetrain upgrade - sohc guys look in here!!!
- Do i need VAFC to tune?
- Hondata Tuning Tips
- b18a torque specs
- ls/vtec - question on piston rings - at a stop with the motor build.
- b20z
- b18c1 with b16 head need help
- The head game.....
- Spoon cams?
- getting valve adjustment today
- Distributor for b18c1
- where to shift at ???
- Best WHP with stock ITR internals?
- Coatings and oversized valves
- itr compression
- milled head .03 and weld chambers (alaniz)
- HCI B16 200whp all motor setup part 2........ anyone else see it???
- Son has 92 Integra automatic with I4 1.8L. What's the best upgrade?
- Help Me Decide what to get!!!!!
- trannys for ls vtec
- how much do you think i make untuned?
- header on a D16 check engine light on?
- ported throttle body?
- does anyone know who sell the best gsr swap
- What cams would you recommend for my setup and why?
- Valve Adjustment issues/problems
- What else should I get for my N/A B16??
- Distributorless Ignitions
- Only 198 whp is ECU the problem?
- Spark Plug Question
- Biggest size pistons you can put in a B16 with out having to sleeve it??
- where to hook up temp gauage on d series
- Building question: What tq wrench do you use? and. . .
- made a velocity stack intake today
- motor rebuild complete first start codes 13 and 16
- safest compression piston for b20 vtec with stage 2 cams on 91 oct ?
- tell why 400 hp not possible?
- Got 4k to play with...what would you do?
- Emissions Failed, Need help, what went wrong??
- Setup...
- Somebody please help me on the d16z6 build up....
- b18c1 stock bottom end bad with stage 2 cams ?
- Problems with 2-layer headgaskets?
- B20Z stock piston compression height?
