PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 [204] 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. time to build up b16
  2. need parts for my motor
  3. leakdown on k20a2
  4. itr pistons on ls rods need help
  5. AFC tuning enough? Or is Hondata necessary?
  6. arp torque specs on ls/vtec setup?
  7. ls crank in gsr block yea i know i searched
  8. Question about valves on a B18B
  9. new to the all motor forum
  10. Searching for a Reputable Machinist in So. Cal Area any help appreciated
  11. Where to set VTEC for Toda A cams in GS-R
  12. F22 to an H22
  13. b20vtec
  14. Wussup NEW TO THE FORUM!!!
  15. exospeedracing info?
  16. What would be th best N/A GSR street setup on stock shortblock?
  17. B16 problem
  18. My setup, My problem
  19. Potential gains of ported IM
  20. Gs-r tuning?
  21. DIY CAI
  22. Skunk 2 Stage II cams w/ 1-layer head gasket???
  23. Final a Reality? 320 WHP in a K series engine
  24. Built k20?!?!
  25. My new B20VTEC setup
  26. Finished the Fuel System Today
  27. Pros and Cons of the Spec C?
  28. Turbo or All-motor????
  29. HONDATA???
  30. little help please!
  31. LS/turbo streetable daily driver build up help
  32. lemme know all things necessary to build the fastest d16z6 ever..
  33. kineticgsr's dyno plot
  34. 99 civic si with type r head internals.
  35. SOHC Intake Manifold Tech - Which Stock or aftermarket is best.
  36. Having a big problem with new skunk2 cams
  37. My LS/VTEC Rebuild Is Underway and Bound To Be A Monster...Details Inside
  38. Draft:Should I get a VAFC (dyno)
  39. Jun3 Cams w nitrous????
  40. Cams for GSR
  41. Tuning ITBs with Hondata
  42. It's DONE!
  43. front mount INTAKE, hurt all motor performance?
  44. Turbo guy goin N/A...HELP!!
  45. Results of track visit #2
  46. b20vtec head questions~
  47. All motor guys list your Fuel Management Setups HERE!
  48. Code 15 and Code 21....ignition and vtec... AHHH!!! help!!!
  49. lowest compression OEM d16 pistons???
  50. whered this motor come from?!
  51. Suggest me a clutch, fast!
  52. Adjustable Cam Gears
  53. going all motor...would this be okay??
  54. Vtec not engaging properly? bogging occurs....
  55. What are good sized Injectors
  56. whats up with the old b20 prelude info needed
  57. Couple of questions, boring, compression etc
  58. what's going on with my ignition timing?
  59. power loss up top
  60. 97 civic 3dr hb- 2000 front conversion
  61. Need pic of the side of a 94-95 b18b
  62. Big bore B16???
  63. 2.0 almost done
  64. where to find a cpu tunned for my b16a2 vti and what cams to buy???(be nice just want help)
  65. Who Knows of kevin tran and doug jenkins, and how do those guys do in the racing scene
  66. How to get pistons off of rods?
  67. Tbones Dyno plot
  68. Need Some Answers on my LS/VTEC build up!!!!!!!
  69. Who has installed a AEBS IM on a b16a?
  70. What should i do???
  71. individual tb on an h22 eg?
  72. Making power tuning N/A with Crome, Uber, etc...
  73. >>> LOOKING FOR B!6 Engin <<<
  74. Pics of my AN-R Compact Header after a coating by HP Coatings
  75. ~stageIII's in b16~
  76. LSD in 99-00 Si tranny.
  77. Suggest me an intake manifold.
  78. need help deciding on pistons
  79. aggressive cams and compression test results
  80. Installing Cams in May, what else should I do?
  81. coolest 8-way ITB ever!
  82. go seth go!!
  83. EP3 All-Motor Setup
  84. B16 roller rockers?
  85. B16 stroked
  86. exhaust questions
  87. B16 all motor. need suggestions
  88. whats the big hoopla about ls/vtec?
  89. DC sports Stainless 4-1 or 4-2-1
  90. pipes
  91. What compression with what Cams in a JDM ITR motor ???????
  92. Assess my Dyno
  93. all motor build up *help*
  94. SLICKS QUESTION?
  95. all motor...over heating?
  96. quick question about ls-vtec
  97. Crower or stock
  98. cryo for engine and parts
  99. AEM cam Gear settings with JDM ITR cams in B16a?
  100. Deck Plate motor relaiable .....
  101. Tryin to get rid of my last things :(
  102. just got back from dyno at DNR
  103. JDM B18c in a 92-95 coupe
  104. All motor B16
  105. ECU question (97 EX with swap)
  106. b20vtec: what to do w/pcv??
  107. 12:1 Compression H22
  108. Crower 404's tuned, results
  109. >>>> ENGINE PRICES <<<<<<
  110. intake components...choice choices?? which route do you reccomend
  111. Question on test pipe
  112. All motor y7, couple questions
  113. no fuel to engine on 95 stock civic dx
  114. Need ASAP about 12.0-12.2 CR pistons and here is....
  115. Vtec controller or chip ???
  116. 85mm bore and stock chambers?
  117. question on head build up
  118. NEED H23 crank
  119. How much can stock H22 rods handle all-motor?
  120. H22a power?
  121. which cams are best for my setup? (actual experience preferred)
  122. 82mm stock block?
  123. lsvtec help......
  124. ALL MOTOR, blue smoke
  125. boring for oversized pistons
  126. H22 intake mainfolds...
  127. Honda Port on Roids - The RLZ Way
  128. Ls-Vtec with Crower 403's?
  129. Time for new arp head studs???
  130. help here for a jdm itr tranny!!!
  131. BEST cams for h22???
  132. ITB LENGTH
  133. Potential of D16?
  134. EF-1 Cams
  135. >>>TRANSMISSION BLOWN<<<<<
  136. Looking for some LS/vtec write ups *Already searched*
  137. Want to see some d16z6 w/ p29's
  138. Buddy Club III Vs. Skunk2
  139. code 54, obd1 engine obd2 ecu
  140. Any Approximations on how much it would Cost to build engine
  141. So what is the next big thing?
  142. Help starting ot would like toknow what to do?
  143. se gsr head?b20 question
  144. Searched.. Some T Belt Questions
  145. Street/Strip setup
  146. Spoon sports balanced JDM type R pistons
  147. my vtec is not working correctly... i got no power
  148. Does cold air filter work on a Automatic?
  149. quick compression question
  150. what to expect with this setup...
  151. wasting my time?
  152. help: need a set of b-series valve n retainers asap!
  153. ping/detonation
  154. Trying to Put Valves from a b21 head into a b20a5
  155. Hot shot header question
  156. B20a5
  157. need advice on valve leakage????
  158. OT: parts Washer Q?
  159. stock p28 on ls/vtec okay?
  160. Someone clear me up!! -Hondata
  161. OEM B series piston weights.
  162. camshafts
  163. cams???
  164. How long has your LS/VTEC or CRV/VTEC lasted?
  165. Tbone's car on the RedShift Dyno (Honda Day)
  166. To RS Machine or Bisimoto please read.... F22 adapter plate
  167. Has anyone ever bought a motor from these companies?
  168. problems with h22 and crower..help please?
  169. Bisimoto or SMSP???
  170. Skunk 2 Stage 2 or Stage 3?
  171. should I stick with skunk stage 1's?
  172. honda itb sizes???
  173. good tuner in connecticut
  174. crankshaft
  175. just got back (dyno)!!!!!!!!!
  176. what kind of springs and retainers??
  177. Header-Tech and Kteller combo
  178. Bootleg ITB's question.
  179. any way to free up more hp
  180. Titan Motorsports \\ Ed's Racing Heads Port and Polish Dyno Results
  181. should i use syntec oil so soon
  182. Any thoughts on Power Enterprise Vtec a/f controller
  183. Who Makes an Aftermarket Cast O.E-Style Piston with Black Moly Coating?
  184. ITB's and IAB ??
  185. b16 trans ?
  186. What is the quickest all motor SOHC 1.6?
  187. Well.... I saw the light, and had an epiphany... (B16A2 200whp)
  188. 4.785 ==> 4.929 final drive
  189. ACURA/HONDA part numbers
  190. 1st time dyno results of my ls/vtec setup.
  191. poor mans type r
  192. JDM B16 LSD, into a GSR tranny ?
  193. Getting crane cams to idle, any suggestions?
  194. Raising compression in my B16A Bottom end....let's discuss
  195. Thoughts on RS Machines Vtec cams???? Anyone have these?
  196. isky valve springs
  197. b20 block sleeved
  198. A new shop in SE Wisconsin
  199. the most out of b16a2
  200. Any Allmotor h22's in here?
  201. Has anyone experimented with rings otherthan OEM honda for 81.25, 81.5 etc...
  202. TDC and more ??'s
  203. Highest Compression B16 street wise?
  204. ARP head stud question???
  205. is there a copper headgasket for c5's, or any single layer gaskets? will they work?
  206. How to identify a ZC motor.
  207. cold air intake
  208. h22 in 89 hatch?
  209. went to the track today: SH*TY TIMES!!
  210. Vertical lines on cylinder wall
  211. Question for Skunk 2 Stage 1 cam owners
  212. What kinda #'s can I expect with my Z6 and a few Q's on how to build my block...
  213. help with cam install
  214. rebuilding my top end
  215. catostrophic failure....
  216. crankshaft holder
  217. flywheels lighted or stock
  218. Simple way to reduce stiff motor mount vibration/shaking
  219. photo comparison:AEBS,ITR,b16 IM's
  220. Anyone recoginze this monster? (Pic from Haonda-Day)
  221. Stock LS valve springs
  222. west coast people fresnostreetracing.com in fresno , clovis
  223. slight dip in power at Crossover with new ITR cams in B16a? what gives?
  224. hayabusa TB
  225. Looking for a dyno in pennsylvania
  226. cam holder direction.......help quick
  227. riddle me this cam experts**
  228. "Ground Wiring Kits"
  229. question about B18b(LS) motors
  230. my DIY ITB progress
  231. who sells arc products
  232. Omniman, need your thoughts...
  233. Buy Complete Swap or Build My Own.....
  234. straight axle or independent?
  235. new to honda-tech: opinions on this set up
  236. ITR crank in LS block
  237. B series dizzy on a H series block?
  238. Why people sleep on a straight LS motor???
  239. Dome displacement of rollerwave pistons
  240. what would u rather use: stock GSR mani or skunk2 GSR mani?
  241. How often to rebuild?
  242. what header for h22?
  243. Now second Thoughts what about the B20 block and B18C head
  244. Cont... 74mm tb and Custom Intake Manifold What about this SetuP??
  245. My NA project - some info and pics :)
  246. question about resizing big end of rod for ls/vtec...
  247. Crower Stage3 cams
  248. what cams for k20 motor?
  249. Building LS/Vtec need some advice.
  250. Newbie....Need help to decide Stick with stock engine or swap to h22
