- plastigage dillema
- 200whp gsr question..
- 183whp dynojet... oem piston
- Aftermarket knock-indicator
- b16 a1 problem
- Vtec wont turn on...no check engine lights TRIED SEARCH!
- lil help would be nice, tryin to build a 2000 civic si all motor
- Anyone ever Flow Test a Throttle Body ?
- Dirt cheap Cams from JHPUSA, anyone have those? how are these compare with Underground Racing?
- "I'm so JDM I rev to 10,000RPM!!!"
- built gsr or poormans type-r ?
- please help asap ---b16b civic type r which cams?? skunk2 stage 2 or buddy club stage 3 or 4
- B20vtec low numbers? Skunk2 pro1
- educate me on back pressure
- f22a1 w/ vtec head????
- head milling question
- what kinda of pistons on b18c1 block and b16a2 head
- K24A2???
- possible poor man's type R head gasket leak???
- help car boggin out at hight rpm !!!!!!!!!!!!!
- LS motor pistons
- stock b16 with type-r cams
- Question about which compression ring is which on OEM rings
- Any BIG Difference between 81mm pistons to 82mm pistons in performance?
- LS vtec reliability for a daily driver
- Do people get good results with the homemade GSXr 1000 ITBS
- Best High Rev mods
- ITBS Vs. larger intake mani, and throttle body.
- Overall Brand Review
- ARP rod bolt install??
- Swirl Effect Creation> I want the Big Dogs to chime in!
- Motor was built recently, burning oil already?
- Mahle Pistons
- Valvetrain wear issues?
- b16 head/ gsr block
- BLOx Spec B valve lash??
- Wet Intake
- obx h22 intake manifold
- chipped ecu caused my GSR to stall out?!
- Buddy Club IV Vs. Skunk2 Stage 2 HEAD WORK
- what aftermarket rods take press fit pins?
- All Motor * SOHC * Chime In !
- act streetlite question
- Blox intake manifold question
- small or large mains????
- tuning with leaded fuel?
- skunk2 pro1 cams question help
- Where is the best place to buy Weber carbs?
- what head gasket you using?
- which cams with my poormans type-r?
- 2.0 gsr question
- What head bolts do i use B16b Block with a B18c1 head ????????
- obd0/obd1 ecu socketing/chipping guys
- Cars Turns Off Randomly
- What happened to the ALL-MOTOR topics?
- Q about using syn oil on my GSR
- JDM Sh!T Racing Header...is it any good???
- LS VTEC 12.1 compression, Timing recommendations
- Passing emissions with an OBDII car...
- how did your ls/vtec turn out?
- built motor and want to upgrade manifold
- Toda C vs Skunk Pro 1's on a 1.8 and vs Pro 2's on a 2.0.
- Compression Test Result
- hamp filters
- obd2 or obd1 ecu
- gsr cams
- U.H.L.?? (ARP rod bolts in manley rods)
- quick arp headstud question
- poorman type r
- will trade
- b16a2/b18c1
- Custom Exhaust help. Searched and even more confused!!
- best k24 block??
- Rebuild with High Comp Pistons ???
- d16a6, z6, and y8 cranks--are they the same?
- Hondata S100 or Chrome???
- Anyone recommend ATS Gears (1,3,4,5)??? for B16 Hydraulic Tranny?
- stock block b18c-R with ss2 cams. cam gear tuning?
- Nitros, High compression, direct port?
- b18 intake on a b16? bad idea?
- jdm p30 ecu question... confused
- best cams for me??in your opinion
- started a parts list for my new motor i am building this winter
- b20/gsr head ?
- header. . .
- Claying B18C1, what about VTEC?
- black smoke !!!
- 2point6's new project for IDRC
- Another LS/VTEC build with Pics
- cams
- another what cam for my all motor h22 thread...
- my k24/k20 build up with IPS parts!!!!
- Spark plugs and wires
- blox cams vs skunk2 cams
- pr3????
- What "EXACTLY" is this head from???
- how much weight?
- engine serial number
- m22x, bc 4 and jun 3????? on my eudm itr
- ITR LSD-B16 tranny help...
- Aluminum Exhaust on NA Car
- How many people had problems with the B&M fuel pressure regulator.
- Did compression,leak-down test but still smoking at higher rpms
- B20VTEC+HEADERS+FULL PIPING=???
- OEM Honda rings
- Well my rebuilt motor is burning oil... :(
- Comp cam question?
- Pre-tuned ECU
- crower valvetrain
- CTR Cams
- ls vtec, skunk 2 s. 2 cams, 150whp HUH?
- My Crank Pulley fell off my car.
- need answered asap about a B20B block
- ls/vetc ??s
- ls/vtec crv
- Rocket m22x cams...overkill?
- 82mm Pistons safe for GSR block?
- markings on skunk2s2??
- h2b eg .......built head!! problems
- IN NEED OF MOTOR HELP
- 2.0L All Motor ITR; Finally Complete
- itr cams or ctr cams??
- Can I run stock valvetrain with 59300 Comp cam?
- Problem with valve lash/clearances w/403s in my ls. A little long, not too bad.
- gsr block b16 head?
- winter project on a budget...need advice
- what compression?
- Stock P72 with Mild LS/Vtec Build. Need Tuned?
- B18, 82mm bore droped a valve
- Internal Engine Modification
- TWM ITB Question for the Pros
- Anyone using Blox type A's
- crankshaft grinding: any solid info?
- what size slick should i be running? what do you guys use?
- b20 vtec vs 2.0L b18c
- Skunk2 Pro 1s or Pro 2s??
- m22x Finally Comes to OZ
- reading valve lift?
- ls/vtec question
- Why isnt the H series the engine of choice for N/A?
- ek motormounts????
- Rod Bearings?
- Camshaft Experts: Your opinion on these specs.
- POWER throttle body
- poor mans type-r engine.....building it.....made a list.
- B18C5 parts into a B18C1
- skunk2 pro2 camshafts B18C-R
- HELP!!!!! b16 cams or cam gears problems.
- How are these headers. Comments?
- Worth fixing ys1 gsr or y1 b16 lsd cable trannys?????
- wats the most accurate site for calculating CR???
- RS Machines 82mm P73 piston question
- First build breaks 200whp
- Will BC spec 4 cams run like shiz without headwork?
- DART GSR Head Flowrate.
- b16 which Intake manifold
- HELP!!!! SPARK PLUG FAILURE ON A RUNNING ENGINE "PICS INSIDE"---------------------------------------
- pleeeeease help!!!!!!!!!!!
- b18c somewhat build
- Apex-i N1 universal muffler on crx
- SPOON VTEC CONTROLLER?????
- CABLE YS1.....which throw out bearing do i need???
- Skunk2 pro cams?
- Poor man's type r .......
- State Referee Inspection Required
- dyno tuned...now car dies @ idle'
- b16 question
- port and polish head
- ITB Daily driver anyone?
- GSR head or B16a head?
- tunning advice??
- Bad idea to leave motor on the floor?
- b16 with GSR cams?
- Block Sleeving
- b20b vs. b20z
- LS Crank and rod VS B18c1 Crank and rods
- a6 connecting rods and a z6 crank...bearing selection process
- Motor Mount
- not sure if stupit question
- Look what came in today!!
- nippon racing pistons?? (search not working)
- cam events m22x
- blox cams on ebay
- torque?
- engine problem!!
- Project LS Non-VTEC begins.
- b18c5....cams?
- Throttle Body Question
- buddy club spec 2 owners!!! NEED YOUR HELP
- gsr block
- b18b rebuild
- poor man's type r build
- things wont fit anymore!!!!
- main bearing bore codes?
- Semi-noob here. Where to buy the all motor shizzle?
- Building B18c1
- stock type r intake better?
- Gsr head on a B16b block HELP HELP HELp
- Help with wire tuck
- i need help finding a shop in so cal.... PLEASE HELP???
- Injectors TOO big???
- need cat
- how much nitrous?
- just got my block back today
- d16z6 head build valve angle help needed dseries
- tranny pop out?s
- assembling SRP pistons onto Eagle rods
- b16a or b18c1 head for build which is better??
- Were the Supertech Flat-faced valves used in Omniman's 200hp B16 Build?
- Replacing pistons/keeping stock rods?
- Need suggestions
- b18c1 bottom block rebuild
- 4-1 or 4-2-1 headers
- deck damage, take a look
- Dilema on camshafts, ended up with 2 sets, what would you choose?
- Need Help. Build all motor street car.
- bent cam shaft possible???!!!???
- Gasket questions?
- Anyone test mod'ed ITR intake box vs. aftermarket ?
- cant rev over 4,500 need help
- For those of you running Buddy Club Cam Gears, Take a look
- jdm to usdm
- BIG THANKS TO AMR~!!!
- My rebuild
- pressed ctr pistons onto gsr rods... but.. they float funny
- K24/K20 tranny question!?
- Damaged Head
- cams.
- Unorthodox Underdrive Pulley Set
- Allmotor 2000 Type R for sale
- how to run JDM ITR 290CC injectors in obd1 car?
- GSR B18C1 Bottom Block Rebuild
- Spoon Engine?
- GSR or TYPE R cams?? which one
- Throttle body too big???
- Rod/Stroke ration + Comp
- k20a2 non type-s
- Should I get this balanced or not?
- a few questions about the b20b
- Cam lobe worn and rocker worn bad.. JUN cams, Supertech Valves (Exhaust mid #1)
- builting cheap b20vtec setup, will it be better to replace rod and mains bearings??
- All Motor LSVTEC Build (ANOTHER!): D-Rob's Daddy's CR-X (Pics, included)
- Dimond like coatings (DLC) and Titanium Nitrate...
- hondata with itr boltons gains?
- Gotta be something wrong, Only 182 whp?
- B20/Vtec, which map to build off?
- All motor Rebuild..DECISIONS...need help..
- OMG this you have to look at!!!>>
- anybody doing this or heard of it o2 sensor for each cylinder
- b18/b20 crankshaft question
