- Ferrea Roller Camshaft ?s
- :fuel cutting off before red line??: please help
- Think I could get 170ishwhp out of this setup?
- H22 EG Cam Issues
- cams shafts and cam gears
- header question on a crx.
- Reputable Machine shop
- lightened flywheel messin with idle?
- instaling head studs
- Timing Belt Probs......fawk!!
- first day of the year at the track.
- Is Rocket motorsport a good place to get cams?
- Question about valvespring seat pressure.
- HELP: Skunk2 PRO 1 Camshafts Tuning
- IB (import builders) valvetrain
- any 85mm guys in here? any overheating problems??
- Can I have a bad valve but still good compression!??
- vtec hesitation
- bad dizzy ?? please help
- shortest stroke possible
- bc4
- nos
- gsr replacement parts
- need valve locks
- 4:2:1 or 4:1 header?
- valve train question -mixed cam caps with pics
- PROJECT UNDERDOG LS/VTEC WITH PICS
- ips cams
- LS dyno results B18B - could there be more left?
- is it possible to run aftermarket cams on stock valves and springs?
- Did a compression test: How are my numbers? Also do my spark plugs look okay?
- GSR, B16, H22 Rocker Arms - Same?
- more power with the b20.
- Valve Clearance/Lash Setting for JUN 3 Cams?
- Drive shaft problem, how to solve?
- ARP HEADSTUDS - MANUFACTURING DEFECT?????
- Ntrous Bottle heater help
- Project stock block ITR/B18C complete.....227whp
- Throttle bodies for Skunk2 IM (for GS-R)
- Action Flywheel?
- Who carries ITB parts?
- ls vtec setup
- PLEASE HELP - How much do you think this motor is worth?
- hesitating on Vtec
- assembling the rocker arms
- Blox type B / Buddy club spec 3 cams
- K20 vs B20 - 1/4 mile video!
- Cam Gears
- WTB built HEAD!!!
- Building LSvtec, what do you think about my setup
- should i get a ctr ecu?
- Slow 1/4 for semi built motor?
- killer power in 1st,2nd but third and on sucks
- head swap problem SOHC non-vtec
- Supertech 1mm valves and Buddy club V cams ???
- Please help me cofirm ITR cams year.
- DHracing head gasket, any one use one?
- Question about b16 w/ eagle stroker crank....
- cam degreeing ?
- Is this motor worth it?
- 95mm B series Worth It now that we have K's?
- thinner head gasket
- dh-racing any good?
- Compression test results? Little Low?
- idling issues with pro 1 cams
- Help what skunk2 cams are these
- LS VTEC PCT compression HELP!!!
- 91 Si B16 Problem
- ITR pistons on LS rods??
- E-10 Ethanol
- blox valve train?
- b16 86mm setup, advice please!!
- b16, going n/a 86mm
- Which clutch
- 85mm Head Gasket
- dyno time in GB thanks to mike @ TSR
- 200whp ls vtec on this setup?
- Cam Gear Suggestions?
- Opinions on a difficult third gear
- 87 civic needs HELP!!!!!!!!!!!!!!!
- DOES THIS LOOK LIKE A DARTON SLEEVED BLOCK?
- bearings...???
- replacing valve stem seals
- Question bout cams with this setup
- All motor improvements?
- Fuel Pump does not prime & no spark!!?!?!?
- code 14
- b16 ?
- need some cam info!!!
- Head porters look (56K iffy), think I was mislead here.
- Rod bolt torque spec for B17a
- Thoughts on my setup, and oil to break in motor
- ECU for LSVTEC...kinda...?? Help
- Some questions regarding cam choice (lsvtec)
- An-R Compact Version Header
- whats the valve train?
- How come crower cams are not in the most wanted list?
- Just Dynoed my B16 (Power Rev)
- after upgrades my track time decrease!!
- DIY head work - removing casting imperfections q.
- coolmax radiator?????
- jdm b18
- itr pistons on ls rods
- new alum. muffler
- different pistons and rods with a d15b7??
- Timing belt tensioner: coat hanger trick?
- Fixing an All Motor Mistake...
- cant get end caps off with arp bolts
- Buidling a gsr turbo
- Tuned @ hookups today...
- 1984 Honda Accord Question
- Fuel Pump and Injector questions??
- after hours of search i am still stuck on which cams to use.. HELP!!!
- All-motor LS non-VTEC: 152.4whp/128.8wtq with i/h/c/e and 403s
- RS machines port n polish -- do you guys recommend?
- The New Apexi AFC Neo = AFC + VAFC in ONE!
- How long do Honda engines usually last?
- Highest compression on 91 octane?
- EF9 clip- who can get these still?
- 2point6 version 1.2
- How to Break In My All Motor??
- Hondata Base MAP PLEASE!!!!!!!
- B20 VTEC QUESTION
- Built All motor OIL?
- Gutted Hondas
- All Motor slight power help
- Rebuild question, B18C1, probably in the wrong place :-P
- B16 w/ P72
- Akmee Valvetrain?
- For those using a VAFC on a 11.5ish comp. motor...MAP question...
- I NEED A ATI PULLY FOR B-MOTOR ASAP!!!!!
- skunk2 pro1 cams vs BC3+ camshaft
- any1 running BC3+ cams on gsr with a single runner mani??
- Port and Polish, where to go?
- skunk2 stage 3s + 1/2 mm oversize valves
- How to measure CAMSHAFTS
- ls/vtec build with pics!
- looking for complete JUN 3 cam specs?
- h22 crank problems
- Anyone use bolts instead of studs on their intake manifolds?
- ctr pistons in a b18b?
- Friend lost cam caps!
- how to break in new cams
- tuner shops?
- Which lube do you suggest?
- What brand clutch/flywheel are you using?
- Quality & reliability of Profab headers
- suggestions on how to up compression high enough to run stage2 cams wiht stock pistons
- B18c5 build - need reliable #'s
- Ethanol replacement of MTBE effects on our car...
- ecu for ls with bolt ons
- BKR7E-11?
- Piston Slap, Rod Knock, Water Pump?
- Quality flow vs. mass of air (throttle body size)
- Problem with my LS please help!!!!!
- b20vtec after wideband tunning. ignition 101 ;)
- Throttle body for a built 2.0L GSR
- How to know how much to shave off cyinder head
- ati dampner question????
- Victor X Intake Manifold
- built d16z6 vs. built z6 head with built a6 block
- Dilemma....spend the cash on ITBs or go with reworked stock mani/big tb/ and velocity stack
- need crower valve adjustment specs for H22
- b16 block b20 head
- SPUN BEARING..WTD?
- H22. Smokes and sounds like a wrx
- Many B16 Tranny Questions
- What tranny do i have?
- Aftermarket IM n TB question
- Which JDM cams are the best for high-end and highrevving?
- b20 rods vs. ls rods?
- Check out the Speed Network!!! Rage (Jason) is on right now!!!
- b16 sir2 in eg6
- what header you guys runnin
- b16a2 valve to piston clearance
- Extrude honed head vs port and polish
- gsr pistons in LS vtec? do i need to modify the b18b rods?
- b18c1 HEAD!!!
- ls with all bolt-ons
- Help on headgasket thickness
- HELP! b16a build up!
- OBD2 To OBD1 Oxigen sensor removal
- What rod bearings for jdm d15b vtec?
- will dohc head work on sohc ZC block?
- Power Secrets?...but a question.
- --~~ ALL MOTOR For Sale & WTB ~~--
- throttle cable
- Syntec or Regular motor oil
- How to raise my Compression ratio B18c/B16a2
- Gsr motor, with JDM ITR ecu comparrison
- grounding systems??
- B18A1 Upgrades??????
- gimme feedback on this setup!! and a few questions too
- My first honda motor rebuild
- Does anybody run a skunk2/aebs intake manifold with bc spec III+? (b16a)
- computer throwing CODE 5
- all motor ls dyno
- b16a head upgrades? gsr stuff
- Supertech valve springs/ installation
- ARP head bolts or stock bolts
- B18 with K20 barings?
- Best way to remove old IM gasket from manifold?
- red on sprak plugs..
- QUICK QUESTION ABOUT Portflow B-Series VTEC Inner Valve Springs
- crome
- Cam Lobe Wear...
- NEED HELP!!! NEW SKUNK2 STAGE 2 CAMS IN B16
- Evans tuned stock K20A2 swap... 230whp/158tq
- LS VTEC!!!!! SOON
- B18C1 Bolt-on choices.
- LS V-Tech Early stages
- <<NEW DISCOVERY!! 2 SEPERATE ECU PROGRAMS IN ONE ECU>>
- anybody using skunk pro2 cams?
- Hondata...where to plug the switch in the interface box?
- My NA nonVTEC build...
- gude d16y7 cam - anyone used it? dyno numbers?
- Eliminating FICV?
- dyno results, my b20vtec, twm itbs, vid, pics, graph 4/1
- JDM non-VTEC D15B carb cam: is it anything special vs a USDM DX cam?
- tranny question???
- Hondata diagram
- whats next on the list
- LS/VTEC set-up?*Searched* need answers asap
- help me pick a header for b16 w/bolt ons, Vibrant or DC Sports?
- **Best Camshaft's for My b18c**
- ITR valvsprings and retainers w/ Blox Type B's
- a question after cam install
- Boring a B16
- electrical: drag cars
- Stock B16A2 cam question
- which intake manifold is better for B16
- OEM valves: b16a2 vs b18c5
- ANYBODY who had purchase Blox Type B Camshaft !!!PROBLEM!!!
- ALL MOTOR TIRE SIZE
- Anyone use 84mm gasket on 86mm bore?
- cams 4 my b18c1 build
- buddy club spec3 cams.. good with what mani?
- ACL bearings
- Head Warped?
- Skunk2 cams ID?
- Crower dosnt recommend the use of synthetic oil in any racing application?
- Pre Build Questions
- Crank Pulley Removal - Special Tool?
- to cold or hot of plug for my car
- any difference between GSR and ITR rods?
- what pistons to use? (B18c1 block & B17 head)
- 2.0 LS/vtec or B20/vtec: both built to the bone.
- How much whp for my setup?
- Block Decked, Timing Question
- gsr crank in lsvtec??
