- who invented LS-VTEC??
- rocket ls cams
- Ideal cams for LS-V?
- Up Grading the R
- pistons need info
- 13:1 on pump gas?
- Non-VTEC B20 Nonsense
- install piston questions
- lsvtec build
- bc III w/ 2liter
- Throttlebody plate totally sealed when idleing?
- Mini-me timing issues
- VTec not working? Cel is off
- SOHC ALL MOTOR SETUP getting ready to time it..
- ARP BOLTS?
- Need help on setup ASAP---
- How high can i rev???
- Will this motor setup work?
- Blox or Skunk2 manifold?
- Some b20vtec questions
- Top Line pistons????
- Totally destroyed my Hasport mount in 2 months!!
- JDM B18C Motor - HPDE's ONLY
- how to clean injectors?
- Dyno trouble. and maybe a bit of a let down.
- Question LS/VTEC
- GSR hb or boosted single cam hb???
- 92 octane in the bay area
- results of broke cam and questions
- Track videos inside (265 whp all motor civic)
- Need tps pinout at tps not at ecu ASAP very urgent
- Finally started my GSR Build!!
- K 2ND POST WHAT TIMING BELT DO I USE!!!!????? need to know asap!!
- ARP Headstud Question--NEED HELP
- full-race Im
- Prelude/H22 owners, how high are you revving with Ti valve springs?
- Max Piston to wall clearance?
- Low compression Across the board
- header question
- horse power and torque estimates
- ITR 4-1 primary size
- Exhaust manifold bolt on B16a Head same as others?
- My set up 92 civic cx
- omini=taiwan
- D16A6 flywheel questions
- question on h22 header runner diameter and reversion chambers
- 11:1 to 11:7 compression worth it?
- """VID"""" crx
- Will a Type R radiator fit a 95 Integra GSR?
- <<wanna send out a big thanks to ARTIETUNED>>
- b16 a2
- Rebuilding my D15. Can someone answer some questions for mpg purposes?
- skunk 2 cams stage 3 for sale
- ease my worries! (cam install)
- Questions on my B series Built
- Found reason why I was smoking-
- pro1 cam users? advice on vtec point?
- Is it true...?
- Burnt or Bent valve make LOUD ticking noise
- Head porters South FL.
- Cold Dyno Air versus Hot Dyno Air
- what is the best motor to have in a 2nd gen crx ? (1988-1991)
- **** Dyno of my Mildly Built D16 old vs new, plus vs a B16 ******
- Ordering custom pistons- what info is required?
- head porting = 320+cfm...
- Good clutch? With Good engagement??
- need help with rings
- Would i make more power with a B16 head on my GSR?
- motor mount advice
- stroker kit
- Collector Size + Quick Header Qs on 190-200whp motor
- Is this motor tuned dangerously?
- puerto rican 9.7sec..307hp..u guess heard?
- 84mm sleeved block (b20vtec)?!?
- My H23 dyno
- CROME tuned from Uberdata tune
- 190+ HP on stock block lsvtec?
- My 200 WHP ITR
- Rebuild?
- toda b or jun III
- loud noise need help
- how to take out ac and cruise control?????
- switching up the tranny
- stage 1 to stage 2
- skunk 2 stage 2 cams untuned, good or bad idea?
- H22-H24 using F23 crank- are my calcs correct?
- Wrong head gasket? Smoking problems?
- ***How-To*** Install Valve Springs & Valve Stem Seals
- reliable track racer
- how to lower compression
- Knock Sensor-
- Vacuum line please help!!!!!!!!! :(
- Where to buy a TPS without the whole damn throttle body...
- Help BC 3 or BC 4????
- ITBs
- which cam for best results for my setup
- quick injector question
- Question about rebuilding head
- What stock cam is better
- highest compression on regular gas? (87 octane)
- HELP cleaning block
- octane with 14.5.1 compression
- new typer motor...doesn't feel all that stong
- tanabe
- ITB's for a B16b
- engine help
- Hone Cylinders?
- 6 point ARP rod bolt?????
- Does Toda Cam Have a letter on side?
- need help with gasket thickness for my build!
- where to buy hand reamer or reamer kit
- I got a weird noise in my head....
- ls/vtec piston choice?
- Buddy club spec 4 cams
- best ac compatible headers
- itbs on an itr?
- 34 MPG with CTR pistons & 91 octane
- h22a all motor need help!!
- engine management
- help! no gains from power mods
- b20vtec problems
- over revved my engine, now i think i have rod knock
- Bent valves?
- installed BC3 cams in GSR along with manifold and throttle body, very low idling?
- Hondata s300 rev limit problem
- Which pistons?
- Dyno on briancrower.com seem right?
- Used copy header
- What clutch/flywheel to get?
- difference between throttle bodies
- b18 Head, D16z6 block, cable tranny?
- What injectors for my setup
- Thar she blows
- VIDEO: All Motor LSVTEC coupe playing with a modded Evo IX
- OEM Oil Filter
- minor problem with ls-vtec instalation
- Cracked sleeve on a b20.. OPTIONS???
- gapping spark plugs
- valve spring question.
- need info on building a h22
- NEEDED ::::::::: GSR cams for my b16........... HOLLA !!!!!!!!!!!!!
- Question after dyno
- vtec not kicking in
- bent spark plug tubes
- ssr street sweeper info
- what compression for all motor b2ovtec?
- B20 vtec build question
- blew my motor.. time to rebuild but what crank??
- Best Cams/Header for road racing setup....
- What Clutch Should I Get??
- allmotor s2000 dyno#'s
- ls/vtec what pistons rings?
- Bought SomeCams need some help
- LSVTEC question.
- Victor X intake manifold???/
- another setback
- B16a2...
- AEBS polished Manifold $140 good price?
- which headers have a 3inch collecter
- 12:5:1 compression for daily driving
- SINGLE CAM BUILD!
- D16Y7 engine questions...
- Cam Corrosion?
- what should I do next?
- Evans NPG coolant?
- B18C Type R Pistons in a B16A will it work and what compression PLEASE HELP
- Cam Question?
- piston to connecting rod help
- B18c1 block with CTR pistons?
- h22 hatch
- Cam + Tune = Hp spike?????
- white smoke coming off the radiator
- B18c-R with a crower 2.1L stroker kit with 12.5:1 compression....
- opinions on my ls vtec build
- need help deciding
- Bored block to 85mm - what about the head?
- are AEM or FIDANZA cam gears any good
- Motor Build Time-???
- what timing belt to use on poormans
- 13mm cams?
- gsr build
- Tapping Valve Cover for Second Vent/Breather
- What kind of cams for all motor ls build?
- Dry sump and stock pump?
- question about valve springs
- D16 ITB's
- back from tuning
- D16 deckplate and sleeves
- Leakdown page in manual ?
- LS / VTec Turbo, is it possible???
- CTR Cams ??
- Any recent dyno/tuning with all the HEAT!
- Fluidyne Radiator ...trans coooler ??
- broken zex valve spring
- Good B16 Header for 200-800 Bucks
- high fuel pressure
- hp increase by type R cams
- vtec not working, need help fast..car is sold on saturday!
- Brian Crower cams
- Whats the easiest/cheapest way to get 20 extra hp into a 130hp b18a1
- d16a1
- My First Motor Build Ls/VtaK. In need of any info/help
- **************h22A vs. any b series motor (help)*********************
- rebuilding b17a1???
- another NOVA R(well kinda, but very NA) stolen
- portflow inner valve springs
- b18a1 vs b18a2
- What places in SOCAL can fix Dents on header???
- Poor Mans ITR Build
- Looking to hit 165+whp with my b16...what else is needed?
- Underground racing cams?
- opinion on custom pistons
- I need some expert opinions.....
- any one running a zex nitrous kit?
- engine build advice
- Brand New RMF Header breaking on the dyno!!!
- B-SERIES OR K-SERIES????
- Zex Camshafts
- how can i tell if a head is milled.. ??
- Broke JDM b16 tranny w/lsd what replacement parts? please help
- off topic....CHUCK NORRIS IS ALL MOTOR
- ctr cams on stock motor?
- My Ls/Vtec Build any suggestions welcome.
- type r head
- LS BUILD IN A EG6
- Best mods for B16 after header and intake????
- IAT wire colors
- itr cams into a b16
- need some help and some advice....
- 5000rpm break up?
- Milled head, High idle after sitting in traffic? Confused
- Help! For my DX Hatch!
- Is this quite a lot of timing? (pic)
- Turbonetics Velocity Stack
- Anyone here build a single cam F22??
- Which retainers with TODA Spec B cams and retainers
- motor placment?
- Zc Engine help
- Honda civic 93-98 questions that i have..plzzz
- ACT failure??
- torque
- crx smoking
- All Motor Build up NEED HELP
- whats a good header for my b18c?
- flame suit ready: power gains from head work?
- A/C Bracket for B-Series into ek.
- JDM SOHC ZC
- dynoed my non-vtec b20
- Good camshaft on a stock b16a2
