PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 [155] 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. SARD Arouse MIG muffler
  2. Question about using a 70mm tb on a lsvtec set up.
  3. steve at SGT
  4. DC sports 4-2-1 made bigger thoughts??
  5. this looks bad, can it be fixed?
  6. my car is pooping out at high rpm's...
  7. Can Someone Burn me a Basemap chip????
  8. WTB: Trashed K20 Head
  9. 00' civic exhaust
  10. Why My LS/VTEC is Slow?
  11. How to measure cylinder width/roundness?
  12. B16 head or B18c1 head? for all motor or boosted..
  13. I really need a dyno tune....I got beat by a hatch swap
  14. LS/VTECH WITH B17 HEAD or B17HEAD on GSR ??
  15. where can i get a ES OVAL ???
  16. Is Honda-Bond on cam caps required as per Helms?
  17. RSX Throttle Body HERE NOW
  18. ls/vtec
  19. B21A1 vs B20A
  20. motor break help
  21. Dyno results b18c-r with Blox Tuner B cams
  22. Header Collector Mod Question......
  23. H22 All Motor Build
  24. AEBS GSR IM PICS!
  25. spun a rod bearing.. ugh
  26. anyone have a pic of a prelude LMA??
  27. b20b vs. ls/vtec
  28. jdm itr motor....what cams?
  29. 91 Accord Ex Hesitation on less than 2000 rpm, fixed twice by cert mech, but still occurs
  30. Crower stage 2 Cam question. Searched. Need guidance.
  31. b20 engine block to cylinder head bolt help
  32. Anyone got feedback good or back about the tuning abilities of Jamie Mun from Speedline Motorsports?
  33. calibrating my ITB??
  34. Hondata S300 versus AEM EMS
  35. B18 4-1 and H22 4-2-1 Header Testing
  36. plug gap theory?
  37. Weber DCOE carbs...anyone familiar with them?
  38. Hondata New S300
  39. B16 Tranny Differences
  40. Help me diagnose problem VIDEO INSIDE!!!
  41. Good setup...B18C5 block...GSR head...
  42. Shot cylinder OEM rebuild
  43. Are buddy club 3+ good cams for my setup?
  44. which spark plugs to use in my setup??
  45. Anyone have info on D16z6 Blox cams?
  46. Friend's car got jacked!!!!!!thread link inside
  47. power please help!!
  48. z6 cam or y8 cam
  49. stock dizzy? what rpm
  50. Running wires for ls/vtec
  51. anyone dyno their B16 on a Mustang dyno?
  52. FLAT VALVES GAINS?
  53. Sound like my Timing's off? LS/VTEC DC
  54. question on rebuild
  55. Building a B18C5, need part recomendations OEM vs. aftermarket
  56. ERL MAIN GIRDLE VS. GE MAIN GIRDLE, GURU'S PLEASE HELP
  57. Ethanol where u can buy ethanol??
  58. how would i gain 250whp without turbo??
  59. help, confused
  60. Spark plugs for high CR built-up
  61. SMSP header received!
  62. I WANT TO RUN ITB'S ON MY B16, ANYONE HAVE ANY SUGGESTIONS ON WHAT SIZE TO USE.
  63. buddy club head gasket
  64. tech43 kit
  65. Machine Shop Over-bored my Cylinders...
  66. i need help ...missfire problem with no end
  67. opinions needed
  68. some new parts for the 300whp project, coming soon....
  69. Ported and polished HP Gains?
  70. suggestions for cam gear tuning?!?!?
  71. Should i dyno dont know
  72. help with vfac
  73. "NA is Best!" lovers....question about exhaust notes.
  74. any gains with p28> p2t
  75. Is there anywhere in So'Cal that does automotive performance coatings?
  76. buddyclub 3+ owners / spec sheet info needed
  77. Omni power or crower valvetrain components? I'm stuck.
  78. Dyno'ed the Sol finally....
  79. TWM ITB Sticking?
  80. zc milled head
  81. 82mm bore GSR possible?
  82. Noobie here, just want your opinions and suggestions on my b18c1 build
  83. Nitrous+LS= ???
  84. Supertech, rocket, or Omni?
  85. Too much compression for stock bore motor?
  86. My try at head porting...Professionals look here!
  87. ef b16a help?!
  88. stock b16a with walbro fuel pump?
  89. anyone have a pic of the aem v2 intake in a crx
  90. set up similar ??
  91. gave up with bc3+
  92. TO LIMITED SLIP or not to...b16a
  93. .050 spark gap on b16a?
  94. I want a new header which one?? exhaust?
  95. ngk r5671a should i get 7 or 8 heat range
  96. 12 sec
  97. Looking for a a Machine shop
  98. b18c5
  99. reliability of machined cranks
  100. B20 deck plate?
  101. Fuel pump problem...already searched PLZ help...
  102. NA build questions
  103. a good shop
  104. D15B1. How much can I mill off the head and still be safe?
  105. ABout which ITR Camshafts fit in an LS motor........
  106. high compression..?
  107. which IM is better for ITBs
  108. Neptune w/ Tony1: 184whp/133tq 13.89 @ 100mph
  109. stroker build dyno part 1
  110. NA build, restrictive exhaust questions?
  111. Connecting rod/bearing cap mark...
  112. ls block
  113. WTS B18c compleat swap straight from japan
  114. taking off air filter and running open throttle body?
  115. Intake Valve snapped from stem, need opinions
  116. Engine honing...what lube to use on the cylinder walls?
  117. D16Y8 Buildup
  118. Cracked my B20, do these pistons look salvagable? *lots of pics*
  119. Installed cams and Eh
  120. Have some ? about crome
  121. IAB ecu question
  122. B16 Coolant Hoses, Can I get a picture?
  123. Question on Engine Building(regarding the Bottom end buildup)?
  124. b16b w/ itr crank and rods stock IM, TB, jdm itr header, j's intake.... which cams?
  125. question about dyno tuning and o2 sensor
  126. Stuck/Seized Injector
  127. my pizza delivery hog
  128. Are these Skunk2 Stage 2 Cams?
  129. slicks
  130. port and polish
  131. Weird Sound tonight out of my engine? help me diagnose
  132. Rocket Spark plugs, whats the gap?
  133. sea foam
  134. b20 in ls how much faster will it be?
  135. Needing a good cold air intake kit
  136. Any hp/tq differences between stock pistons and .025" overbore?
  137. stupid question, what do you guys mean by shot peened rods?
  138. PLEASE HELP CHOOSING RIGHT HEAD FOR SETUP
  139. 300WHP All motor?
  140. More Plastigaging Problems
  141. lsvtec problem
  142. cel 3
  143. Valve Clearances for Crower Stage 2's cams
  144. DIZZY QUESTION
  145. B20A help
  146. Anyone running an NA project with ATS FD and no LSD?
  147. Crane stg 2 cams and valvetrain
  148. ITR springs and retainers...need help
  149. the air intake filter test link
  150. cast v/s billet cam shaft covers/plates...any benefit to either??
  151. best bang for my buck
  152. H22 Type s "Kit"
  153. bad timing...now engine is LOUDER
  154. good clutch????
  155. Horsepower of a stock 1991 accord
  156. Milled B16 Head + B20 Block Clearance Problems?
  157. anyone use itr ecu for b20vtec?
  158. any tuners in baltimore area??
  159. Old School ANR Street header vs.DC 4-1 JDM Replica
  160. p72 ecu with hondata?
  161. VAFC question
  162. looking for itr p73 ecu specs
  163. Dyno Sheet - My Old Motor (Comp 4)
  164. experiences with COSWORTH PERFORMANCE MACHINE SERVICE??
  165. fuel psi for this setup?
  166. Anyone running side-drafts have dyno numbers?
  167. b17 internals..into LS block...for lsvtec good or no
  168. LS block spun bearing yah or nah with my b16 head for my ls/vtec???
  169. Zeitronix Wideband????
  170. does having a bad o2 sensor affect performance?
  171. After 8 Months Of build....My LS-Vtec build (56k....umm sorry?)
  172. adapter plates
  173. .40 oversized = to 81.5mm ????
  174. Header wrap or High Temp Paint?
  175. B20vtec max RPM?
  176. b16a max bore
  177. valve adjustment
  178. revving to 9k without a girdle?
  179. IS LEADED RACE FUEL (C12) OK TO USE
  180. F22C (90.7mm) crank snout modification for K-series
  181. VAFC stuck at 760mmhg?
  182. top gear on discovery channel!!
  183. K twizzle, MoTeC, iVtec, Vtec power
  184. LS/Vtec rebuild??'s
  185. Vtec point...
  186. my dyno day at HOOKUPS
  187. K-series: Castillo's 105mm crankshaft
  188. LS/V-TEC BULID HORESE POWER NUMBERS
  189. What is this hole for?
  190. b16 tranny over gsr tranny
  191. Canadian Engine Stores???
  192. ugr camgears.
  193. I receive my RMF header today
  194. Stock GSR Head/Cams, Stock B20z block - Do I need to open up valve reliefs?
  195. Need Engine build help! (Destroking)
  196. How good is the Si hatch K motor?
  197. help
  198. Ls/vtec questions
  199. Fully Built K24A block by ERL Performance : A different approach
  200. Need to get tuned, advice
  201. Rocket Motorsports = Junk? You Decide
  202. News From SKunk2
  203. Skunk2 Pro 1+ Cams does anyone have these cams ???????
  204. Cam Key Direction???!
  205. b20 blocks-91 prelude
  206. Triggering MSD 6AL off ECU?
  207. Electric vacuum pumps?
  208. header experts only - toda b16b header on b18c?
  209. itb in alaska
  210. Best 4.785 Tranny combination setup
  211. Car in shop, what times do expect
  212. post you b20/vtec and ls/vtec dynos HERE!!!
  213. ls/vtec reliablilty
  214. b20 vtec needs a rebuild... what pistons? can I find some stock that will work?
  215. Cam gear question
  216. 87mm pistons in h22a....
  217. Need some advice on my B18c1 rebuild
  218. need little help with tuning stage 2 skunk cams
  219. does anyone know of a stroker kit for a D16
  220. ls/vtec build
  221. This set-up..any thoughts or opinions?
  222. quick question for gsr girdle in ls block
  223. I need a New Map for S100
  224. testing waters w/ 2.0
  225. Build cost
  226. Fuel pressure w/ skunk stage 2's???
  227. Factory settings for S-AFC2
  228. Quick Question about LS/Vtec
  229. gsr valvesprings fit on LS ?????
  230. Header on LS/VTEC. Feels slower, possible?
  231. Stone Headgaskets, Anyone use them?
  232. any info on the new pro series skunk 2 cam
  233. car cuts out at high rpm
  234. Skunk2 cyl. head components (new stuff???!?!!) 256hp/181tq
  235. h22 civic questions
  236. Help! Question about Fuel Injectors.
  237. Suggestions on motor biuld
  238. Clayed Motor, kinda...
  239. untuned 180whp b18c1 dyno inside
  240. P8R B-series head! "What is that?" Well look in here and I will show you!
  241. which plugs are these??
  242. trade off, tq for hp????
  243. Can it be done
  244. wiring harness
  245. universal world sport2 muffler
  246. My square port head
  247. blox spec a??
  248. help wit individual throttle bodies
  249. type r pistons in ls
  250. Toda Header
