PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 [156] 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. new SMSP D16y8 header
  2. p8r valvetrain question
  3. B18C1, ITR Cams.. Springs/Retainers ?
  4. 12-14 comp on pump gas?
  5. what would you choose as the shift point for this motor, and why?
  6. opinons on my n/a b18b build up......
  7. all motor b16 build
  8. Dynoed my new set up B16a3 CTR slugs ITR Cams tuned w/hondata
  9. Stroked LS/vTEC help Please.
  10. b17 block...pistons??
  11. The NEW B series shoot out
  12. B18b Question
  13. HYTECH SIDE EXIT DRAG HEADER OR SIMILAR, WHO"S RUNNING ONE?
  14. Intake Manifold is Port Matched - Smooth or Rough Finish?
  15. Skunk Stage 2 Cam Install HELP
  16. how can you tell aftermarket valve springs
  17. Who going to Summer Slam ?
  18. make vtec open at 4000 rpm
  19. ITR valve springs sufficient?
  20. Question for tuners regarding check engine light
  21. anyone know any websites where i can buy a complete k-series from?
  22. itr cams in b20vtec
  23. EGT gauge?
  24. ? about ls rods & crank into gsr block
  25. what stage cams?
  26. Heavy Flywheel vs Lightened Flywheel
  27. Im so torn between these two swaps....
  28. building a daily driver for school
  29. h22 or b18c1
  30. Noob Question about Cam Lift/Duration
  31. *********please help me, i have a problem*********
  32. -DYNO TUNED my B18C JDM GSR-
  33. ls/vtec dyno finally
  34. Boring out a B18C1
  35. crank pulley question....(already searched)
  36. Whose got a good b16a recipe??????
  37. shooting for 200-225whp w/ this setup, possible or am i crazy?
  38. Swapping Stock Cams
  39. allmotor gurus help
  40. Kpro tuning issue, final step, 50 degree high speed cam angle........help
  41. b16 build up
  42. A22
  43. can i do a b16 swap in my 2002
  44. b18 build with ls crank rods?
  45. ECU question
  46. Compression Ratio Tips!
  47. best cams for a b18b1
  48. 02 CRV help - won't shift out of park
  49. TAPING HEAD FOR LS VTEC
  50. rod numbers
  51. 12:5 compression. Skunk Stage 2 or 3 cams?
  52. can u switch water hoses?
  53. Compression loss from port and polish?
  54. sk2 stage 2 cams
  55. Rods in an H
  56. real dyno number's
  57. Running rich cause you to burn oil?
  58. Tuned the car last night!
  59. b16 mild build
  60. OBD-0 O2 sensors?
  61. does a bigger valve leash make more noise?
  62. Socal people i need your help
  63. Scammed
  64. HOW HIGH CAN I REV MY STOCK LS RODS
  65. catalytiv converter question
  66. your thoughts on my compression
  67. Dyno tune my car yesterday
  68. Adjusting valves LS-Vtec built HELP PLZ (already searched)
  69. lsvtec bored or b16 bored and stroked?
  70. I need a few questions answered!
  71. Breaking in Pro Series Engine 14:+ compression
  72. Compression specs for D series motors?
  73. Odyssey Transaxle fill plug?
  74. 89mmx85mm 12.0 cr itb's 248whp 171 tq..(not mine)Evans Tunned
  75. Tsudo header???
  76. MOLLY rings in a h22?
  77. All motor solutions to GSR
  78. B20 Prelude Crank
  79. injectors recommed???
  80. Bought a r-head did i pay too much
  81. Installing piston rings onto piston...
  82. Problems w/ Alaniz?
  83. jdm b20b spun rod bearing = burnt rod, crank cap and crank???
  84. Spoon Computer on a stock b16a
  85. Need a little help with tuning cams with vafc!!!
  86. B16A 2 is it worth going N/A?
  87. Free Gas for One Year!
  88. Free Garmin eTrex or Magellan GPS!
  89. fuel pressure...????
  90. what size injectors to use?
  91. B18C5 Troubles... hesitation?
  92. b16 intake manifold
  93. Intake Manifold Theory
  94. Anyone use a Snap On leak down tester??
  95. Just got my head back from the machine shop
  96. Allmotor K20 question/trouble shooting????wiring related
  97. Clutch Grease?
  98. Where to mount wide band o2 sensor for Innovate LM-1
  99. 84.5MM W/VTC HEAD
  100. LS valve to piston clearance specs
  101. Ls Vtec cam cap problem help...
  102. tuning?
  103. Wideband location ? for SOHC
  104. Just got a B18C put in my EG Please Help...
  105. building motor need help.
  106. building a b20 vtec motor
  107. Are Gsr cams safe for a allmotor setup?
  108. Need cams
  109. Legendary Motors... DEBATE...
  110. ACL Main Bearings - Please Read
  111. D17??
  112. 96 hatch civic swap
  113. swap on my D16Y8
  114. B18C5 vs K20A3
  115. gsr 2.0 vs. lsvtec 2.0
  116. question with vafc!!!!????
  117. toda killer cam timming specs
  118. ::PLEASE HELP:: - Installed vtec controller.. Car won't hit vtec now..
  119. euro r cams and vavle springs & retainers
  120. Losing A lot of horespower when vtec engages.
  121. got a P8R head!
  122. What cams will make the most power and is safe to run on only portflow inner springs?
  123. Does Spraks have a web site?
  124. computer chipping check list
  125. Comp Cams stage 1
  126. help, did a compression test are these nubers right?
  127. gsr tranny Q' please help
  128. bolt-ons
  129. oil spots in IM
  130. fully built itb,crx,b20vtec looking for old post!
  131. Just got my car back spoon del sol
  132. itb's on d16
  133. Is any tuning necessary for my setup?
  134. Need Cam advice.
  135. b16b in ef 4dr
  136. Who has a Skunk2 IM on a b18 or b20?
  137. problem with my h22 in eg
  138. GSR blcok markings
  139. Only saw 7500 on redline!!!
  140. Circuitworx / Prodrive final drive
  141. need serious help with motor
  142. need to smog check. passed last time. you guys think i can do it again?
  143. torqing a cam gear to a camshaft
  144. Long Block vs Short block
  145. Prelude LMA's
  146. My NA SOHC build
  147. AEM EMS Help.
  148. What crank is this?
  149. water hose help....
  150. TEST PIPE?
  151. Anyone running AIR/endyne manifold on a mild setup?
  152. what pistonsfor ls/vtec
  153. Checking your timing?
  154. compression tested, does #'s look good.
  155. Dynojet 248C - Drum Wieght
  156. Running on 90 Octane
  157. Wiring RC 440cc saturated injectors obd1 into obd2 lude harness?? Please help
  158. Re-honing Cylinder walls?
  159. Johnathan Chea
  160. Difficult LS vtec question
  161. Power Coil and Spark plug wires
  162. Revmaster connecting rods...any one using these
  163. Can my b16 run with obd2 SOHC ecu?
  164. Oil pressure question on b16a
  165. B16A2 Misfiring in VTEC b/t 7-8000rpms
  166. vtec kicks in but bogs my car down... what could it be?
  167. Rattle
  168. Sparks Gap ?? (need help)
  169. Smoke, No Vtec, Low oil, and Coolant on the dip stick!!!!!!!!!!!!!!!
  170. itr valve train
  171. d16y8 Cam install question
  172. What to look for?
  173. Help with cams identification...
  174. AF tuning for b16a
  175. Way to tell for sure, S2 stage 3 cams
  176. stage 2 skunk 2 cam problem!?!?!?!?
  177. IM Sensors on GSR Head same as LS Head?
  178. B18B timing belt lose? how to fix?
  179. B16 to 1.8l StrockerKits good idea?
  180. how much octane??
  181. gsr/itr pistons?
  182. DIY Porting: To Gasket match or not?
  183. Which Rocket Motorsports valvetrain to use
  184. B20Vtec knocking problem! Please help!
  185. RS*R Header
  186. how many mm's is a stock gsr head gasket
  187. itbs= dirty runners?
  188. pm3-13 a single cam vtec head ?
  189. Official HT Crome Rom Log.
  190. where did this head come from?
  191. Injector leaking on AEBS Manifold??
  192. All motor H22 compression ratio
  193. fuel issues
  194. Ebay's JDM Pitstop Header. Any Good? Dyno anyone?
  195. What size T.B for my set-up?
  196. bc3+ users- is your keyway too big?
  197. ???noobie k motor question???
  198. Is this B-engine bottom end setup possible?
  199. B16 or GSR head?
  200. little smoke at idle
  201. High Compression on stock cams? losing top end in my setup
  202. how much whp can i get w/ this setup ?
  203. VTEC CHOKING....HELP
  204. Selecting Rod Bearings, need some advice!
  205. if you have a choice which one would pick and why?
  206. first timer (motor build)
  207. I BLEW UP MY MOTOR W/pics tell me how bad it is lol(pics are big sorry)
  208. Poor compression, and poor leakdown in cyl #4! Could it be just the head?
  209. new cams and valves, now fuel injectors??
  210. what i need to run 13.7s
  211. Please help me
  212. somebody tell me about dyno tuning at prostreetimport
  213. Ls Vtec Question
  214. all-motor ls timeslips
  215. anybody using ERL 5-bolt main girdle with dart block?
  216. Possible Head Gasket Leak... Need Advice Please
  217. Back from the Dead? Whatever happened to Omniman's 200whp B16 Video?
  218. tryin to spread the word
  219. Need Help With New Setup Please!!!!!
  220. question about head porting...
  221. anyone done a f20c in a hatch?
  222. Pick My Parts
  223. What piston specifications...???
  224. Help!!!!
  225. Apexi vafc vs safc
  226. what kind of numbers are you guys putting out with built sohc?
  227. 1988 crx b16 or b18b?
  228. Thrown a rocker?
  229. Sparks Stainless header vs my Hytech-dyno inside.
  230. Put some all motor whoop on a new STI!
  231. buddy 4 cams or m24x
  232. who runs stock fuel pumps and high hp?
  233. Video Of my B16B EK
  234. What's up with my rocker arms?
  235. obx intake manifold????????????????
  236. ebay headers?
  237. Best pistons and rods for the price!
  238. Miracle escape for rally driver!!(Vid)
  239. B18B cams and valve springs
  240. injectors for all motor?
  241. Can you tell the difference in these headers?
  242. help with pistons for lsvtec
  243. All 2.0L daily driven guys out there.... What kind of times are you running?
  244. Need HELP on my B16a!!!
  245. final drive for b-series cable from meccanic shop north?
  246. need help w/ vafc2
  247. B18C5
  248. New all motor engine "built" pics. Rlz/Tbone/Smsp.
  249. ls-vtec timing
  250. Dynoed the LS today, disspointing #'s
