PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 [135] 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. b18 crank in b16?
  2. K Series CRX Dyno
  3. cam gears
  4. CRVtec build Q's
  5. Need some Input
  6. AEM pully kit
  7. Can you accomplish 250whp out of a B18B?
  8. cheap a$$ no money junkyard build up
  9. B16A2 Head Port and Polish
  10. k20/24 ecu question
  11. Ideal compression for b16 to put me on the 200whp?
  12. first few mods
  13. where to buy JDM h22a internals?
  14. What should I waste my money on.. PnP or hytech header?
  15. Spoon engine..
  16. anybdoy have a ecu for a b16?
  17. Looking for an exhaust....
  18. Change of plans... going all buddy club
  19. ls vtec headers
  20. CTR pistons GSR block what ECU?
  21. B16b with skunk2 pro 1 cams. what vtec changeover point?
  22. k20 N/A ????
  23. stroker kit ?s
  24. PCV
  25. anyone here know what's M22xx's life and duration?
  26. 81mm bore
  27. Just did compression test on Built B16. Results Good or Bad?
  28. K20 type R swap.... Q?....
  29. LS-VTEC BUILD
  30. changing springs & retainers......rocker arms IN????
  31. Heklp me pick the right cam for my build up...PLEASE!
  32. 95 dx hatch w/gsr w/blox manifold which intake!!!!
  33. B20 bottom end buildup and ARP mainstuds
  34. b-16 engine dyno!!!
  35. h22 injectors on gsr/ TUNE
  36. Dyno'd My GSR... not sure if I'm happy with it
  37. advise on cams
  38. fuel pressure regulators
  39. compression question...
  40. BETTER WIDEBAND???
  41. what year b20 is better for power
  42. H23A1 gasket leak..
  43. Any of your all motor guys have a better way of selling all motor parts?
  44. usdm itr vs. jdm itr headers?
  45. Ls/vtec Rev limit?
  46. rim's and Shrt. Block
  47. SKUNK 2 PRO CAM SPECS???
  48. h22a
  49. Harness bar for EF?
  50. H22 valve springs in b16?
  51. Strange bog/hesitation problem
  52. skunk2 set up
  53. Pulsating Idle Map Sensor?
  54. My Dyno Results: 2000 Honda Civic Automatic
  55. Buddy Club III+ or Buddy Club IV??
  56. motor building price questions...
  57. ported b16 vs. aebs manifold?
  58. Got tuned!!
  59. Hello/Tips
  60. Best headers for high compression 2.0 w/ itbs and maybe direct port?
  61. should i dyno tune this setup or not?
  62. Running to cool....
  63. does anyone have a built k20a3 engine?
  64. xs power camshafts
  65. Cam Identification
  66. look at what happen today!!!!
  67. rpm service throttle body problem...
  68. Quick question. Highest afr you want to see n/a?
  69. 82 mm pistons
  70. Rage header H22 anyone making good power?
  71. Rebuilding my h22a1 ?'s about horsepower gain
  72. intake question
  73. is the gsr distributer the same as the d16 (93 si)
  74. Underground racing cams
  75. question for you NA pros. [noob] [flamesuit on]
  76. Bisimoto/AN-R Header and STS?
  77. High flow cat....how much power lost??
  78. How much power on 402's on your GSR's/b16?
  79. B18C HeadSTuds on B16 head
  80. B16a2 Project on Hold, Lets hear your Opinions
  81. Nissan Head's Flow good !!!
  82. NITROUS OXIDE, whats safe.?????help
  83. help fuel delivery
  84. TWM ITB fuel lines
  85. Dear All Motor Regulars...
  86. Toda Vtec Killer Camshafts
  87. My plans for my B16
  88. help on rebuild tranny...
  89. b17 cams in b16a
  90. all motor b16 setup
  91. b18c in a eg hatch 1/4 times?
  92. does this sound like a good deal???
  93. Type R blown to million pieces
  94. Blown Stroker Motor!
  95. spark racing header
  96. ALL DONE....Big Block K series EG.....
  97. who's hatchback is this?
  98. Opinions on this
  99. NEED ADVICE on Ring in 99' Prelude
  100. show off your CUSTOM INTAKE SET UP!!!!
  101. fluctuating idle then dies ...problem when warm!!! HELP PLEASE!!!!
  102. wiered intake noise ?
  103. Blox Hsl On a b18c1/b16a2
  104. anyone done this b4?
  105. Project officially under way....
  106. $500 header???
  107. b20 vtec, SPECIFIC QUESTIONS...
  108. Header Choice? ProFab or JDM ITR
  109. wireing question?
  110. all motor non vtec buildup
  111. My cars engine........
  112. N/A Nissan Head work pics inside *56k NO WAY!!!*
  113. Bigger then 3" intake pipe??? anyone try this??
  114. Exhaust Thread
  115. 4.9 in jdm s1?
  116. will it be safe to use this pistons on this engine ?
  117. h22a prelude WONT START :( help asap!
  118. Fule injector help.......
  119. any cams for b18b1 ls on stock valvetrain?
  120. 94-00 inetgra axles vs 96-00 civic axles....r they the same??
  121. Does anyone know..?
  122. B16a2 help!? (mods)
  123. F23 Crank
  124. my NA build up.......
  125. Need Tuning!!!!
  126. has anyone heard things bout the PRO 1 header?
  127. Euro R Dyno... mite!
  128. Knocking noise. Puzzled.
  129. Fuel psi for my SI
  130. what are the consequences
  131. b18c with aem ems leaning out at 8k--suggestions please!
  132. max rpm on ITR valvetrain
  133. anyone got info on tranny conv. hydro to cable help me out
  134. tool for honing aluminum
  135. Angle milling Intake Manifold...?
  136. Where can I locate this?
  137. Finally Tuned! jdm gsr w/ bc3+ by Hookups on Crome
  138. gsr cams in b16
  139. Aem 3 inch intake
  140. Possible idea problems?
  141. help me choose a piston. pr3 or a p73?
  142. what header is this - saw FS here - please check out
  143. Any good aftermarket immediate/mid shaft for B-series engine???...
  144. DIY-ITBS
  145. Quick trans fluid?
  146. cable or hydro tranny....???
  147. Just how much HP can a tock driveshaft handle....anyone??
  148. Which of these two cams for my needs?
  149. B20 Botton Blocm or LS Bottom Block???
  150. What You Guys Think??
  151. Broke mr rs machine intake cam today. is this fixable??? help!!!!
  152. Quick nub question!!!
  153. RS-Machine Cams?
  154. tried searching
  155. GSR Block, ITR Pistons??
  156. cam gears
  157. B20 stroker kit?
  158. Quoted $1300 for valve job. Get a new head instead?
  159. b16 block
  160. Help me tune my EP3R
  161. ATS final drive?
  162. I don't have a k20 I have 20 k's
  163. Skunk2 Stage 2 compression
  164. help:zc engine code
  165. What do u think of this intake idea?
  166. Eagle rods w/ Big Bolt Or Small Bolt??
  167. Any 12sec integras here?
  168. port and polish head question
  169. Just want to get your opinions
  170. 250 whp on stock block without VTEC
  171. 00 civic si stock fuel injector cc'
  172. problem starting stock 93 civic si
  173. Ls-vtec vs Built Ls on Spray
  174. jdm f20b piston?
  175. old school safc installation
  176. Valve springs for 512" valve lift ?
  177. ls/vtec spun a rod baring, rebuild or do b20vtec? how much hp to look for?
  178. individual tb's
  179. methanol injection
  180. B-series head with 250CFM exhaust flow.
  181. max rpm on gsr crank
  182. im and tb boring ques.
  183. best tranny wit b20 vtec
  184. how much should i mill head?
  185. Gsr with itr
  186. found filter that fits rs akimoto velocity stack!!
  187. LSVTEC bottom end HELP!
  188. Stock computer-Most N/A power
  189. Changing timing to 18 degrees?
  190. Question about boring sleeves for NA project
  191. Help me build a b16
  192. whats the next step to take?
  193. CRV-B20/VTEC info
  194. All motor build?
  195. Cams for my new b18c1/b16 build, what would you recommend?
  196. Im a total looser, what should i get?!
  197. is sleeving really needed?
  198. Need help! to identify some cams
  199. Tranny go BOOM!
  200. 310 cc injectors for 11.8:1 LSvtec?
  201. New header test fit on Rodrez's beast no 56k !!!!!!!!!
  202. all motor set up
  203. level of octane and compression affect knock?
  204. Couple Questions after my swap
  205. The BigGest QueStioN_PleaSe HeLp
  206. which cams
  207. d16y7 and d15 vtec (jdm engine) whats best combination for more power?
  208. Can an ECU just....go bad?
  209. this is what happens when u dont run a toda belt with toda cams
  210. dyno vid
  211. BC% cams??...anyone using???....pros and cons???
  212. b16 putting down low numbers
  213. Starting project, looking for opinions....
  214. Anybody break 200whp without standalone, piggyback?
  215. how to rebuilt a b series short block....step by step guilde...
  216. what oil are you guys using?
  217. crvtec question
  218. AutoCom clutch
  219. Type R Clutch with ACT Stage 2 PP?
  220. Help Intentify these cams.....
  221. LS/VTEC setup
  222. Inline 4 P&P
  223. Flowbench testing in so cal for d series heads?
  224. Real Quick question..b16 pistons in a gsr make what CR?
  225. Toda Springs with other retainers?
  226. k20 supercharge
  227. GSR b18c1 build time: help/opinions?
  228. X-1R Engine Oil Treatment in my jdm itr
  229. h23 vtec compression and deck height?
  230. catch can question
  231. How do you identify ctr cams???
  232. ls/vtec setup?
  233. degreeing skunk2 stage1's in stock b18c....
  234. Ported Intake Manifold Cleaning Out (Please Read)
  235. Best Motor for a Newbie to Build
  236. ls camshafts?
  237. 3000 HP All MOTOR set-up (not 4 cylnder, not rotary)
  238. my b18c5
  239. all motor ignition upgrade...
  240. 82mm bore on stock sleeves safe?
  241. ***SOHC DIY ITB QUESTION***
  242. HELP ME CHOOSE THE RIGHT CAM!!!!
  243. Help????
  244. Got my b18 Tuned 188whp 136wtq
  245. B18 block durablity
  246. 240 whp LSV build on Pump Gas Possible?
  247. 200 whp possible with my setup??
  248. i just got cams
  249. b16 cam?
  250. A couple questions about a stroker setup...
