PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 [123] 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. car not starting? iacv?
  2. LS/VTEC water neck question PICS
  3. timing belt and BC4's
  4. Anybosy Using Hondata S300 or S300J for their Motors?
  5. Need help upgrading 2006 Accord LX V6, want more power!!
  6. SRS exhaust systems. Any opinions?
  7. quick questions about B16a Blocks
  8. B16A CAM GEAR QUESTION~!!!! PLZ HELP
  9. Hole in Intake, does it hurt or doesnt matter?? *pic*
  10. SRS exhaust manifold
  11. Rocker arm ratios for B/H/K?
  12. Acura B18 engine
  13. HELP! Are my compression Numbers Good?
  14. how was your first time?
  15. Oil pressure\oil temp, run off T at stock oil pressure location?
  16. WAT CAMS??
  17. HELP with N/A power
  18. Exhaust question
  19. gsr and b16
  20. Aftermarket 2layer headgasket?
  21. timing questions for high comp.
  22. buddy club spec III or Blox type A cams?
  23. forum for information about non vtec (b18b1) engine .
  24. what size exhaust?
  25. injectors "how big should i go"
  26. Crome partial throttle
  27. who makes the best headers
  28. rs b20 pistons/head gasket question
  29. Code 20, ELD, need help fast!!!
  30. TAIL LIGHTS WANTED
  31. 2.0 b20v setup cam suggestions?
  32. Please tell me what you guys think...
  33. opinions on header choice.
  34. Tbone Built 2.0 RLZ,SMSP,Skunk Pro-1,pump gas,238whp 158tq Mini-Crx
  35. wut head should i put on my B20???
  36. Best header/IM/TB combo for 2.0 liter
  37. how is jdm shit
  38. who makes pistons to use ls crank, rods in b16 block?
  39. M22 cams
  40. M22 cams VS buddy club spec IV cams
  41. Aebs im .. what CAI?
  42. best header
  43. 84.5mm GSR Dyno Graph from Intec Racing
  44. Looking to buy b-16 with tranny.
  45. ls/vtec
  46. Inlinepro Comp4 hatch runs 11.01@122 at Nopi
  47. Excess heat???
  48. h22 into eg, having some issues need help asap dailydriver
  49. B16 Jumps from 2200-2700
  50. cam gears...
  51. orange c4 hatch @ mir yesterday
  52. Tbone built 1.8 oem piston 214WHP,RMF Header,Rocket ported,Skunk pro-1 cammed
  53. Who has Buddy Club Spec IV's ?
  54. question about RMF header..
  55. Which Crank pulley would you choose??
  56. quick question about p30
  57. b16a2 swap, half of del sol cluster not working
  58. Intake Manifold question
  59. rmf hearers info needed
  60. Where to buy Headers
  61. What sort of parts are involved in a engine overhaul?
  62. B16A1 swap into 96 Civic HB - Confirmation questions before buying
  63. intkae maniofold
  64. Headers for B16 with GSR head on 96 EK
  65. Cams and Piston questions
  66. b18b
  67. ls/vtec
  68. HONDATA or VAFC2/3
  69. Skunk2 Pro 1 cam specs needed. (no cam card)
  70. DC 4-1 ceramic finish question
  71. need help with engine build
  72. Anyone know of a good Dyno Tuning Shop in the Philadelphia area?
  73. First test-BP Stack vs Prototype Stack. Mild H22.
  74. Recommended Fuel Company
  75. cam identification
  76. Will the clearance be ok? and question about bearings
  77. 95 GSR BLOCK WITH TYPE R HEAD w/ itr pistons????
  78. b18b block, ctr pistons, gsr head. DONT DO IT
  79. whats a good cam to go with a 12.5 - 13.1cr
  80. TODA Hi-Comp Pistons - Piston-to-Wall Clearance
  81. cam question..
  82. After ls/vtec swap in crx, idle, power delivery issues. What do you think.
  83. I need some help! Is this head finish!?
  84. exhaust...
  85. replacing the intake manifold and throttle body any other replacements I should do?
  86. PORTED GSR stock manifold VS skunk2 manifold
  87. lsvtec questions
  88. Brand NIPPON GOOD OR BAD
  89. how does this sound guys??? B18c1
  90. where to buy ericks racing throttle body from?
  91. Tuners in Canada??
  92. Help with choosing piston size???
  93. h22, b18c1 or b18c5
  94. skunk2 stage1's or stage 2's on a GSR!
  95. HEaders.....
  96. Stock injectors for my all-motor set-up?
  97. 1 dead cylinder....PLEASE NEED HELP ASAP...Tuner's coming on Monday
  98. ITR intake manifold question.
  99. fully built h22a histates when i shift !!??
  100. for the price which one would you get? fuel rails
  101. How much to mill a b16 head with ITR cams
  102. good tuner in nw florida, south georgia, south alabama?
  103. ??rod LENGTH ???
  104. SKUNK 2 THROTTLE BODY FAILURE!!!!!!PIXX PIXX
  105. Oil Seal, not sealing? non-vtec build
  106. i need some help here
  107. Q: Chip Burning?
  108. Burns Stainless featured in Race Engine Technology Magazine
  109. should i swap in a b18b or b16
  110. What problems (if any) will I run into with this setup?
  111. B18c1 All motor build questions
  112. what rev can stock LS bottom handle
  113. sorry for all the stupid ?'s but should I change my LMAs?
  114. are these number correct?
  115. K20 pistons in b20 block
  116. TECHS: IS THERE A DIFFERENCE (B18C)?
  117. PR3-3????????
  118. b18c1 with 87000 miles.. is it worth buying???
  119. Stock valves or oversized?
  120. B16 valves, OEM replacement.. OBX?
  121. m22x cams with this valvetrain..............
  122. New Toys!
  123. jdm b16 cable trans lsd in a hydro tranny
  124. best cams that can run on stock/ITR valvetrain?
  125. what 2.5 exhaust
  126. where can i find dyno graphs of skunk2 manifold?
  127. ive searched and searched, all i come up with is Toda sucks!!! cam choice?
  128. Anyone have a Stock b16 dyno graph?
  129. I have the 1st Gen. Skunk2 Intake Manifold.but how much?
  130. Which intake for my setup? just checking around
  131. Best Cams @ C/R 11.0 & 12.5 - Jun TODA Buddy Club
  132. Are the Venom type intake manifolds worth getting?
  133. What should I expect to pay for a bottom end refresh?
  134. Dynoed my Pro1's today
  135. zc head fit on a d15
  136. walboro 255
  137. Fresh Motor, blowing smoke whats up?
  138. j's racing air filter
  139. Power FC users running ITB's
  140. Valve stem seals - replace or reuse?
  141. All New R-Crew K-swap race header
  142. help adjusting cam gears
  143. Any B-Series valvetrain is compatible right?
  144. OT: I have brand new Skunk2 Stahe 1 cams for sale...let you guys know first
  145. I NEED HONEST OPINIONS
  146. Air Intake Design theroy?
  147. stupid question
  148. Walbro 190 too much??
  149. RECIP WEIGHT
  150. possible detonation?...
  151. need some ideas -- B18C1 won't start
  152. ITR tb and ITR intake mani, 200whp+?
  153. Edelbrock Type R throttle body on B16
  154. Anyone that had their rods resized with ARP rod bolts, what did you pay?
  155. zc motor
  156. Best place to get Custom Cometic Head gaskets?
  157. b16 head
  158. ANOTHER cam choice FUBAR
  159. Having an issue... Interemittent "power" cut at 8k sometimes 9k sometimes 7k Rpms...
  160. msd 6a question
  161. what header is this? real sms?
  162. Safe to drive with this check engine light?
  163. Internal Vtec oil passage
  164. B20 Vtec question
  165. anybody ever seen anything like this??? lsvtec tuned on crome
  166. Buddy Club valve springs?
  167. supposedly I am not allow to run pump 91 gas on 11.5:1+ compresson any explanation why?
  168. Question
  169. anyone have the Toda Spec B's??
  170. Hi-Reving All Motor (Paper Thoughts)
  171. ARP Rod Bolts for OEM LS Rods...8mm or 9mm?
  172. Quickie no0b question...piston related.
  173. clearance with rage(hytech) production header
  174. Stock ECU ok to run my B18A engine with Crower 404's and PR3 pistons to the dyno?
  175. hondata setup
  176. B18C5 Smoking after 7500 rpms
  177. Friend's Integ: H22 H2B K KILLA
  178. AEBS IM with what size throttle body?
  179. do they use the same wire harness ?
  180. best engine for 89 civic hatch?
  181. Skunk 2 IM
  182. Cams for B16a
  183. what size throttle body to AEBS IM
  184. lights dime down
  185. Dont Know what is wrong?
  186. any 4-2-1 Headers w/ 2.5" collector?
  187. I have a problem, could someone assist me
  188. Professional Products - Power Throttle Bodies
  189. Can you tell me what my car is doing?
  190. HOW DO I GET THIS OFF MY BLOCK????
  191. bearing reading at .0010-.0011"
  192. I think i'm finished with cars......(part 1)
  193. any engine shops in sac
  194. New motor problem - oil in exhaust - need help
  195. injectors?
  196. cams for ls vtec
  197. What type of cams are these??
  198. I just received my AN-R.......
  199. I just want a Better header????
  200. JDMshitRacing B series 4-1 SS header. Opinions?
  201. what fuel pump and what size fuel injectors are you running on your NA setup??
  202. Powerband for '97 stock Accord
  203. JDM ITR w/ Skunk2 Pro 1 Camshafts
  204. CTR PISTONS W/ OEM RINGS 10 OVER Sized
  205. Stock b18c1 block, Stock b16a head. What are some good cams 200+whp
  206. k20r or JDM Integra Type R motor in 91 CRX?
  207. Where can I get Wiseco piston/Eagle rod combo for a good price?
  208. carbon fiber Velocity stack
  209. d16 head swap? (help peas?)
  210. is my setup good for 220-230 whp..
  211. MSD Plug wires???
  212. who does crank knife edge work in oc/so-cal?
  213. motor buildup
  214. What can I do to reach 200+whp????
  215. acl bearings "need quick reply pls!!!!"
  216. POLL... what tranny are u running with your NA set up??
  217. Best Velocity Stacks?
  218. Buddy Club 4 - Primary & Secondary Lobes?
  219. Best type of intake???
  220. Which B16
  221. fuel pressure + 91 oct. + ctr pistons + CROME ignorance
  222. *vid* b16a, 154whp, ls tranny, 10 foot patch into second.
  223. Zex 57400 camshafts. anyone runnign them??
  224. Intake manifold questions
  225. 2006 Si bone stock with k24 shortblock
  226. Please help identify these camshafts (GSR?)
  227. Tips!!!???
  228. What happen here ( rod bearings )
  229. need help with my comp test results...
  230. Yo how much does it cost to bore cylinders by 2mm? Also, built F22 or stock H22?
  231. s2s1 original cams + b18c head milling 30 thou; need to clay?
  232. eagle 1.9l b16 stroker
  233. ~~~~~~~Anyone using Bubby Club Stage 4's camshafts?~~~~~~~
  234. Skunk 2 or DBL throttle bodie
  235. Your opinions on block guards?
  236. WTB New clutch for D16y8
  237. quick boost...?
  238. JE pistons question
  239. CTR Pistons with rings
  240. simple exhaust Q.
  241. skunk2 throttle bodies
  242. b16b question
  243. B18C5 + BC4 + ITB TWM questions
  244. What do Type R look like compared to GSR rods?
  245. quick ???
  246. uhm, is this normal for a leak down?
  247. head gasket blew?
  248. Whats your shifter setup?
  249. PCV question........ Valve cover fitting????
  250. The b16 swap in the crx was the worst thing I've ever done
