B18C ITR SK2 stg2 Tuner Cams, Piston Advice
Old 12-03-2019, 02:03 AM
Domi4718's Avatar
Default B18C ITR SK2 stg2 Tuner Cams, Piston Advice
Stock JDM ITR motor with SK2 Stg 2 Tuner Cams...Made only 180WHP, tuner said these cams bleed off compression and I Would be better served if I had more compression....ran it for this for a Year looking to make more power with aftermarket pistions.
Looking at 12.5 JE Pistions .50 oversized
Dome CC = 9.0
Compression Height = 30mm
comperssion caculater says I'll be at 11.89:1
Are these too agressive for my cams in terms of V2P clearance?
Head never surfaced, Block Never Decked
Thanks
Old 12-03-2019, 08:31 AM
Chance EG's Avatar
Default Re: B18C ITR SK2 stg2 Tuner Cams, Piston Advice
You'll be completely fine, those aren't necessarily super aggressive cams by NA standards. Just make sure you get the cams degreed, which will ensure the best power output and also that you won't have piston and valve contact.
Old 12-03-2019, 09:12 PM
JRCivic1's Avatar
Yes... this ^^^^^^^^^^^^
Old 12-07-2019, 05:25 PM
xchipx's Avatar
What about running cast pct CTR pistons ? Would be quite a lot more compression than you were after, and would need very very good fuel, but don't really need a forged piston for a mild n/a build IMO.
Are you against a bit of heavy head surfacing? That could get you to the same compression you wanted without having to buy new parts....
Old 12-23-2019, 09:26 AM
FlewByU352's Avatar
Get a different tuner if he is telling you crap like that. I've seen plenty of factory GSR motors put down 180whp with those cams and you should be pushing 200whp on an ITR motor. Either they are degreed incorrectly or the tuner flat out doesn't know what they are doing to timing and fuel.
crooklyn_outlaw
25
12-01-2008 08:50 PM
eg6madness
01-08-2008 09:22 PM
A2_8U
10
05-31-2006 11:15 PM
MJobe
20
03-30-2006 07:16 PM
tomlinson619
03-21-2006 08:14 PM
Quick Reply: B18C ITR SK2 stg2 Tuner Cams, Piston Advice
