- 90mm bore is it possiable??? experts only
- valve specs
- Differences between b16a vs b16a2
- LS or Type R crank in a B18C5?
- Are your retainers worn out yet ?
- b18c GSR motor Question
- 225whp all motor?
- anyone port and polish their own heads?? diy
- VIDEO: DRAG RACE LAST MONTH
- hot hot tanking
- Swapping valve springs? True Tech Question...
- H22 All Motor Header
- cam broke-wtf? pics and stuff
- any way to tell the newer skunk2 cams from the older ones
- DIY PISTONS
- CALLING OUT GLEN BURNIE/ NORTHERN PWKY !!!!!! GET READY 2 LOSE !!!
- Intake Manifold/ Throttle Body Setup
- throttle body tech-d and b series guys look!!
- Header dyno result
- putting CTR pistons in B16..got some questions
- HELP me make my N/A GSR in the high 12's low 13's
- b21a
- which cams to use
- cam gears wobbling??
- what kind of power would i expect frm a built b20/vtec
- intake manifolds----- who here has made their own manifod
- ERE got nothin on me: timeslip
- LeT's HeAR EverY1 SeTuP ...& 1/4 TiMe please!!
- SAFC II blackface
- how do u wire knock sensor?
- ITR head flow compared to a base P&P'ed B16 head
- B16A N/A Monster?
- B18c short block question
- Timing belt for H22. Powerhouse industries etc.???
- DYNO TUNING>>>what gear?
- ctr intake problem
- Bent valve
- new driver
- SKUNK2 RSX???????....where is it?????
- Just got my DTR Street header dynoed
- carburated vs. ITB ????
- stupid belt!! what to do?
- ever heard of...www.japanmotorimport.com?? are they good or bad?
- octane
- where to get high compression pistions
- piston ring suggestions??
- Car cranks, but wont start. HELP!
- How To Get More High End Power From a LS Motor
- 10 sec combo for less than.....7k
- spoon ventuli plate????
- ls vtec
- k20 ?
- detonation
- Put a test pipe on my car---sounds like poo!
- Have a few ? on Jun Cams
- extrude hone price?
- converting obd1 to obd2!!!
- web cams 148e
- Crank Case Vaccumm?
- My experience with Portflow & REV valves
- VIDEO FROM TESTING LAST NIGHT
- thoughts about my set up
- Is it worth the trouble?
- Heads up d16z6 Peoples
- SOHC headwork – basic questions
- Who can make me a custom header?
- The Ultimate Header ?
- occasional blow by smoke normal?
- h22 all motor w/ oversize valves?
- B16 HP predictions
- bone stock 00 ls what to do?
- what do you guys think of ef-1cams??
- HELP FAST!! at shop now!!
- p30's, itr, or ctr in B18a block?
- b20a vtec worth the hassel
- honda LSD
- Can you help identify which tranny parts I need??
- Anyone run smaller cams for LS? Crane #12 or Crower 62402?
- D-series cam shaft – is it worth it in an EJ?
- d15b6 to b16a what's involved?
- Cam tunning
- Somethin real bad with my car today...please any help is appreciated.
- trap speed
- Intake manifold...
- JE B20 pistons in B18C1 block?
- how much of a gain from hondata on stock h22
- Tuning
- all motor b16 block fs
- Tips before you go to they Dyno.
- Jun camshaft for the D series
- engine problems... cranking to fast, and no start.
- Just bought Hondata.....
- Car running rich what to do
- What to do...what to do... header-tech or jdm dc/skunk2 mani
- Engine management for all motor race car...
- check this intake manifold out
- Skunk 2 SOHC - Stage 1 cam: any experiences?
- shot peened crank good for n/a?
- factory lsd
- Valvetrain Noise - What is normal?
- Need opinions on usdm/jdm itr or built gsr on eg hatch
- lsvtec all motoring potential!!!!!
- jdm comp.?
- Another Hondata question...
- CRV block, LS head...all motor non vtec questions
- steve longs racing cams?
- VTEC For you Domestic!
- Lost Motion Assembly Question
- S2 S1 install
- Building up b16 bottom.
- B16 pistons in my LS....how??
- highest compression ratio on pump gas
- is there a lot of difference betweem the gsr and ls tranny
- Ericks Racing GSR Manifold??????
- 1layer headgasket?
- Crane cams VS. Crower cams ....
- Is there any room for a d16y8 is the all motor world?
- Ls crank vs. GSR crank
- Mix Match Cams?
- Does coating your retainers make them stronger?
- where to get a 1-layer headgasket?
- Poor Mans R! Help me Build it!
- 11.3:1 comp ratio good enough for skunk2 stage2 cams?
- all motor HP #'s
- h22 internals in f22 opinion please
- do u know what shotpeened rods is???
- Test pipe (no cat) cause damage to DC Sports Header?
- camshaft experts
- all motor 2 liter combos still using gsr manifolds
- I NO I NO but with:Smsp vs. jdm ITR vs. Header-tech headers does it matter when running open header?
- crank ?'s
- best cams for the H22
- ls-vtec gasket and belt question!
- valve clearance with 404 in LS engine
- Question about octane for high compression?
- ericks racing header???
- Hondata....
- JG header and race pipe Results
- Con-Rod difference?
- Help with rod bearing selection?
- Whats everybody running for headgaskets on B20?????
- Best NA Tuning für a B16A1 Engine?
- Best All motor setup with....
- All Motor or Juice?
- k20 all motor potential??
- standalone users
- pre ls-vtec going from auto to manual tranny which tranny to use???
- B16'S
- Accord Exhaust...please help
- how much is my stock airbox hurting me
- Valve lash using JUN stage3????
- H22's...what's your setup and how much whp?
- Good, safe cam setting for this setup:
- What type of seat to get??
- loud vtec x-over with aftermarket cams?
- ? about my new motor
- Discount on swaps?
- for my EG. whats the better bang for the buck? whats easier to mod? h22/b18c1/5
- ctr cams in 01 b18c1 with jdm itr pistons??
- does the cryo2 work?
- problems with newly built motor??
- individual throttle body setup?
- I finally got all my parts, my Endyn head, and now time for assembly!
- How do you wire up IAC
- Dart Block
- Hondata Question
- raising compression
- b16a valve lash??
- where can i get my B18C rebuilt?
- Header Velocity Starting with 1 3/4
- wich injectors to use, tried search but it was useless
- help no vtec?
- valve settings
- my build so far...
- 4-2-1 Header Better For B18B But What If I Have a Built Head...
- My poor mans Type R is running.......
- did I mess up?? header/exhaust questions???
- Best N/A Engine
- LS/Vtec & Oil squirters
- Who wants an All Motor class at the next Bandimere
- Toda Cam gear Crack Mark???
- Headertech information
- What would you rather run? b20nonvtec or b20vtec
- thinking about putten b16 pistions in my ls
- JDM Integra Type R in an eg hatch
- Help tuning Skunk Stage2 cam
- Need help with a sk2 intake manifold install.
- Methanol? Anyone using it.
- What kind of power can be expected from 11:1 compression on a B20VTEC?
- temp=loss of power
- About to buy engine!! Which would be stronger?!
- head milling quesitons
- H22A allmotor from N.M.
- Anyone use the JG Edelbrock header and race pipe?
- crower valves
- truth or myth: it is possible to change out valve springs with out taking off the head...
- H22 All Motor w/ Crower Stage 2 dyno graph
- B16 bs. LS tranny... Allmota Powwa
- Would a B16A2 block work with an ITR crank?
- redline-performance.net p28 ecus ??
- will these injectors fit my car
- tunning w/ out timing cover
- SKUNK2 VALVE SPRING Q'S??
- where get header tech
- all motor nos and itake manifold ques
- For All Your 'Who Has VTEC' Questions? (U Should Read :wink: )
- how much are you paying for your headers and which ones do you have???
- All Motor LS vs. LS/Vtec
- if u live in DFW area and have swapped a motor before, look at this.
- SOHC all motors set-ups!!!!!!!!
- Compression question?
- Whats the max potenial of a NA CTR motor....
- Let's discuss toda's different cam grinds on a type R motor.....
- One quick question...
- spring and retainer question
- AEM intake or Comptech Ice box
- Crower all motor stage 3 cams w/supercharger?
- Intake manifold question?
- all motor b18a1.. question need help ...
- Anyone running an AN-R Header???
- 13:1 on 93....
- maged and reconditioned rods?
- type r lost motion assembly
- optimum clearance for main bearings
- J's intake on B18C1 IM??????????????
- Gear Ratio Calculator Help
- CTR intake cam...Worth it?
- lsvtec newb
- LS/VTEC Question
- Felt like being innovative tonight
- b20 vtec rev????
- jun3 + stock timing belt
- Crower for my B18 Engine
- b18b head question?
- JDM ITR/USDM ITR Pistons ??
- need some input on this all motor crx setup
- Supertech Valves and Mushrooming.
- b20z on b18a1 block
- Dyno Plot - '00 PY (I/H/E) vs. '01 FBP (foam filter)
- Will 11.6:1 compression in GSR be okay for now?
- please help? b18c gsr
- Is a lightweight flywheel really worth it?
- whats the easiest hp gains
- what is the best header to use?
- LS Theory (Probably stupid)
- SMSP or Header Tech?
- where can I get high compression pistons for H22 FAST?!!!
- what motor is the best all motor 4 xauto??
- Ok, so here is my plan... B16 - allmotor project.(no haters)
- 93 gsr head?
