PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Valvetrain/Cam/Compression - QUESTIONS
  2. Starting Out
  3. car will run on stock ecu bot not on S300, need base map
  4. Possible bent valve :/.
  5. External oil cooler B18C Question
  6. n/a Gsr motor on Eg coupe
  7. EK4 Coupe Engine Swap
  8. h2b build help
  9. Injectors
  10. B16a SIRII help.
  11. h22 crank not turning
  12. Intakes
  13. Just need to know a few things for my Ls swap
  14. Need timing help
  15. B18B1 Into '97 EK Coupe
  16. B20 running rich?
  17. New setup Civic b18c
  18. B18c Head build
  19. ITR airbox eg gsr??
  20. '93 del Sol Si engine won't fire up
  21. help whit my b20vtec setup
  22. Rebuilt gsr for dd
  23. supertech valve banged up
  24. stroker poor man's seems slow
  25. Remote Oil Filter
  26. P8R head on B18B1 block- will I have problems?
  27. ***Lazy ITR!!! needs a wake up call***
  28. b20 dipstick tube leak
  29. Skunk2 cams how do Identify them/stage?
  30. Chops13 Ls/V Build
  31. 3rd pcv valve leaking
  32. B16 ALL MOTOR BUILD ...help
  33. cr question
  34. adjustable cam gear settings database
  35. Help!! D16z6 dies above 4k after 6 laps circle track
  36. Engine swap for 1991 Integra? Best Choice?
  37. b 20 problems
  38. Trimming the top of a block???
  39. h22a head gasket
  40. Valve Clatter in a new Ridgeline
  41. almost ready to do a motor swap but have a question
  42. best b series swap
  43. B20b swap issue
  44. what engine loom would i need? B16a2
  45. F23 not idling or revving
  46. New build, low compression
  47. b20 vtec idle/choking up issue
  48. Little concerned about this block
  49. H22 vs. H23 crank oil orifice size comparison
  50. outlaw engineering IM/TB gasket kit
  51. lsv arp headstuds question
  52. Are head studs needed
  53. skunk 2 intake manifold issues
  54. Duration v. Lift: What is more important
  55. Flow v. Velocity: What is more important?
  56. Apparent Head Gasket Leak
  57. Pro Series paperweights.
  58. b20b vtec swap help
  59. Pics of spark plugs
  60. Main Bearing Q. Factory upper limit(s) versus even clearance.
  61. EPic Tuning Ls/Vtec Kit
  62. Recommendations?
  63. blue smoke in the vtec
  64. b16: Open breather box cause of oil burn on fresh engine?
  65. J's Racing B18C header?
  66. Water in the throttle body
  67. Quick timeline of my B20B/P8R engine build
  68. B16a2 Repair question
  69. ►► ALL MOTOR classifieds ►►
  70. Bottom sleeve damage
  71. RDX Injecter fuel pressure tuning
  72. enlighten me and forgive my ignorance B18c2 all motor
  73. catch can, confused on fitings for valve cover
  74. B18c1 rebuild vs honda specifications
  75. H22 main/rod bearings
  76. Head Porting How-to. Are you guys interested
  77. Need lma part number for my b16 head
  78. Best way for more power in d16a6????
  79. Need to bounce some ideas..
  80. CAR BLEW UP. smoke pouring out exhuast
  81. Cam throwing me for a LOOP
  82. F20B question
  83. Strong N/a D16a6 non vtec
  84. B16a vs b16a2
  85. Skunk 2 Megapower RR exhaust for N/A B series
  86. Honda Pilot 2003 (Timing Belt Issue)
  87. b18c build and numbers
  88. Worth rebuilding this?
  89. Intermittent stalling. B20b
  90. b20vtec N/A
  91. Cylinder damage from dropped valve - salvageable?
  92. Need Help on installing Skunk2 Ultra Series IM
  93. Am i measuring plastigauge correctly is it accurate????
  94. Random "tick/tap" coming from t-belt side of head. B18C1
  95. High comp B series vs H22a4 in a Da9
  96. 24mm comp height pistons
  97. Does it need more fuel or is timing wrong
  98. blox cams hsl
  99. True 1.8 12s Daily Drivers?
  100. D16Y7 build
  101. Cylinder rust... help please!
  102. B20v header all motor please help!!!
  103. B20Vtec compression question
  104. B16 vs b18 pros cons anything else (im new here please dont hate)
  105. B20 (Engine noise)(mystery noise)Videos inside.
  106. Skunk2 Ultra Street Intake Manifold for B series
  107. H2b intake manifold setup or itb
  108. Excessive crankcase pressure?
  109. b16a built help please
  110. please excsus the question :P
  111. Are those 99 gsr cams
  112. INLINEFOUR Valvetrain
  113. b18b1 rebuild help
  114. are eagle rods torqued/stretched from factory?
  115. h23a vtec crank ?..
  116. D16z6 help -EAGLE H BEAM ROD CAP PUT ON BACKWARD bearing usable????
  117. Skunk2 pro 2 clearance questions
  118. What Exhaust manifold fore my Fully built b18c All motor.
  119. Ways to keep the tune safe with 12:1 comp
  120. would you rehone this block?
  121. Stock GSR sleeves taken to 84MM
  122. B20 Vtec - valve train rattle diagnosis
  123. B18C1 main bore size
  124. WTF DOES THIS MEAN? help PLASTIGAUGE
  125. P30 piston is it worth charging them for a dd?
  126. Question on Pressure Plate
  127. PLEASE HELP WITH H23 problems..
  128. whats your input on this setup?? (81.5x95 b series)
  129. DDTECH prototype H22 cam test
  130. No vetc no cel and no noob lol
  131. Quick question on cams ect
  132. B18c1 Rebuild
  133. Type R DC2 weirdness question
  134. LSVTEC GSR and B18B1 build questions and suggestions.
  135. B17A1 with B16A SIR-II Internals
  136. Valve/LMA wear Question
  137. Brian Crower Stage 2 Cams
  138. f20b help / ideas please.
  139. help , help...
  140. retunning questions
  141. Reputable Engine Builders in North Florida****
  142. Cam Card Specs for Delta 272
  143. B20v high Compression question
  144. Input/thoughts on Y8 head build?
  145. Lsv W/ B16 pistons
  146. Skunk2 IAC ?
  147. F22A1 Build
  148. intake length, bumper scoops
  149. Buddy Club Race Header for 08 CIVIC SI
  150. need higher compression
  151. HSV010 got VTEC?
  152. Skunk2 pro2 +1mm oversized valves
  153. Oil leaking in to spark plug chambers LS/VTEC
  154. supertech piston to wall clearance for NA
  155. AEBS vs SKUNK2
  156. Vtec crossover point
  157. ls vtec p73 pistons
  158. Built 2L GSR Issues...
  159. What is the Ratio value on my Dyno?
  160. Building a F20C
  161. quite exhaust
  162. GSC N1 Cam's tested on I/H/E GSR.
  163. H22 main + rod bearings (Kikumoto)
  164. b18b1 lsvtec pcv questions
  165. b20 build questions...
  166. h22a swap 96 honda accord ex
  167. rocket m24xx set-ups with #'s
  168. Looking for YCP 84mm Pistons
  169. D16 evap system delete? Any tips?
  170. Who repairs cams? Is it even possible?
  171. Blox valve spring and skunk2 pro 2 cams
  172. Lsvtec build, what cams are ideal?
  173. F20b valves/h22 valves
  174. JDM d15b vtec obd1 swapped into 00 civic ex obd2?
  175. Neptuner in Houston
  176. help?? b20ls build
  177. My long term drag build... Input/suggestions welcome
  178. Pro1 intake cam with smaller Exhaust cam?
  179. choices for bottom end b18c
  180. H series oem part build
  181. Please HELP! Idles, revs to 2k then dies.
  182. Engine build removing gaskets/surfaces cleaning easier way????
  183. confused by GSR compression test results
  184. b18c obd1 or obd2
  185. B18B1 pcv question
  186. d16 z6 turbo
  187. H22 lower intake plenum - removed runners worth finishing
  188. B20B Bolt on questions
  189. what CR are these pistons
  190. LS VTEC block and head options?
  191. wiseco piston light scoring
  192. ls/v p2v question
  193. High compression piston mystery
  194. DDTECH All Motor
  195. my build.... reccomendation welcome
  196. B20 Builds share yours!
  197. Advice, opinions, experiences on a mild b20/vtec build
  198. My H22 build, tell me what you think
  199. HELP >Is mY NEW DECKED BLOCK F**KED???? STAIN >PICS>
  200. throttle body
  201. Head Suggestions for my b20 swap(ITR,B16,GSR)
  202. ignition timing clarification
  203. cam my b20 or go gsr ?
  204. Exremely basic spark plug questions
  205. Bearings..... Honda or acl
  206. I have a set of Blox tuner 2 cams for by B16 who did they copy?
  207. B series build for track days NA or FI help
  208. f22a1 cam cap/seal?
  209. Wiseco ring gap over spec, issue?
  210. Integra Crank Pulley
  211. 11:6:1 or 12:5:1 ?
  212. Opinion on short and std length con rods
  213. B18C O2 Sensor Voltage High
  214. "PPE" Stamped on my Crank?
  215. PR3 Cyl Head Damage - trash or fixable?
  216. All motor guys with high compression 11.5 to 13.0
  217. LS/VTEC timing belt snapped (need some pointers)
  218. H22 pro1 cams, fuel and compression?
  219. My new B20Z Non-vtec Crower III
  220. In Need of a good Engine Builder in Jax Fl
  221. what cam is best for performance and dd?
  222. TopoBuilt 17.0:1 All Motor D16
  223. Modifications for 1.3 l LDA with i-DSI + pause i-VTEC?
  224. B16A2 rebuild help
  225. Why did I drop a valve post-mortem pics
  226. d16y8 rebuild questions
  227. Found metal pieces in the oil pan
  228. Help installing eagle rods facing which way??? 4 d16z6
  229. CRX B16A INTO EK1 CIVIC
  230. Do i need a new valve guide
  231. f20b eg
  232. B16A in CR-X help
  233. catch can help n/a b18c1 I've searched
  234. B18C1 valvetrain: Upgrade or Honda OEM? Help!
  235. looking for a b16a wiring harness
  236. H22 head dowel pins
  237. Brake Booster Delete
  238. [QUESTION]k24 rod bearings. (Compression)
  239. Obx Itb & Hondata s200?
  240. N/A stage 2 cam higher comp tuning help
  241. skunk2 intake/throttle body install.
  242. d15b7 n/A budget build.
  243. H22 aebs head studs torque spec
  244. B18C1 cam holder placemeant question.
  245. Vtec bogs with new cams
  246. 2000 integra gsr sedan, keep it or sell it off
  247. vtec stopped working & tossed CEL.
  248. What TB's do I have here??? ITR? CTR? gsr??
  249. b18c what to do next
  250. Wta | big stroke vs long rods for drag setup
