- b16a2 with ITR head
- How to know if my engine has cracked sleeves?
- B20/VTEC dyno result
- Spark Plug Help
- skunk2 stage 2 cams and compression
- 3 inch collector NA..okay or just a loss
- b16a2 stroke and bore
- rmf header
- Results of the Royal Purple Dyno!!
- Dyno'ing soon. Q's about cam gear tuning w/ no fuel upgrades.
- CR-VTEC Head problem
- New header.
- all motor b20b or crvtec?
- Buddy club STAGE 4 or 5????
- Ti Valves
- What do you think about these
- Project (insert name here) To start Feb. of '06
- My 2L B16 build.
- cheaper to build stock bottom end, or build new long block drop that in?
- D-series gurus...?
- SK2 Mani, Pro Series better ???
- what fuel pumps are you guys runnin on ur 220+whp motors?
- ....................................... ls crank with gsr bearings?................................
- ECU purchase
- Has anybody posted a 300+whp dyno sheet on H-t?
- Rocket M22x with supertech valves, springs and retainers (valvetrain)
- Not starting
- OT: All Motor Parts For Sale:
- F series monster?
- Swap in D16VTEC, or B18B with integra auto tranny
- what exactly is the difference between Blox cams, and the HSL version?
- Oil Question synthetic?
- where can i get a "cosmetic" headgasket?
- My project is almost complete!!!
- rod small end width?
- what injectors for this setup?
- which headstuds for b20 with gsr head?
- vafc or chipped ecu
- Swapping valve cover
- piston rings for ctr's
- Smog legal build in CA ?s
- When milling the head, have to deck the block?
- ES Oval - Quality?
- Exhaust sound clip?
- ECU HELP
- how many of you are running w/ dented headers?
- K-series rod bearing width
- please help my friend
- What should i buy/install before i get my engine tuned?
- b20b vtec all motor or turbo?
- Blox Intake manifold GSR
- Need help TWM 2000's sticking very slightly.
- need some answers on ROD clearence!!!!!
- skunk 2 pro 2 cams or m22x
- Just did a leakdown test on my B17 with 239,400 miles
- Swapping Built B20vtec in a CRX. Need Tips.
- My new dyno #'s. 98 spec b18c with Toda b's tuned with s200 Hondata.
- Boring a B18A/B to a 2.0l
- M22x => pistons to valves clearance?
- Distributor keeping cam from turning.
- b16 cam question
- LS VTEC QUESTIONS PLEASE HELP
- Cams with OBDII...
- Suggestions on Cams for my B16
- How to do a leakdown test?
- Reliable Build
- Just built a leakdown tool.. going to test tomorrow.. what to look for?
- b16a rebuilt and swaped now, problem ?
- Dallas All Motor Tuning
- All motor Mickey Thompson Slicks
- oil clearence question..
- itb sys loosing vac when hooking up pcv system
- itbs allowed in street stock?
- H22. Skunk 2 Intake Manifold or DIY ITB's
- Buddy club cam gears
- need help1!!! rod bearing clearence problems...
- Valve size question for 85mm ls vtec
- ECU
- h22 dyno
- Buddy Club Spec 5 cams......
- Going lean when entering Vtec..and kind a strange overall..-*Dynosheet inside*
- BC Spec 5 VS Jun4.......
- throw your 2 cents in on this setup
- high mileage B16: rebuild or swap?
- ATS 3.077 fit 2nd 1.909
- Timing is way off Please Help
- how do i know i have real buddyclub cams?
- Car stalling...need some guidance.
- what valves with blox(hsl)
- What dyno results can i expect?
- How Is This N/A Setup?
- more pics of the R
- my air fuel ratio is leaning out at throttle.... any ideas
- Kinda new to the site, gimme some advice on my buildup!
- Is anyone using Skunk2 Pro 2s with 11.0:1 compression?
- Shipping block to Earl.
- Golden Eagle intake manifold??
- CRX HF radiator: Is it more narrow?
- Port and Polish....is it really worth the money and time????
- Need suggestions for best cam setup without loosing any horsepower!!!!!
- PSI cams.....
- Gsr Head Gasket
- The Ultimate B-series Intake Manifold (ENDYN)
- v-bros header?
- running twm itb setup question
- couple quick frankenstein questions
- 68-70-74mm how big is TOO big
- 9:1 JE Pistons in stock B18C1
- new setup
- need clearence adviced for B18a1
- resizing cumbustion chamber
- ITR cam install
- Starting my mild buildup so confused Need expert advise
- Installing upgraded valvetrain/req head removal??
- central cali headwork
- RMF'ed lude problems??
- ctr piston on b16 no power!
- **exhaust sound clip request**
- Help me out with my Lsvtec build
- ctr pistons in a gsr?
- custom exhausts
- need help on thickness of headgasket (ctr pistons w/ b16 head)
- HEADER HELP
- help me with my lsvtec....
- piston oversize?
- ?? Can this Valvetrain Handle these Cams ??
- Anybody ever hook up an CRVorLS/VTEC like this?
- RMF contact info?
- shooting for 240whp on 93 octane with AC in full street car on custom sheet intake manifold
- all motor in RSX
- best N/A setup for JDM D15B SOHC VTEC??
- omnipower internals
- buy my b series and a 92 hatch
- Honda/Acura Motor Specs
- lates k20 headers WTF!!! LOOK
- Lumpy Idle Much? The new motor is in! 11.6:1 CR, Skunk Pro1 (With Video)
- 97 Coupe swap questioning
- HELP PLEASE
- building a B20b....do they make or can I use the pistons they sell.......
- header damage = power loss
- removed pcv system on built d16
- Is the B16a engine harness the same of the B18c5 harness
- Got Tuned up Today
- bore size on b18b??
- Question for you top-end techs
- Anyone know the specs for a Zec 59300 camshaft?
- Bogging bad while steady on throttle/acceleration
- quick question about ITR pistons.
- Injectors/ECU
- cam timing on an h22
- ITR or GSR valvesprings?
- dennis the cop
- AEM hybrid Intake vs. Apexi VAFC II ?
- h22a owners>>>>>
- anyone know of high horsepower na d-series?
- datalogging help.
- what yall think of this setup
- arp head studs install instructions
- B16A2 QUESTIONS!!!!!!
- TLC- Trick Lightweight Crankshaft...ultimate BLING BLING that PERFORMS!!
- B-Series (Race Only) Alternator Questions????
- B18B Swap Into 2000 Civic EX - Thoughts?
- need sum insight: Pro1 cams aiming for 250 whp 150 tq +
- Best IM for b18c1
- 228whp and 156tq, pump gas, all motor with AC and Exhaust....
- Connecting rod stretch at high rpm
- H22A Swap
- B20 VTEC OR H22??
- High Comp. pistons for ls/vtec?
- What else I would need for ls/vtec conversion?
- Use gasket compound with 2 layer Mugen gasket?
- Need some compression answers on ls/vtec?
- skunk2 9.6 sec ?!?!?!?! im i late on this news or what??
- tryin to get into the 13 sec club, need some infoo
- all motor D15b
- Need a race car!!! Come and see us
- 85mm on b20 stock sleeves
- bigger fuel injectors??
- how much should this set up cost?
- forged pistons (expand???) so how much clearence???
- Anyone running Comp Cams Quiktyme 290's?
- Poor mans vs. LS Vtec
- New motor beign installed at Mobile Electronics this week.
- exhaust question
- Just pistons?
- H22 Crx and hooking up IAB (secondaries) to vtec experience...
- ECU tuning ?s
- Single layer HG??
- non vtec head on vtec motor?? please help **
- New to N/A: h22a1 Rebuild
- where to buy a 2 1/2inch exhaust manifold gasket?
- 307whp by Ppo of Puerto Rico using RM Cams
- what parts will i need to change putting a b16 head on my gsr?
- Install Pistons on Rods?
- Spicer Report with ref to K&N Filters
- BUYER BEWARE: prospeed / prospeedpower.com
- Miss Shifted in vtec
- NEED HELP WITH BRAKE IN...
- Could you use a toda timing belt for a b18c on a b18b???
- spun bearing, egg shaped rod, help! pic
- I would like to underdrive my accessories... and keep stock crank pulley
- which cam is better for a day to day (only car)
- Need Advice for B20/Vtec in EM1
- All Motor F22....worth it?
- switching over....need advice
- Help with track times
- need some more input on a mini me
- D15
- TWM induction video. Does anyone know the setup on that car?
- B series pulley ?s
- GUAM RACEWAY PARK Vids
- Need advice on a new header and exhaust
- b16 or gsr head??
- D16y7 block/ D16z6 head
- 95 z6 motor in 99 civic ex what do i need
- HELP NEEDED !!!!!! tranny slipping problem, need your INPUT !!!
- Well, just added up my price list, thinking of trying something more simple. PCTs in a LSVTEC???
- Cold Start Injector Question (Please Help)
- my ls/vtec setup
- Built GSR or Built POOR MANS
- LS/Vtec Cam choice
- THIS IS FOR 2PIONT6!!
- Oil: That time of year again
- Is th "H" motor worth the time to build or nothin but problems??
- I'm not a bike guy but it is "all motor"
- B16 Tuning help???
- 1/4 CRX vs DA
- CTR n1 Crank-pully
- Aftermarket TB: Idle Adjust?
- More than 89 mm stroke on a B series?
- CRX installing a SOHC VTEC
- Shops in southern california for engine rebuilds
- k20a2 ITB setup
- Ultra high compression
- b17 head question TRUE or FALSE
- for those running/ran side exit headers
- whats your recommendations for this setup ?!
- Piston ring gap.
- What exhaust for RMF H22??
- chillin at modacar today . decided to throw the car on the dyno real quick. 207whp 148tq
- pinging?
- Which rod/crank combo 2.1L build
- how much power can i get from a d16y7????
- obx vs DC sports header?
- Im Out, my lost your gain
- Redline for all stock crvtec motor, or should i say SAFE redline
- My B18C1 set up--Which Cams and Valves?
- What piston ring for wiseco fordged piston
- Head gasket for 16:1 K24A/K20A
