- What do you guys think.
- L'Natural CRX for sale... What would you pay???
- what do you guys think about HOlley AIr mass headers?
- Which NGK plugs for a relatively stock B series?
- what kinda power difference would this make??
- What valves would be best to use?
- ? 15.1 compression!
- Rev-higher than 8000
- Skunk2 Stage 2 Cams
- used arp head studs?
- color of type R valve springs? sorry to repost, search found nothing.
- What's the deal with this intake manifold?
- BBK 62mm tb and sk2 intake manifold
- rebuilding head.. need suggestions
- Good all motor setup so far?
- Dry sump H22
- When to upgrade fuel system??
- Getting a chipped P28 ECU, need suggestions on program to use.
- PROBE vs Eagle, anyone use PROBE?
- lsvtec w/ Toda C
- Is a port and polish worth the $900 on a B18C1
- Best rod/stroke ratio? and one more thing...
- Make me an exhaust :P
- expect whp....
- Big Valve K20 (RSX) head with Toda cams
- What to do with $3500?
- Would Spoon Balanced Type R pistons be good in a Ls block for Na?
- B20, LS, or GSR block?
- Anyone running the RS Machine cams?
- differences with the 94+LS header and a 99-00 SI header
- best program (chip) for a p72 ecu
- Anyone tried p30(jdmb16) pistons in a type r block , with b16 head.
- ****Looky I found a NEW type of Intake Mani. Is it any Good??!****
- Hondata vs. Vafc
- Skunk2 Stage 2s and Compression
- I was wondering if I built my own motor...
- valve specs on a stock 91 civic dx
- complete B18c5 head with a b16a2 bottom end will a stock ITR ecu work.
- are OS .25 CTR pistons necessary in B18C?
- Camshaft and Valvetrain upgrade on a d16y8
- Frankenstein
- Swappin blocks
- Are my STOCK Retainers fine to use???
- all motor king of the streets
- WHP of this setup?
- Injectors and fuel pump needed?
- Ooh sweet. An All Motor forum!!!
- All motor hondata tunes
- clutches and flywheels
- b18c, to Vtec or to non-Vtec that is the Question
- My car is drinking Coolant like a bum in a bar ! HELP !
- gsr motor build up!
- installing cams - separating/conecting cam gears]
- LS VTEC insights please. Need a general idea on this custom set-up will respond.
- how high can a B20 Vtec motor redline to ?
- valve spring specs.
- RS Machine valvetrain??
- Bolt ons or internals first?
- JDM ITR pistons in a ls, what compression? (tried searching)
- Any body running allmotor setups in a delsol?
- block girdle
- 97 EX Civic Coupe - Engine Mod Ideas???
- B16A2 all motor set-ups
- What would be a good type of motor to in order to run a all motor setup in a 92 vx
- All motor ls, whats possible??
- J/G's T/B.......................
- port flow valvesprings & retainers,skunk2 stg3 cams .wd it work?
- :rightarrow: b18c vrs b18c1
- ls all motor potential
- Hondata and Cam gears and tuning. Worth it?
- what to do................!
- spoon engine?
- whats the best pistons to have in first gen b16
- comptech race header (Already sereched)
- All motor B18c5 setups? help if you can
- Help me out all you D series all-motor guys
- What should I rev to????
- Looking for a good machine shop
- Motor and car!!! please help
- any good shop in so cal
- Need to replace head gasket, what to do while the heads off?
- Valvetrain
- Crane/ferrea Roller Cam followers B-series engines
- Skunk 2 ECU Program
- never been to the track, what will my car run on the 1/4 mile (please read)
- yet more ls/vtec q's...
- what would be faster out of these 2 setups?
- D series numbers
- My friends b16a dyno chart (comparing only,no bragging/$hit talking).
- Stroked B16! to B17, plus.... ITR/CTR pistons???
- Whats a cheap inline fuel pump to run a stock motor?
- where to get SOHC jdm vtec motors?
- what cams to get?
- bigger cams for my 99 civic si
- any tips on how to get an ek(ctr motor) into the 13's
- header question?
- Couple of questions regarding LS/vtec
- How high an RPM can 84-86mm bore go?
- Slightly modded B18C1 dyno also Tach question???
- Anyone running EF-1 cams and valvetrain components?
- streetable compression
- ITB users : Vacuum log sizing
- Opinions on DH-Racing?? (on Ebay)
- jun 3 owners take a look inside please....
- Dart B18 Block
- GSR rods for NA
- where to get head rebuilt in New York?????????
- dyno numbers
- OBDO-OBD1 harness
- rods in a ls/vtec... keep stock LS rods + ARP bolts or eagle?
- itr head vs si head...I forget =/
- LS Crank in a b16? (Theorys, Deck plates, Strokers)
- H series or B series?
- ??? about my b16 allmotor setup???
- Anyone Dyno these Cams?
- ctr pistons?
- Ls/Vtec... couple of questions come inside =)
- How many rings are on your pistons?
- Very satisfied with new setup ls/vtec
- B20VTEC w/ DSM 450cc's
- header and exhuast combos.
- i want to know everything about skunk stage 3 cams...
- Piston ring question
- Quick Time Electic Cutout (qtecc30)
- type r cams and valve clearances.
- All motor set up theory: Alcohol/Methanol with Water Injection
- 68mm or 70mm
- Need Help!!! What are good parts to use for ALL MOTOR SETUP???
- Check out what this miss shift caused!!!
- **BEST cam gear design and BOLTS---vote
- trying to get a better understanding. help.
- PCT pistons in LS block questions?
- Does this make sense?
- Deck Plate Questions?
- Is it safe to remove the middle layer out of an OEM headgasket?
- What do you guys think about this all motor set up?
- Sk2 Stage 2 Cam?
- Need help and opinions..
- anybody wanna post pics of there all motor cars
- will integra type r pistons .25 over bore fit a b20 block? what needs to be done to make it work?
- B18C 1/4 mile times in EG
- crower cams and web springs and retainers
- N/A Gurus: Cam, LMA, and lash spec questions..ls/vtec (sort of)
- b16 block with GSR internals????
- Anyone use electric water pumps on N/A setup?
- 02 sensor??
- all motor ls waterpump???
- quality of skunk2 cams
- Mir import hybrid shoot out June 6th
- Help me pick the proper grind for my setup.
- let me know what you think?
- Skunk 2 Intake manifold
- what Cams & Valvetrain for all motor ?
- Best All Motor Headder
- what should I do with 800 left in my budget?
- help me decide motor
- pics of my car '93 hb h22
- My beast RB26 !!!
- Ported + Polished Euro-R accord type-R h22a manifold, pics..... please post comments etc.... (enjoy
- what retainers are you using?
- my ghetto all motor set up
- Break in period???
- LSvtec/B20vtec water pump - why change to B18C1/5?
- How to tell the difference from stock cams to skunk2 cams
- b16B to ITR?
- ITR crank v. GSR crank
- Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at?
- all motor weights?
- JG valve springs
- full ls set up's
- best oe pistons for my set up?
- LS/VTEC Proven Reliability
- where to buy inexpensive upgaded valvetrain components for all motor aplications?
- Expected HP with this setup?
- Eagel Rods?
- Built motor, what times?
- LS/VTEC Valvetrain Q's
- somewhat OT: is Nitrous a form of FI or can it still be considered "All Motor"
- OEM Injector Upgrades
- Best ITB's on the market?
- Fastest all motor on street tyres???
- B18A1 Head ... Some advice please
- My new motor
- b20vtec 1/4 times in EK
- My Header Tech Header - Not 56k friendly
- Need some all-motors tunning help: Which to do first VTEC crossover, timming, cams..etc.
- Mild b20vtec Dyno tune at Trackmasters
- how does this header look>?
- who here has used toda cams?
- LSvtec build and reliability?
- Bigger TB. Does it really help HP wise?
- Aftermarket rods for N/A? Lets chit chat.......
- Is 190 whp possible from b16b?
- final drive for n/a drag. 4.7 or 4.9
- big mix of a setup: b17 shortblock, b18c1 head, ctr cams...what do you think?
- h22 all motor setups?
- Intake manifold
- anybody going to kick eriks out of the number one all mota spot
- Won the all motor class at a local event this weekend....
- Need help with ITR IM on B20z
- prep for a zex kit??
- Is Bigger Always Better?
- difference in ITR motors???
- www.allmotorgroup.com
- most HP on NA sohc?
- ITR pistons lighter than B16...?
- Would 7500-7800 be a safe rpm range for a D16y8 with arp rod bolts
- newb question?!?
- Anyone ever use any engine building software?
- all motor prelude?
- whats a good girdle to use?
- Golden Eagle question?
- itr pistons in a b18c1...will it change CR?
- Spark plug problem
- turn my B18C6 into a 2. Liter
- GSr drive train into a 1990 Rex si.
- Kinda new to the all motor thing got ??s
- ITR vs. GSR rods
- VAFC hack
- LS/V-Tec Question?Having a problem!
- 2 to1 rod ratio?
- CTR vs. GSR cams
- anyone in chicago deal with hondata??
- could you guys tell me what you think of my set up
- Dart Honda B series blocks
- Looking for opinions on a set-up and finally have a forum to post in...
- Bagder sleeves in h22a
- "Y" spraying injectors???
- a/f tuning for all motor engines??
- B20z w/ stock bottom end and stock 2nd gen B16 head????
- Which motor oil to use for racing?
- what ecu program do u have?
- GSR Injector suggestions
- is a B17 block good for anything??
- D16a6 Motor Mod ?'s
- Some pics for the new forum - B18C1 All Motor (56k Warning)
- how much hp do u think im making you try to guess
- AN-R headers......... all comment and thoughs welcomed
- Good set of rods
- how to tell type S from normal lude LMA
- hey guys new to the all motor world EX f.i. guy need head help
- all motor b18cr
- what motor to buy for a fully built all motor set up in my 4th gen
- I volunteer my car as a test mule.
- OEM All motor rebuild
- GSR R/S...
- Whats needed to take my B18B to a 2.0?
- skunk2 camshaft
- B20/B18 CR/LS/vtec all motor bottem ends.
- is there such a thing as a "beginner" cam upgrade?
