- pistons or just shave?
- gsr motor swap, what cams?
- ITB's on stock motor.....?
- what cams should i go with....
- which pistons would be best for itr
- 12.8:1
- Motor stalls etc etc on cold mornings..
- AEBS intake manifold
- gsr head with type r cams
- CTR pistons
- Stock LS 1/4 mile times...
- d17 crank in d16
- Which Way would be Better
- IDRC Pro-Am All Motor - Palmdale, CA November 22nd-23rd
- Ls Shot Peened Rods with CTR pistons on B18a1
- rods
- Crankcase Evacution Pump
- VAFC settings - built motor
- JDM ITR 81.25mm o/s pistons on b18c1 rods
- JG ENGINE DYNAMICS intake manifold
- Erik's racing...no longer fastest all motor honda...
- 94 hatch with obd1 b16, obd2 gsr will go in next
- skunk 2 stage 3's vs ef-1 m24's
- Stock GSR rods with CTR Pistons
- best cams for torque? (non drag racing)
- Automotive Performance Engineering: The Great Header Test
- Apexi power intake
- Can my b18c1 hit 200whp and 12 second slips?
- b20/ls guru's
- Changed intake manifold now NO SPARK AND CAR WON'T START??????
- How do i get video from the cam corder to here?!?!?
- valvetrains
- AEM v2 is it all hype?
- Toda Spec D's.. 14:1?
- Opinions on this setup????
- USDM B18C1 buildup-mild(tell me what you think)
- milling question......tunners
- milling the head...
- Anyone know where to buy Dart/Mr Gasket "Beast" crate engine?
- No one likes JE pistons?? Wiseco are betteR?
- which piston would yeild a higher compression?
- how do you like your walbro fuel pump?
- Anyone that had problems with their sleeves sinking?
- all motor route now i need some advice from the all motor crew
- ctr cams and 01 itr cams....same?
- My plan for an Engine
- Build Me an Engine!!!
- 250whp N/A B18C1..... can it be done??
- Need Help with Piston Choice for LS/VTEC (N/A)
- new b20/vtec time...horrible details inside - i raced ALLEN from Honda Heaven!
- wot model wallbro fuel pump
- Best head package for gsr - daily driver - responses MORE than welcome. - not past 8.5k
- jun head package?
- Potential of a sleeved b16?
- All-motor LS?
- Eagle 4340 H-beams and CTR Pistons
- cam caps
- Whats th most HP youve seen out of a B18c?
- best production header?
- HP guesstimates
- d16a6 or mini me?
- how to tell sleeves cracked???
- will the edelbrock header for a b16A work on a B18C?
- Best camshaft for H22A? (already searched)
- Would like some advice on my all motor setup
- starting my gsr build up
- exhaust too laud
- how hard is it to swap cams,springs,retainers?????
- raising comprssion?
- HELP ME MAKE MY B20 CRX???
- I'm buying oem pistons, should I stay with the oem rings?
- Contemplating NA build up.... What Intake Manifold to use?
- who has a 13 second b16a?
- B18C5 or K20A2 (Type S) Engine in Your Opinion?
- b16a1 + skunk2 manifold(b-serie)
- **** who & where to get extrudehone performed? website?
- advantage to reving higher?
- honda tuning shop in PA or Ohio
- reddish deposit on spark plug
- V-TEC Killer Question?
- High Compression = No Pass Smog?
- revving up to 9000 or more
- lightweight flywheels for drag or not
- valves
- B16A2 SiRII motor question???
- All Motor
- $2000 to spend, what shoud i spend it on
- Canadian Sport Compact Series All Motor Champion
- Stock Retainers?!?!?!
- cam clearence
- going all motor......
- Make house payment, adjust the rockers.......
- H22 dyno results - 209 whp
- Titanium Retainers expected life??
- Jun Type II Intake Cam VS ITR Intake Cam - Dyno Sheets
- looking for a new train and need help
- Hytech headers, or an-r headers?
- EF-1 Non-Vtec Cams
- 9:1 comp driveable, no turbo?
- head work?
- maybe a stupid question, but i dont know ..thats why im askin.
- Dyno of my latest Civic motor...
- Should I use the LS crank in GSR???
- Steering problems, gap in the middle.
- Ericks racing pistons?
- Aeromotive Fuel pump..
- 12:1 LS with a 50 shot?
- Hondata?
- b20/vtec....thoughts on setup.....
- kamikaze headers h22a
- Poormans ITR setups
- all motor setup questions.
- Best size TB for my setup
- Crankcase Evacuation Systems ??
- Anyone switch from Turbo to All-motor??
- JG Engine Dynamics Stamp
- All motor H23 ?s
- Eagle rods or Probe rods?? please help
- JDM CTR Piston kit
- jun cams valve specs???
- where to set cams
- Eibach Valve Springs
- GSR head....with dpr stage 6 headwork
- where in SO cal is a pretty good price to get an ls head ported + get a valve job?
- fully built bsr, or fully built crvtec
- dyno ran my headertech header
- ITB question
- Header this, Header that - Who is Down for the Definitive Showdown?
- convert it to ODBII
- What should i use??????????
- How to increase displacement??
- Orderin motor from HMO tomarrow..
- where can I find the wiring diagram to make my own conversion harness?
- b17 who has one and what do you have done?
- What axles are you using for all motor with 25" Slicks ?
- good machine shop in utah?
- pic request: AN-R Compact header
- New 2.0 time slip!
- civic si 99 ecu fit in a 99 civic hx?
- itr valve springs?
- Wiseco high comp. Pistons CR?
- HOW BIG?????
- arp head bolts for ls vtec
- Another Header into the line up... ((56k Overload))
- going ls/vtec
- Should I get around 200whp w/ these cams?
- greddy exhaust
- My latest motor
- toda spec c-daily driver ok?
- * List your head setup or dream setup
- toda head package or skunk2 headpackage
- what valve springs, retainers, and valves to use with toda spec b's?
- what headgasket to choose?
- I only need 1 rod and 1 piston, Suggestions??
- Toda timing belt owners. is your belt loose?
- Motor Question (GSR Block, b16 head, type r internals, gsr pistons)
- Good Machine shop in MD
- 94 GSR IDELING WRONG
- Would the ITR Cold air intake improve my setup
- Cam setup in 00' Civic Si?
- N/A questions?
- b16 knocking when i top speed it
- 12.5cr on 92 octane with skunk 2 chip?
- h23 vtec?
- ls/vtec, want to raise cr, need help!
- jdm b16a vtec!
- LS TRANNY W/4.9FD Vs. B16/Type R TRANNY
- New rocker assemblies?
- 195.2WHP Golden Eagle Sleeved Block.....
- lsvtec, what ecu program to use?
- TWM ITB's
- HONDATA ROMEDITOR??
- how do you like your bearing clearances???
- need someone to diagnose this problem.. ecu related.
- ECU pin removal.
- valve spring spec's needed
- an-r compact header
- H22a euro-r tranny gears
- will h22/h23 TB fit on a bseries?
- help: need opinions
- b17 what pistons?
- What size TB on my all-motor LS w/ my setup????
- who makes a 65mm t/b? (b16a)
- carbon build up
- skunk 2 valve springs with jun II cams..good idea or not?
- Trottle body on a B16a2
- Quad throttle bodies on ZC...what numbers can i expect ?
- cel 20
- Which chip for p28 ecu?
- p28(vtec)
- cam gear settings for itr cams......did search
- Breaking Axles!!!!
- JDM DC header, cat length question?
- Pulley applications
- getting ctr cams need help tuning
- skunk stage 2 or toda spec b or c
- can anyone provide a dyno of toda spec b's and c's?
- AC compatable headers fpr D series?
- d16 header question
- cams + valvetrain on an ls/vtec
- post pics of you 99+ JDM ITR cams..
- Needed: S2000 Shortblock info...
- better cam for gsr: CTR or ITR?
- most recommend flywheel?
- for the ef-1 gurus....(valve trian related)
- Injector question
- b16 hydro tranny gear ratios?
- My B18C6 ITR engine , resleving , stroker or DART block
- crv crvtec dyno run
- stroked b16b reliability
- b16 help(headers)
- valve springs/retainers in B18C1 with CTR cams.?
- how to tell if skuk2 cams are real
- all motor rsx type-s owners
- what's the best manifold and header for jdm b16? type r?
- Programable Hondata DC5 release date
- The fastest ALL Motor DC chassis Integra 1/4 mile times
- so how much could I be looking at?? (WHP)
- TODA valvetrain question?what retainers and valves in b16a
- New standard size pistons.
- UPDATED: First dyno of my new LS/VTEC. Looking for opinions
- do i need bigger injectors for vafc?
- How about RC 310 injectors?
- Q about JUN III's
- (Please read) All motor B16 power....Need help to get 200 WHP
- another dumb question! What intake system are you guys running?
- need advice on all motor upgrade
- Did AEBS Intake Manifold Install Today and Now Car Won't Start....HELP!
- Fuilly built h22 only 197whp??
- thoughts on hp and times with my setup
- H22A1 Modifications what Can be done?
- SOHC roller rockers?
- Need Help - Look at my dyno!
- Please Help With My D16z6 Build.....
- JDM FD & ITR LSD into B16a2 tranny? Is it possible?
- ls/vtec, which 02 sensor ls or gsr ?
- GSR with ITR pistons Q?
- crower 60403 vtec cams ?
- best All Motor tranny....add all relevant info
- Type R versus B16a head with R Cams. How much of a difference?
- cams for b18cr
- JG goodies, +/-?
- Mini-me project
- has anyone seen the dyno of the skunk2 vs aebs vs itr intake manifold?
- My SIR II Dyno in an EF!!!
- 450cc injectors LS/VTEC
- pro's and con's
- trying to figure out my compression....
- how to build my all motor screamin b16a
- Hrmm.. which fuel pump to use????
