- B18 w/ B16 pistons -- Any Numbers?
- Questions on b20vtec.
- Why titanium valves?
- need buddy club spec 3+ vs. RM m22's info for an ls/vtec
- B18 JDM or USDM?
- b18c5 head on b16 bottom end with ctr pistons???
- spark and fuel but not starting
- Dyno Sheet!
- scratched B20 cyl walls with forged pistons ???
- B20 Vtec vs. LS Vtec
- 150hp+ from 1493cc's
- *****H22/23 OEM parts measurement Help********
- what head is better for ls/vtec b16a1 or b18c1
- rev high on b20
- gsr rods in ls will it work
- how much should i shave my head
- n e 1 know?
- Balance Motor or Custom exhaust piping
- lsvtec with powersteering??
- Apexi jdm civic type r header
- what motor can pass smog from D15-B18C1 in a 88-00 civic
- h22a1 swap... Looking to put one in a 93 prelude.
- crower stoker kit question
- all motor exhuast question?
- valve tech article
- How much HP do 240 cc injectors support?
- throttle body question
- Intake Manifold
- who makes block braces
- what rods bearings do i use for my b18b with eagle rods?
- I got my head back from ENDYNE
- What do you prefer, teflon type sealant or loctite to plug vtec head??
- just want some quick ideas
- ACT 6puck/heavy duty vs. clutchmasters.
- b16 head tourqe spec
- b20 block with gsr/itr internals
- LS crank in my GSR with Oversize p30.
- oem b16 pistons, where to buy??
- Tuning question......noob please help.....
- Stock b16a head Stock b20b block, do I have to cut the valve reliefs ?
- Help, USDM ITR vs. JDM ITR in B18a/b
- Installing Breather Filter???
- Piston to Head Clearance
- Rebuilt valvetrain, who does the best work? (D16Z6)
- what ecu for high compression?
- gsr block needed bad
- cams made almost 20 hp without vafc
- Wideband o2 sensor
- bad knock sensor no vtec?
- anybody ever heard of.......
- intermitten start problem
- What cams are these
- Help! Car died in storm
- ITR camshaft camgear setting..?
- New EG throttle body?
- fuel pump and injector size for this setup?
- expierenced h22 builders
- FAST hooked up by ParrisEngDyn
- boreing out b16a stock block out to 85mm good idea or bad idea?
- jdm 98 spec type-r header
- Curious about 89mm stroke
- ok i got my b16a block ls crank,ls rods what to bore my motor to .25 are more? an what pistons to us
- 13 sec. daily driver
- What Valve springs should i get?
- Question for all motor ls guys
- H22 SMSP header dyno...
- New motor break in smoke? how long? is it too late? advice
- CaLS/VTEC Cma suggestions
- is it possible ???
- high comp d
- need some opinions on 85mm
- HOW TO refinish rockers arms... (lots of pics)
- ok i got my b16a block gsr crank,ls rods what to bore my motor to .25 are more? an what pistons to u
- CTR pistons in a B18a/b clearance? not an LS/VTEC question!
- Initial Toda B setup Cam Gear Settings?
- who makes a light weight front crossmember 91 crx?
- What about Mugen valve springs ?
- what do you think the best setup a stock bore B16a there is out there *FOR ALL TO KNOW*
- AEBS manifold and B16A2 manifolds....
- Sleeves?
- HELP!!! still burning oil, but everything is normal
- Quick question on Walbro 255 fuel pump
- d-series compression
- Question about Hondata and ITB?
- Deck Insert; Closed Deck?
- questions about hayward perf. i.t.b.'s.....
- need some advice on a set up
- skunk2
- ice box owners
- Cam Gear Advance Retard Question...
- CTR pistons in a GSR???
- ITB help...
- D series engine rebuild...
- Oil squirters in an F22/3 ???
- Skunk2 Stage 2 cams + Skunk 2 valvetrain = rev limit?
- b18c6 w. I/H/E and stuff..Back from the dyno
- Skunk2 Valvetrain + Buddy club cams
- Jun 3 cam settings
- built bottom end/stock head
- 195hp 140tq All Honda parts!!!
- got back from the track with the EM1/B20
- slick size recommendation with 4.92 final
- Cams
- looking for simular setup??
- what ecu program would be best for my setup?
- LOTS of PICS DYI ITBs H22a
- question about heads b20 and b18b
- throttle body ?
- ITR and undercamed engine. What cam?
- Headwork.....break in yay or nay?....
- problems with my motor. any help/suggestions please
- Sohc Vtec Cam
- TrueRace/Burns Stainless K20A 4-1 Collector Done
- camshaft timming??
- What's the size of an AEM sri tube?
- Can I gain more power chipping or hack??
- What would cause new bolts to snap?
- What Head Gasket? 12.5:1 I want to lower it for daily driving
- Have JUn3 cams and springs want to use portflow Ti retainers?
- few q's about swaps
- engine swap question?????
- guess... i need help
- hey guys check out this setup, tell me what u think!
- crower cams stage 1 any good
- b18c1 pistons>b17a1
- cams for a b16
- cowler cams stage1
- arp head bolts, special socket?????
- Sohc Vtec Build Up
- PR3 pistons in B18C1
- NEW PARTS FOR THE GSR
- omni power b series valve springs,valves and skunk 2 ti retainers
- H22 Catch Can
- Anyone ever have Jun retainers fail?
- my new b16
- All motor 2.0 question
- Sohc Vtec Question
- 233whp on stock pistons/stock cams h22 ibspec setup
- Intake manifold butterflies?????
- brand new, "tarnished" bearings?
- Spoon Stroker Kit for the B16b worth it..??
- How much will slicks knock off my time?
- 81.5mm bore, do I need 81.5mm head gasket?
- B16 ported intake manifold vs. ITR or Skunk2
- Why won't Vtec work? I've checked everything!
- Fuel Cells legal or illegal in all motor street class?
- Buddy Club SPEC III vs. SPEC III + (plus)
- How many miles do you have on your all motor set-ups?
- Stroker kit from Eagle
- in need of a tuner / builder in the CT area
- CTR PISTONS????
- LS VTEC Update!!! PICS
- Does gas rase compression, will more gas give you a better 1/4???
- My All Motor Setup is for sale....
- Back from the dyno!
- LS/VTEC rod milling ?'s
- cam question
- Dumb Question but I searched
- CTR pistons on LS block?
- Quick question...Is this the quench pad?
- Question about detonation..
- How To Change Valve Seals?
- Stock B20B (lower 8.8 CR) / VTEC anyone??
- Spark Plugs for all motor, Hot or cold spark plug
- Squeezing more out of a dual carb 1.8
- Looking for max power out of my LsVtec allmotor
- LSVtech set up please help me thanks
- dh racing
- What is it called?
- ready to be tunned, what to watch out for? tips?
- Pics of my Ls/Vtec!!!
- greddy sp2 or rs*r exmag?
- i need help
- could a bad oil pump mess up the head
- what is safe bore on b18c1 without sleeveing
- cam grinding at 3000rpm
- wide band question
- Eagle 2.0L stroker kit for B16
- High comp shaved head timming off HELP!
- Do I need to have my motor tuned?!
- VTEC/Rocker arm ?
- Which is a better deal
- has anybody ever ran these itb's
- high compression + n2o + ?
- add more power to my 93 4dr. DX
- wear on rockers...
- cars started smoking after oil catch tank install????
- put the b20vtec in the EM1 finally......
- Does your Fuel pressure jump up less with bigger pump and vaccuum off??
- How big Compression for stock B20 slevees can handle..???
- New parts...need a "how to"
- comments and questions about my GSR..
- Compression?????
- check this out... crank scraper
- Header Tech header pics and sound clip (in a bit)
- H22A4 with -0.010" out of the hole piston to deck height
- JDM D15B Internals Question
- b18 cranks
- Which 2.5" cat to use with jdm 4-1 header??
- Has anyone used an e-manage on a N/A build up?
- All motor Dseries...Zdyne SECU overkill?
- How much more aggressive are JUN3 cams then CTR?
- D16a6 Tuning
- Decking the block 0.013"
- crv performance
- high compression with 92 octane
- 99 civic wiring up my vtec si ecu obd2
- Cylinder running lean/detonation
- B16a help
- PICS of JG's New CAMS
- D16 all motor...stock injectors ?
- GSR Head
- Sleeving for N/A
- Q..? for the k series gurus.....
- J's racing intake or AEM V2???
- need oil pump advice
- bearings for eagle rods
- B16 with a GSR crank?
- 310cc injectors on this setup? will it work?
- new motor -- code 20,22... only happens at certain times???
- ALL MOTOR Tips !!!!
- JUN III or TODA spec C
- Lost!!! Help Please!!!! Ecu Chipping Info!!!!!!!
- ALLLMOTOR RECORD set in Bakersfield - Saul Salcada - E.T. and SPEED
- engine probs
- problems installing my block guard
- Where to get SOHC ITBs?
- did compression test
- fake j's racing?
- Did a search, what about B18head on B16Block?
- head for b16a
- TODA TYPE D CAMS
- upgrading pistons???
- Help Tranny Issue Can't shift into 1st, 3rd, 5th or Reverse other gears not working!!!
- cam grinding at 3000 rpm
- 89 crx ecu for mini-me???
- does speed sensor have anything to do with vtec
- ported head pics
- Build block? Or new block? Help me out!
- where to get smsp
- Does anybody happen to know the dome/cc volume for the OEM prelude Type S piston?
- Check out my dyno Video b18c1stockbottomend 176whp!@!
- b18c1 compression with...?
- 98 accord chugging
- crower 402 vtec cams?
- Spark plug ?
- help with rev limit....
- radiator
- Latest build:B18C1 w/CTR's and ITR head
- Hytech Header!
