PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 [212] 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. How would I know if they are type s pistons and eagle rods in my car
  2. toda cam/cam gear??
  3. d16 cams????
  4. peter chan, 11.41 ?????
  5. Itr cams or Ctr cams
  6. taking out A/C and PS
  7. Difference between CTR OS and standard pistons......
  8. All Motor d16z6 setup..
  9. b20vtec
  10. GSR block with iTR head
  11. anyone ever have a cam gear slip??
  12. GSR question
  13. anyone running the RS b series camshafts??
  14. JDM ITR HEADER OR SS JDM 4-1
  15. the beast motor?
  16. Trouble starting?
  17. Oil Jets in ls block........searched
  18. Sleeved B18A block to 85mm (lsvtec)...what head gasket?
  19. Honda Civic HB racing parts (cams/gears)
  20. which valves springs can handle up to 12500 rpm????
  21. Billet USA or Evolution Cam gears?
  22. Crvtec Piston ?
  23. Is this enough for a 160whp b16?
  24. eagle rod bolts size?
  25. comperssion pease?
  26. what should i go with?
  27. just seeking reassurement and or suggestions
  28. best cam gear setting for my set up?
  29. motor problem! can someone help
  30. what dicatates optimal VTEC crossover?
  31. N/A budget LS/VTEC
  32. whats the best setup for na
  33. Good cams for 10:1 compression?
  34. what is shot peening?
  35. d16z6 + 88-89 a1 pistons?
  36. ecu troubles? no vtec in 5th?
  37. Buy LSD or ITR Tranny
  38. d16z6 rebuild ?'s
  39. All Motor Street Car......Optimal Gearing ?
  40. N/A d16z6 with integra pistons?
  41. crack stock b20b sleeve stock bore
  42. skunk 2 stage 1 users...how do u like them?
  43. help me out guys, double check- mpfi
  44. Does anybody know the NDRA rule for.....?
  45. all motor ek's(hatches)..please post up setup, whp and 1/4 mile times
  46. acl bearing thickness???
  47. CEL 20 - ELD (electrical load detector)
  48. machine shops in az?
  49. 2 Layer headgasket what do u think??
  50. cleaning bottum of valves?
  51. My CR - Please help me clarify this.
  52. Edelbrock 65mm Throttle Body worth it?
  53. B20 head on a B16 block
  54. need some info on the hytech and edlebrock header
  55. Trouble Installing Skunk 2 Intake Manifold Please Help ASAP
  56. spoon engine assembly??
  57. PR3 pistons,C1 block,35 thou milled head
  58. my turn at the f20b
  59. CTR pistons in cali... octance question
  60. shoudl i ceramic coating header myself?
  61. who's running crower 63402's?
  62. With all the TB talk goin on..........
  63. LONG, need help from cam gurus!
  64. need lsd, where and what to get?
  65. All motor tuners in the tri-state? (searched)
  66. Skunk2 Valves and Springs
  67. NA ls nonvtec
  68. Some Pics of My New Motor
  69. ctr intake cam
  70. best street tires??
  71. How much timing advance on cars w/ standalones?
  72. strength and durability: P30(JDM b16) vs. P73 pistons(JDM ITR)
  73. fuel pump for carb conversion
  74. how important is a knock sensor on a jdm b18c with stock internals?
  75. piston rings
  76. whats the benefits from going to high comp??
  77. .50 over pistons
  78. cams for 10.5:1 ls-vtec
  79. AEBS Intake Manifold plus Hondata Gasket - Qs
  80. ls crank in a b16 block???
  81. Highest compression on 92 octane?
  82. What is the highest comp. you can run on the street without having to retard the timing a crap load
  83. headgasket or mill
  84. Revisted: 215whp with Skunk stage ones. Is it possible?
  85. power numbers for JDM ITR cams in an LS/Vtec (b16 head) and b16
  86. Crower Stage 2 Cam in JDM D15B?
  87. ib motor
  88. d-series internals questions
  89. Swaping parts from ZC/D16Z6 to D16Z6/ZC
  90. Gains you've seen from head work?
  91. domed zc pistons in stock si
  92. 35 thou milled?????
  93. (Searched) Looking for a stock GSR dyno
  94. d16 block with zc pistons
  95. What is the best exhaust header?
  96. what times have you ran with 12 to 12.5/1cr
  97. good machine shops in southern wisonsin area???
  98. "Stock" C1 blocks with built head......figures...
  99. GSR cams in JDM Sir2 B16? Gains?
  100. How ADVANCED is your timing?
  101. Keihins carbs
  102. where can i find a cheap b18c1 bottom end?
  103. All Motor Head
  104. ** help machine overbored block****what can i do
  105. about my ls/vtec project!!!!
  106. ib spec ibeam rods
  107. Dyno results H22A header (header-tech)
  108. b16a tuning advice
  109. B16A1 question - About lost motion assy
  110. carbed in the crx
  111. You got a stock block gsr? what did you dyno?
  112. HKS High Power exhaust 99-00 Si!!
  113. my set up wat yah think?
  114. port and polish?
  115. Expected break-in period Q's
  116. My ctr/skunk2 IM planned setup and smog
  117. HEELP!!! LS/VTEC engine setup!!!!
  118. who has or is running kg's valve train? what will they suport?
  119. About my ls/vtec project??
  120. Anyone have K24 VTEC Experience? Need help!
  121. JDM D15 TURBO..NEED UP..SO CAL
  122. Compression questions???
  123. D-series sensors in a Type-R Manifold???
  124. Whats the difference between type-r and ls/vtec conversions????
  125. B18A Bottom End Parts List
  126. cam question - lift/duration...
  127. Max Bore Size on a B18C1, where is the line drawn for....
  128. Offical Norcal high octane/race gas spots
  129. Anyone bore TB's??
  130. Dyno Day...Its Official.....Free Dyno Run....Feb 21,2004
  131. whats the CFM numbers on a stock itr head vs. a ported head...?
  132. Do brand new ITR valve springs and retainers need to be broken in?
  133. whats the average price for this type of work?
  134. NA setup help
  135. compression low, leakdown fine...
  136. ls / vtec questions (I searched)
  137. need help improving times
  138. sensor Q
  139. V-AFC Question/Problem/ECU problem
  140. b20/vtec set up
  141. dyno time / tuning in NYC area
  142. Ported GSR intake Manifold Finished
  143. need stock 4th gen h22 header. JUN header F/S
  144. ctr cam
  145. how much HP at the Dyno???
  146. cryo vs. shotpeen?
  147. Where can I buy the Aeromotive FPR???
  148. acl bearing kit for an ls/vtec set up??
  149. anyone have the dimentions of RS sleeves for B-series and D-series?
  150. When does oem itr muffler become inefficient?
  151. toda valve springs and retainers
  152. je rings, what end gap?
  153. Jun 3's or Toda B's? Which are better cams? What will make the most power?
  154. where can i get good thick gaskets?
  155. dont know my compression ratio...any guess?(help)
  156. GOING FROM DX TRANNY TO EX!!!
  157. Camshaft PWR Band?
  158. AN-R dyno numbers
  159. ls crank in b16a
  160. b18b block and gsr head questions
  161. toda c/b18c R
  162. Je 12.5:1 pistons with oversized crower intake valves?
  163. itr or ctr cam shaft
  164. toda spec c cams
  165. What is the best standalone setup (Haltech E6K, etc...)?
  166. B16A with Toda Spec Bs...dyno
  167. Operation Red Hatch (all motor rebuild)
  168. Are Crower Crower 63402 too much for stock B16A1 head
  169. Engine Building Tips: Questions from a first timer.
  170. ls crank and rods into gsr block?
  171. CEL won't turn off
  172. Ignition Timing on a PMR 11:5 compression
  173. 200whp project/Daily driver...need a few more tips.
  174. what can i do to make my engine last more than 200 miles. lol
  175. Where to find the highest octane in N.Y.
  176. H22 INTO A 91LS TEG HELP
  177. Warming up your ALL Motor in the Cold
  178. greddy sus header for 98 gsr......?
  179. Shattered Oil Pump Gear
  180. Fastest N/A ITR on this board?
  181. ITR valves vs B16 valves
  182. how to tell if you have a lsd tranny?HELP
  183. Knock Sensor necessary?
  184. Anyone w/ Skunk2 Stage IIs Camshafts Cams in their All-Motor H22A ?
  185. ctr pistons in a ls/vtec???
  186. is 190-200 whp possible with a stock bottom end (b16a)
  187. Motor Mounts question
  188. Giving props to the ls/crvtec motors
  189. NEED HELP ASAP!
  190. B20 VTEC power output w/ITR head
  191. Best LS/VTEC combination?
  192. 3 OR 5 angle valve job??
  193. Comptech USA World Challenge Engines for sale B18C5 and B20B
  194. I need some source sites for my senior project....help!!
  195. what rods do you guys like for NA?
  196. TODA V-Tec Killer Camshafts
  197. B20 block, GSR crank, GSR rods, B20 pistons???
  198. skunk2 stg2 cams & clearance
  199. Sound clips, where can I find them?
  200. survey on a motor ... what a jdm gsr in my 98 ek .... what are your thoughts
  201. help...TWM individual TB
  202. Ported Head Gains????
  203. gsr intake manifold
  204. ignition timming need help
  205. Dynomax HIflow cats, are they as good as carsound ???
  206. what will my CR be?
  207. 99-00 Civic SI Owners!!!!
  208. QUESTION ABOUT QUAIFE LSD
  209. rod bearing clearence
  210. skunk 2 stage 3 cams
  211. ITR Crank, CTR Pistons compatable w/ stock LS rods...
  212. roller rockers?
  213. how to saving weitgh on a 4 door civic 92
  214. 3 angle valve job -- What exactly is done? Is it beneficial?
  215. reviews on balanced performance and their tuning
  216. ls/vtec valve relief clearance on stock pistons ??
  217. Fuel Filter?
  218. yet another compression ratio question
  219. Gude Camshafts??
  220. engine lube?
  221. Pistons, need advice for whats best for my setup
  222. SI-R2 cams
  223. Will a Y8 IM perfectly swap to a D16Z6?
  224. How much milling can I do with 403's?
  225. Cam Profiles on B16A1 question.
  226. What should I do next?
  227. Need 40 DCOE Carbs
  228. What should i do next?
  229. High CR pistons - Toda, Wiseco....
  230. Question about ITB's and fuel mixture.
  231. Help! Need to know a few things before Toda A's go in my B18C1
  232. gsr head on b16 block
  233. its a good set-up???
  234. Piston to valve, will this work? Also compression gains from milling Q's
  235. 200hp b16 project?
  236. Standard rebuild (rings, bearings, gaskets, etc.) costs for a D15B7
  237. H22 STROKER KIT RELIABLE?
  238. new to all motor need help
  239. H22 w/ type S valve clearance question
  240. okay motor prob and dyno tuning???
  241. help with my new ls/vtec setup
  242. B16A2 bottom end, JDM GSR head.
  243. b16a2 long block
  244. Custom Race Header for Nissan Sentra Spec V.....?
  245. What is port cross section
  246. CRVtec rods
  247. NEED New main and rod bearing info...
  248. best block guard for my b20/vtec?
  249. Is two mufflers hurting me that bad??
  250. Q's about getting the Edelbrock Header IB mod done locally.....
