PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. B16 head with a GSR block
  2. Head to match bottom end??
  3. JDM D15B & Y8 Head loosing power.
  4. Oil Catch Can question
  5. Starting a new build, and had a Q
  6. Bore Gauges
  7. B17 Rebuild, Clearances??
  8. Pics of Replica header beside Skunk2 header
  9. Leaky Injectors.
  10. stock fuel pump on ls/vtec
  11. b18 issue btwn 3000-3500 rpm
  12. Blox competition series HSL cam?
  13. Blox type B questions
  14. b18c1 head,b16 block,b16 tranny.How much power?
  15. Oil overfill, how much is too much? B16A2
  16. Dailing in cams: Equipment
  17. gsr with ls internals.....what pistons?
  18. Can I do a ITB build with Water Injection?
  19. Mugen Replica Header
  20. rebuilding b18b and broke! got a question
  21. worth building a d16y8?
  22. oil question
  23. OEM headgasket on bored out engine?
  24. obd0 tuning
  25. Is My Fuel Pump Dying?
  26. Skunk2 header or rmf narrow knock off????
  27. OBX ITBs
  28. LSVTEC knocking noises!?
  29. honda-tech is closing down!!!
  30. all motor d16z6
  31. Got some goodies today!!!!
  32. nippon h22 type s pistons
  33. Milling head
  34. B18b swap done, FITV coolant hose problem, help!
  35. b16 block with gsr head?
  36. ls/vtec and b16b pistons????
  37. Pm7 in d15 mini me????
  38. Help!!! Timing issue!
  39. which is better all motor or turbo
  40. Lost PM's
  41. Machine shop recomendations.....NY prefered
  42. Extrude hone injectors
  43. Building a poor mans type r
  44. B16 build opinions
  45. stock injectors?
  46. having problems with oil/smoke from tailpipe
  47. 310s Not big enough?
  48. N/A spark plug gap
  49. B16B with LS crank and...
  50. GSR Build. Does it sound good
  51. what retainers should i use?
  52. d16 head question
  53. injector help
  54. h22a torque specs
  55. D-series build...
  56. b16 head question
  57. BBQ heat paint on header?
  58. Got the motor in my crx today!
  59. So I decided to build a flowbench
  60. need to identify a head
  61. LS short block, need some advice!
  62. Looking for advice for B18A1 Head Build
  63. Help me id this header!!!
  64. h22 thrust washer damage?
  65. skunk2 cams???
  66. 12.4 to 12.5:1 CR question
  67. Valve Spring Compressor
  68. poormans type r cams??
  69. HELP: B18B Fix It or Leave It
  70. is anyone using these????????
  71. Camshaft identification help!!
  72. Cam shaft cap bolts??
  73. Code 9 question and suggestions on next step (All motor JDM B16A CRX)
  74. honda oem injector question
  75. compression test question
  76. Buddyclub B-series racing spec header
  77. ATS 4.928 final drive in GSR tranny
  78. skunk2 knock off cams????
  79. intakes
  80. throttle body?
  81. Post your Highend header #'s/Builds
  82. best power adders?
  83. my gsr rebuild
  84. buddy club spec v identification markings?
  85. Valve Seals and SMOKING?
  86. IM vacuum vs. TB sizing?
  87. ctr pistons in gsr block
  88. oil problems
  89. hMMM?? IS MY MOTOR CoNfUsED?
  90. h2d i installed for a customer
  91. usdm b16a2 vs b16
  92. what is the best FR pressure for skunk2 fuel rail?
  93. skunk2 tuner series?
  94. Nitrous with stock rods
  95. stock b20 swap using oil=crankcase pressure?
  96. Help! need spec sheet for TODA SPEC A's
  97. b20 engine problems
  98. decking/resurfacing block question
  99. referred to N/A... best head setup
  100. How to control IAT's
  101. front mail seal r&r how do I get crank pulley off
  102. CEL help!
  103. Time sert vs Heli Coil
  104. B16B Pistons in a VTi?
  105. Single layer head gasket help
  106. No PCV system? WTF?
  107. Intake and Exhaust question!
  108. This intake gasket doesnt look right to me at all
  109. knock in b16a head
  110. boost or NA
  111. is it fair to say h22a euro R is compairable to k20a2
  112. all motor ls build for dd hatch
  113. King motorsports super b16???
  114. b20 v-tech
  115. b16a camnsahft degreeing
  116. Bubby Club/K20-R
  117. Valve to valve clearence writeup ?
  118. integras with h22a
  119. b18c5 all motor or turbo?
  120. Ls-vtec, my build?
  121. Should I Take Apart My Engine?
  122. RSX TYPE S INJECTORS modified rsx clips in a BSERIES?????
  123. need to get crank micro polished
  124. 1.9l b16a
  125. Should I rebuild my B17?
  126. 2.0L GSR smogability queston for the CA guys
  127. Exospeed B18A/B LS909 (Stage 2) regrind camshaft
  128. Victor X, When do you need it?
  129. Direct Injection and the Future of Honda
  130. Best Header Clearance?
  131. Got a new LS crankshaft... Grooves on oil pump journal and main seal journal?
  132. Itb install question
  133. *Need Verification on Ring Gaps before final assembly -- Engine Builders Chime In!*
  134. ITB's
  135. Ask for B20 build
  136. questions about break-in
  137. LS solid rocker assembly?
  138. stiff motor mounts=vibration=knock sensor retarding the timing?
  139. info on GSR Cams??
  140. blox c cams
  141. Anyone else installed skunk2's new header?
  142. Anyone else installed skunk2's new header?
  143. turbo cams in a n/a lsvtec
  144. mini me swap question
  145. 200HP build...what do I need?
  146. itr pistons on ls rods?
  147. Header Choice?
  148. skunk2 stage 1 tuner cams
  149. B18c block
  150. Hytech Tri-Y Replica Cleareance
  151. secrets or advice on motor assembly?
  152. TODA Cam Gears
  153. B20 non vtec piston ?
  154. torque specs
  155. Dilemma Again
  156. what oil is everyone using
  157. Blox vs BPi Velocity Stacks
  158. Crx with B18a1?
  159. Buddy club Spec 4 cams for B16a in DD.. good idea?
  160. OBD1 Vs OBD2 Oil pump on a OBD1 block-
  161. B16a oil pump vs GSR oil pump
  162. Anyone running a Edelbrock Performer X intake manifold?
  163. First build
  164. K20 Type R Build
  165. ctr cams in factory ls-v
  166. Quite a few questions... GSR Block LS Crank what bearings?
  167. Swap from a d15b7 to a d16a on a del sol...
  168. how long did your b20 vtec last you?
  169. best pistons for a b16a
  170. What is making that sound? GSR motor blown?
  171. Gsr vtec problems
  172. blown gsr!! HELP
  173. oil pressure sending unit
  174. How strong are the bottom ends?
  175. OEM v. Aftermarket valves- wear
  176. Resonably priced 68mm TB who has them?
  177. Piston to Valve Clearance in a k20?
  178. Mis shift, 11,000RPM hmmmm.
  179. Tuning with adj. FPR?
  180. ? On Bore/Stroke for B16 Stroker Project
  181. K20-R build problem, HELP
  182. cylinder out of round?
  183. intake manifold question
  184. gsr bottom end rebuild.
  185. my b18 build up...i need help
  186. my b18 build up...i need help
  187. what [istons should i choose
  188. Spark Plug Wires
  189. Compression required for a Breather kit?
  190. B18b Rod Knock.. Questions about rebuild.
  191. Which OEM cam gears are compatible with CTR cams?
  192. valve keeper question
  193. d16y7 top end to a crx 1.6lzc motor
  194. Engine Drawing Vacuum at "High" RPM?
  195. Weisco Ring Compressor Question
  196. installing injectors grommets?
  197. how to make block look new???
  198. i need answers on a ls build
  199. Stiff motor mounts and engine life
  200. B16a bad rod bearings/crankshaft bearings?? How to replace??
  201. best flywheel for my b16a2
  202. Acl engine bearing ?????
  203. notched b20z2 valve reliefs (pic request)
  204. h23vtec compression test results
  205. Low End Rebuild.
  206. open header??
  207. Valve adjustment for Exospeed SR909 Camshaft?
  208. Fitting breather tank to NA b series
  209. gsr with p30 pistons build (mild build)
  210. low fuel pressure running lean HELP!
  211. d16z6 rebuild
  212. Port & polished/ head work
  213. 1.8L ls vtec
  214. How a Four-Stroke Engine Works
  215. Tested our header on Chunkys Car
  216. Did you know toyota builds a better N/A 4cylinder?
  217. b16 help !!!
  218. b17 build questions pics!!
  219. Graphs before and after catch can install
  220. oil catch can
  221. Trackspeedracing.com any experience??
  222. starting lsvtec build!
  223. ls motor
  224. What cams are these copies of? (specs inside)
  225. Help with type r valve springs
  226. b20vtec question
  227. S2p2 vs s2p1
  228. My friend is having some wierd problems...need help.
  229. B16 Throttle body on d16z6
  230. Quick Settings for Cam Gears on S2P2
  231. h22a wit k20a CAMS
  232. @@@ Does an OBD1 USDM P30 ECU have a knock sensor ?? @@@ HELP !!!!!
  233. Port & Polish Intake Manifold?
  234. What Engine mounts?
  235. Ever heard of Lightspeed parts?
  236. All motor know it alls
  237. 89mm crank in b18c5 good or bad idea?
  238. Any experiance with JG Edelbrock Header?
  239. H2B what tranny best to use????
  240. Help!! Smoke on fresh build.
  241. D16z6 build, need advice!
  242. Stamping on my motor?? B16A(WIN)
  243. Help! Ebay'd Again!
  244. Formula One v. Nascar engine
  245. b16b stroke to 1.8L
  246. Alpina B7 BiTurbo based on the Bmw 7-Series
  247. Brian Crower Stage 2 cams CRACK?
  248. anyone using crane 101-0012 "stage 1" cams in their non-vtec setup?
  249. I know this is a honda forum, but anyone build other NA motors?
  250. shaved head ???
