PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 [163] 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Where to buy porting supplies?
  2. diff between jdm and usdm GSR?
  3. coil on plug?
  4. need pic of the skunk2 stage 1 cams PLEASE HELP!!!
  5. Question on TYPE S piston
  6. best 2.1 all motor cams?
  7. RMF Headers new location
  8. rare B17a1 ??????????
  9. Vids: H22 with ITBs
  10. finding a motor
  11. where's 1mm on this dial gauge
  12. rev.....
  13. LS-VTEC getting no spark?
  14. head gasket leak....
  15. ctr n1 crank pulley ?'s
  16. How loud are your forged internals?
  17. How do you retard timing?
  18. shops known for cylder head repairs!!!???
  19. what's my compression... and valve clearance?
  20. United Bimmer
  21. anyone ever adapted a B16 manifold to fit a gsR??
  22. b16a mugen header on b18c1?
  23. LS setup
  24. How to identify different B-series heads???
  25. toda spec b fs skunk 2 stage 2
  26. Best way for most power...ideas?
  27. b16b stroker need help
  28. Dumb question on torqueing the head
  29. Are the new Skunk2 Pro1 cams really a stage 1?
  30. ctr in a b18b
  31. What would you do?
  32. Another bc4 valvetrain Thread
  33. B20a//B18b
  34. H22 Engine All Motor Parts
  35. What pistons to use????
  36. cutting collector on my greddy headers...
  37. is greddy a good header for my setup?
  38. what can you get your car tuned with?
  39. SMSP 1 Piece 4-2-1 vs Greddy Stainless On A Built LSVTEC
  40. B16 All motor in 91 si.
  41. just curious about stock motor HPs
  42. AEBS mani causing EACV coolant leak??
  43. Using just one adj. cam gear on the intake cam???
  44. Need dyno chart for stock '89 1.5l
  45. underdrive pulleys and tuning...
  46. nOOb tuning question.
  47. Anyone who has bought engine/trans from hmotorsonline...
  48. toda spec b cams anyone using theese
  49. B16 Blow Up On ITB's
  50. Very small coolant coonsumption issue
  51. ::having problems with my TWM itb's::NEED HELP! 56k maybe
  52. Swap help?
  53. cams 4 k24????
  54. vtec only works when car is hot
  55. What is the most power made without removing the head?
  56. ITBS PORTFLOW portmatch ???S
  57. Dyno numbers on the new b18c1
  58. Would i be able to use Jun3 cams for my set up !!
  59. Why is my cars RPM is to High
  60. 12s stock block b16?
  61. engine problem (84mm high cr) lots of white smoke super loss of power
  62. Edelbrock question.
  63. name this cam/valvetrain
  64. Stock head flow...
  65. all motor hp...
  66. Piston's Piston's Piston's...helpp mee.
  67. rmf
  68. HELP NO SPARK
  69. can i hit 180hp???
  70. Need help, tried everything! Bogging, doesn't go past 2400 rpm
  71. 300bhp F20C n/a...ideas?
  72. 94 vtech head on 96
  73. How many quarts of oil for b20vtec oil change?
  74. 11.5.1 cp in b20
  75. who can burn me a stock p30 chip?
  76. lsvtec vs. poormans type r
  77. all motor problem
  78. ls/vtec
  79. car shake
  80. any tuners willing/planning to come to hawaii anytime soon?
  81. people with experience with zex 109300 or 59300 cam
  82. do i need to get tuned?
  83. port flow valve springs
  84. for those with aftermarket coils.
  85. Engine swap
  86. what next????......
  87. EDELBROCK 1 PIECE PRO FLOW HEADER
  88. LS/VTEC Crazy James Bond Smoke Screen - What to Look At?
  89. best budget 4-1 header whats your opinion
  90. b16a2 head on b18c1....advantages?
  91. HEAD SWAP GONE WRONG ANY HELP APPRECIATED!!!!
  92. Narrowband AFR Tuning LSVTEC
  93. hoh high should i rev on this setup
  94. built motor boys - at what point are you ditching the 2.5" exhausts and going bigger?
  95. Dyno Results: Weapon R (HyTech Knockoff) vs DTR 2L vs SMS 1 Piece Mild Steel
  96. ITR Cams Difference
  97. transmission - 1990 honda
  98. 2 layer headgasket??
  99. Long hybrid header folks & b-pipe questions...
  100. b16b vs itr cylinder head
  101. ENGINE WIRE HARNESS
  102. Oil Consumption questions/poll...please look.
  103. how do i get more power for my 1st gear
  104. rocket valvetrain/cams question
  105. B16 Build
  106. ls/vtec question
  107. more hp for my gsr ??'s inside
  108. Tuners in central TX, that are good with NA and Hondata
  109. All Motor Header that makes power between 4500-7500, not just TOP END
  110. Can somone answer these questions?
  111. Compression combination
  112. tranny lsd question
  113. Undercamming?
  114. looking for newest uberdata upgrade
  115. So anybody know where Kteller went?
  116. breaking in a new motor
  117. zc engine - '90 honda civis si
  118. NJ vs NY-All Motor Run
  119. h22 injector recommendations...
  120. Are my injectors enough????
  121. headgasket question?
  122. My new ITBs. How to use filter(s)?
  123. what kind of numbers with this setup
  124. NUMBER for Rs machines or Bisi ERz?
  125. Do I sound set to take on this install?
  126. good numbers b16 and dyno video inside
  127. A FEW ALL MOTOR QUESTIONS?
  128. How Do i connect the vtec on my swapped engine
  129. Which EPROM burner for CROME?
  130. Need HELP! MAGNAFLOW OR FLOWMASTER EXHAUST?!?!
  131. what power does everyone think ill make?
  132. Supreme Record breaking H22 build....
  133. AF gauge gone wack! WTF
  134. oem plug wires or aftermarket?
  135. Intake Manifold....
  136. LSVTEC Build
  137. gsr or ls or b20/vtec???
  138. type r head on gsr block HELP!
  139. ALL MOTOR B16
  140. Type R cams on GSR Valve Train?!?!?!?!!?
  141. can i use a auto starter on a manual trans?
  142. greddy headers... keep em?
  143. B20 Crankcase Ventilation
  144. looking for a good shop
  145. Need help
  146. need help on my timing belt
  147. How to build a B20 VTEC
  148. built block what next?
  149. b18c1 rebuild question on head work...
  150. zc or z6 rods
  151. valve springs retainers
  152. Reasons for valves to be bent?
  153. a few mini me questions please help
  154. tuning
  155. 2.5" > 2.36" bottleneck. Should I be concerned?
  156. CTR cam from Hmotorsonline.com?
  157. Plasticgauge - Where to buy it?
  158. The New 5Zigen Header and reviews or anything??!?!
  159. S2000 Video With ITB's
  160. Import builders head
  161. DPR valvetrain yay or nay
  162. anyone have info on bike ITBs
  163. What cams for my b18c
  164. lsvtec
  165. what are the engine specs for a '91 crx si (german spec)?
  166. b16 and b18c1 question
  167. ECU's for high compression motors
  168. VTEC Questions
  169. where's that damn vacuum port tester thingy link/ pics?
  170. clutch masters stage 3 disk, made by exedy?
  171. Simple thread: Free CRX, best bang-for-the-buck motor setup?
  172. wheres a good place to buy Hondata?
  173. Oil pressure Issues.
  174. skunk 2 stage 2 vs pro 1
  175. Buddy Club stage 3's
  176. b20vtec vs. lsvtec
  177. will the d15b7 valve springs hold the d16a6 cam and 7200 rpm?
  178. Broken header bolt inside head...problem?
  179. Need advice on H22 build
  180. AFR street tuning all motor
  181. Spark Plug Wires?
  182. Hybird H22a Civic
  183. Installation of Skunk2 IM
  184. jdm gsr build up
  185. Is it normal for my oil to be this low?
  186. Let's get FLASHED!!!
  187. rising idle?
  188. Exhaust Question: Don't really know where else to post this...
  189. h22a header(search)
  190. computer for b16
  191. All motor B vs Turbo VIDEO
  192. timeing vs horsepower
  193. Lets talk about the gsr head!
  194. little oil leak on headgasket by vtec solenoid
  195. shave 1mm off rods for CTR pistons?
  196. LsVtec...i need more hp!!!!
  197. Can somone answer these questions?
  198. Throttle body question
  199. Battery light flashing when in Vtec???
  200. who has oem pistons in stock i cant find them!!!
  201. LSVTEC Redline
  202. OBD1 DOHC ZC HELP PLEASE!!!!
  203. Crower 403's or 404's?
  204. Slow, very slow?
  205. Buying on a budget. No brand names, just my knowledge to guide me.
  206. Is this normal? How much engine oil do u burn with a new motor?
  207. b17 problems
  208. toda itb's + gsr head?
  209. ZC vs. D16A1 integra cylinder heads
  210. gsr block /ls head
  211. WHAT GIVES BETTER HEAD..... POTENTIAL B16A OR THE B18C
  212. Anybody running anything other than recommended lash (.008") with toda cams?
  213. short ram for b18c suggestions
  214. quick question about a comptech header
  215. Installed crower 402s why is it so hard to turn the camshaft?
  216. recommend me final touches...and why?
  217. burning oil on 2.0l b18c with forged internals
  218. CTR cams in a JDM GSR?
  219. Apex'I AFC
  220. Cut Valve Guides and RS Machines Port Work
  221. LS build
  222. Engine Knocking??!?!
  223. performance crankshaft
  224. CRVtec B20/GSR build. Water leaking. HELP.
  225. Best cams for my setup...........
  226. How do you tell stock cams between performance cams visually
  227. Engine Builders, What are you gapping the rings at?
  228. Need immediatte help with ZC motor
  229. large 2.1 liter intake manifold ?¿
  230. Can going with a aftermarket valvetrain with stock cams make you lose horsepower?
  231. ITB's OR Dual carbs?? which would be better 4 my setup?
  232. Code 43
  233. new build plan let me know what ya think
  234. where to find carb setup for Sohc crx
  235. over heating problem.....
  236. cams in b20 - wont idle
  237. Clutch/Flywheel Setup H22
  238. D17 Crank in a D16Y8?
  239. PLEASE HELP ASAP: timing belt replacement and check afterwards
  240. B20vtec issues w/ timing belt...
  241. Any changes in flow patterns with flat faced valaves?
  242. Building a B18C1...Suggestions?
  243. SKUNK2 intake manifold?
  244. ITR valves and retainers on a b16a2 head with ITR cams
  245. need help!!!!! LOOK!!!!
  246. Muffler question...
  247. what pistons to get?
  248. B18 PR4-1 PR4-4 which years?
  249. just a funny quote i was reading from importreview.com
  250. how do i break it in?
