PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. best size itb size for built 300+hp h2b?
  2. B18 All Motor combination
  3. Which H Series Block Would Be Best For ALL Motor? Planing To Do H2B
  4. 2000 B18c1 ECU Question
  5. B20 Vtec/GSR stroker/95mm TODA B CAMS vs Crower 62404 Non Vtec Cams
  6. Can this be saved
  7. need help choosing right bore size for my b16a n/a build!!
  8. I need a second opinion on CTR cams
  9. B18 ls/vtec build help
  10. high comp z6
  11. Fresh b18c gsr build. Need advise.
  12. Em2 starting problems
  13. help toda cams.? how to knoe they are in good conditon
  14. h22 Euro-R
  15. do I need to change piston rings?
  16. Header thoughts for moderate B20V build?
  17. B18c1 all motor build
  18. Port and Polish Question. Do I grind this down?
  19. ATI damper question
  20. Fresh build. B18c gsr. Start up and oil pouring oil.
  21. Starter not responding no start no crank!
  22. Build D16 for SCCA Street Prepared
  23. gsr 215 whp goal?
  24. B18c-r compression
  25. B18c timing not aligning???
  26. B18c Build
  27. witch tranny to use
  28. TWM Itbīs for B20v ?
  29. B18C1 GSR VTEC ENGAGEMENT BLOX IM
  30. S4C viscous LSD (SI) vs S4C Helical LSD (CTR).....
  31. Decision to go either 82 or 83mm
  32. B16 allmotor build on ef9
  33. B20b4 with 270k on it
  34. How To Make An All Motor H2B Swap???
  35. How to make an all motor b16a2?
  36. Skunk2 pro 2/3cams stroker 92mm b-series?
  37. 96 civic hx project
  38. Difference from a B16 and a B18 tranny.
  39. b16 things and stuff
  40. balance shafts for road racing
  41. B20 VTEC -- Replaced lma's, lost vtec
  42. Need help with gsr vtec
  43. Disect my build
  44. Merited TB size?
  45. 82x89mm lsvtec finally back together
  46. Screeching cam horror
  47. B Series motor for 4.9 final drive?
  48. BFG G Force drag radials or M/ T et Street radial radios
  49. New D16A1???? Questions & Help
  50. Help with Crower cams replica
  51. B18c + BC stage 3 cams
  52. ignition timing and hondata s300.. help required
  53. B18b Idea's
  54. High flow cat size and placement on K20
  55. NA B20Vtec build
  56. Help choose a upgrade : Cams vs Intake
  57. GSR with B16 head
  58. help identify valves
  59. What comp pistons for a b18b with b16a head...95mm stroker kit
  60. B16a idle fluctuation problem
  61. f23a1/f22 head
  62. b series valves weight
  63. All Motor wagon looking to update setup
  64. what to build b18 vs b20
  65. Cams : B16A VS B18C GSR
  66. S2 ultra street Mani, IACV bypass on TB help
  67. B16 OIL GALLEY PLUGS,
  68. Plan -> D14A1 to hybrid d16
  69. Anyone willing to cut a ctr/pct piston in half ???
  70. B18b1 ALL motor build questions
  71. Fuel Pressure Regulator?
  72. best cams and headers for me??
  73. cutting it close
  74. Pistons pins for 300whp
  75. coolant temp higher than normal with heater bypass
  76. Velocity stack
  77. 300 whp
  78. rocker arm wear
  79. 2.2 l enginew
  80. EF swap idle extremely rich, poor mgp
  81. cam holder dowel pins...?
  82. Supertech Pistons
  83. 2.0L Bore b18a1 High Comp pistons?
  84. skunk2 manifold with blox tb...install questionn
  85. sohc questions please help me out
  86. ZC D16a6 clearence
  87. Need specs on a D16Z1 multi port engine in a 1992 civic hatch vx model.
  88. BEST STROKER SET UP
  89. B18c Issue... Tired of it!
  90. valve seals.
  91. b18c vs k24
  92. d16z6 to b16a swap
  93. Torque specs for B20V
  94. Toda piston rings
  95. cat vs hi flow cat vs testpipe is it worth it ?
  96. problems after installing skunk2 im and tb.
  97. H22 cross section of the ports
  98. D15b rebuild help!
  99. DD/Drag B20V build
  100. D16z6 Cam Shaft won't stay at TDC
  101. Should I port/polish my S2 Ultra before install?
  102. help.
  103. Looking for Brake Specific Fuel Consumption (BSFC) curve for D16Y8
  104. P3f valve reliefs with p8r head
  105. identify my cams
  106. b20v
  107. Noise in/above cylinder 1 high compression GSR
  108. Professional Products Dampener
  109. All motor vs forced induction
  110. EF H22_WEIRD vtec
  111. gsr rod bearing question (ACL RACE)
  112. h22 vs h23 headgasket? -kind of complicated inside!
  113. DDTech vs Skunk2 B-series \ Hybridworks
  114. ls/v motor help
  115. I/H/E max performance...
  116. Pro2's with Super tech valves and valve springs?
  117. all motor b serie help
  118. performance chips '08 Accord 4 cyl
  119. expected numbers or further ideas before getting ready for dyno 82x87.2
  120. Skunk2 pro 1/2+ cams - too big for b18c?
  121. 240 HP all motor h22??
  122. Just how ridiculous is 13:1CR B20?
  123. Help me to get info about my K20A2
  124. hondata cpr issue
  125. Skunk2 ultra street 74mm???
  126. Best na header
  127. B-series experts, wanna build my own.
  128. B16A high compression
  129. b16b rebuild
  130. No o2 sensors cause loss in power?
  131. 01 prelude fuel pressure
  132. Ls/vtec running issues
  133. LS-VTEC TURBO BUILD w/pics
  134. Anyone Looking for a Real RMF Drag Header.
  135. Why are my cam seals leaking?
  136. looking for more power for my b16b
  137. Pacesetter ceramic header
  138. b18c4 engine b16b pistons ?
  139. What is my b18c1 worth?
  140. Reusing stock wrist pins
  141. What happended to my cylinder wall!
  142. Looking to Add More Power to LSVTEC
  143. B18c6 civic from hungary
  144. NEWBY here with qurstions about a prelude motor interchange
  145. EM1 B16A2 N/A
  146. D15B upgrades?
  147. b20
  148. Spluttering/chugging/struggling at low revs
  149. DDtech Cam vs Skunk2 Pro1 H series /TURBOGIXXER TUNING
  150. MAP sesnsor diagnostics
  151. Gsr Ctr pistons b16 head
  152. My Simple Bolt - on K series Dyno Graph
  153. B20 with gsr head build advice needed
  154. Cam and header help
  155. B18A1 dyno with I/H/E/pulley lays down 148WHP?!
  156. B16a2 o2 help
  157. P73 ported intake vs VictorX
  158. LS/V won't start, NEED HELP (Pics)
  159. My B16A build. Looking for knowledge/advice
  160. help me . . . .
  161. F20b swap in a DC2?
  162. Stock D16z6 build for n/a need help
  163. Question For Non Vtec Guys
  164. Nippon Racing Pistons, size and p2w questions.
  165. 97 Civic EX with JDM ITR B18C burning oil during VTEC
  166. B18C JDM ITR burning oil during VTEC
  167. Can't time B20Z2 motor
  168. S2 "street" ultra series...where does stuff connect!
  169. STILL have ?'s regarding balance shaft removal!
  170. Fresh B16 consumes oil on decel
  171. H2B here we come !!!
  172. ring gaps
  173. Vtec complications. Need help bad
  174. Thinking about going bigger in my autoX car from my B18C1
  175. G23vtec build help
  176. Header test: PLM 4-2-1 versus PLM 4-1 Megaphone, K24
  177. best high compression pistons for d series
  178. Oil pump timing required?
  179. Skunk2 H22 manifold injector/rail problems
  180. h22 rod options.
  181. B18 stroker kit
  182. P.R.E. 84.25X89 Stock port/sleeve B20V Dyno
  183. B16 project "lowballer"
  184. Need help with itr throttle cable
  185. Oil Galley plug on a b20v
  186. can carb'd civic run without o2 sensor?
  187. eg hatch d16z6 swap, few questions
  188. Advice for hondata s300 or stock ecu
  189. Whats the highest hp record for k20
  190. EG6 B20/VTEC head 252Whp 189lft/lbs Tq
  191. bad bearings?
  192. Rebuilt b18c1 won't start but back fires
  193. b20vtec ITB misfire
  194. experts please help.
  195. K24 Nippon Racing Pistons. Do the wrist pins fit stock rods? Ans: Yes
  196. Need help with skunk2 manifold
  197. Toda B camshafts + extras (?) for my 2001 DC2R
  198. Timing Belt
  199. 3 layer & 2 layer head gaskets
  200. how to recognize a Type R cam
  201. play in the oil pump gear?
  202. Going GSR
  203. piston rings?
  204. H2B Reverse head CRX
  205. need some help on GSR build
  206. gsr ferrea/skunk2 valvetrain questions
  207. lsv with po6 on b16 tune. need help
  208. f23 block/f22a head
  209. EF civic CAI on DA Integra
  210. B20b4 upgrades
  211. Oil light staying on longer than normal @ startup
  212. I have a 5th gen h22a4 JDM Vtec Engine. Serious question here.
  213. b18 rebuild question
  214. Bought and rebuilding a b18c1. Info would be awesome.
  215. Ultra street manifold install
  216. Trying to figure out what head gasket I need
  217. Gsr cam install.
  218. Gsr main bearings
  219. 2000 si b16a2 head work?
  220. Slow oil pressure build up?
  221. B20 misfire plz help
  222. H22a euro R N/A project
  223. cams, valves, pistons questions
  224. stock vs aftermarket keepers/locks
  225. Which Motor should I get? - B20 (HiComp) v B20 (p8r)
  226. Fuel rail/inlet manifold question
  227. q and a
  228. B18c gsr, end cam cap bolt busted!!!
  229. twin disc overkill for 240+ hp
  230. Simple tricks to free up HP
  231. Need advise to lower compression (all motor B20, well built)
  232. P72 GSR piston compression?
  233. 2000 Civic Ex Power steering pump
  234. Are those real JUN Type 3 or Fake?
  235. b20v crankcase ventilation question
  236. B18C Full Build Complete - GSC power division cams Dynoed
  237. B18b All Motor Build need opinions
  238. evans tuning, cam installation method
  239. H2b or f2b ?
  240. d16y7 throttle body options
  241. rods for ls/vtec build
  242. Stock Valvetrain on Skunk2 Tuner Stage 2 Camshafts
  243. Do I need new head bolts
  244. quick question before i dyno
  245. Identify Tuner 2 Skunk cams
  246. b16a2 200+ hp any ideas?
  247. intake manifold question
  248. Parts List?
  249. Does a bolt go here next to the tensioner?!?!?!?
  250. How do I upgrade my injectors.
