- PLEASE HELP. ITR cams make more power than Skunk2Stage2. Whats WRONG
- Pop quiz..(searched)
- some bearing questions for a first time engine builder...
- spec 4 cams in a gsr. need valvtrain advice!
- New Project-All motor guru's please help
- Rebuild my lsvtec monster or go k
- 440cc injectors
- how safe if oil squiter is block on a stock gsr block?
- Stock B flywheel weight deduction
- Z10 Girdle, YES or NO? ---> LS/VTEC already built and running. Should I add a girdle?
- LS crank to go into GSR. straight drop in?
- Dollar for dollar the best horsepower for $5000?
- Reviews on this exhaust?
- Piston Pin Installation & Removal Help - JINOTIQ...
- 300WHP Achieved!
- Where to find needed valve train parts
- looking for info on jdm 16 a and jdm 16 b
- Collecting parts for a B18C5 N/A build. Feedback appreciated.
- blox velocity stack vs. bpi velocity stack
- HELP...black Carbon Fouled spark plug
- n/a noob question:
- H22A low power
- eg gsr build
- Trouble with a fully built ITR
- Low budget build
- what head to use
- tb size question
- Junk or Not?
- Needs inputs and advice on my N/A build and suggestions
- cam gear settings...
- blow by smoking
- block sleeving????
- Copper head gasket?
- FS: jdm b20b sleeved block
- Civic exhausts
- buddy club spec IV gsr build questions...
- Help with install injectors n fuel rail please
- motor build and questions
- How to decarbonize a 89' B16a Head
- noobs first build HELP!!!!
- So my motor is almost ready to go..........want your opinions.
- Throttle Body cable, need help asap!
- VTEC only setup for street use? VTEC mechanical issue
- Help educate me, pulled my head (Pic's Included)
- Where to buy angled defouler?
- Fastest all motor cars!?!?!?!?!
- Vtec Problem [HELP]
- Oil... does it go bad??
- Taiwanese Header Showdown!- TDM Hyech Big Tube Copy vs. Spark Racing SMSP Copy
- WIRING FOR A AUTO VTEC
- Ist Gen B16A vs 2nd Gen B16 Need some clarification
- CALLING INTEGRA OWNERS WITH ENDYN catcahcan setup where's your located
- best crank for h22?
- Toda Spec C or Jun 3 cams?
- I got a problem with my gsr
- 89x85 Project: Latest numbers
- Extended Manifold studs?
- mild lsvtec build
- ***Dark's All-Motor Build*** Work always in progress
- D16a with z6 head?
- Bisimoto
- crower stage1 vs. skunk2 stage 1 cams
- Will the intake valve out of a D15B7 fit and work in a D16Y8
- Is it possible to mill the primary lobes of a skunk2 pro I cam???
- Couple Questions Before Freshening Up?!
- anyone used phearable.net? good or bad?
- How important is Zinc content in motor oil?
- higher vtec cross over?
- 3 puck clutch is it good for everyday car
- powersteering belt on b20vtec
- HELP! Need socket size for Golden Eagle head stud nuts!
- Crower issues.
- ls/vtec wit blox hsl !
- header question
- Are b series vtec and non-vtec valve springs and retainers the same?
- cooling help please..
- Stock head bolts vs. ARP head studs
- itbs and overkill
- NEED HELP ASAP
- Exotic Piston-Rod Combo: High End Pieces
- 9,000rpm b16a... Suggestions on Head Work??
- Hi-Milers! How Many Miles does your Engine have on it ?
- How Many Miles can 4 Cyliner Honda Engines Go... ???
- ls vtec allll the info
- B16 motor fried.
- horror stories with eagle crank's.
- crankshaft
- WAT WUD BE BETTER ON MY B17 A B16A OR B16A2
- GSR block build help
- b16 in 94 civic dx
- exhaust opinion
- b20vtec overheating
- When using nippon piston rings, Is "N" the marking for up?
- B16A Head Package Choice
- Bolt-on Euro-R H22 dyno results (194/148 SAE)
- CRX track times
- how long can you keep engine oil for?
- B20 Header?
- Ti retainer Diameter? pic inside.
- B16 dizzy/ls head?
- Spoon Ventuli Plate?
- porting intake side on all motor B16a bad?
- question ITR tranny
- Lobing from 1100 to 2500 and rev limit issue
- starting from basics
- k series monster updates?
- help with allmotor ls
- Whats the best CAMShaft on THe market??
- Brian Crower vs pocketrocketsracing stroker kit??
- block guard question
- b18b1 two questions for build gurus
- rocker arm shaft removal b16
- header info needed please
- B18C1 Cam Caps
- y7 higher revs?
- Identify these cams?
- need help skunk2 setup
- Highest compression on 91 octane?
- resurfaceing a head
- what cams?
- another CAM MY SETUP thread 1.8l goodness :)
- Can i use a 96-98 EX TB cable for a Bseries swap?
- Surging idle after new tune..Running threw the steps.
- Finally cranked my ls/v ::video::
- Last resort. Oil consumption issues....
- spark header anyone have info on it?
- Help with ALL MOTOR setup
- Main Bearing Woes...
- my setup, question?
- Factory Honda- fuel consumption curve
- adjustable cam gear setting?
- block ?
- vafc ii wiring
- b series all motor, crank and rod questions.
- B20/VTEC runs bad on P28 but okay on p30, any help??
- B16 Mahle pistons - anybody?
- Edelbrock two piece headers
- sohc gurus help me...
- Installing Hytech Header this weekend, Should i upgrade the exhaust..?
- bearing question h22 f22 crank
- Which cams can be run with the factory valve springs and retainers?
- toda cams?
- poor man type r build help
- which fuel pump should i use?
- D16z6 vs B18c1
- map sensor ? mpg
- Dyno runs for K24a1 (CRV & Element)
- pump gas GSR comp. ratio?
- Took off my head and found this on my cams
- ls/vtec with ctr pistons
- Are b16a1 intake valve springs the same as DC2R (ITR_ exhaust valve springs?
- almost there
- New cams or head work?
- Anyone familiar with all of the cams that Blox offers?
- need some input..
- what cams
- .040 B series headgaskets other then Cometic?
- Another cam choice thread
- have a k24a4
- Code 15 Ignition Output/ICM
- Can i keep the rocker assembly on when using this valve spring compressor? And steam seals
- Piston to valve clearance on a b16a?
- About how much does a twin cam head weigh?
- Engine Break-in / tuning Question
- $1000 too much for a stock type r head? See what's included. . . . . .
- adjustable cam gear question
- recommended throttle body
- Any of you index your sparkplugs?
- h22a intake manifold options
- Comp Ratio
- Best advice for a B20Z ?
- I want to build ls/vtec using stock parts(on a budget)
- Proper procedure for copper spraying a head gasket?
- my GSR all-motor build
- Need super lightweight muffler. Who's doing that?
- What fuel injector to use on my lsv setup im building
- head gasket
- Ls motor, want to go lsvtec
- b16 not starting after upgraded cams? Please look, weird problem...
- skunk2 intake mani question
- GSR block w/GSR or B16 head?
- itb's with suge tank or pleanum
- 1997 Honda Civic catalytic converter
- B20 Rev Problems
- Which header to get?
- What Valvetrain setup??????
- want to increase stroke, 92mm crank? is it ok for dd car?
- B18 hybrith
- toda header - will any cat/test pipe work?????????
- B-series BC stage 5 or 6 dynos anyone?
- Middle Piston rings have no markings...what side goes up?
- Adding a muffler to straigth through exhaust
- need more WHP
- toda cams on a b20vtec
- JDM ITR build up - Need help with everything !
- How would Blox HSL's cams be on my motor?
- has anyone ever tried the obx ITB'S
- any crv motor advice
- cam cap bolts?? need help!
- Need help identifying Skunk2 cams
- headers
- B20B camshaft selection
- gsr or h22
- ls/vtec build
- weird thing i saw at work....
- BC3+ Camshafts. Lost 15% power @ vtec
- built gsr v built b20vtec
- OIL LIGHT will not come on after LS/VTEC build
- gsr all motr how do i know what length rods to use?
- Shift points
- B20Vtec w/ Stock P2T ECU
- V-tec all sudden no engaging??????????????
- h22 can or can't....
- B20 build...finally underway.
- B series 204/135
- Performer X B16 intake manifold install issues. Help please!! Why is this?!!
- B18c1 GSR All Motor Build Finally Finished & Tuned!!! Thanks RedZone Performance!
- b16a2 172whp with minor mods!!!
- b16b cams
- high compression and pump gas?
- new wrist pins?
- Rod bearing size selection
- Engineers, What is the b20b Piston Ring End Gap?
- Port matching my H22 manfiold to TB
- ctr pistons in ls block
- jdm b16 build need some tech info
- Non Vtec Tri-y header?
- H2b with f23 crank
- What rods for all motor
- .: Skunk2 68mm TB not good... [scanner can't even get it]
- VTEC OIL LINE QUESTION.....WHY 6AN?????
- Fluctuating oil pressure
- Need some input on my First BUILD! B18C5!!
- Breather setups and how they work... Lets see em'
- b20b issue
- 2k on performance
- Performer X users..throttle cable issue
- best way to get the power
- B16A2 Engine, B18 Block - Options?
- 82mm LS-VTEC - Am I heading in the right direction?
- Post your Allmotor D-series dyno!
- Buddy club camgears - one marking is how much?
- iacv?
- My First N/A Build......
- cam, need tuning?
- BC3+ Camshaft. were they dialed in during tuning?
- ls vtec suggestions please
- JDM ITR + SMSP + ROCKET + PERFORMERX... dyno... PART II !!!
- Recommended cams on ITR head?
- Hondata or similar insulating Intake Gasket Material sources?
