- Trying to find RMF aka Randy ..... who can help me out..
- help with engine re-build and bearings?
- what cp pistons to go with...
- piston size vs block bore
- question: How many teeth on 4.4 f/d ring gear?
- Valve in new engine question
- another pro1 ls/vtec build.
- BEST N/A setup for b16b
- Header size and dimensions article
- !! plz help me build my motor !!
- b20vtec or lsvtec
- 1.5L head swap?????
- B20/VTEC
- Eagle rods
- ? on ls/vtec setup
- H22 Cam question!!
- Having a cooling issue with a 1998 Civic DX
- H22 header AN-R vs Camp 1320
- breaking in a motor
- helpon build please give some idea's.
- how to buff rocker arm pads ?
- Whats the deal with these cams???
- To hone or not to hone??
- Please help me select an intake mani for my Build
- hytech twin loop exhaust?
- LS VTEC
- How to improove cooling (especially when not moving)?
- ANYONE IN SAN DIEGO WITH 97-2001 PRELUDE TRANNY SWAP HELPP
- What happens with only one VTEC?
- Exhaust question... Stepped Exhaust??????
- want to get more power for a b16a2
- Best Pistons 85mm
- piston and cam clearance question
- 200 whp, couple of questions
- Endyn Breather kit, install info'
- B16a w/ PCTx pistons: Should I use the PCTx head gasket or the PR3 headgasket?
- B16 sputter!!!????
- How to read TODA Cam Gears (Vernier Scale)
- p30 pistons and crower 404s
- I need a picture of a honda civic 92-95 tube diagram.
- My current b18c or a k20a2?
- b20vtec horsepower
- b16 backfiring to much
- Balancing bottom end
- Skunk2 fuel rail (some results)
- Question about the k20 igition system..?
- LS/V project
- Anything else...before i dyno/ my Set-up etc'
- ProFab?
- how to build a dd b16 head gsr block
- My NA 81.5/89 ITR Build
- What cams would be right for my set-up?
- 2.0l LS/Vtec build, help me out with IM/TB/cams/header selection
- B18A/B Head Questions...
- dapump2003 LS/Vtec swap in civic!!!
- Freakin head!!! help please
- all motor oil pump.
- Crome Setup for Lsvtech
- help w/the Delta 272 spec sheet
- Valvetrain & Cam Break In??
- valve movemnet???
- B17 build - I need all the input I can get
- this is curious... 2.25" JDM 4-1 header?
- B20/B18C5 setup?????
- Cam Help
- Anybody here know who own exospeed?
- Picked up some CTR parts -0- I have a few questions after searching
- Timing and AFR questions
- Just finished dyno on my son's LS
- ok searched and tired of for sale threads. ctr pulley
- Question about fitting header and intake manifold
- b18c1 or b20vtec
- Heres the setup and want too get more power..need some help
- persistent H22 oil leak
- stop knock
- is 210 too hot
- TYPE R or TYPE S in a bub?
- Chasing a oil leak down!
- RMF Narrow - B16 Users!
- HP guess
- headers for b18c1
- Best turbo H22A Setup
- 93 hatch. has d15. got an OBD d16a from 89 teg. what should i use?
- Need A Good Machine SHOp NYC or tri state
- 200HP Goal...does anyone have any suggestions or advice?
- B16A or B17 head, on a B20 block
- Crower cams
- why use ls oil pump?
- need help diagnosing stumble k24a2 swap in EG
- question about twm 50mm itb's
- WHICH MOTOR????
- Hey does anyone mind posting some pics of h22/all motor builds.
- ctr pistons into my N/A b18c1 build.....
- transmission
- B16A siR swap
- non-vtec motor into a vtec car
- Edelbrock performer X VS. Skunk2 pro series intake manifold
- how do you identify cams
- tuning
- Integra GSR & RSX Type-S dyno graphs.
- Advanced Engine Machining in Huntington Beach ??
- Fidanza SOHC flywheel TOO light?
- cam gears
- Air / oil seperator
- interchanging tranny bearings
- Damn it....B16 valve springs...intake/exhaust mixed...8 taller than the others..which is which
- WTB: K series or B series engine
- profab stainless vs. mild steel... help me decide
- P29 pistons into a d16y8, how to lower compression??
- All motor ls/vtec
- Buddyclub cam gear cracked
- Check engine light just turned on! help
- Blox Throttle Body
- Bottom End specs and clearences h22
- balance shaft
- this is funny
- HELP!!! how 2 build b18c1 block with B16 head
- B20-vtec dyno graph
- piston to wall clearance discussion
- block gaurd problem
- How do i lOwer HC and Co?
- LS/VTEC Problems HELP!!
- HELP !! looking for engine builder on OAHU
- H22A target #'s...
- Valve Spring Compressor
- CEL on!
- F23 stats
- H22 all motor M&H options besides 22/8/13. Please help
- ANYBODY KNOW HOW TO DO A VTEC CONVERSION!!!!?????
- K24 high performance parts
- Intake manifold test results on a 1.8L Edelbrock ITR IBspec Take a look!
- Is this motor worth it?
- NA GSR (Beginner build)
- Skunk2 Pro1 with Ferrea valves?
- Best Catalytic Converter?
- 2 new toys, but which to use?
- 240cc injectors... max hp?
- Upgraded FPR and fuel rail
- LOWERING EMISSIONS????
- Header primary size for all motor application
- what is the highest comp... piston for ls/vtec build for a street car?
- all motor ls/vtec build?
- timing belt problems
- b20vtec build.. help
- LS Motor High Idle Problem
- GSR HEAD GSR BLOCK LS CRANK N RODS 84MM PISTONS
- i have some important questions,i'll do my best in asking though.i am a noob.please bare
- valve adjustment jam nut torque spec?
- apexi mani ?
- oil out the back of the head.
- H22A1 Supercharger question
- Built head... fuel?
- mild all motor build
- Header decision
- ls crank with gsr rods and itr pistons
- S2000 valve job on B16a head
- JUST FINISH MY BUILD CHECK IT OUT
- Anyone moded iridium plugs
- best valves for n/a?
- What to do???
- h22a hp?
- piston to deck hieght ?
- What to expect, b16a2.. with mods..
- ITR Head and B18B block question
- b16 Header...no idea what to do
- b16 block With a Gsr Head?? Please Help
- bore size on a skunk 2 intake manifold
- Highest all-motor B series?
- Translations for a mexican guy.
- Limits of ITR Springs @ Retainers???
- Which Harness for Simplicity, 97 EK Chassis
- leak between down pipe and cat flanges...
- Randy at RMF, where is 1GPlusSH's header??
- Is this manifold too big for NA set up
- Quick and easy all motor question(s)
- what chip can i put into a b16
- skunk 2 intake manifold will it fit
- Should I use these cams with this set up? (Skunk2 Pro1)
- LS VTEC Hmm? OBD 0 Or OBD 1....
- DOHC ZC + JG 301 cams = dissappointment.. Any tips?
- intresting build I cam across. f22a1 with f20b internals and an f23 head
- All Motor Setup Experst Step Inside...
- GBRTuning.com Allmotor K-series Civic Type R buildup
- Header+Heat+Coating'
- h22a with PasswordJDM Carbon Intake Question
- what valve springs?????? help!!!!!!!
- Integra G2 ls 4-1 jdm header swap?
- D16y8 intake manifold.
- Your Luck can Won you a FREE VEHICLE…
- best bang for your buck performance header?
- Quiete Mufflers ?
- D16a6 Solo2 AutoX build
- What to do with my D16Z2 engine :?)
- RLZ
- ITR Crank Thread pitch, etc
- Manual swap shop????????
- need some help
- Skunk2 Pro,golden Eagle,ctr Pistons gsr swap
- GSR, what y'all suggest?
- h23/vtec build up question?
- dyno B16A stock sleeve
- D-Series Build: How much power could you get...
- back cutting valves for skunk pro2's
- B18B/B20B good compresssion??
- Anyone out there running an 84mm+ "unsleeved B18C"?!?!?!?!??!?!!?
- Resoration of original specs
- Are they making FAKE DC,JDM,Flowmaster Headers?
- Recent dyno of the B16A in the coupe
- Machine Work prices?
- all motor ls help
- Which cams?
- Post Up Your Custom Tuned Intake!!!
- I Want Camsssssssss
- Engine won't fire.
- CAM QUESTION!!!!!!!!!
- More power???
- what forge pistons...
- typer with skunk2 pro.2
- tuning benefits?
- Frustrated in need of help from experienced builders!!
- need someone to torque head onto block!!!
- transmission
- twin loop vs. straight through
- Golden Eagle or Full Race vtec kit?
- ditching my NA civic for a S2000
- quick ls vtec ?
- Help? im lost
- 2.0L
- any nice g23 builds out there?
- Toda stroker kit
- limits of stock bore ITR throttle body?
- only h222 dynos welcome
- have an AEM map i need to convert to burn onto a chip
- Headers Question.
- D16z6 Horsepower Questions.....
- B20 VS GSR
- pissed off
- ls/vtec question
- main relay problem?
- Moving injectors further back....is there a limit?
- motor
- wear in cam procedure??!!
- GSR HEAD?
- Looking for thicker head gasket
- READ THIS!! - Cam Wear
- Which rods? sleeved GSP block, CTR oversized pistions, LS crank.
- camp1320
- need advice crank/stroker kit for b20 vtec???? DonF, Tbone, etc2 please come in
- Rate this setup
- 81X89 LS/VTEC
