PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. best Camshaft for a gsr
  2. B Series Tranny
  3. ITR REPLICA HEADERS
  4. LS Vtec opinions
  5. b series injectors
  6. view on fuel pressure gauge?
  7. Where To Buy?
  8. advice and help needed!
  9. Is there an up side and/or down side to portflow inners?
  10. sixsigma or prospeed header?
  11. Supertech Valves on Daily Driven Motor - Recommended or Not?
  12. Help determine my compression.....just need people to double check some calculations
  13. Throttle Body spacers Anyone Real reviews??
  14. ARP 8740 or ARP 2000 bolts ??
  15. Crane Cams
  16. What option to choose before pluging the motor in???
  17. problem starting ls motor...
  18. very low gas milage..
  19. TURBO KILLER> ?
  20. Raising my compression
  21. unorthadox crank pulley
  22. Does RMF Make A K series header?
  23. 97 ACCORD SE F22B2 makes a valve clacking sound only under acceleration. WHY?
  24. LS vtec Question
  25. HELP with jdm b16a
  26. ls/vtec problems
  27. Question about rods...
  28. wtb valves
  29. MAHLE FORGED PISTONS FOR NON-SLEEVED BlOCKS?
  30. Help me
  31. installing itr .25 over in my gsr block
  32. new build, oil in cyliders
  33. help ... need to clay motor
  34. headgames head
  35. Re-torquing ARP head studs.
  36. Bike Carbs on a D16
  37. P30 o2 sensors
  38. Best Way to Build a Motor?
  39. k24 a little weak?
  40. is the machine shop trying to rip me off?
  41. Any GOOD headgaskets for 86mm B-series?
  42. B18c build, anything else??
  43. need help with wiring a h22 in a 95 dc
  44. je 12.5.1 compression pistons too high?
  45. ive searched!! catch can with itbs?
  46. Anyone know comp. ratio of d16z6 or y7 pistons on D15b vtec
  47. Head work question
  48. ALC bearings vs. OEM
  49. OBD2-1
  50. h22 tranny question
  51. tips for removing stubborn dowel pins?
  52. Need review of JDMshit inatke for B series
  53. Injectors Q
  54. my H22A build up
  55. timing off
  56. Mis-firing issues? Or something else?
  57. EBAY tri-y header installtion
  58. 3 quick questions
  59. Question about installing piston rings (ring land related)
  60. just getting in to all motor...
  61. New H22 motor is up and running! *pics attached*
  62. Creating oil pressure before startup of new motor
  63. HELP... VTEC PROBLEM
  64. Oil Dipstick length B16a vs B18c
  65. 2 quick TB questions
  66. What is the best intake manifold for a N/A b series engine?
  67. Stalling when clutch depressed.
  68. Am I flooding my motor? <Walbro 255>
  69. VTEC Light issue
  70. whats better 4 a all motor
  71. What kind of ECU Jumper Harness is this?
  72. lost one of my dowel head pins for my ls/vtec,which one do i need
  73. Wut pistons to go with... and wut compression??
  74. Stock exhaust question
  75. yet another cam question
  76. What would you do--H2B or SOHC TURBO???????
  77. rm spark plugs, what to gap them at?
  78. buttdyno results
  79. Intakes Suggestion!
  80. with or without PCV
  81. My civic is sick... Timing issues?
  82. Exedy Stage 2 Clutch Sticking
  83. tuning?
  84. so all of a sudden a b20 vtec is outdoing a k20?
  85. h22 secondaires open or open only with vtec
  86. Diy exhaust ideas
  87. obd1 ecu and block with obd2 head?!?
  88. RS piston question
  89. AEM FPR orifice size question
  90. LS/Vtec Build...I am a honda noob and need some expert advice/guidance.
  91. LS bottom end
  92. Need Help Please Respond anyone that knows!
  93. integra pro fab headers????
  94. JGE header?????!!!!!!
  95. Hytech B series?
  96. ebay special? f1 header = knock off of hytech header? :o
  97. Nitrous and Agressive Cams
  98. Need advice on B16a project
  99. Pro 2's IN stock B16A.
  100. Is this true?
  101. All motor ?
  102. Another LSVTEC ready for tunning. . .
  103. b17 rods
  104. B20/vtec spark plugs???
  105. Do I need different Bearings when switching Ls rods to Eagle?
  106. all motor B18B/A setups post here
  107. Valve Guides
  108. H22 Motor Mounts
  109. engine bay help please comment...
  110. JG Edlebrock intake mani.
  111. High Compression GSR???
  112. help ls/vtec or h22w/h2b setup help please
  113. need some help. all motor gsr
  114. supertech flat head valve + spoon headgasket , how much difference
  115. Tunning help... pinging at between 2-3kRPM at low and full load.
  116. Car seems to loose power when floored
  117. Post your grams...
  118. Dynoed b16a2 ctr cams..
  119. Interchabgable throttle bodies
  120. ITBs For LS Head?
  121. I know you all motor guys hate this but.......
  122. h23 horsepower
  123. Six Sigma Racing/Quartersports 2.3L H2B CRX budget build MONSTER!
  124. How easy is it to blow out the piston rings???
  125. All Motor Intake Manifold
  126. d16a1 build help.
  127. Quick Question about JDM B16a Header.
  128. Help... B18c or b18c5
  129. OEM USDM ITR rod tq specs
  130. help me figure out what kind of TBs these are
  131. <<<<<<<<<3/28 REMINDER/NOTICE>>>>>>>>>
  132. Block Guard???
  133. OEM 1997 ITR TB
  134. B20/vtec
  135. What Do I Need For 13 sec. ITR!
  136. guage Q n A
  137. b20 info
  138. 00 SI Engine Harness for Ls/Vtec(NEED HELP!!)
  139. help please rod?
  140. c/r of flat face Valves ?
  141. Big Number non-vtec engines?
  142. cam caps and head bolt tourqes?
  143. Civic Si Questions
  144. Head studs VS Head bolts???
  145. What header is this?
  146. what bolt on would help me the most
  147. Nos
  148. Cam gears and Stock Cams.
  149. Ferrea Roller Rocker Arms
  150. Manley Valvetrain?
  151. TB/skunk2 IM question
  152. breaking in a used engine?
  153. anyone wanna share some maps for pct pistons in c5 block/ pr3 head?
  154. big throttle body and bog??
  155. good header and use a/c?
  156. H22 or type r...I NEED SUGGESTIONS!!
  157. Spraying on My B18C
  158. Are all retainers created equal?
  159. Fuel consumption!!!
  160. B16 block with GSR crank?????
  161. I know you guys hate build advice threads, so do I....
  162. People familiar with BC IV's?
  163. Retainers...
  164. Dynoing my car today!!!
  165. spun a rod :( need a quick fix so i can drive my car..
  166. .50 over pistons wich ones ?
  167. jdm ITR pistons vs. usdm ITR pistons
  168. Wiseco ceramic coated p/w clearance
  169. What cam gears are these?
  170. ls and gsr water pipe
  171. LSVTEC build
  172. NEED HELP!!!!!!!!! B20 NON-VTEC STOCK.....4-2-1 HEADER (2 1/4) OR JDM 4-1 (2.5)???
  173. best header out there for b motors ???????????????????
  174. B20b VTEC profile with Hondata S300
  175. All motor- injectors?
  176. Cam selection - need help
  177. hybrid setup. Open for opinions.
  178. Anyone running B.Crower VTEC cams?
  179. S2 S300 ecu Q's
  180. a few questions on some bolt ons and there affects!
  181. anyone build a ZC before?
  182. F/S*** Ariias pistons and buddyclub spec 4 cams
  183. What to do now B16? or rebuild B18?
  184. Portland, OR - Torque Freaks Dyno Day - Saturday 3/31
  185. Uk spec h22a7 help
  186. block boring
  187. ???OBD1 DIZZY???
  188. Dynamic cr vs. rev
  189. 96 Accord problem, help!
  190. itb's on h22 vaccum probs..
  191. ITR cams vs BC3's?
  192. Final question before my built!!!
  193. D16z6 Rebuild....Opinions needed!!!
  194. How do i choose my ARP bolts???
  195. which cams with stock B16a?
  196. holding SOHC cam gear in place...any tricks?
  197. Your choice on sleeves in a H22
  198. new ecu and horrible idle?? what to do??
  199. p2v with bc4 and srp 11:5:1
  200. engine reving
  201. which gauge cluster does everyone run?
  202. shooting flames!
  203. what size are the transmission bolts?
  204. CTR equivellent cams?
  205. water in catch can?
  206. Decided to go NA instead of FI
  207. B18C Build Questions
  208. Going back for a re-tune...suggestion?
  209. degree settings for JUN3 cams........ help!
  210. b16b ctr valve clearance
  211. skunk2 manifold help
  212. crower 403's b20 problems
  213. good Clutch for allmotor??? exedy, clutchmaster, act...etc....
  214. converting the dizzy to coil on plug ignition
  215. B18C block with LS Crank = Oil squirters
  216. plenum size VS throttle body size - theory/help
  217. I NEED A SWAP IN THE CENTRAL NEW JERSEY AREA!!!!!!
  218. Blox Tuner A Cams
  219. Skunk 2 Stage 3 Cams
  220. Rocket Plugs VS NGK BKR7E-11
  221. project PLAN B
  222. all motor b16
  223. b20 semi built recomendations/questions
  224. **WANT TO BUILD A GSR MOTOR HHHEEELLLPPPP***********************
  225. buddy club hg part number b16a
  226. Intake system length input.
  227. RS Machines 84mm ITR style piston specs wanted
  228. Velocity Stacks-what's the difference in brands?????
  229. Blox HSL cam timing?
  230. toda killer b's
  231. I BEAM QUESTION
  232. the smokeing......
  233. all motor + NOS = All motor??
  234. B20 OR B18
  235. Difference In Intakes
  236. Budget Cam Degreeing Valve to Valve Clearance for dummies
  237. jdm D15B NON VTEC INFO PLEASE
  238. Getting ready to tune, need a little advice on how much things will cost
  239. motor bogs at 2k+ rpm
  240. 99 civic stock motor rebuild questions
  241. Piston Ring Packaging
  242. Car was in limp mode, now it wont turn on at all!!!
  243. p28 ecu on a b18c-r question about chip
  244. question about performer X TB (fitv blocking plate)
  245. QUICK QUESTION P75 ECU?
  246. GSR oil pump
  247. fully built b16 with itb's
  248. stage 1 or ctr cams
  249. degree for itr cams
  250. Drag RACing 2006
