PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 [168] 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Stacks
  2. ROD KNOCK in my poor mans R..what to do?
  3. All motor on street tires record?
  4. Sportcarmotion.com N/A build-up for Time Attack underway. Few pics
  5. b16 burning oil?
  6. under axel exhaust?
  7. b16a1 rebuild/ build up
  8. H22 N/A setup. Crower or Skunk2?
  9. Piston?
  10. Do i need engine mod to run this header?
  11. Aftermarket gauges & sensors and OE oil temp & water temp sensors
  12. My Bored and Stroked B16 buildup.
  13. cometic head gaskets good?
  14. Convince me to go NON VTEC
  15. opinions... gsr rebuild... what would you do?
  16. all motor HP vs turbo HP in the quarter question ???
  17. Looking to get 200whp
  18. Most WHP on stock block?
  19. Skunk2 throttle body idle problem
  20. Factory retainers
  21. which way do Rods face???
  22. high comp. Ls pistons
  23. SMSP HEADER on a JDM ITR motor?
  24. Wich compay to use for Valvetrain on h22?
  25. Stock head with 2L block?
  26. CR on B16A2 w/ LS crank?
  27. teaser vids, jdm itr + cbr itbs
  28. ---Sunk Sleeve---
  29. injectors, peak&hold or saturated?
  30. P30 pistons
  31. cant decide...give me your opinion.
  32. What is an "align hone"?
  33. Need a good Allmotor Header For a drag car?
  34. machine shop prices
  35. compression test numbers high???
  36. best cam for 85mm ls 13:1 compression gsr head?
  37. compression ?
  38. what numbers should i expect ?
  39. valves
  40. E-bay CTR pistons...any experience?
  41. Question about cat placement and sound reduction.
  42. <b16 camshaft suggestions>
  43. what bearing sizes
  44. aftermarket retainer needed??
  45. what happens when your oil filter falls apart
  46. All Motor LS/Vtec-Guages
  47. ring placement???asap
  48. Estimated HP # on my possible setup, CTR pistons, CTR cams, B16 swap etc......
  49. removing girdle on b18c...new bearings?
  50. b18 crank w/ b16 connecting rods?
  51. gsr block
  52. this set up ok?
  53. need tech help
  54. b16a with ctr pistons and cams. what else do i need?
  55. h22 injectors in a 94 eg civic with b16
  56. SOHC ALL MOTOR?
  57. Question about ENDYN Breather Kit....
  58. ls vtec = bad night
  59. sk2 stg3 cam tested on b16 with 11.8-1 @ methodmotorworks
  60. on my way to goin slow crvtec style
  61. Removing wrist pin..i searched
  62. Just picked up crower 402-2 today. I was told my 402 broke because of skunk2 valvesprings...
  63. DEL SOL EXHAUST/ MUFFLER
  64. need advice on gsr or ls block.
  65. 4 into 4 exhaust???
  66. b16 head with gsr? or just plain ol gsr?
  67. D16Z6 vs. D16Y8?
  68. HELP...ASAP... head studs
  69. Some New Exhaust Bling Bling
  70. B16A2 block W/ B18C1 head GOOD?????????????
  71. Just pulled it out the shop!
  72. Throwing a code 22??
  73. shop in so cal?
  74. Crower Stage 2 Cam gear Setting
  75. 2000 Si obd1 buildup help - need expert help
  76. cams in bulit b16a
  77. Head Overporting
  78. fidanza flywheel and pressure plate bolts!??!!??
  79. help with rebuild....
  80. when getting the knock sensor code would vtec not engage
  81. Cylinder Wall Rust on GSR Block
  82. SS header
  83. 99 accord
  84. MEGAN header part II installed,,,,,,,,
  85. wait wait ive never heard of this..................?!
  86. O2 sensor code and cel, no vtec. Can't get rid of code?
  87. bottom end bearings
  88. well he claims the head is bored out
  89. anyone have the code 23 (knock sensor) on a p72? What was the reason?
  90. mildest cams to make 200whp
  91. GSR crank in my b16a. Benifits?
  92. New Skunk2 Pro IM...
  93. skunk 2 stage 2 cams???
  94. Main bearing install questions - calling experianced engine builders (B20 VTEC)
  95. MSD ignition box and external coil -- run it or not?
  96. Motec M4
  97. b20 motor replacement in type r questions
  98. Buddy Club Cams
  99. post your buddy club spec 4 dynos...
  100. any decent LS builds out there?
  101. B18C5 in EK coupe
  102. pics of B20B blockpistons that came with a P8R head...anyone got em?
  103. where can i buy velocity stacks
  104. Pictures of the HOOKUPS header !!!!!
  105. Valves.
  106. b18 n/a info
  107. highest compression ratio on pump gas for B16
  108. Help diagnose smoking and ticking issue...
  109. anyone running all motor sohc zc?
  110. High CR guys please take a look!!!
  111. Head Gasket??
  112. 300 cranking psi...........
  113. Question for all motor geniuses...
  114. comp cams street cam vs ctr cams
  115. who's using datalog... NO HONDATA!
  116. H22 head build question (JUN)
  117. Tranny ?s spline counts 92-93 gsr tranny
  118. Cams Cams Cams!!! Which Cams?
  119. all motor quest?
  120. Help! White smoke coming from oil catch can.
  121. B16 in CRX AEBS/throttle cable problem-HELP??
  122. b18a swap into a 92 cx
  123. Hookups B-series Header pics
  124. ls vtec
  125. wtt mugen twin loop
  126. b20s sleeves
  127. D16 build up- Honda Expert Advice please…
  128. Who is using Toluene in here?? Experiences??
  129. Cutting open and porting Skunk2 Manifolds?
  130. reusing pistons?
  131. MEGAN RACING JDM 4-1 Header......info and pics!!!!NS56k ....no more unknown bashing!!!!!!
  132. Will type r rods fit in a b18b?
  133. Please help question on my retainers.????????
  134. Advice on N/A & Nos
  135. ctr cams or not ?
  136. Help. What kind of turbo kit for my civic??
  137. need advice
  138. Putting down over 200 FWHP and 175 FWTQ with a stock block and head???
  139. Valve Replacement: Oversize to Stock Size
  140. how does my build sound? and what power to expect?
  141. Opinions & Criticism
  142. Intake Manifold Problems
  143. anybody what kinda D series camshaft is this ???
  144. Skim/flow/porting for low to mid end power on B16 head
  145. headwork..getting valve job on gsr head what else should be done?
  146. burning distributors!
  147. intake manifold jg?? skunk2?
  148. which head studs to use????
  149. Need help CBR 954 ITB's..IACV? Velocity Stacks?
  150. KMS Valvetrain
  151. What intake and TB to run on a 2020cc?
  152. For those of you pushing 200+whp and or 12.0+ compression
  153. JDM H22 stock flywheel vs aftermarket...
  154. 11:1 CR with 75 Wet Shot - Dizzy Timing?
  155. GReedy SP2
  156. Throttle Body
  157. jdm vs. usdm help
  158. 13:1 piston clearance??? all motor build???
  159. Mugen Head Gasket
  160. CTR piston install questions...
  161. Anyone usin comp cams in B series
  162. do magnetic drain-bolts work or filtermag?
  163. AEM cam gears...
  164. Itr with Ctr piston
  165. Who has highest revving engine?
  166. 13:1 piston clearance??? all motor build???
  167. Skunk 2 Stage 2 Shafts
  168. h22 lost motion assembly into a b16 questions.
  169. Build Newbie
  170. new Oil
  171. SCE copper head gaskets
  172. Cam selection for ls/vtec???? need some information
  173. SMSP?
  174. has anyone had a problem w/ their intake manifold leaking???
  175. Looking for a better D16 cam for setup...
  176. Open exhaust manifold
  177. rpm/speed ratio 2002 civic
  178. 1st gen b16 into a 90 HF crx, only reving to 7000. why??!?!?
  179. ls/vtec question
  180. Getting to a dyno for break in
  181. suggestions on my build up
  182. Cons of Thicker Headgaskets
  183. very mild ls/vtec opinons what i need and dont
  184. head porting prep
  185. 81 civic wagon
  186. LS Rods in d16
  187. Does my build sound good?
  188. GSR Cam help
  189. Rebuilt z6, car won't start
  190. Machine Shop Owned me.....need Help
  191. STR 70 mm TB Surge Problems.....
  192. valve to piston clearance question
  193. What would be the best chip setup for my B18C
  194. Experiences using Crome with High Compression Motors
  195. Car almost dies everytime after refueling??
  196. Should I swap out my b16a2 itm for itr? Mods listed. (thanks guys)
  197. 200 hp ls motor no vtec
  198. Nitrous
  199. crush bent exhaust can suck my balls
  200. Intake Manifold question
  201. 96 Accord swap question
  202. Catalytic Converter Or Testpipe **PLS ADVICE**
  203. one more itb question
  204. Hondata problem help??!?!B18
  205. Sneak Peek - My All Motor Build
  206. car dies out and afterwards, car has a hard time starting
  207. Idle problem when engine is cold (please help)
  208. need advice from u all motor peeps
  209. Picked up Stealth 95 gs-r's ol MOTOR....R HOTTNESS!!
  210. BLUE SMOKE JDM B18C
  211. all motor b18
  212. Del Sol VTech Question
  213. Dynamic Compression
  214. Dyno Video
  215. Tuner shop near Rochester/Buffalo/syracuse NY area.
  216. IM for n/a ls
  217. plx wideband convertor
  218. JDM Type R's with B18C5's?
  219. Baseline .BIN for bolt-on Type-R. Anyone have one they can share?
  220. CERAMIC VS. STainless Steel
  221. PR3 Piston Question
  222. B16 200whp
  223. My Dyno sheets
  224. wicked/blox cams stage 2
  225. My h22 base dyno pics plus Vis
  226. I Need Some Help Guys
  227. A few questions
  228. skunk 2 manifold?
  229. need help and advice
  230. Anybody tried BUDDYCLUB V cams yet?
  231. Buddy Club Spec 3+ and ITR valve spring and retainers
  232. all motor integra r
  233. TIRED OF THIS NOISE...
  234. need advice
  235. b16 ported head with about 80k on botton is this safe???
  236. fully built type r head on gsr block
  237. obd2 type R head on obd1 b16 block
  238. I NEED HELP FAST
  239. 94-95 GSR/ITR Oil Cooler on 95 LS B18B block, need help and opinons
  240. bc 4s or bc 3s hmmmmm
  241. what does it take to get mid 12's n/a
  242. EGR Valve - Search performed...Great thread
  243. stock ls vtec
  244. air cf intake manifold vs itb's
  245. crower 403 ?
  246. Cams for B16a (M22's / BC3+) (help)
  247. CTR Exhaust cam question
  248. ls-v set up what valve train help?
  249. those with gsr motors with b16 pistons....
  250. removing pistons from rods
