- SPI micrometers, anyone heard of them or used them?Essential engine building tools
- hf motor mini me
- ThankASoldierWeek.com -- I Think this is cool!!
- resonator
- blown headgasket??
- B20 Block with B16 Head tech questions
- Quick Tuning Question
- What's going on with my new engine?
- how much should i mill my gsr head for my setup??
- 2.36 vs 2.5 on a 2.0 motor
- shop in anchorage ak
- Check engine light w/VFAC
- review this b-series setup
- a little help please.
- b16 head question
- NA d16z6 going into my EF hatch
- i want to know how much i should deck my head just bought cams..... help
- FYI
- Do you think this valve is bent?
- 909 header shootout - DTR-Fab, Highend, Rage
- 1.9L 12-5-1 comp. toda c gsr
- Prototype Racing velocity stack
- BUILT GSR LOUD TAPPING AT IDLE ONLY?!?!?!?HELP
- wheelie bars.. how to install them to the car
- Where Should i Send My Head For PORTED n POLISH..
- Milage on built JG Engine Dynamics Head, how many miles are on your jg built head?
- Catch Can Help
- is this setup good???
- which sized exhaust for b16?
- Pick my Intake Mani
- help lsvtec
- Look at the Goodies!
- need a bit of help
- Buiding a 2.0l JDM B18c
- lsvtec
- just picked up d15 b1 block any ideas?
- Turbo a B16A2?
- all motor a/f
- B16A untuned w/CTR Pistons & S2 st3 cams 13.3@102mph on CRX 1800lbs is he cheating us??
- EXTRUDEHONE OR CNC HEAD PORTING A B-16/B-18C1OR 5 HEAD ? WHICH IS A BETTER CHOICE
- new contact for golden eagle
- Cleaning the castings on a IM
- fuel problem???
- Machinist and engine builders please share your experience
- More power?
- B16B engine shortblock OEM part number
- b18b frankenstein...
- ATTN: All Cylinder Head Experts Review this Port work
- 200+ whp out of a B18c1
- So, P30s are rare, what other piston choices for B18C1 (GSR / B18C)
- ?? Piston Dome Displacement of USDM B18C5 Piston (P73-A0) ??
- RC 370cc injectors - Peak/Hold or Saturated?
- will b16 tranny shift forks, swap from cable to hydro?
- Offest rear main seal or crankshaft repair?
- 13.5:1cr, 2.0l gsr, and itb's, or ported IM, lose power with itbs?
- ls/vtec build idea's needes
- B16 ShortBlock /Dust -HELP-
- mild built 1.8L motor with 2.25 exhaust
- v-tech not engaging
- ls/vtec question
- 3 angle valve job Vs. multi angle valve job
- wut intake mani and tb?
- My N/A Ls/Vtec dyno! comments/opinions
- diy ITB's?
- Those of you with ARP rodbolts!
- valve clearence for skunk2 stage 2
- Skunk2 Stage2 Cams, what is engraved in them?
- Blox Cams....????
- valvetrain break in
- Where to buy oversized h22 (type-s) piston rings...???
- Do you guys filter ITB's or just leave them?
- Will a B-20A-5(88-91)prelude crank fit into a B-20B/Z block ?
- using new and used pistons
- b16b n b16a timing belt =?
- Insight into home hone job
- ___car revs really high after motor build??? HELP ASAP___
- B-20A5 BLOCK !!!
- Raising compression without touching the bottom end
- s200 ?
- SOHC ITB runner dia?
- ls/vtec vtec problems
- My Custom Narrow RMF header
- Starting with a bare B20B need some help
- how many of you have installed a bad thermostat
- transmission question
- Port Job OK on new head? JG ported.
- 0.5mm or 1mm oversized valves?
- problem w/ bored throttle body
- my integra shuts off while drivin
- best header under 450 bucks
- WTF, whats my compression????
- Pro-fab vs JDM ITR Header.
- The Dynapack vs. Dynojet controversy
- my ls/vtec setup?
- H22 ALLMOTOR RODS
- Skunk2 Throttle body high idle?
- Help, need support... krazie1 = SCAMMER PLEASE READ!!
- my set up
- toda spec a's and skunk2 stage 1's on stock gsr
- Case Study info
- aftermarket block gridle
- k20, k24
- Which intake manifold (yes, I searched)
- Question about price of tunning
- zdyne with TWM Itbs
- Need info on crank pulley for B18c5
- OBD1 swap issues
- 52mm TWM on B18 ,too big ??
- 89 to 92 mm crank (Offset grinding)
- Crower All motor Cams?
- DANG IT!!??? H22.. WHY????
- D15 with D16y5 head
- H22 Skunk 2 Stage 2
- valves ticking very bad
- How to advance the Powerband?
- Building H22A5 NA engine.
- deck hieghts??
- How much did you pay for tuning??
- Hook-Ups in Upland, CA
- HELP ME PLEASE I NEED Velocity Stacks
- i tuned USA , a bitch to deal with.
- Keep B18C5 or sell it for a B20vtec?
- 190hp.. ?
- no power when vtec kicks why??
- puttng my ls-v bottom end together over xmas break
- PICS OF BLOWN B16A
- all motor ls w/hondata Idle very high
- Can I make my b16 into a 1.8l or more without switching blocks?
- BC titanium retainers......URGENT HELP NEEDED!!!
- Finally the Ls-Vtec is done
- SSAC now makes cams!!!!!
- Apexi V-afc2 controller.....
- LS/Vtec street tuned...bought S2S1 cams.....ok to drop in?
- na or turbo which is bests
- Don't know?
- pistons above deck????? Hitting head help!!
- CR-V B20B Stock injectors size???
- Auto to manual swap
- help with cams
- some help with my gsr mild build
- GSR mild built
- Any truth to this??
- Jun
- skunk2 vs blox... intake manifold...
- BRRRRR....Cold starting issues
- do u really need a block guard for a N/A motor
- Milling ITR head
- OBD2 + Straight pipe = lean??
- Skunk2 IM intall + Pullies question b18c1
- New tuning on the B16b
- need help for parts priceing
- Leakdown test help
- 24.5's too big for 210whp?
- LS or GSR HELP!!!!
- 87mm build, looking for info?
- ACL quick question
- NOT WARMING UP??!!??
- i have a jdm d15 sohc vtec in my 95 hatch, And like every one i want to make more power without doin
- best intake manifold??
- bogs during vtec
- RPM problems
- which cams make more POWA (type s or euro R)
- will 91 octane be safe in a LSV w/CTR pistons?
- Cam ideas?
- Fed up with slipping skunk2 cam gears (bolt swap?)
- After Market Cams
- Anyone heard of a Feel's Intake for DC2????
- Q on new motor tune....
- cars bogging at 700 to 1000rpm range on a LSVTEC
- tunning ?
- Stock gsr build up Come help
- upgrading from ctr cams on 11:1 b18c1...
- which ecu to break in with?
- D16a6 head build......questions inside
- Another name this part thread!
- Need new piston rings.. question
- just redbuilt a b18c motor
- fuel injector question
- crower stage 2 or buddy club IV?
- b16 bottom end with gsr head
- Buddy club cams spec 3 vs spec 3+
- obd0 manifold on obd1 head
- b20b longblock or ls/vtec build?
- H23 Vtec. Clearance Issues with Big Cams?
- Anyone have over 200 WTQ all-motor?
- ideling problems need some help!!!!!
- who tunes hondata
- big NA cams for turbo and dialing out overlap.
- B16B NA dyno numbers,think i can make more?
- smog? for you all motor b18c1 people in cali?
- IN NEED OF HELP PLEASE
- Crank Fluctuation Crap Question...
- Searched but had no answer...Stock gsr w/ itr cams and skunk2 mani.
- Ok so has anyone actually dynoed a aebs GSR intake manifold?
- highest compression with 93 octane
- Going nuts! Cuts out only in WOT?
- Non-VTEC head with GSR valvetrain, Czech it out.
- Built GSR/PR3 Head what else should i change???
- p73 piston replicas made by inline four
- B18c1 in my EG needs new rings
- Exhaust valve seals VS. intake valve seals.
- 2.25" or 2.5" exhaust piping
- whats wrong with sk2 springs and retainers
- Feedback-Help me out.
- B16 head milled?
- skunk2 stage2 vs skunk2 skage3 vs toda spec c vs toda vtec killer cams
- d16y8 head onto d16y7 block; mini me
- JSR Type R Intake Manifold -- Any experiences?
- 90mm Pistons by CP *pics* N/A Nissan inside
- new piston in b18c
- Ticking Noise Maby waterpump?
- anbody use a DH race pulley?????
- Worried!!
- GSR W/ CTR cams
- please list all valvetrain that can with stand my skunk2 stage 2's
- identifying flywheel
- Oops Crankshaft sproket
- Those using Prelude LMA's please read.
- Best option for block/motor setup help...
- cams
- vtec crossover for s2s1 cams
- Neeg suggestions/info/feedback. JDM h22a setup. Changing from FI to N/A
- dont know if it belongs here but here it goes
- ___0.8mm headgasket w/ b16 head milled 0.30? whats my compression PLEASE___
- IM GOING CRAZY! gurus/experts PLEASE help me!
- how high are you reving your itr valves to?
- dyno b16a 162.9/112.6
- went to the dyno yesterdar
- piston and sparkplug problem
- Ls/vtec setup
- Power dropoff @ 8500ish???
- Muffler Suggestions
- Edelbrock or Skunk2
- B20A JDM Versus B20A5
- Hondata S300 + P73 OBD2 ECU?
- Any negative effects to switching to a larger TB?
- Drivers review of my new motor.
- Set up: LS/VTEC, ctr cams, upgrading to skunk pro2, Hondata.
- ITBs/Carbuerators
- Pro-fab install problems.
- Skunk2 cams
- dyno'd my b16
- 2point6 making a little progress...
- help me decide
- JDM H22 Type S H2B VS. K20R
- exhaust o2 sensor
- My NA LS VTEC build...kinda NA
- what header to use in gsr ek?
- built d16z6/y8 with skunk2 cam... loud valves normal?
- Ls/vtec Hp #'s
