- Hatchy b16/b18 swap
- eg coupe with jdm h22a :)
- MT 24.5x7x13 slicks
- Z6 VS Y8 Head??
- what to do??
- Built GSR high compression question kinda confused...???
- b20 block sleeve difference???
- nippon pistons?
- B20V Bogs really bad!!
- D16Z6 Head
- head oil control orifice fitting
- F23a block+F22a head=202hp
- How would you BREAK IN A Re-Built Motor?
- 99 civic with gsr swap itr header question
- header question for my build
- help me measure piston to deck clearance
- what plug wires to get
- How To: Homemade Bolt Stretch Gauge
- NO Go i repeat no go
- H22a oil orifice in block or not?
- Bye bye b16 hello ls V? ADVISE!
- Brian Crower vs Crower Quality
- 11.9 Full interior 99Si K24/K20 (Delirium-Motorsports.com)
- Skunk 2 Pro 2??? Idle
- WHAT K SERIES SWAP? (HELP)
- Building a moter
- eg + twm itb's = what throttle cable?????
- Who did your HEADWORK?
- JDM B16A VTEC Head 4 sale. $600.00 O.B.O
- LS vtec... Piston to Deck Clearence height. Questions
- k594m845 wiseco pistons compression
- Help w/ DD Gas Mileage Build!
- soon to be frank motor
- whats my compression
- Question on B series valves and cams.
- b-series bearings and rebiulds
- vibrant 4-1 problem
- 95 civic swap need help
- <---- building a b20v are skunk2 stage 1 cams to big? for b20v??
- help please
- which of these do i get?
- b16 from hmo?
- main relay?
- Any carbureted K-series out there
- ls block with a b20 head
- need a quiet exhaust already have world sport
- Type R Pistions in GSR block require tuning to run.
- what cams to use?
- F20b Build
- Radio block off gauge mounts???
- Oil pan gasket leaking on my LS/VTEC
- First build, engine selection. Where do I reasearch Honda engine models?
- motor build
- Why do the Newer D series have higher compression ratio vs. older?
- All Motor D16a6 DD build
- type-r fuel pressure
- dsm injectors
- My four door h22 build
- SOHC ALL MOTOR
- S2000 LMAs for B VTEC a possibility
- Sorry for another traction bar question...
- Is my setup considered High output so that the Big Tube header would work well
- H2B DYNO THREAD!!
- Use regular gasonline in an engine optimized for E85?
- ls/vtec 3 layer headgasket
- bad valve adjustment????
- trap mph what do you think
- Need some direction in choosing camshafts.
- I need help with some ? about an Mild N/A build..?
- Will this work, CTR pistons on ITR motor??
- GSR Swap in EK (Question-Searched)
- what to be expecting in my build
- Crower LS B20 NON-VTEC Steel Retainers...
- jdm gsr head vtec wire up
- HOW TO DETERMINE WHICH CAMS I HAVE
- JDM b18c5 Eg civic Itbs high idle causes?
- Maxing out 370cc injectors on na setup? help!
- Is this the correct spark plug??
- B16 what cams should i use?
- Cam timing.
- Very mild D series build questions
- what exhaust 94 hatch w/built ls vtec
- vtec no working??
- My goal: To pull away from the 2009 Cobalt SS Turbocharged
- Using e85. Smog and performance.
- need help b20v
- Stage 1 or stage 2 cams decision?
- need some input and help on new build
- New header 02 sensor not going in
- wat is peak and hold and saturated?
- Identify these B series cams. Yes another one with pics
- Is this b20 built ? please be nice lol
- f20b + t2t4 + 91 Prelude
- White Smoke??
- LS/V wont start after work shift ended!
- gsr rebuild 220whp!!!!!???????
- Traction bars a good idea for an all motor car?
- B18B B20 Valve springs
- all motor ls traps from today.
- I need Head Bolts for a JDM SOHC VTEC?
- just wondering
- what exhaust doesnt sound like crap
- What Crankshaft is this, B18, B16, TypeR, LS
- 244hp GSR Knocking on 1st Startup of the day
- Milling head causes Cooling Problem?
- How much power do you think my built b20 vtec will make!!
- An oldie... ITR cams and b16 LMA's?
- PCT pistons in B16a
- Hytech Replica Big Tube on a 1.8?
- Lets Talk: Volumetric Efficiency
- which spark gap. b18c1
- have some question
- need help comparing blocks
- Can someone est. my hp/tq
- ctr crank pulley?
- JDM ITR Block under JDM B16A2 Head
- jdm type r header worth it ?
- Plenum MAP pressure log required - dyno, road or track please
- ARP rod bolt nut
- Buddy club header
- rate 1 to 10 blox hsl competition series camshafts
- tuners - basemap needed
- Help with aftermarket Cam ID?
- b20vtec new build, nead advice on a few things
- new mini me
- arp rod bolts????
- Dyno and gearing question?
- Cams
- help, ignition timing off after cam seal replacement
- Which Header for my NA build
- From user experience throttle body, professional products, skunk2 or blox??
- what kind of ecu for lsvtec
- Equal to Spoon Engine Specifications?
- Dyno Graph Request: ITB's before and after
- ***DYNO GRAPH***B16
- ITR intake manifold vs Skunk 2 Pro Series
- axles pop out b20vtec in 94 EX ferio
- New F22 build
- Clearance issues on B18C6 Head/B16 Block
- b18c camshaft decisions
- 200hp is not hard.. where are they failing?
- what size slicks?
- f23 build questions
- KMS Engine Development....any good?
- need exhaust and header opinions(ls/vtech)
- best cams for stock internals
- What can cause a bad idle
- Crower 413s
- bisimoto camshafts
- need help in b20v fully built
- YCP b20 pistons...where can i get them?
- 90mm Piston weight.....Whats the lightest?
- Performer X install
- Rod bearing issue
- Clearance issues?
- b20 crank on ls block!!
- Building up a B16...Help please
- .005" Grad Dial Bore Gauge or telescoping gauges and Mics
- b20 build+ stock liners and nitrous?
- Spark plug question?
- best b18c
- anyone had blox hsl camshafts degree'd?
- all motor JUN cam ???'s
- do i have to get a retune?
- jdm b16 block with a gsr with type-r internals
- Buddy Club Cam Gear Degree Marks
- b16 / gsr combo selections, input wanted
- Diagnosis: Mild Build GSR, Black/Grey Smoke, Loss in Power
- Idle Problems....please HELP!
- Cam Timing on a B18C6 Cams/Head - B16A2 Block
- oil pressure
- LS/VTEC rod bolt swap out: one at a time method.
- B16 Block GSR head Question
- lsvtec oil leak...input please
- TB swapping q
- new valves used head question
- clearance question!
- B20 VTEC BUILD CRANK IS BAD NEED INFO
- h22 drag style header? personal opinion?
- jdm b20b tall intake manifold can i use?
- Misc Mis-Fire @ Idle Without A/C On??
- Check out this GSR head
- b16 block rebuild questions (searched)
- s2 stage 2 or pro 1?
- GETTING IT STRAIGHT - Da Port Polis
- rebuild gasket sets 2
- How to identify Buddy Club Spec3 Camshafts?
- b16 tb blox manifold help
- ITR - factory valve seat angles
- Will B18A Block Internals fit into B20B4
- Motor knocking when hot only on fresh build
- Timing Belt Hummmmmm...
- Header Gasket Compatibility?
- basemap for gsr
- Noob to all motor...Questions????
- reliability 13.5:1 87mm ls vtec
- b16 cai piping diameter
- B16A2 all motor build. The track project.
- Toda Spec Cs
- Pro3's on Supertech springs
- Stroked B18C..
- skunk2 Pro S Intake manifold??
- cams for my jdm type r.. quick DD question?
- fully built 11 second 95 bubble
- 12.7:1 compression. Daily drive?
- Spoon cam gear help!!!
- H22 cams?
- piston ring wear
- Results from porting?
- H Series Question Please Help Inform Me.
- Cali residence- What catylatic converter are you usiong on ur daily driven car?
- 240 whp 2.0 LS/VTEC. Done.
- What size injectors do I need?
- k20 RBC intake mani. on a h22?
- b16b w/ itbs questions
- compression
- help with cam choice
- ECU problem
- basic motor rebuild help
- Crower Valve adjustment questions?
- What spark plugs for a mild build GSR?
- long rod d16a6
- OBX 70MM THROTTLE BODY K SERIES
- bronze guides VS oem steel
- need quick advice
- zc bottom end with a vtec head
- Spun rod bearing
- Head gasket?
- Cams and idle quality
- ARE THIS MODS NEEDED?
- trouble measuring v2v "click"
- pulstar plugs???????????????
- swap
- bkr7e-11 spark plugs
- where is this oil comming from
- B16 Head... JDM or USDM? Dual Spring?
- b18c first time with race gas???
- Block Assembly
- UPDATE!!! (from "Sad Dyno Day")
- What makes a stage 3 engine?
- B16A2 Block / B18C4 Head to B18C6 Head
- itb's problems
- my first time building a all motor header...
- CAN'T DECIDE ON A CAM SKUNK PRO 1 OR 2 VIDEO INSIDE
- Can I get a price check on an engine rebuild?
- Redline for Forged internal B20 vtec?
- car idle funny after valve adjustment................
- which sensors for vtec?
- Poor dyno numbers on mild build...
- Engine Overheating Mystery
