PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 [197] 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. B18c Sir-G build
  2. RPS clutch??
  3. Max hp on stock b18b--all motor
  4. Wicked industried Intake Manifold ...what do you think?
  5. Another quick question about the skunk2 intake manifold install
  6. best cams, valve springs, retainers for bseries vtec
  7. b16 head or b18c1 head
  8. help vtec not working
  9. LS VTEC Question
  10. what am i missing? Building B16A..
  11. where to buy buddy club racing spec III cams
  12. how to reconize a type r crank
  13. LS/VTEC w/ Skunk2 Stage 2 Cams
  14. Ecu specs?
  15. Wicked-Industries flywheel
  16. jdm itr cams and usdm itr cams
  17. Can you Spray on LSvtec motors???
  18. claying engine - what clearances?
  19. Need some opinions
  20. modified c5 going in my 91 crx si
  21. b crank
  22. p&p head
  23. stock bore size
  24. reputable shop to do valve job in San Jose area preferably
  25. My LS build!!!!! Its close to being done.
  26. ctr/itr cams
  27. Building a motor will this combo work???
  28. who makes a damping underdrive pulley?
  29. Back pressure question
  30. maximum hp and tq from hondata and 290 cc injectors(ls/vtec)
  31. 13.7@100mph street tires!!! Merced Imports
  32. what is a good quality cheap oem piston...
  33. pistons for b16a1
  34. 5k dead spot..
  35. ITR intake manifold ?
  36. Which NGK Plugs For 12.3:1 CR ls/vtec?
  37. how do i want to hone/block guard my block ?
  38. is nitrous considered a means of forced induction?
  39. ATTN ITB users and fully built allmotor's i want to know your set-ups. not a BS post
  40. Best for daily driver....toda b's or skunk stage 2?
  41. ITR/Skunk2 cam (GSR Motor)
  42. Red Civic Standard -- dyno tuned!!!!!
  43. question about ctr pistons
  44. gsr vs poor man type r
  45. Increasing CFM flow through head?
  46. a lil something i built at school! (central ga tech)
  47. ctr pistons and stock itr injectors?
  48. need dtr phone number
  49. need help to go faster with h22
  50. CTR Injectors?????
  51. d16z6 build ideas
  52. all motor wont rev past 5800 @ wot
  53. heavy rims??
  54. i need some help
  55. trust anyone to port and polish?
  56. Daily All motor
  57. J's Intake Pics w/ stock gsr im/tb
  58. d16z6
  59. Installed Skunk2 Stage1's and timing is off + no gains in power
  60. port matching help a lot?
  61. Crower K20A2 Cam Specs
  62. p30/b18cR
  63. intake help *already searched*
  64. stock injectors on ls/vtec w/ buddy club cams, vafc, stock block
  65. toda valvespring question
  66. NEW DYNO IN THE HUDSON VALLEY NY AREA
  67. Fuel Pressure problem?
  68. old to HT.com, new to NA forum...
  69. 91 ocatne in a higher than stock compression motor
  70. ARP head studs
  71. another quad throttle bodies supply
  72. IAT sensor question
  73. Yo
  74. Endyn Skunk2 manifold
  75. Suggestions On Best HP Gains?????
  76. Endyn Skunk2 manifold
  77. cams vavletrain going in, clutch break in??????????
  78. I need help to find bearings for my LS
  79. anything wrong with SKUNK2 stg2 cams?
  80. Looking for some dyno results for Toda spec A cams
  81. Toda B20 Piston kit?
  82. itb's............ what to do with pcv?
  83. Port and Polish Dealers ? ? ?
  84. can my VTEC HEAD WARP from this...
  85. Throttle body & intake manifold question....
  86. Golden Eagle Ls/Vtec Gasket Opinion
  87. How much TQ do you have???
  88. Found some oil around threads of spark plug
  89. injector question for gsr
  90. quick question
  91. 12.5:1 to high for 91 octane?
  92. b16a jap spec do they come with dual valve springs
  93. 02 civic LX intake and exhaust
  94. Opening up combustion chamber and efffects on compression?
  95. aftermarket cams for hondas and emission
  96. All motor gsr compression questions????
  97. Valve springs too strong?
  98. closed loop/open loop question
  99. Has ANYONE ever put pistons in from the BOTTOM???
  100. Best thing to do to a ls?
  101. Progress pics of my mild GSR build *56k ok*
  102. Header Help!!!! Mugen
  103. Civic noob needs Weber help 4 d15/40DCOE Repost from civic forum
  104. My Future Setup..What do you think?
  105. LS Crank in GSR Block...
  106. LS/Vtec pistons
  107. New Headers Pics What you Think 56k Watch Out I Kinda Took Alot of PICS
  108. Anyone in Toronto Canada able to dyno tune my B16B
  109. ls/vtec
  110. Doing a fully built head and running Skunk2 stage II cams, What go you guys recomend for valve train
  111. itr b18c6 mods
  112. in what order should I buy my parts?
  113. opening chambers up to 84mm on GSR head ?
  114. CRV Block?
  115. All motor guys, what bearing clearances??
  116. JDM H22A EURO R Engine Swap
  117. Noob to all motor. Need some help.~ about cams~
  118. ITR, CTR and '92 GSR Cam Specs?
  119. What's the best cheap tranny fluid?
  120. Steel or Titanium retainers?
  121. no vtec and revs to 5000, b16
  122. not sure about this one
  123. loud ticking after adjustment help please
  124. help a newbie build a single cam..
  125. Dont know what to do, need help?????
  126. how do I get oil out of my spark plug passage?
  127. lsvtec axles?
  128. 345 cc Can it be run on P28 without Vafc.
  129. What's the bore size on K20 and K24?
  130. Does my setup sound good?
  131. SNEEK PEEKS: TECH43'S K24 SWAPPED EG4 VTi AKA "ktwizzle"
  132. h22 crower stage II please contribute things to look for??
  133. d15b vtec n/a build questions
  134. Mugen ECU?
  135. need help...ITR Mani swap...now Idle surge...
  136. all motor just bolt-ons
  137. Chipped ECU for Toda B's?
  138. problem with cam install
  139. JDM B16 CAM VS GSR CAM
  140. missing problem
  141. Jdm itr pistons in a Usdm itr motor
  142. need ctr pistons have cash
  143. Attn: Tanabe exhaust owners
  144. Compression vs. Weather vs. Octane
  145. any "how to's" for installing b series dual valve springs?
  146. VAFC help
  147. Mini-Me Swap vs. D16Z6
  148. Skunk2 Header?
  149. Fuel upgrades
  150. what r some good cams
  151. Skunk2 GSR Intake Manifold - Bore Size?
  152. ctr piston in B16a! (what is compression???)
  153. skunk 2 stage 2 cams with stock pistons.
  154. d16a6 head gasket
  155. b16 with ls crank
  156. Vibrant 4-2-1 ss header
  157. 200 whp GSR's
  158. CRV K24 in a 7th gen Civic
  159. How long to tune hondata?
  160. Reputable machine shop in DE,MD,PA area?
  161. stroked gsr
  162. jdm b16 into 94 civic coupe?
  163. Good engine machine shop in WA?
  164. Need Ideas and Opinion on LSVTEC build up?
  165. hondata! where???
  166. track tested my 404's
  167. 404's
  168. intake manifold???
  169. d17 build up help
  170. does anyone know the torque spec for a b16 head?
  171. stock valve spring and retainer rev to?????? help asap
  172. lsvtec ppl -- knock sensor
  173. Timing question
  174. LMA question
  175. D15b7....Vtec or no vtec???
  176. best intake manifold for GSR
  177. Good NY engine builders?????
  178. ctr pistons vs je high compression pistons
  179. intake install
  180. Any differences between a USDM and JDM GSR head ?
  181. ctr pistons
  182. BULLFROG(GUDE)
  183. where to buy hytech muffler
  184. cams cams cams, how about bottom ends?
  185. help choose between toda cams
  186. A good header on a B16B? Opinion Please!
  187. Piston/Wrist pin info needed... (708 pin)
  188. b17 exhaust cam specs???
  189. Q's about the RS cams..?
  190. JUN Type 4 Dyno numbers
  191. What would be next with my setup
  192. overheating
  193. HELP!! NEED TO HOOK UP VTEC CONTROLLER.
  194. install it or wait on parts?
  195. my radiator fan wont turn on, please help
  196. Threw down 161whp with my B16.
  197. which series motors can you feel a kick in the seat at vtec? just B? maby H? not D lol
  198. Crane Cams 253-0012 for B-series VTEC - a good cam?
  199. Stock 240cc injectors or RC 290cc injectors with Toda A's in a CTR motor??
  200. best frankenstein setup?????????
  201. dynoed my car yesterday need help on what is wrong please look
  202. em1's with ls/vtec or b20/vtec*where u at?*
  203. can't decide on upgrade...
  204. cannot diagnose this problem
  205. which block is better to use b18a or b18b
  206. parts list...
  207. Getting ready to plastiquage?
  208. B20Vtec dyno sheet
  209. Omniman?, anyone try this????
  210. GSR motor what do i do about the tranny????!!!!???
  211. just asking
  212. new cams for my b16a
  213. Question for the Hondata tuners?
  214. need b16p30 pistons asap have cash
  215. Installing Cams tomorrow--break in period?
  216. advice on pistons/rod combo
  217. code 22 vtec oil pressure help
  218. anyone with dc header and 2.5 exhaust? annoyingly loud!
  219. JG Cams Vs JUN III??????
  220. Throttle cable??
  221. new to all motor. have a ? about setup.
  222. any fast b16 with ctr pistons here???? please post up
  223. How much porting on head is too much
  224. 404's on a Low CR JDM B20B?
  225. built ls head vs almost stock ls/vtec
  226. skunk2 itm
  227. pwr radiator cap?
  228. Torque to turn Crower 403's with dual valve springs?
  229. itr pistons in an ls
  230. jdm/usdm K20?
  231. oil burning on fresh rebuild?? what gives?
  232. longer rods for H series?
  233. HELP..w/B18c (Your my only hope!)
  234. jdm b16 pistons vs. itr pistons
  235. Good tires for 14" rims????
  236. 20V ITBs on a D16Y7 engine
  237. IS IT POSSIBLE
  238. poor man type r
  239. Finally got pics of new DART motor!
  240. Does anyone have a difinitive answer?
  241. good compression for an ls/vtec???
  242. What Intake Manifold are you guys using?
  243. Oil dipstick pops out
  244. RLZ race car?
  245. Vtec not engaging?
  246. distributor
  247. vtec water/oil pump?
  248. exhaust fitment
  249. Would B18C1 sleeves fit a B20B?
  250. SCAT Crankshafts??? Anyone used one yet???
