PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 [166] 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Port -N- Polish?
  2. DHL Delivers today..........ooohhhhhh
  3. I asked the Nitrous question cause i have an all motor car with a high compression and wish to put a
  4. Machine shop prices
  5. CTR pistons... A yes or no?
  6. Cam Recommendations for my Build
  7. DIFFERENCE BETWEEN PEAK AND HOLD AND SATURATED INJECTORS
  8. mantaray motorsports head package
  9. san diego HONDATA
  10. ls/vtec for 96 ek?
  11. are k20 and k24 cams interchangable
  12. Brand NEW GSXR 1000 ITB'S!...the new project
  13. Picture Request - b18c5 Valve-train
  14. Problem w/ Oil Pressure Switch
  15. Shorty Watkins Wake and Funeral info
  16. ANYONE ever had a chipped/flashed ecu stop working properly for no apparent reason???
  17. buddy club cam gear timing??
  18. itr cam gains in gsr?
  19. Crower 402 cam questions...need advice
  20. bigger injectors or more fuel pressure...
  21. je pistons or usdm integra type r pistons
  22. pre-tune help
  23. Mini Me Swap Possible With a D15A2 Block?
  24. Worn LMA's effect on power?
  25. b16 a few questions i need answered.
  26. K20A2 IPS-K2 Dyno
  27. CTR throttle body
  28. Safe compression #'s to use nitrous on
  29. which plugs and gap??
  30. what size are hayabusa itbs at the opening???
  31. DC 4-1 Header Fit All B-series??
  32. destroked b20vtec on juice, fillin in gaps
  33. b18c1 compression with b16b pistons?
  34. gsr bottom end, what oil pans fit ???
  35. Ls vtec tend to blow?
  36. question on crower stage2 cams without springs/retainers..........
  37. Gsr cams Peak power
  38. Titanium retainers worth it
  39. after skunk2 mani install...car idle flys from 1500-2000 consistantly
  40. JUN 3 all motor setups??
  41. Q's about claying block
  42. Rocket Motorsport M24 Idle Sound Clip
  43. Need D15B7 Replacement, #4 Cyl is @ 15psi Compression.
  44. Locking the rocker arms by compressed air
  45. what website
  46. K-series Crankshaft: Race Preparation by Castillo's Crankshaft Service
  47. Does this sound about right?
  48. anyone with e-cutout on allmotor setup?
  49. at what rpm do blox stage 2 cams stop making power?
  50. tell me what yall think of my build up
  51. b16 measurments quetions
  52. a real good site with basically everything u need to know about B-series motors
  53. limits of stock ign system.
  54. good streetable cams for an ls-vtec
  55. b16a crank pully difference
  56. possible to use FAST system w/ K20 ?
  57. 12:5:1 help
  58. 2,200$ to much for worked block?
  59. Machine shop in San Diego.....who to go to?
  60. Porting b18a head(pics and ?'s)
  61. ITR heads for ls/vtec??
  62. skunk2 valve spring broke
  63. b20/vtec+buddy club 4+01 type R=good times
  64. b-series exhaust vtec camshafts...are they all the same?
  65. <<~~ 211 hp 1.8liter pumpgas~~>>
  66. NEED HELP WITH MY MOTOR SETUP
  67. compression question?
  68. Florida/Georgia machine shop to offset grind crank
  69. Crower cams and Omnipower valve train
  70. What do u guy prefer?
  71. Need headwork. Where to go in New York
  72. car blowing out white/blue smoke
  73. Checkout pics of new HyTech Production headers ... insane !!!
  74. JDM 4-1 header vs Megan 4-1 Header
  75. Why does my power drop off so sharply at 6700 rpm - B18c1 block + B16a1 head
  76. Proper injector cc's for 11.5 to 1 compression forged h22?
  77. automatic b16 retainers
  78. stroked b16 to 1.8-1.85L?
  79. i just installed my FPR.... is this right ?
  80. what the f@$k is causing my misfire?
  81. H23 dyno 248whp & 195trq pump gas, stock cams
  82. back pressure. too much/too little?
  83. exaust and crank case venting
  84. Breather kit fittings
  85. Octane Question
  86. Opinions On A Mild Set Up
  87. Car doesn't idle after Skunk2 Pro1 cam installation
  88. msd ignition need opinions/suggestions
  89. 1.8 to 2.0 Do you need anything
  90. Reconditioned Rods?
  91. reving b20vtec to 9000rpm
  92. where are my cams?
  93. new ls/vtec swap... power expectations
  94. Dyno results J's racing Intake vs. AEM CAI on my ITR! J's intake racing all hype?
  95. Questions on putting GSR girdle and other parts into LS Block
  96. anybody have intake & exg valve clearance for h23?
  97. fitment problems with OBX-R Precision power Underdrive Pulleu kit for EK ??
  98. few LS vtec questions
  99. Exhaust Diameter
  100. best cams for CTR's in a gsr????
  101. Y.C.P pistons?
  102. Velocity stacks for Suzuki Hayabusa ITBs?
  103. Experiences with STR 5bolt cam gears?
  104. Question about cams
  105. Does Portflow make outter valve springs?
  106. DC sports 4-2-1 from 95 LS will fit B16a ????
  107. H22 valve adjustment specs with Crower cams?
  108. High revving LSVTECs, chime in!
  109. hondata s100 and ecu po6 for ITR
  110. how high can it go
  111. h22 cam question..need help
  112. Built high compression motor with stock cams??
  113. GOOD INFO for Skunk2 cam gear owners/curious HTer's
  114. Car stumbles
  115. Quaife LSD Question
  116. gsr rebuild
  117. mugen chipped?
  118. Cam Question?
  119. TB sensor question
  120. which is best ecu for my gsr?
  121. OK guys a Maxbore gsr TB vs stock gsr how much hp after tuneing?
  122. who has swapped main caps???
  123. new rods? necessary?
  124. Engine Management systems?!?!?!?!?!
  125. questions about ITB's for B-SERIES
  126. 230+whp and Street Traction?
  127. ls vs gsr throttle body inner diameter
  128. Need Help!!! Timing belt removal. Thanks
  129. (WTB) A 92-95 DX or Ex motor
  130. Down on Power?? Your guys thoughts
  131. all motor b16 help!
  132. "X" markings on B18C1 crank?
  133. b16 pistons in Ls/V-tec
  134. Flat spot at 5000rpm in 5th..?
  135. JG Sheetmetal IM + RPM Service TB install
  136. ITR FPR on a JDM B16a?
  137. GSR with P30s, M22s and Supertech Valves
  138. CTR VS ITR PISTON in a GSR
  139. f-d series hatch
  140. is b20/v-tec reliable
  141. suggested fuel pressure?
  142. B16 S2S2 SETUP. DYNO TEST RESULTS.
  143. Spoon BUILT B18 question.
  144. Compression ration for stock b20b/z with 1st gen b16 head?
  145. spung crank bearing ?
  146. all motor b18a questions
  147. f20 vs h22
  148. gains from a JG Edelbrock
  149. Another DynoPack and DynoJet comparision... please help.
  150. How is my planned build sound?
  151. Omnipower dvd out??
  152. CP 12.5 Pistons but which one???
  153. Anyone ID this k series head?
  154. ls-vtec fuel injector wiring, help.
  155. my bin file for ITR with itbs (Crome and Uberdata)
  156. im sure this has been asked a million times before but cheapest way to get 200 whp?
  157. torque
  158. LS/Vtec, 3000 rpm idle, no vacuum leak!
  159. 87 CRX si Orphan
  160. New Setup, Tell Me What You Think
  161. non vtec 2.0 guys..just a couple questions
  162. bosal performance products
  163. Should I upgrade the timing belt?
  164. Poor mans R..Help with cams...
  165. anything im missing
  166. Is this true?
  167. Why not just a S-AFC?
  168. Help on Compression Ratio on LS Vtec
  169. tranny fluid?
  170. rebuilding my motor....what else?
  171. Metal Shavings in Vtec Solenoid
  172. itr valve springs / blox type b's
  173. new to all motor
  174. what size rod bolts.....
  175. New DTR B-Unit header
  176. ls/vtec
  177. anyone knows r&d websit address??
  178. blow up??
  179. Head worked GSR Vs. Type R integra
  180. TBONE Piston Coating ... Best I have seen !!!
  181. F*ckin Crank wont come off oil pump
  182. swapping b16a1 automatic cams to b16a2 manual cams..vavle adj?
  183. These look like civic type r cams, but are they??? Please help
  184. B17 sleeveing
  185. CRX HELP
  186. BC3 vs. BC3+
  187. B20 injectors??
  188. Need suggestions
  189. I need someone to tune my car...ATL, N.GA, etc area...who do you recommend?
  190. B7 pistons in a D16
  191. <<<<<<<<<<<K Series CAMS Thread >>>>>>>>>
  192. Clyinder Head porting for all motor.
  193. Type-r trans Vs. Gsr trans
  194. Timing belt
  195. kamikaze header?
  196. I need a couple tinths off in the quarter
  197. exhaust fumes, smell it from inside the cabin?
  198. Best FPR
  199. f20b ITB update
  200. To use a heat shield or not?
  201. Tapped for LS-vtec, then untapped... stay away?
  202. do my valves need to be readjusted?
  203. Valve Guides
  204. this owns you!!!
  205. B18C1 Stroker Kit
  206. need help passing smog
  207. anyone know the number to RS Machine?
  208. h series aems on b series motor
  209. Pinging = Timing or Fuelling?
  210. Catalytic Converter (What's the worst thing that can happen)
  211. ECU question
  212. Which flows better
  213. Buddy Club Spec. 4 valve lash.....
  214. VART !!!!!!!!!!!!!!!!!!!
  215. street all motor ls
  216. 11.8:1 Or higher Safe?
  217. YAY!! Omnipower Skunk2 presents!!
  218. compression
  219. H22 Tuning Questions
  220. 200whp practicle with this GSR setup?
  221. crower 403's
  222. OK guys B-motors - Vs - K-motors ????
  223. b20vtec
  224. throttle body recommedations for built na b20v
  225. rebuildin b18a..need help
  226. Jenvey itbs... best place to buy em?
  227. Help me squeeze some more hp out of my GSR All motor setup...please.
  228. is a b16 with ctr pistons, bcIII cams and tuned with vafc recomended..
  229. how to make a b20b a b20z?
  230. LSVTEC exhaust?
  231. Custom CP Pistons 87.5mm
  232. 500 to spend what next? (looked at old topics before)
  233. OBD1 dizzy with OBD2 harness What to do?
  234. how common is pinging while under no load?
  235. Expected Performance??
  236. B20 guys NEED ADVICE!
  237. I need a BASE MAP for LSvtec!
  238. destroking b16--> 1.5liter b16
  239. Where to buy P72-00 pistons?
  240. 370cc injectors too much?
  241. What size fuel pump for my setup?
  242. air filter or screen
  243. Throttle body queston!
  244. smc+
  245. ---246whp&170trq--- MY ALL MOTOR STREET CAR.
  246. Ls block problems
  247. raising compression
  248. @@@b16a HELP ME TO HIT ATLEAST LOW 14's OR HIGH 13's@@@
  249. what's going on with detonation?
  250. How Long to break in ?
