- Best Spark plugs for a b18b
- will i hit 200 hp with this set up??
- Toda header clearance?
- Need Professional advice about muffler performance
- Whats a good way to increase Compression??
- gsr rods ls crank???
- piston help
- Identifying BLOX cam's?
- HELP with LS/VTEC!!
- need help:gsr block ls crank
- please help to identify these camshafts
- Question: Locking vtec with air pressure on d16y8 to degree cam
- TB/IM air inlet size question
- teach me about cam specs in relation to HP
- Identifying B-series cams
- I have a quick mini-me question
- Shaved Dowel Pins
- b18c5 vs b20 bottom end
- Boring stock sleeves for my daily driver
- m22x vs pro1 and pro1 vs BC 4 dyno graphs
- question on cams and stock ECU's
- Another what cam to buy thread...
- LS-VTEC build help
- Help With Engine Build Ls/vTEC
- replica header
- should i trade my b18c block for a b20 block???
- engines dies after starting (only sometimes)
- engine building tools
- Forged Rods on Cast Pistons????
- chances of ARP head studs stretching?
- ebay header
- F22 crank in H22A1 block, reliable?
- Using a turned crank?
- CBHaus Flywheel and Valvespring Specs
- Re-sleeving a Sleeved Block
- First engine build some time soon??
- hey how much would it cost
- Fastest 1/4 mile time with B-series in EK?
- my ENDYN engine have finished
- Mugen 421 or LogicMotorSport tri-y
- Need one persons help
- Can anyon help a brother out!?
- Smoke with VTEC and black soot on bumper
- Does anyone know what hp will be made?
- Shop help
- lsv ideas
- bouncy Timing belt
- Post your stock bottom end b20v/lsv dyno numbers/track times
- new b18a1 build check it out.
- build thoughts..
- Link for ls vtec wiring in crx
- Anyone know ARP torque specs
- All motor drag cars weight street class question ?
- ticking engine. bad lma's???
- d16 ITB's
- b16 all motor .Need some input!!!
- winter build! what cams do you reccomend?
- My All Motor B18C1 Build Kinda Died... After 3k miles....Help?!?
- OFFICIAL HONDA-TECH.COM ANNOUNCEMENT EVERYONE READ!
- Throttle body difference's-help with identifying.
- another weird idle thread
- Anyone have a clue to RLZ's cam specs?
- NoTec? (JDM B16A block / USDM B18A/B head)
- b20 vtec high compression problems, possibly tuning? PLEASE HELP!!
- Adding a second headgasket, how much loss in compression?
- y8 head to y7 motor?
- LS vtec swap..what head to use?
- Sunrey crank? or eagle?
- My Engine Build
- Great job Bisi!
- ROCKET MOTORSPORTS VALVESPRINGS
- Another B20VTEC Build in progress (85x87.2mm)
- The right solenoid...???
- Rod and piston question
- 72mm Throttle Body too big for my setup?
- b18a1 rebuilld kit!!
- salvagable cams? (no pics sorry)
- is ALANIZ TECHNOLOGIES closed down ?
- where can i get rockets m24's cams?
- D16A6 block with dohc jdm zc pistons valve clearence issues?...
- Open exhaust can it damage your engine on s2000?
- What should my setup do?
- sleeved b18b block
- compression test of 300psi b18c
- b18a... b20 head
- Gsr Cams In B16 . Whats ur input
- Has anyone tried ThermalGasket.com Intake Gaskets?
- Difference in compression calculators
- gsr with itr pistons and ctr cams
- B16 Head Height! PLEASE need SPEC!
- B16B Upgrades...???
- Want some tips and opinions on a GSR build.
- 5 point main girdle
- Ls/vtec build
- what hp to expect out of a built ls/vtec?
- Good brand rod bolt stretch gauge besides ARP?
- Need advice on a build
- Gsr build help
- All motor s2k ideas needed...
- what cam for a b16
- high comp pistons in b20
- Problem With GSR, type R rebuild, White smoke, File to fit rings?
- my valves wont seal no matter what... wtf??
- **** b20 vtec. need size for tap*********
- Anyone built f20c/f22c motors (N/A)
- Need advice on b18c build
- boring
- b18 A/b, b18c1, b20 B/Z
- Its about time I post mine.
- Raised wrist pins of the stroker Rollerwave pistons
- My build/progress thread
- bent valves issue?
- new 3" collector header question
- H22 Skunk2 vs Euro R Intake Manifold
- Just a little advice is needed.
- LS Vtec pistons which ones?
- Issues with fuel injectors
- Exhaust throttle theory
- ls motor build?
- Tapped B16 head back to normal...
- WHAT HELMS MANUAL FOR A B16A?
- where to start?
- Running on warped cylinders??
- skunk2 stage3 cams - set up suggeestions
- OBX ITB's
- Buliding H22 Need help
- The Mystery Header Revealed
- Installed OEM timing belt: Too much deflection?
- JDM F20B Blue Top Accord SiR-T into EGhatch--Post your opinions.
- I need a port n polish for my gsr head
- Has anyone tested the Blox hi-flow header?
- Weisco pistons and stock gsr sleeve = ok?
- My K20 rebuild
- question on addressing idle problems on new build
- LS vtec story
- cracked distribiter cap
- b16 distributor leak-new o ring but still leaks
- Question on oem piston pis
- running really rich fully built h22
- wiring harness question??
- obd0 b18a w/ b20z cams?
- ferrea+supertech=???
- I need help choosing between three cams for my setup and goal
- Need help identifying this sensor! Oil pressure?
- BEEF IT UP Also Vtec SOLENOID
- Outlaw Engineering ThermoBlok SPACER KIT
- big 86 mm build acting up need all info.
- 1998 Type R
- What Size Exhaust?
- where to locate aftermkt oil temp & pressure sensors on K-series
- K20z3
- Head Off Valve Pressure Test Tool?
- LS-vtec problems
- Sk2 Composite fuel rail.
- ross racing rings
- Ring around crank. Very Faint. Ok to use?
- advice on engine build
- B20Z non-vtec P2V issues w/ Crowers?
- QUESTION ABOUT GOLDEN EAGLE VTEC CONVERSION KIT
- Head build, help
- Rocker arm question
- 1.9L ls?
- itr intake cam help plz.
- B16 head help
- whats rods and pistons for gsr block
- odd discovery with crower 401 cams, the gears and timing
- gsr intake mani w/no butterfly
- Thoughts on future 2.1L Lsvtec build
- port and polish ls head!
- skunk2 pro2 questions
- Lmas still Knocking
- knockin noise? fresh built engine
- question about b20 distributor
- all motor F2B 13.3 on street tires!
- Who makes a block off kit for oil squirters?
- Sizing for OEM bearings
- How to Properly determine a power goal
- D16Z6 MAP AND TPS Connectors
- High C/R SOHC, DD?
- OBD0 B16 looking to make 180-190 whp.
- Victor X IM throttle cable bracket??? chime in please!
- help.?!? skunk2 camshafts or not.?
- Bowl blending, port/polishing- Is this Valve seat Ruined??
- H23 with H22 pistons??? Help me out please
- NOTICE: Immaturity Level
- Plastigauge with stock rods
- i need help!
- b16 all motor
- ls/vtec help?
- b16 head on b18 block
- ??? Compression ratio ????
- GSR all motor build help please ???
- ctr intake cam on stock itr motor
- N/A Help Please
- Problems with N/A F series - header flow issues?!
- help really a noob
- b16/b20 questions
- Project 85x89: Bittersweet Track Day, Season-Ender '08
- d16a6 fitmit to a d15b2 block
- OEM piston-wall clearance in a street motor
- Building a set of ITB's for my d series motor.
- product review: SKUNK2 PRO 1 H22 cams dyno inside
- B18A1 vs B18C1
- d-series
- compression ratio of a jdm b16 short block with a gsr head.
- why change for a stud ls-VTEC
- a few pics of my daily driver!
- Pressing wrist pins?
- what is the meaning of a compression ratio?
- B20Vtec Pro3 P2V clearence issue
- Poweer!!!! jejeje
- Crank and Rod Questions from a NEWB!!
- ITB on a Daily
- Limits - B16 Stock and compression
- gsr rods....itr pistons? or b16?
- LS/Vtec build. Questions about parts and smog.
- Very Strange!!!! (EM1)
- b20b?
- d16z6 upgrade
- ENDYN K-series headwork marvel - this is what makes HP (will be at SEMA as well)
- toda b's with stock timing belt?
- blew my d16y8
- can a d15 block stand up to 12:1 compression
- b16b stroke
- NOOBILE QUESTION
- air duct
- skunk valve springs vs crower valve springs
- Opinions on a b20z dyno
- STR intake manifold on stock gsr
- Looking for detailed dyno info, not charts...
- Need help finding detailed dyno runs for sub 2000cc. N/A builds
- Combustion chamber fix?
- ignition timing, cam gears and the shaved head.
- spark plugs?
- JG vs ported Skunk2, you pick
- LS connecting rods in a D16
- Ti or OEM retainers for my set up???
- Hows my practice pnp job haha
- F1 Heritage
- b18 block b16 head
- NA h22 dyno at Import Auto Pros!!! 205hp stock head and block
- fox race co h2b headeranyone use it????
- LS V-TEC Q'S
- blueprint mfg
- GSR pistons on ls rods?
- high compression poor mans type r
- toda spec b camsw/ spoon cam gears on a b17a1
- what u think ill get
- all motor overbore powerbands
- Injectors and fuel atomisation > power
