- how do i get into the 12's all motor
- ACT chromoly fly wheel. is it worht $200
- who is a good machinist in chi town or area
- does this make any sense?
- need prof. help new to hondas
- super duper pistons
- name my spark plug.
- who is a good machinist in socal?
- Precision injectors- anyone using them?
- B18C1 setup
- JDM ITR rods balanced?
- having mad issues
- how much would it cost my 2 put a K20 in my civic?
- raising compression in a type r
- Getting Crower stage 2 cams for my H23 w/retainers and springs...
- Highest WHP on SOHC?
- custom 2.5" exhaust for a 1st mod:::: Overkill???
- Wiring help ??
- CEL 22: valve timing oil pressure switch... Howdo i tell if switch is bad?
- GS-R setup questions
- LSVTEC high rpm reliability..vs GSR... cost effectiveness.
- Head Gaskets and compression questions for mix and match engine
- how to get most out of b16?
- How to check if your block surface is warped.
- h22, gsr vs spoon???
- want to do all motor stroker on a budget
- k series cams??
- HOW CAN I IMPROVE WITH...GIVE YOUR THOUGHTS...13.9 SEC...WANT TO IMPROVE
- Titan Motorsports Dyno Test \\ Rocket Motorsports Spark Plugs
- 94si94cx Project Log (56k blow me!)
- Air filters!!
- What can i do
- which way do i turn my cam gears to advance/retard them
- Hotshot 4-2-1 Header B series
- Need help on my swap
- LEAN Problems
- Question about 94-95 LS and a 98 LS
- how many degrees should i adjust my cam gears to get the most power out of them
- H22 civic race car.. where to start
- Dyno Run Before Cams and After Cams
- Can i cut my own valve relifes deeper with the motor in the car?
- ECU help
- whats the deal with blockguards?
- Budget Build
- VTEC smoke
- neep some opinions on building a b18 motor!
- AEBS vs Skunk2 manifold
- D-Series non-vtec cam question
- IB Wiseco Specs?
- Which fuel pump should i get? 190?255?
- Weapon-R header question
- how many have just "bolted on" a block girdle?
- Advancing timing on a 11.5:1 GSR engine...
- REV valvetrain or PORTFLOW??
- Please help - CTR Piston problem!
- what clutch and flywheel combo for good price? close to 200 whp setup
- B18c1 VS. H22(a) ???
- itb's on daily driven h22a??
- b16 rebuilt, how the average labor cost???
- Jun header.
- LS notec rebuild NA motor..
- All motor LS, read please.
- best IM and TB
- mildly built b16 question
- Ls/Vtec Vs. Poor Man's R
- jdm type R header part number
- ls/vtec knocking!
- b18c almost done coupe more questions
- Compression test
- GSR crank or LS crank ???
- Rev limit B16a w/ built head?
- H22 motor swap
- engine swap s2000
- ls vtec question
- Dart block question
- Crower 404's, where to find, don't see on groupbuycenter anymore???
- 62404 intake cam and JG 301 exhaust cam, much difference than straight 404's?
- Looking for engine mod suggestions
- stock car, looking for suggested modifications
- d16 to b20
- HAS ANYONE had an ECU chipped by JET...NEED YOUR HELP?
- ARP rod bolts and head studs, worth it w/ my lsvtec?
- automatic intake mani ???
- rs machines
- Getting to the 200 mark.
- obd0 to obd1 problems
- b16 pistons in ls motor
- where to get d16 high-compression headgasket
- B16A problems!!
- lsvtec rev limit???
- Cam Help
- Help! JDM ITR header with B18A1
- RC Engineering Clean and blue printing service.
- how do i remove a layer from OEM head gasket?
- Comp guru's please help me.....
- ZDYNE ECU ON A CRX LS/VTEC????
- anyone have rod weights?
- ls/vtec opinions and suggestions
- Whos going to win the nhra, nopi, idrc, all motor class this year?
- b18c1 and b18c5
- help new to hondas b16a2 into 95 coupe
- King engine bearings
- LS Motors
- RODS FOR NA
- *Quickie: Spark plug gap, trying the BKR7E's....
- where to find or a place to buy ferrea valves
- high compression = lower vacuum pressure ??
- Potential for a D16z6
- injector size for my application.....
- Aftermarket Cam Gears.
- can I mill my B16A head .030
- DH racing, Does anyone use them?
- 3' intake for a type R
- My setup... comments please!!!
- WIERD PROBLEM PLEASE HELP
- should I keep the gsr or get a h22
- who has a hytech twin loop on their hatch
- Is a ported head worth using
- **CRANK BALANCE QUESTION ***
- Wanted: Dynos of 4-2-1 vs. 4-1 header on the same car
- Questions about the LS transmission and compatibility with other engines
- wich sleeves has the best price?
- Cool JDM B18C (SiR-G) Video
- Is this Gsr block worth $700
- A/F Ratio Question
- Take a look at my new setup will I need vafc?
- skunk2 im and stg 2 cams???
- Check List...
- Can you reuse intake and exhaust manifold studs?
- Question about Air/Fuel ratio.
- In with the good air-out with the bad hahahaha
- bits for porting/polishing
- JaredH's Dyno.
- CTR pistons in GSR block?
- How long do titanium retainers (like Skunk II's) typically last???
- Oil in spark plug hole?
- revvin my b20vtec
- Darton or Golden Eagle Sleeves?
- what headers for 98 GSR?
- cam gear degrees???
- What is a better intake system AEM CAI or Spoon
- anyone know of a good compression calculator?
- ericks racing tb
- DOHC conversion for D16 series engine
- how to tell CTR cams?
- Buddy Club Racing Spec III cams?
- buddy just got a type r and we need ideas....help
- k series final drive??
- Need Help with my CRVTec!!
- proper break-in methods...
- prelude injectors
- ecu code troubleshooting....(yes i searched)
- Gas mileage
- The Definitive CTR Piston / B16 Thread
- What do you think about an Allmotor K20a Race engine?
- whats the best motor setup to run in 92 civic si for daily driving and capable of 12's
- itr valves.
- LS Head Milling Ques.
- copper gasket spray?
- b-16 w/golden eagle sleeves can be bored to????
- Q..FOR THE HEAD PORTERS...
- Boosting power on daily driver? Civic
- Crank Angle Sensor HELP please
- obd2 question
- dumb question but: what markings would be on an JDM Integra Type R Intake manifold?
- PLEASE HELP, valve adj nut fell into oil flow hole!!!
- Best filter for CAI?
- Desperate for Horsepower
- **check my set up please***
- JDM B16 sir v1 or v2?
- b18c5
- B16a vs B18c1 Head
- what should i use to get to here?
- DC JDM 40-1 header, how long is it?
- CAI with airbox
- B-series Camshaft Specifications
- Finishing up my motor have a few tuning questions
- Adapter for P73 ECU...
- compression calculater
- wiseco pistons for b20?
- Building my JDM GSR!
- Mugen TL and T1r b pipe will it restrict power?
- B18a with high NoX levels what to do???
- What's the lingo????????????????????
- Axle Bind??? PLEASE HELP
- HELP!
- Ignition timing 95 ls
- Tuning ecu after rebuilding head??
- Toda spec b valve adjustment with toda cam gear question
- comparison between 11:9:1 and 12:5:1
- TYPE R CAMS VS. ZEX QUICKTIME STAGE3 CAMSHAFT
- May have to use stock injectors on my setup...Yay or Nay?
- CAM SPECS??
- is a stroker kit even worth it?
- HOLY OIL LEAK - PLEASE HELP...Were STUMPED
- Parts NOT To Re-use During A Build
- Main & Rod Bearings Re-use?
- injector for a b18b
- MILLED HEAD, CAM TIMING???
- what c/r for stage 3's
- civic cai
- Price of headwork in southern Cali
- Re-ringing block, low miles, replace bearings?
- MHR head porting
- k20a2 pistons!
- Skunk2 Stage 2?
- TRANNY QUESTION PLEASE INPUT
- hi flat cat or oem cat
- Swap Questions
- h22 all motor questions and nos
- What kinda suggestions for a NA buildup with a stock b18c1 block.?
- B20VTEC, 225 WHP possible?
- B16 Head, any head porters, analyze these numbers....
- How do i measure my oil pump gear to determine if its 80 or 84mm?
- probs with 82mm pistons in gsr??
- e
- ls/vtec
- Just wondering, do you all get burned out? Little History.
- Toda Valve springs work on Jun type 3 cams?
- Wanna trade ECU's
- H22a Throttle Body vs. B16a Throttle Body.
- JDM P30's in B18C1?
- are there any head porters here?
- DIY: OEM thin gasket questions
- valve lift specs?
- Code 43!!!!!!!!!
- Anyone ever put a B18C head on a B16
- CTR pistons in b16a2???
- How many teeth on tranny gears?
- suggestions??
- full race headers??? where from???
- b18a vs. b18b... which head flows better? or are they the same?
- Explanation of LSVTEC & B20VTEC
- Where is the VIN number on an B18b block?
- Pics of my 10-94 header and kteller exhaust
- Need Help choosing Cams and Valvetrain plz
- B18B head bolts for GSR?
- What do i need to acheive 15:1 compression? VTEC eliminators etc...
- Help w/ basics on V-AFC
- SiR2 camshafts?
- sohc itb
- HELP! I noticed something while starting my build. Tell me what you think
- ghetto block brace
- WHO thinks a Lightweight Flywheel is WORTH the $$$
- 13:1 or 14:1 compression in Race car?
- What kind of Pistions to go with?
- are stronger A-arms needed for ls vtec
- injectors size
- BLOCK PUNCH OUT???
- would a b18b auto trans fit in a 93 integra automatic?
