- Got my build dynoed!!
- questions about my build
- Civic H22 Mild Winter Build...
- Cut valve guides good for DD?
- skunk2 pro1s too much for my aspirations?
- ID this header
- A good one??
- Head won't come of
- Valve Cover Bolt BRKE OFF..... Anyone help with this???
- Wrong size rings in motor
- valve lash
- big or small tube
- Dowel Pins
- b20 build sleeve question
- lsv problems in my 00 hx coupe
- Could use the Imput
- cam gear adjustments for skunk2pro1 cams
- cel code 21 comes on after each pass??!?!?!
- Advance Street Performance?
- How much to machine off the oem PCT/B18C1/B18C5 piston to run a factory LS rod???
- Intake manifold help...
- Antone using B17 Pistons?
- z6 or y8 head
- Bisimoto headers, worth the money????????
- First Gen B16a Lost Motion Assembly
- ls crank and rods in a gsr block
- itr parts
- i wanna quite down my car but not loose hp? help
- b18 block build....searching for 250
- How big is my combustion chamber?
- D Series Bottom Ends
- FIVS on a skunk2 pro series intake manifold
- where to get 3.5" intake?
- ITB advice please??
- Cant decide on itake setup
- B16 and LS torque specs?
- What is backcutting a valve?
- Need a "how to" on H22 LMA's in a B16
- b18c1 stroked
- High compression B20
- Opinions On My B20VTEC Build?
- H22a4 Rods, condition ?
- k24 all motor non-vtec?
- Test for bad valve seals?
- Where can i buy a freshly darton sleeved B20 block
- 402 hp race K26
- dart tall deck Vs K series.
- High CR, Aggressive Cams And Street Driving?
- Installed ITR throttle body, now I need help!
- has anybody used this site or can put input on this block
- B20 RS ITR Pistons
- whATS THE BEST WAY TO GO ALL MOTOR B2OB VTEC
- Quick Cam question
- dowel pins not linin up wit headgasket, plz help
- Anyone Here Running 12.0:1 on pump gas??
- B16A2 Cams vs GSR cams?
- new stock rod bolts, questions about installation
- AN-R?
- my lsv compression results
- dome top vs. flat top
- dynamic flow effect
- Rocker Pad wear. OKAY?
- usb16 pistons in gsr
- high HP NA D series? where?
- Problems w/ flywheel and ITR crankpully
- EK Ls swap, can stock size piping work: BAR? SMOG?
- Do I need new valve guides?
- what is a good exhaust size for a stock gsr
- Highest c/r on pump gas?
- fastest b-series all motor....
- Question: D16Z6 with ZC Pistons
- tapping or knocking, tried searching
- going to up my compression what do you think..
- 11.5:1 CR on ls vtec build... cams?
- Building a new motor for my 1999 si
- Blox B Cams for b16??
- What size intake for my bolt on h22?
- OEM CTR pistons vs Nippon Racing pistons
- 2.0L Poorman's ITR Build Questions
- n00b-Tech: Gain a bunch of power for FREE! (dyno inside)
- nasty vibration
- mild b16 mods
- Tuning a B18C4
- Buddy Club BC3+ cams 10:1 compression vs 11.5-12:1?
- b18b1
- what is a good estimate of quarter mile times for a bone stock jdm gsr lsd in a eg hatch
- h23 pistons
- ITB Facts
- looking to buy a b16
- all motor LS vtec gsr head cam question
- Buying a motor
- intake manifold
- any b series experience with buddy club spec V's???
- Am I knocking?
- What kind of plug wires do you guys use?
- How Fast is this setup?
- crank question
- help: LMA (lost motion assembly) replacement
- can a gsr head fix in a b16 block???
- Buddy Club Spec 4 cams ?????
- ARP rod bolts dont want to seat on rod.
- convert obd1 motor to obd2.....
- D16A9 Pistons on a D16Z6 and Cat question
- H23 Cams - Help -
- Another NA b16a question
- ls/v need help
- H22A engine torque specs
- 310 rc's or 310 precision injectors?
- B18c or B18c1 Official dyno thread
- how high of rpm do you think ls rods/crank can handle?
- Crower Valve Springs
- Main Girdle with Dowel anyone using this?
- megan racing headers or stock headers?!?!
- LS/vtec or GSR
- head question?
- Help me with my plugs NGK BKR6 V-Power
- Quick question about a B16 head?
- Header issues/question
- Is My Compression Right
- n/a build 200whp goal
- need help building jdm gsr
- F20b2 valve adjustment.
- all motor question...
- gsr builds show me what you got!
- d16 help
- B16 crank on ls block?
- need advice on b16 build
- 92 hatch which motor head and tranny for n/a setup
- need advice with build
- Reinstalling balancer shafts in a block that's had them eliminated- lubrication
- Plzz help engine sputterin at high RPMs
- Jerrybuilt vs. Bubbabuilt vs. Eugene @ Prostreet
- b20 vtec build: are my rod bearings too tight?
- Water Methanol System Prohibited?
- coolent out of exaust!?!?!
- Exhaust Options?
- Any one using the Eagle 90mm B series crank
- Hot B20VTEC-N.Cyprus-EU
- Ls/vtec build, input appreciated :)
- How to make a b16a, have 200+whp???? any advice?
- integra type r build up help
- What's better? High or low revs?
- 65mm throttle body
- E-cutout?
- street b16a rebuild
- head gurus need help if possible h22 head
- need help on valve
- Measuring P2V clearance on euroR H22 with JUN III
- Cams & Tuning Question.
- help reading spark plugs
- Buddy Club Spec III Cams In B16a
- Car suffered flood damage from Hurricane...S300 under water!!
- 13 sec possible with NA H22
- 97 civic engine into 99 civic?
- n/a build Type-r crank or ls crank in b18c1?
- Is my setup daily driveable?
- Valve spring install help, HG question.
- who makes 2.2L bseries setup
- help with rocker arm grinding ..
- Cam gears, do i really need them?
- f20b vs h22: technical(oem and aftermarket) specs
- Biggest B i've seen yet on video
- nasty misfire...
- Has anyone seen this valvetrain before?
- what motor oil do you guys use
- need help!!!
- Jdm 4-1 header(modded) vs edlebrock proflow(2.5in collector mod)
- Thinking about doing a Dyno of Oil filters Anyone Think its a good idea?
- Whats next from honda after the k series?
- what is there to about the d-series motors(swap thoughts)
- What will the compresssion ratio be at???
- NEED HELP SMSP HEADER
- how do I know if they are REALLY toda cams?
- itr head question.... PLEase help...
- Anyone Running one Adjustable cam gear on DOHC engine?
- anyone know how to get ahold of Mike Belben ???
- shop estimate too high?
- Omniman build thread. I can not find it. Could someone point me in the direction?
- LS/VTEC concern
- How do I Identify CTR Valvetrain?
- Anyone tried Skunk 2 Megapower RR 76mm (3in) exhaust on their NA motor yet?
- hytech replica vs logic motorsports tri y....
- VTEC SHUTTING OFF..NEED HELP!!
- Re: Comparison between H22 and H23 VTEC
- Re: Quiet Aftermarket Valve Train
- Misfire in cylinder no.2, on a jdm 98spec ITR
- Built lsvtec, High revs, Low oil pressure???wtf "continued"!
- will a b series fluidampner work on a k motor???
- question on flywheel for all motor ls/vtec(couldnt find anything searching)
- LSVTEC timing problem
- new cams in h22, need machining?
- b18b autocross set up
- B20 With B18C Crank
- Block/head disassembly and reassembly
- can i mix two different octane gasses eg) 91 and 103
- n/a gsr, cast pistons, plugged squirters, ngk bkr6e or bkr7e?
- Cam swap questions
- H22 head swap on H23 block.
- Possibly buying an integra with LS/Vtec built engine: NEED SOME ADVICE
- B18C Virgin, Please Help With Rebuild!
- how does one identify h22 type s cams
- ls crank and rods in gsr
- Do I have enough motor for the SK2 pro2s?
- h22 allmotor build help 3.5k to spend!
- messed around with the cam gears after milling. figured it out...i think
- DPFI TO MPFI
- HELP D16Z6 Rebuild - Ticking
- Official All Motor Street Car Thread (11.00-12.99 1/4)
- blox throttle body. Won't stay idling till car is warmed up.
- Motorcycle ITBs
- identifying cams and some other stuff on my friends car
- What Gauges?
- ALL MOTOR H23!?!?!? ZOMG
- b18 bored to a 2.0
- daily driven all-motor pistons...help
- new to hondas...rebuild em1 advice
- Torque Settings? B18C2 (similar to B18C1)
- need advice on new build
- Help me build my motor
- Is a manual transmission swap worth it?
- question on HyTech headers
- GSR block help
- can i run 91 pump gas on 12.0:1
- Starting Problem B16A2 Help!!
- question about cam timing
- Defective ACL bearings for 1991 Honda Civic (repost from Civic column)
- 95 gsr build
- NAME THAT CAM
- need help on my build.....!stroker kit....! long rods or short..?
- what cams are these? yes i've searched!
- ls/vtec 13.5 compression, can it pass emissions?!
- Any topics on 2Liter Type R All Motor builds
- post your allmotor 4dr eg set ups!!!!
- Filter brand? Does it really matter?
- B20 rebuild shopping opinions
- valve to valve clearance skunk 2 pro 2 cams
- Kteller? 3'' exhaust Experinces?
- About to buy a B16 Head, few questions?
- h23vtec rod choice
- Did wire tuck. runs bad.. ran good b4
- real quick question about a gsr head
- b20 with b16 or b18c crank
- b20 or b18b bored to 84mm?
- ctr pistons on a gsr
- ARP head studs for ls/vtec question
- Has anyone ever seen this on Skunk2's Cams?
- Velocity Stack VS. this:
- build ?
