- Rmf/i/e Dyno Results
- what exhaust piping size for a ls/vtec with 11.5 to 12.0 CR?
- Just tested my new Rage header on the track, IT'S A BEAST!!
- Whats the Best PCV System
- smsp sparks profab
- CTR Piston in all motor B18b?
- LS/VTEC What next?
- Integra 96 LS NON VTEC B18B Dyno 172hp
- engine grounding
- h22 skunk 2 pro series manifold
- stock manifold question
- type r pistons in a gsr
- installed Pro 1s and car does want to start
- what rev
- Pics of my modified CTR pistons...
- I need CTR bearing clearance and ring gap specs , Help!
- ITR Rally Engine
- Fluidyne half-size radiator for EF/crx
- what is a dart motor
- my current build
- Mugen oil filter?
- What do you think about CTR piston's
- Noob here. JDM 94 GSR engine, skunk2 IM, vacuum/idle issues.
- estimated power?
- LS/VTEC
- Tryin to reach 180whp.
- What do you think of my setup?
- Roll Cage For 92-95 hatch
- Stroker B16.....am I limiting myself with CTR cams?
- old vid of my R powered coupe on the dyno
- help
- 2.0 vtec w/ RC 440cc
- lsd trans????????????
- bottom end fitment/build
- Looking for advice on head work?? What to do/not to do,what I can keep/replace???
- ported out head
- Where's Jerry built racing on HT?WHERE!
- Valve question- B series
- Reving problem on a b18 LS motor swapped into a 88 crx
- do I need a v-tec oil pump
- D15b2 Bottom End With B18a1 Head?
- Beehive style springs/retainers?
- D16A6 + D16Y8 Head + few other things...what should I expect?
- which headgasket would carry me to 11.5-11.8 compression?
- D Series Pistons Comparo - P28, P29, PM6 and Others
- M24x?
- Carbing Catch Can....Recirculate or not?......
- what are the best mods for a b16A1 OBD0????
- cam gears gotta go
- 240 WHP 1/4 mile times??
- B16b+M22x+Spoon exhaust = xxx whp?? (dyno inside)
- Hookups tuned ls/vtec.
- Vtec or non-Vtec
- most aggressive cams for 93 octane?
- ahhhh the mighty B20....
- b16a build
- How much they charge for sleeve Job
- looking for a tuner in sf
- swap questions
- Fit or Not
- DTR narrow header questions
- b20vtec setup nedd more power
- reputable machine shop in 909/951
- B18C1 vs B16a cam caps
- B series deck heights???
- How to produce 186 wheel HP per liter on pump gas.... (all motor of course!)
- My itbs. few questions regarding them
- looking for the guy that sells Exhaust pipe
- Ubderdata Guidance or starting map needed (B18C w/ ITR cams)
- 24.5x8x13 MH
- Ls/vtec with ls pistons...
- X VIC Vs AEBS manifold 2.0L (PICS) HELP!
- compression is 11.3:1....want 11.6:1
- Road Race B16 Build Up in GT Lite Civic 1200
- Stock Sleeves or Aftermarket?
- S2000 Injectors. And will they work on a 99 civic si
- couple of noob ls/vtec questions.
- ok to go 86.5mm on k20a2??
- Motorbuild Setup quistion B18C4 blok..
- itb hondata
- Most power made with DC 4-1
- vtec heads
- sk2 camshaft ans sk2 mani. what ecu to use?
- Auto To Manual swap>>>>>
- Mini-Me Swap
- help with gsr head
- Golden Eagle Vacuum Manifold work with ITB?
- How to make my civic fast w/o turbo???
- header question
- Safe AFR to get to my Tuner
- Injectors for my build up.
- gsr head wont budge. help.
- 440cc injector question
- poorman's ITR question
- what to do next eg with 99b18c itr motor
- B20b VTEC and Nissan CA18 Pistons?
- Need GOOD or Great Engine builder close to YONkers not no muger
- Building my Type R head.. SoCal
- which cam will be the best for my d16y8?
- The Wonder 1.8 liter ITR motor hits the Dynojet!
- Buddy Club Spec 5 cams??????
- Poor mans type r build need input
- Which cams should i get
- GSR Oil pan swap onto LS...Need to change pickup???
- B16 Throttlebody w/ sensors.....
- ITB's Individual Throttle Bodies
- DIY ITB, velocity Stacks
- I have two choices of available blocks, please advise.
- Hi i got some ???? if u could help that be great thanks
- Question...Dart Tall deck block + b18c head = hood clear when high rev??
- car releases black smoke after vtec engages...
- JUN Type 3 on stock B16A?
- instaling Arp rod bolts with block in?
- Driveability with Skunk2 stage 2's in a b16?
- cams for 94 LS w/ 12.5:1 compression
- SOHC 600rr ITB's
- TWM ITBS + k20 + dc2 = hood fit?
- re use piston rings??
- B16a head, core shift pictures
- Can anyone help me identify this head?
- best intake for your money
- RMF Headers!!!
- Ls/Vtec reliability?
- skunk2 stg 2 cam on stock valve train
- Are there any identifying marks on Buddy Club spec III+ cams?
- Crower Cam.......
- pix
- amateur wanting to build all engine
- meet my new power plant
- Engine machining procedures? Need Info on metal shavings
- dx question
- ecu question
- need some info on 2.0 set-up
- looking for tuners... p28 ls/vtec obd1 Ohio...
- come on Honda people you should know this?
- Injectors or fuel pump/regulator
- The Intentional Destruction of Laboriously Engineered Artifacts - A Pictorial
- type r valve job angles
- A couple of questions for the experts! ( Basic Rebuild )
- jdm itr header...
- 81.50 mm CTR pistons
- Race vlave train
- 8600 rev limit!!??
- all motor setup
- motorcycle muffler design
- What MSD should be used on ALL MOTOR H22 Civic
- wat year b18c?
- plastiguage question
- What pistons would you recommend?
- Is this a CTR Intake cam?
- P30 Pistons with GSR Rods? I searched, Read
- Valve Springs & Retainers Couple Question's
- 1.8 N.A. build up! what kinda cams????
- Tearing down and parting out motor.
- Knock Sensor Problem
- DH racing ported IM & TB combo.... any good?
- another OEM build HELP!
- bare jg engineering head pro gen 2 porting
- Dyno Results Skunk2 1.8L ITR with crap tune!!!
- Help ID some part
- What is the best OEM cat to run on a swap?
- WHY??????
- Is this a cracked cylinder head?
- Whats intake setup for my 2.0L, looking for 250whp+!?!?
- Help CTR pistons into b16a
- What will a catch can do for me?
- RC injector gaskets for TWM itb's
- Good all-motor hondata tuner in norcal?
- rebuilding my ls vtec that went bad
- b16 chipped ecu vs. knock sensor.
- ls/VTEC build, pics soon, rlz cams, arp hardware, take a look, what hp should i expect?
- burr on piston???
- LSvtec distributor? need help quick
- type r intake valves
- B20 or b18b build
- MY MOTOR : ( KABOOMM!!
- need help
- PCT piston part number?
- jdm itr pistons in a b18c1
- 01 Integra Type R build up
- head bolts?
- WHERE TO GET UBERDATA????!!!!????!!!!
- WANTING TO PUT ITB'S ON MINI ME!!!!!
- header bolts / studs
- help i'm slow
- Can you allmotor guys help me out (cam related)
- ITR GSR intake manifold adapter plates
- ALL MTR LS HELLPP!!
- Type R head & GSR head?
- question about skunk 2 pro 1's
- LS crankshaft + GSR block = HEAVY TORQUE + BIG HP?
- non-detergent oils
- How much compression do I need???
- b16a2/b18c1 build
- beginer what is the best engine swap for a 96 civic
- my lsvtec
- What size exhaust piping and cat are you running on your setup?
- where can i get an uberdata bin for a modified gsr?
- Omni power springs and retainers
- Mobil 1 Delvac
- code on block?
- removing oem pistons from rods
- Builders / Tuners in Upstate NY???
- Quiz-diagnose the misfire on this K series motor.
- ls/v-tech
- b20/v revving?
- Does anyone know info on this mystery tranny? p2t4
- My build setup B16a2
- got some question on a 2.0 set-up
- Test your Internal combustion knowledge.
- results after bubba tuned
- post ur 2.0 all motor set up
- wire harness help?
- jdm type R header
- Friends Corolla XRS Dyno, FUNNY!
- want to see ur stock bottom end b16 w skunk2 stage2 cams dyno sheet or video
- b20 vtec build will teg type r pistons work?
- Question on head swap
- ALL S.O.H.C. Monsters check in !
- where to get a nice 4-1 jdm copy?
- where can i find a fluidamper or ati ( searched )
- ARP Main Studs, what benefit are they? If any.
- integra all motor ?
- What is the highest compression on stock sleeves???
- Help on future plans!
- Ayone dyno Blox cams
- H22-b series
- what do you think?
- DAantagonist get's tuned at Mainstream Performance....
- crx type r
- rough idle
- Fluctuating idle
- uberdata question....?
- Stock B18C1 with a Full-Race Turbo
- HOLY SHIT DID YOU SEE THE OPENING CEREMONIES
- Best books to read about engine building?
- catch can q's lsvtec b18b1
- 96 gsr running like doo doo NEED HELP!!!
- Portflow reworked IB head makes 244 HP on the Dynapack thru the muffler!
- Evans Tuning Comp4/Street Stock EG hatch, 254whp/170tq
- quick lsvtec question
- rod bolts?
- Question About Rocket Cams
- Got Tuned at CHURCH'S today.
- 2.0L ITR Dyno: Cams: BC5's vs ITR
- plans for my car
- Injectors, pump, regulator..
- H to b series swap...
- Exhaust question for my B17
- 22's vs. 23's?? N/A who has ran both here?
