- Difference in Trannys ?
- Something Has to Be WRONG.
- Differences in Trannys
- OBX stage 3 cam event info
- Help P0341 code
- NOVA tuners? DC?
- Exhaust Diameter
- 11.8:1 LS/VTEC + nitrous???
- coating pistons whats the point and how does it help
- All motor 1995 GS-R discussion
- who is doing some good efi tuning in PA besides Jeff Evans?
- Searching for Primary Lope Specs on B engines
- Geddy SP2 or RSR Ex Mag
- valvetrain question
- cams
- Duration/Lift for B-Series cams.
- dyno'd my engine (GSR)
- New setup B16a2 any suggestions,expected hp?
- b20 build. need opinions..
- I need Help whick cams should i use for a stock Bottom End?
- What compression will I need?
- gsr with itbs
- what cams???
- Sce .V.s. Mr.gasket .V.s. oem
- weird noise (timing belt to tight?????)
- Swap vs. existing B16A build-up... Need opinions PLZ!
- how does this belt tension look?
- Crome full throttle luanch vid
- valve clearence on b16a Q's?
- which timing gear for H23/vtec??
- how much power should this put down...
- zc motor
- Any cool all motor cars or shops in South florida?
- ls vtec conversion question on dowel pins
- burning oil like crazy
- Buddy Club IV, Skunk2 Pro-1, JUN 3... which one?
- Cracked head replacement/rebuild: Cleaning up
- Jun 3 spec sheet ??
- Dyno Figures Seem Low
- Valve spring question???
- anyone in the redondo beach/los angeles area with rex?
- Weird timing problem!
- How much my head is milled?
- something very bad?!
- For those rocking "NA is BEST!" stickers...
- What IS the valve adjustment spec for SKUnk St 2 Cams
- If measured by dial caliper.. How big are lobes on Skunk2 St 2 cams supposed to be
- Compatability of CTR head with B20- block?
- Buddy club spec 4
- abes vs skunk 2 IM
- itb flange and runners
- Is it necessary to run an aftermarket sump?
- k-series (k20a2 head on a k24a) question
- i have a ls in my crx need know if i should put b16 pistons in
- Toyota's V-TEC?
- a chance to give your b16 opinion
- are ALL D-series motor SOHC?
- aebs?
- HELP CRX PROBLEM: exhast is coming out my radiator
- Oil leak problekm.
- IAB vs. no IAB (dyno results)
- need help
- milled GSR head question on a LS block
- 2Hrs of pounding on the crankshaft
- Fuel Pressure... LEAK? or is this normal?
- b16 del sol all motor
- something wrong with my motor?
- Anybody using the Comp Cams #57400
- b18b1 with GSR tranny....how does it compare?
- Plug difference between #4554 (R5671A-8) & #7173 (R5672A-8)
- K-series: Castillo's 82.5246mm crank
- ??intake manifold fo b18b???
- Help with R/S ratios
- My Dyno Results. Mild built B18C.
- flywheel torque..??
- just got back from the dyno
- ????air fuel managemnt on itb's?????
- New engine?
- H22A Head Gaskets
- d-series to b-series...???
- TODA B series header- NEW VERSION ?
- K-series: rod/piston combo comparison
- help please
- Opinions: LS crank in VTEC block. What main bearings?
- Lost motion assemblies
- JDM B18c Type R
- Just did a leakdown test on fresh engine, check results
- gsr swap into EG civic, alternator fitament issues...
- Valve Guides (Portflow) and Valves (Supertech)...
- what distributor is this? TD-55U 3Y12??
- How to port a stock header??
- Ls crank into gsr block = what kind of thrust washer??
- Suggestions on .... b20b head on b18b block.....
- The mystery about tuning cam gears
- Weapon*R's New B-series SPL Race Header
- ????200 allmotor whp possible on ls?????
- 1998 honda crv belt tensioner
- Calling all f20b owners!!!
- oem gsr build info
- gsr or b16 cams --tried searching
- What cams and TB?
- fake bc4 cams???
- gem oil adapter
- thrust washers
- H22 dyno: 200whp/159tq
- h22 throttle body on an ls
- Putting cams 0,0 with milled head...
- ls vtec turbo
- LS/VTEC.......what about using a LS tranny?
- RM valve springs
- would an oem headgasket fit?
- buddyclub III's or Buddy club IV's
- Cams for 84mm b18c, 12.5cr?
- synthetic oil question
- TWM ITBs sticking
- (lsVTEC)no vtec what so ever
- can anyone vouch for JDM CONCEPTS 11lb fly wheel?
- ITB port matching
- My potential all-motor H22 setup--any thoughts?
- Who have you had your motor/s built by, vote and post your results
- Head Gaskets and Sleeved Blocks: Lets Discuss
- tranny gear change?
- GSR ITB with plenum
- itr motor problems. help....
- Opinions, comments on my cam set up.
- HELP! plz read, engine knocking
- how to identify m22 cams?
- 03 civic EX i need help please
- Wristpin diameter comparison (JE & Western)
- b16 i/m fit on gsr or itr heads?
- H23 crank in H22 block?
- Skunk2 stage 3 cams sheet typo?
- testing waters: semi-built ls-vtec motor
- b16b rod length
- Are Cam Caps interchangeable between Vtec heads
- ls vtec turbo
- ITR: Connection riod bearing colors, one doesnt have a color
- Witch cam should i chosse?
- varied runner lengths on an intake manifold?
- Video- JUN III Vtec screaming on the dyno
- portflow inner springs on intake and portflow inner springs on exh
- K-series - 2672cc: 90mm x 105mm short block
- b20vtec.. jun stage 3 or buddy club 4 cams?
- take a look??
- motor rebuilt.. how long ........
- ls chipped ecu?
- buddy club spec 3+ cams spec?
- Need Help ASAP Fuel/ idle issues
- Quick All Motor Question (b16 or b18c1)
- JDM ITR with JUN 3 cams
- H22A lma's too tough?
- LS/Vtec Nears completion, quick question
- Just bought Porflow Ti Retainers...Now which valve springs to run with them?
- Sparks Racing Header CTR motor Test 1
- 1.9L B16 Build up starts today, pics and more......
- What shop to take a motor to in N. Cali??
- lsvtec 199.8hp dyno sheet
- buyin a engine
- tranny gurus help gsr gears b16 gears need advice
- Dyno Results: GSR All motor
- How to gain 20hp on Japanese DOHC d16 ZC non-vtech...
- all motor tuner in the bay area
- Gaskets for rc310 Injectors
- Signs of a blown Differential after being recovered from theft....HELP
- flat valves vs standard valves
- Buddy Club vs Omni Power
- ebay swap
- Broken Golden Eagle Cam Gear
- 98 Civic Coupe with JDM ITR swap
- which cam
- cams recommended for ls motor
- I'm on a roll: have you ever had THIS problem - timing belt stretching.....!
- oil on spark plug threads, opinions?
- Where to purchase a complete short block
- Uberdata Tunner in TN
- Injector Query on S2S2 setup.
- LS-Vtec smog? Bay Area
- LS/Vtec oil line
- 84mm ITR pistons?
- H22a1 pistons in H23a1 A couple quick questions
- ls vtec oil questions!
- SportcarMotion CTR gets it's first taste of the dyno.......
- tech43!!! wheres my stuff?
- Worn Vtec Lobes on ITR cams
- b16 build help
- valve clearance on ls/vtec.... (shaved head)
- 1.8 i-VTEC
- Omni valvetrain: are valves worth it?
- Plateau Hone..Novus brush
- .10 head gasket too thin for h22?
- *Please Help* RM gen1 or gen2
- how to hook up vtec wires?
- poormans type r vs ls v-tec
- Have you ever had to shave down your rocker arms? (Trick question.....)
- Im lost about what to get???
- I need you guys to recommend me on a B16A2 gasket set.
- revving limitations
- rsr exhaust
- looking for a good machine shop in the new england area
- Milled head questions (H23 milled 4 thousandths)
- will this fuel pump work with my 93 civic vx?
- golden eagle head studs???
- Intake mounting
- Compression check on fresh build: Results
- 84mm gsr combustion chamber volume question for the masters
- all motor sohc
- i have a little bit of a problem and i need HELP NOW!!!
- loose bolt INSIDE motor - need expert advice
- help me achieve my hp goal 215+ whp out of my b16b
- dsm injectors (tuner input needed)
- B20 with a GSR head..... help
- what to do with my stock b16a1
- build for skunk2 pro 1's itr motor.
- stock p30 oversized pistons?
- skunk2 stage 1 cams on stock b16 valvetrain yah or nah??
- B20 Problems need help ASAP
- Project questions NEED HELP
- compression ratio?
- Looking for machine shop in ny/ct/nj tristate area
- B18B SMS Header
- Starting ls/vtec should i use LS or B20 bottom?what differences would there be?
- Toda C cams...any advice?
- b16b stroked
- B18A1 Dyno graph, feedback wanted
- Anyone want to trade brand new Edelbrock intake mani for blox or skunk2?
- Omni Power Parts?
- My b16 is boring
- exhaust manifold ?
- HP numbers from a full bolt on b16?
- quick ? on ls and b20 rods....
- H22 Stroker Engine update.... 2point6
- B20 build time...
- Questions regarding an all motor LS build, need advise!
- D16?
- B20vtec Injectors Question
- b16a2 intake manifold (2 questions)
- My Worst Nightmare!!! PICS inside
- Having trouble picking comp ratio
- ACL bearings vs OEM bearings
- can stock GSR injector handle ITR motor with jun III camshaft?
- LS/Vtec build
- Link for Curb Weights of all Hondas
- Pics of my setup i will be dynoing...before and after.
- Information- import power house
- what should i do i just got a b16a for my crx
- ef header
- Piston damage
- b18>stock ex
- how come fuel pressure can't be lowered? help
- K-series: Castillo's 94.9mm crankshaft
