PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 [208] 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. IM EFFIN STOKED!
  2. b20z vtec buildup question????
  3. anyone running RS Machine Dohc Vtec cams?
  4. how come c-speeds calc comp is so off???
  5. I need help . . what exhaust cam is this!?!?
  6. install tips on changing valves? help!
  7. will 2mm make that big of a difference?
  8. my car ran 12s stock with only $300
  9. CR-Vtec
  10. need a dyno.. pls help me out.
  11. H22 Question about a swap.
  12. ITR cams in GSR with stock ECU??
  13. Ctr pistions in a b18c5 Toda B's or C's?
  14. worth it?
  15. which camshafts to use ?
  16. f22 head milling question (basic head milling question)
  17. Can't Decide: Order 12.2:1 or 11.5:1 CPs for daily...?
  18. New member and i have a couple of questions
  19. Milling a head & cam timing issues.
  20. vtec solenoid
  21. LS/VTEC I/E/H, how fast is this setup capable of in an EK hatch????
  22. justice racing engines street B20 dyno plot......223hp/162tq
  23. Question about a engine fresh from machineshop
  24. 200whp Ls/vtec what do i need?
  25. All Motor On EP3
  26. FINALLY! 10-94 MOTORSPORTS Header has arrived!
  27. crower 63403 in ls vtec with ctr pistons.....valve clearance issue??
  28. Head question
  29. Bunch of B18C5 questions
  30. LSVTEC Kit??????
  31. ls v tec tech questions
  32. What rings can i uwe on my CTR pistons ?
  33. Bigger gains: CTR pistons or CTR cams in b16a1
  34. ITR manifold on B16a head... modifications?
  35. 2.5" header mod question.
  36. 270hp/185 trq GSR motor. :O
  37. ctr intake cam
  38. Grrr...Bent another valve!
  39. What Exhaust Isn't Stupid Loud.
  40. B20Z Cams are they intercahngeable in a b18b?
  41. ctr cam question
  42. NEED A CLUTCH....
  43. Quick question about swapping B17A crank into a B16A?
  44. need advice with all motor build
  45. when to replace LMA?
  46. Valvetrain questions
  47. What 02 sesnor for Air Fuel guage?
  48. pre-tuning checklist
  49. Fuel Injectors Dying????
  50. b20 setup for street use
  51. hondata o2 question
  52. quick question about obd 1
  53. Budget B16...
  54. Help rattle comming from engine area when I depress the clutch
  55. Best place to get new sleeves
  56. Building a 2.0 B18B
  57. b18c1 or b18c5
  58. help! lsvtec burning oil!? need ht diagnosis!
  59. Ericks Racing OR SMSP Header...
  60. cam upgrades.. whos got what
  61. what suspension???
  62. JG Edelbrock IB 2,5" vs SMSP B20VTEC header
  63. COMPRESSION with skunk 2 cams...
  64. GSR oversized itr piston build - need appopriate cam choice poll
  65. Stroker Kits
  66. what do U guys think on this
  67. LS crank in GSR????
  68. I think I am a future turbo boy, but some "Motor" dyno's might Change me! LetsCEm
  69. fcomptech race header work with jdm 2.5" cat?
  70. all motor h22 dyno plot
  71. V-AFC Tuning
  72. Check My head...tell me the deal
  73. ls/vtec: bore or buy
  74. short intake
  75. all motor b16a2 vs b18b
  76. oil pump question
  77. 99 SI+N/A motor=13's?
  78. Ideal compression for Skunk2 Stage 1's?
  79. hondata or vafc?
  80. Cheapest place to buy JDM ITR pistons OS w/ rings ?
  81. Another Header Question
  82. CRVT learning curve
  83. What other parts do I need if I change out my valve springs, retainers and pistons?
  84. Max rev, and gearing question
  85. B18C Throttle Body
  86. B series with knife edged + Lt weight flywheel Q's
  87. Top Five Mods to GS-R hatchy
  88. b20 with a b16 head
  89. B16A vs B Exhaust cams
  90. machining a cam cap?
  91. Help, What cams are these,,,,,,,,,,
  92. motor revving too fast?
  93. JDM ITR 4-1 Header or JDM Mugen ITR 4-1 Header???
  94. Draft:Buying a civic with 12:9:1 c/r need help
  95. Type s cams making jnoise
  96. skunk2 stage2 GSR(stock)???
  97. how do you use a v-afc?
  98. Opinions on MSD Coil and Cap for All Motor?
  99. what type of fuel mods do i need?
  100. DH-racing.com Custom Intake manifold ?
  101. some questions about skunk 2's...
  102. in the 13's
  103. B18 C5 in Civic
  104. sleeved b18a bore problem
  105. ferrea valves with skunk2 valve springs????
  106. does any one know what are the specs on a crv/vtec on a stroker kit?
  107. replace valve seals with new valves
  108. Would these pistons work in my B16A?
  109. weight of a stock crank?
  110. Ticking engine...Just after valve adjustment...:shrug:
  111. crower 63413 cams vs 1999 type R cams
  112. b18c or b20 vtec.
  113. pcv and b20
  114. bent valves on b18c motor
  115. going from p73 to pr3 pistons on LS rods, possible?
  116. LS/VTEC setup I am putting together, if there is anymore advice or ideas let me know.
  117. Building up H22 the Skunk 2 way
  118. Odd idle, possibly slight ticking, but I don't think/hope is my valves...? [kinda long]
  119. Eagle RODS bearing
  120. ITR vs B16 Cylinder Head flow.
  121. del sol track times
  122. 2" collector on my DC 4-1...
  123. did any oem IM gaskets come in plastic?
  124. Rebuilt and now leaking all the oil
  125. best (most powerful) cams for 10.5 comp h22a???
  126. Piston Part Number ?
  127. head for ls/vtec
  128. squeezin' out more horses
  129. help out this noob! what do you think of this all motor setup?????????
  130. A/F Mix
  131. how can you tell...??
  132. How best to make (DIY) an IM gasket for 70mm B-Series tb's? Or does someone make already?
  133. Anyone actually use/support any of these A/F ratio gauges?
  134. Sk2 intake mainfold problem...Fuel rail and injectors...Please help!!!!
  135. Help with built h22a please!
  136. ROCKET or FABRICATORS READ ITB intake flange
  137. b20 ?'s
  138. homemade h22 ITBs Q's
  139. b-day coming up next month...
  140. Skunk2 GS-R questions
  141. Portflow springs & stock retainers ?
  142. Car is running lean.. I have an AEM fuel pressure regulator but no Gauge..
  143. looking to do some upgrades to my LS engine. I need some tips and pointers!
  144. K20A
  145. underdrive pulley for b20vtec
  146. what gauges do all you all-motor peeps use?
  147. crank pulley question
  148. DH-racing race pulley, anyone running it???
  149. CTR piston compression question
  150. I have a few questions!!!!
  151. K&N high flow filter worth it on b18c with bolt- ons?
  152. ALL MOTOR B16A2 OWNS!!!!!! slip inside
  153. DYNO 1.6 SOHC VTEC
  154. just boring a b18c to 2.0
  155. GSXR Trottlebody's on Road Race civic, pictures inside
  156. DTR Header comparison & review
  157. high 11 low 12 1/4 mile range, what setup would you do NA.
  158. fuel pressure for ls vtec
  159. help on h23 to h22vtec
  160. ls or gsr
  161. Looking to go from B18b To B20 Help
  162. Looking for a clutch recommendation!
  163. Suggestions and Opinions Please ...
  164. who would buy used cams?
  165. TPS problem.
  166. question on my cbr itb's tps
  167. Head Milled...what now?
  168. ITB's or type r mani with bored TB???
  169. GSR or LS VTEC opions... im getting a good deal
  170. getting 200whp on stock 10:1 compression..ill try it!
  171. Motor = Running like crap could it be my configuration?
  172. help me get my gsr in the 13 sec 1/4
  173. transmission problems, popping out of 5th gear
  174. Getting Educated With Hondata.
  175. any tuning needed if we install higher CR piston?
  176. crane cams stage 3 cams
  177. b20b bore and stroke size
  178. Who would best know how to port and polish an ITR intake manifold? Should I send it off or any ol'
  179. Installing cams: How tough???
  180. Some problems after Toda cam install
  181. slow crank problem
  182. highest compression
  183. This LS/VTEC swap kit thingy....
  184. What machine work do I need?
  185. code 23, help!!
  186. AllMotorSOHC.com Updated
  187. vtec crossover ?.
  188. GSR owners with Skunk2 manifolds...where does this harness go?
  189. intake manifold for my gsr?
  190. B16a Torque Specs
  191. 00+ 310cc Celica Injectors
  192. LS/VTEC QUESTION?
  193. kinds new to hondas. got a few questions.
  194. Question about longblocks
  195. Valves, Springs, Retainers
  196. STROKER B16 and a Birthday greeting to GEM
  197. need ported and polished d16 head for 2000 civic Ex...
  198. Need your opinion....
  199. Hard Motor Break-In
  200. arp rods bolts question?
  201. best price on jun 3
  202. D16Y7 block/crank/everything besides head...same as Y8/A6/Z6???
  203. proper valvetrain break-in period?
  204. itr or aftermarket retainers????
  205. Rumor'd 200 hp b16......I did it too.....ya wanna know what it is is?
  206. skunk stage3 cams
  207. how can you tell the difference between a type-r head and a regular b16 head?
  208. Homemade ITB.. I got a Few Questions
  209. b18 bottom end build up
  210. synthetic breakin
  211. buddy club cams?
  212. What head for A Lsvtec ?
  213. Gude cam in DX
  214. b18b tranny fit b20?
  215. vtec crossover w/TODA B's
  216. need some help with b16 build up
  217. Chipped P28 ECU
  218. b16b stroker kit
  219. 82mm B series pistons
  220. need help with a head
  221. B16A Head Work And Mild Bottom End
  222. Tach installation????
  223. Timing a d16z6 comp cam in a d16y8 .... whoa I got confused.. lol
  224. Question on b&m fpr
  225. a/f ratio
  226. B16 with Comptech 4-2-1
  227. LOOKING FOR CAMSHAFTS AND INT MANIFOLD UPGRADE FOR H SERIES
  228. Here my setup
  229. ITR pistons
  230. Crower Retainers
  231. Low compression test #'s...
  232. Help with a CRVTEC conversion
  233. Hondata Questions?
  234. Need help! LS all motor
  235. B18 gsr. build up
  236. LS crank on a b16????
  237. Uberdata?
  238. B16 torque settings
  239. b16a timing
  240. compression question
  241. Built LS VTEC motor
  242. wtb. integra type r longblock?
  243. need help with ctr cams
  244. HELP WITH PISTONS......not edyno actual question
  245. King Motorsports Projects
  246. displacment both storke and bore changes
  247. Building Poor Mans R..Need some advice!
  248. What Intake Manifold Should I get for this Setup??????
  249. Skunk2 Stage 1 Dyno.. ITR vs GSR
  250. Searched :-P Question about CTR cams...
