- First ever dyno. i dont think this a is good start
- Toda Spec B's, ITR w/ CTR Pistons
- Ls vtec , 3in piping , what muffler?
- B20 Vtec Timing
- D series build
- ALL MOTOR b20v Fuel Pressure !
- 2002 civic lx problems
- potential power of b16a
- lets see some stroker setups
- asdjust tensioner whille timing covers are on? !!!!!01 gsr
- gsr question and not the obvious
- B20b block hair lines cracks.
- Integra GS-R Rebuild
- gsr exhaust manifols vs ebay header???
- clutch break in needed? xtd stg3 6 puck
- Very interesting engine build!!!
- ls vtec sputtering at low rpm
- Semi Built B20V vs E85
- b20b motor problems
- b20v starts but dies instantly...
- Advice needed: Slick size??
- B16A Upgrades.
- Tiger Japanese Autos
- Questions for b16a2 with gsr head.
- H22A www.Logicmotorsports.com Tri Y/Highend Header
- F20B compatable parts?
- how to get better flow on high RPM
- What manifold to buy H22A
- GRINDING NOISE HELP NEEDED PLEASE!!!!
- Cam bearing damage
- Eg engine choice
- 2000 Civic Si Bolt On Question.
- B20vtec Build Plans
- high hopes b18c1 build
- Just swAped camshafts and now car wont start. Help please
- too light?
- Crower Cams and Valve springs , How much a difference on b20b?
- 86x89 Fully built! what kinda header, clutch, flywheel?
- y7 noise
- B18c1 with p73 Pistons no tune
- B16b exhaust manifold heat shield same as usdm type r heat shield?
- wire harness color code help?
- b18c build
- Compression question for my build.
- D16Y7 to DB16????
- nice IM for H22A inside.......
- valve spring help needed
- Rebuilding GSR head question [Pictures]
- HEY MANs all motor question
- Intertune.tv All Motor B16A DVD
- precision or rdx injectors
- B20 with gold eagle main girdle. What bears should I use???
- ticking noise in my b16 only at idle
- FORGOT TO PUT IN DOWEL PINS
- "Champher crank"???
- FIRST BUILD SETUP, OPINIONS PLEASE.
- S2 Pro Cam Gears Valve Timing Issue
- B16A Automatic transmission Vtec performance (help)
- d16 motor to b16
- thinner headgasket ,how much to shave the head? degree cams again?
- Mugen header on a 96 spec itr
- Vacuum at WOT
- i have a question...
- What Cam Gears Do you guys Prefer ??
- Toda replica header vs RMF narrow replica
- porting tools and attachments
- how to tell how much has been cut on a gsr head
- B20 VTEC POWERSTEER HELP!!!
- PLM Toda style B series header
- b18c itbs Fpr guage
- Jdm B18c type r motor
- Milling/decking to achieve desired compression ratio?
- N/A build opinions
- All motor race fuels
- hondata tuner in SW michigan
- Priming the oil system after oil cooler install
- crower or tuner cam
- H22 Header
- f20b upgrade opinions pls
- Poor mans type R advice
- need some help..
- Working my way towards cams b16
- B18c Wiseco/Eagle ITR build
- How reliable is it for STROKER engine?
- b16 manifold vs sk2 manifold
- which motor is best to start with for h2b
- best b series cams for stock valvetrain??
- Pr3 rod question
- need number got NGK V-Power b16a plugs
- cam switch on my b20vtec
- Custom arias pistons- need help determining CR!!
- Exedy Organic Pressure Plate's limit?
- H22a rebuild questions
- please tell me why !
- SERIOUS CAMSHAFT QUESTION
- Fuel Pump not priming. CEL stays on
- VTEC HEAD good or no?
- SSA K24 Testing Results
- RM header?
- H22 setup opinions please?
- Cams spec for old supercams
- 92 or 95 mm crank with stock sleeves and rods???
- Inovate Lc1 wide-band issues. need help ASAP.
- Car belt noise and various questions
- h22 Dyno opinions
- honda help
- Cam help
- Best header-$500 BUDGET
- Help identify these cams(ITR?)
- Pulled rod bearings...strange observation...reccomendations?
- Alternators
- d16a6 p29?
- Do these itr cams look good condition?
- CTR tranny 4.9 final or stay with 4.4 final
- What is this nipple/ barb for on the TB?
- Need advise with a choice b16a or d16a8 zc read on
- how high can i rev it? plug choice and gap?
- skunk2 pro 3 cam card typo?
- what kind of numbers should i put down?250 ish?
- Prelude/K-Series/NXS LMA + .040" washer trick for B-series
- what intake for beastly b20v all motor?
- ITR cams vs S2 tuner stage 1 for dd
- need some advice on rod bearings....not the size either!!
- 90 dx hatch... My new all motor project
- BowMan's R
- H22 Rings and bearings?
- vtec solenoid question
- Dynapack vs. Mustang Dyno
- d15b7
- head gasket help!!!!!!!
- f22 block h22 stroker kit
- 94 integra is a swap worth it?
- New Skunk2 Camshaft Markings
- ITR head upgrade
- *****How reliable are LSVTECs?*****
- D16y7-d16y8 mini swap
- cam degreeing help...bciv
- breeak in oil?
- B16a swap question
- Need to buy parts
- Milling piston dome to lower compression ratio?
- burning gas...
- Camshaft Question
- H22A VS H23 noVTEC headflow, F22A VS F22B headflow
- Crank pulley bolt problem
- B20vtec or 84mm sleeved B18c5?
- H23A Mod and tune options
- degree camshafts tool-WANT TO RENT ONE
- new here need advice from sumone wit similar high compression build as me b18/b16
- H22 Intake/Redline
- ►► July- August | All Motor Classifieds | FS & WTB ◄◄
- All Motor with Turbo Valvetrain?
- help!!! d15bdual vtec head on a d16 block..worth it or not??
- my compression is 16:+ 240psi and need help
- b16a2 all motor build
- Some good gains on a h22 with just bolt ons
- b series builders
- ChumpCar/24-hrs of LeMons motor choice
- what oil can i use.....
- B20 with b16 head or just go b16 engine
- redrillng gsr manifold to fit b16 and vice versa.
- Virtual Dyno Data needed
- b20 with ctr head
- B20v valve to piston clearance, skunks and RS pistons
- Need feedback on this...Billet Mega-Flow 1 H22A Intake Manifold
- K head porting.....
- B16b Rod and Main bearing Size (allmotor or Clean Rice Please help!)
- Which Coil over Plug
- questions for guys running 3in exhaust
- higher cr pro's & cons
- itr valvetrain or aftermarket???
- What motor is this?? Was out of a magazine Picture inside
- port and polish
- 2.1 LS VTEC Build in progress
- Piston Rod Help
- Tune Ignition Maps
- phearable.net..... any words?
- ls Vtec N/A lowish numbers
- How do you know VTEC engages?
- B20 swap into EG.. need HELP ASAP!
- have anyone experiense with Crower 2 3/4 race plus camshaft???
- what size slicks 23`s or 24.5?
- Thinking about type r engine
- 98 gsr - Early Redline
- block guard or not?
- Ring Gaps with RS Machine ITR's?
- civic eg starts but wont stay on
- Better 2L Header...RMF Narrow Rep or Hytech Replica
- finding true tdc when degreeing cams!!
- Build help/questions ?
- Break in oil?
- Coolant levels drop, no external leaks?
- Whale Penis Brand??
- Help determine cams
- Analysis of my dyno graph
- Replacing header.
- b20v intake manifold bracket fitment
- car will not stay on. HELP!
- what to look for when looking at specs for a camshaft ?
- USDM ITR Pistons in GSR Trying to BAR
- what cams?
- b18c1 build invest in ported head?
- AEBS VS Performer X VS ITR Manifold
- Reading Spark Plugs....pic inside
- Who can repair and mend these stress fractures around the intake valve guides?
- B16a head
- DSM 450cc Injectors(blue top)
- Honing required on SCAT 4340 Pro Rods???
- B20 NonV with itr pistons??
- motor swap
- b16 swap
- Is Mechanic Being Truthful or Trying to Get $$ From Me?
- B16A with CTR pistons? What's my CR Come out too
- Necessary equipment for tuning an un-modified B20v to OEM-spec
- Skunk2 Megapower R 70mm quiet down suggestions
- ITR Build Ideas
- special oil to break in fresh build??
- D15b1 with a z6 head
- Do i need to upgrade OEM fuel system to tune my ....
- Help with b18c1 swap on my EM1, TN HELP!!!
- b17 block b16 head head gasket leak
- How to tell what kind of Valve SPrings you have???
- 2.25" Exhaust on B16 with Tuner 3's
- aebs manifold porting...
- d16z6 rebuild.. please help!!!
- all motor b18a what cams would you get
- H22 w/ S2P2 cams won't idle
- Skunk2 pro1 peaking high?
- Does Engine Block from an Auto Directly Swap Into a Manual?
- Maxbore TB taper size
- Torque damper...Good or not?
- P30 Pistons supplier
- h22 bearings
- arp rod bolts necessary on gsr?
- What intake Mani for my built lsvtec???
- GSR Head damage
- What could this be? 99 Accord dying when cold...
- which intake mani? PLEASE LOOK
- 1992 Civic DX hatch Idle surging IACV question
- Thrust bearing placement?
- ls vtec set up advice to make it run really good
- B20vtec Rebuild, Advice/Input, Spun Rod Bearing
- FAST/STUPID IDOL!...ish. just read. lol
- GSXR TB modified to fit GSR info needed
- Let's see your custom B-series cold intakes and dyno graphs if you have them
- exhaust cam not spinning.
- Cons of changing headstuds one at a time without removing head?
- H23 Bluetop BSE Install Issue
- Car Won't Start After Head Gasket Change... Ideas?
