- BC3+ vtec engagement
- clutch-type or helical lsd? which one is better?
- What header to use on my itr motor????????????
- ProFab header vs comptech header
- suggestions welcome...
- Redoing my exhaust setup. need some advice!
- Exhaust diameter for OEM H/A cars
- b18c all motor 240whp 180 torke
- In need of direction... Need a good mid-range cam that peaks at 8500~
- Wiseco applies strutted/boxxed piston technology to K,H,F series
- Valve Clearence?????? B16 head w/ type R cams
- Those that rev beyond 9k, Problems w/ Alternator
- itb owners/ users. how are you routing/ re-routing your coolant lines?
- eagle rod with oversized piston for d16z6
- Reasons for engine "hunting" between 800rpm/2000rpm?
- Hondata Tuners in Pheonix AZ area
- are all b-series differentials interchangeable?
- Cold Start Engine knock/tick (NEW ENGINE THOUGH)
- Anyone know where that article "definative GSR build" went?
- ported intake manifold
- Anyone got a spare counter shaft?
- greasing the axles
- 11.5:1 comp. probe pistons ls/vtec and my head is shaved 40 thousandths..will it work???
- B18c1 GSR Bottom End Rebuild...What should be replaced? Suggestions, Help, etc. please
- All Motor Gsr Hatchy ?
- another wiring question
- oil pressure switch wiring
- Hey u b20/b18c1 vtec people.....hows it going for u?
- sparks header owners or anyone who has tuned one??
- gsr b18 problems?
- ALL-MOTOR GSR B20-VTEC OR LS-VTEC
- z6 milling the head questions
- Compression Q for an ITR
- building a reliable LS/Vtec?
- Axle seals
- SOHC VTEC ALL MOTOR GUYS, can i use a d16z6 cam on a d16y8??
- b-18c1 rebuild
- just got civic type r pistons
- M22 cams eating rocker arms?
- 226whp and 155ish wtq. my graph inside.
- B16A2 setup?
- Questions on Toda header
- 00 SI all motor build up question
- b16a2 all motor plans but i have some question first
- oversized valves, good or bad?
- Ac makes my car whistle and tick
- Street tuned B20VTEC
- Ridiculous Fuel price!!!
- give me your opinion
- Pistons and Camshafts, need help!
- detonation/pre-ignition... HELP!!!
- Spoon tuned ITR
- motor makin a tickin noise
- valve cover to intake pipe thingy
- Hondata Tuners/Dealers and Tuning in FL??
- ls/vtec shifting points?
- plx devices m-250 wideband install help
- N/A guys curious about turbos?
- B16B stroking options
- Cam help?
- Emissions, what you guys think?
- electrical harnesses, which is which?
- Timing Belt with Shaved head and Decked Block
- oem header gasket - which way does it face?
- problem after camshaft install and camgear install HELP please!
- Hondata with Kenji?
- Block Guard
- b16 vs itr intake manifold? which has more area under the curve?
- thinking of b20 block
- Can someone clear up Manifold/TB port matching?
- knife edgeing the crank?
- ls vtec ??build comments
- Power increase from BC spec 3+ cams in stock GSR
- Finally got my motor together. 2 questions. (problems)
- Stock ls rod bolts?? What do YOU rev to? please post.....
- jdm itr head vs the dc sports jdm 4-1 thing..
- Header choice for 'mild' b16, RMF or AN-R... or others...
- GSR intake springs for ITR cams ?
- b16 build up
- quest for more gas mileage
- Portflow Inner\ITR Outter - Largest Cams??
- del slow
- exhaust port has alot of carbon deposites what does this mean???
- which b16a cams?
- B16A indies on a daily good or bad?????
- Probley a simple question for the gurus...... regarding 2 fuel fouled plugs.
- anyone ever had problems with skunk 2 valvetrain?
- how much hp can a ...
- skunk 1 and itr cam combo...
- M22 Question
- **Frustrated** alternator issues :(
- do high c/r engines burn oil faster?
- Forged piston and FRM sleeve compatibility
- ***JUNcr-x got a new Header***
- 02 Sensor ?
- will stock b16 rods handle high compression?
- LS/Vtec
- retourqing head studs....is it necessary (HELP ASAP)
- Quick noob question
- Just read some archived Intake Manifold threads, whats the current consensus?
- 98 civic with b16 for sale
- WTF?? My tachs are going crazy
- Question on Crane Cams
- Is my tranny dead?
- Engine Break In Method
- gsr and b16 header interchangeable
- Crankcase Pressure?, Oil coming out of dipstick pipe
- b16 or ls/vtec
- GSR, Crank and Rods
- B20 vtec head gasket?
- b18c5 block with b16 head ?? Some Questions ??
- Alternator with Optima yellow top?
- please help b20vtec and cams
- b21 timing adjustment
- Compression?
- is it ok to mix up these bolts?? please help now
- H22/F22 Compression Ratio Calculator
- ATTN: Members needing shims for Prelude LMA's.
- are you guys happy with all motor. is this all that na has to offer for full weight integra
- took built b20-v to track the other day. not that happy.
- Need torque specs for the b17 and b18??????
- sir II cams
- Dyno? Testpipe VS. Highflow cat (searched)
- Stage 4 cams with stock block on B20/vtec?
- torque specs on b17 and b18?????
- Recommend my friend a header!
- 13.5:1 compression on the streets?
- RS Machine Phone Number
- difference in ITR and CTR IM's/TB's?
- Which pistons should I get for a B20b?
- tranny problems please help!!
- H22A NO VTEC, opinions please, stumped
- K-series: 2415cc - 90mm x 94.9mm short block
- W T F ---> Why am I losing power with itb's? More money = more problems.....?!
- Help with B18c1 build
- 2.25'' or 2.5'' piping...need help!
- built b16a problem!! plz look
- White smoke, compression ok
- rmf flex pipe installation
- Gsr rod bearings VS Ls rod bearings
- Endyn or DH-Racing
- 200 whp w/ dc 4:1 2.5"?
- Help in my build. b16a 85m
- make my b16b a 1.8 or keep it as is?
- gsr crank into a b16
- Cam Gear + how much? (Milled head, 2-layer headgasket)
- *****Looking for an Awesome tuned LS/VTEC Bin. file, or better yet Chip!!!*****
- Ls/Vtec Problem Need Help right now
- Header Question
- Fully built LS/VTEC
- stock rod bolts and nut issue ?? help needed
- wtf my VTEC!!!!
- plx install having cel prob
- 929 cbr TPS!!! same as car?
- cams and throttle body
- Camshaft break-in procedure, is synthetic oil bad...........
- skunk2 intake mani on gs-r motor
- Datalogging question
- Modify B16B Issue
- 310cc Injectors/B20VTEC 85x89 w/s2 pro cams, too rich???
- Is my 4.7 ITR tranny actually 4.7?
- B series Final Drive from Prodrive or SRR?
- How many of us have had positive manifold pressure with an allmotor setup?
- any good twin loop mufflers for cheap
- EK9 jdmB18C-R wanting to hit 13's..............help!!
- b20 in eg hatch.
- how long does a new motor burn oil for?
- what are my options on tuning?
- Need some parts selection help
- K-series: 2672cc preliminary results
- what bored out throttle body is this i found it and would like to use it on my obd1 gsr motor witha
- erd17a distributor???
- need crower 403 proof of purchase
- IF my tps sensor goes bad, can I use my vafc2 to compensate the change?
- AEBS Intake Manifold for B16 TB
- IS MY 99 GSR with stock compression make power with 100 octane gas?
- compression is low on one cylinder....#2 is 150 psi
- 1 question about vtec (searched)
- B18a Transmission Rebuild?
- Fuel Question
- Catch can question!
- dumb ?
- random question: do any honda engines come with forged internals?
- Toda B's in GSR
- Dyno chart of AEM V2 intake on BONE STOCK 2004 RSX-S
- NEED SLEEVED BLOCK ASAP!!!!!
- ITR Intake camshaft in a B17a1
- Engine Dyno?
- suggestions please
- What size bore headgasket
- oem budget lsvtec build questions
- where is wil exospeed?
- Looks like a good deal, on the other hand you know what they say....
- Which tranny ? and where ?
- Cheap Rebuild...Thoughts, Yes or No
- B18C1 block with a ITR head
- Newbie wants good power
- Need suggestions B20 VTEC
- n/a nissan on a honda forum??
- Good recommended bore size for ITR Throttle body?
- having valve springs cryo'd
- Which manifold n tb would better for my setup
- 2.4 ltr H22 dyno (2point6's)
- Any way you can use 04 Yamaha R6 ITB's?
- gsr del slow
- stroker
- h22 all motor build
- Timing belt, water pump and tensioner change, HELP!
- f20b cams what to use
- Unorthodox pulleys.....
- what thickness head gasket for a LsVTEC 11:1?
- Noob question - engine type?
- Some Spoon exhaust questions
- vtec cutting out
- Will apexi gt headers fit under B16A2 heat shield?
- Bored stock headgasket?
- b16 header fit b18 header?
- B18C5 base, B18B crank, B16A2 head
- good or bad for all motor
- how to remove the crank
- Figuring compression ratio from compression test results?
- titanium or aluminum retainers?
- K-series: Cunningham Titanium rods - 5.500" & 6.235"
- stroker kit??
- Do Valve springs really go bad?
- How do you put a b17 crank in a b16 and can it be done?
- B20 Vtec....Got some setup Questions....
- Fuel pressure to high?
- Yucky ls/vtec 1/4 mile time!
- finally hit 200whp! yay!
- Why do some of you build up heads without port and polish?
- JG Cams
- Can This Be Done?
- High idle problem after new motor install....
- HEAD BOLT SIZE
- Map Sensor Codes....still having issues...All Motor Newbie wants to learn...
- Suggestions on a throttle body
- Gas milage....stock B16 sirII & stock B20VTEC
- Best for all-motor CRX...
- Non-Vtec camshaft ID
- DTR or SMS header?
- help all motor gsr setup!!!!!!!!!
- Injector setup for my buddies H22 swap with chipped obd1 ecu?
- help wih hondata
- I NEED HELP ASAP!!!!
- Installed cams and over-torqued bolts & nuts...how bad?
- JDMshit Intake Manifold
- My setup at 4500ft
- Check this B18c1 setup out!?
- SSworks Keihin FCR Carburetor Kit
