PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 [213] 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. dohc d16a?
  2. stock cams
  3. is skunk2 IM for 95gsr CARB legal?
  4. Exedy Cerametalic 3-puck
  5. my b20/vtec with TODA Bs dyno, what do you think?
  6. b16 setup, want some advice
  7. Can I run 370cc injectors and tune them with a VAFC ?
  8. What will a LS?VTEC set up would or should run in my EG SI
  9. Pre-Ignition and Knock - Let's Get Things Straight
  10. turning the head on the block.
  11. ericks bottom or side exit header
  12. Overlap and adjusting cam gear question
  13. Destroking a b18c
  14. Where to start?
  15. Skunk2 camshafts vs OEM Type R in a B18C1?
  16. lightened flywheel !!
  17. which mark is TDC on the flywheel
  18. Picked up one of these today
  19. 1 piece Edelbrock proflow header?
  20. New guy here with some n00b questions... Toda A's in my GS-R?
  21. DFW/Houston shop for LS/VTEC ??
  22. New Project need help to choice
  23. What size TB bore would you recommend?
  24. difference in water pumps, ITR, SI, GSR
  25. Is this a crazy idea? Flame at will... [Throttle Body]
  26. WHich Pistons?
  27. dyno numbers?
  28. head work on mini me z6
  29. What do you guys use to cut an Intake manifold open?
  30. HELP: Belt Tensioner Bolt 1.8L B18A1
  31. AN-R HEADER
  32. Cometic Head gasket
  33. Best GSR Intake System.
  34. Need help with tunning.
  35. fs b16 block....in nor cal.
  36. Do I need to change my injectors?
  37. JG cams n cam gears
  38. Need Help Engine Break In (please read)
  39. Engine Reving question
  40. Rocket Motorsports Official Modified Spark Plug Dyno comparison
  41. B20 rotating assembly in a B18C1
  42. b18c5 or LSVtec?
  43. open header for daily driving
  44. vtec solinod (sp?) leaking?
  45. looking for all the ITB's companys out there
  46. STR 70MM Throttle body problems ?
  47. type r mania
  48. Best exhaust?
  49. Just one more LS/V question guys...daily driver issue
  50. Gearing
  51. NEED HELP! ADVICE for my allmotor engine setup in DA integra
  52. NEED MORE PONIES
  53. Catch can Oil diagrams.
  54. B16A1 - Recomended mods for N/A power without headwork or new pistons?
  55. Anyone with some pics of the headertech header
  56. Are aftermarket/bigger injectors needed to tune Hondata
  57. Little game for everyone....NAME THAT LSD!!! (please)
  58. valve specs for skunk2 stage 2 on ITR motor...??
  59. When building custom exhaust...
  60. jdm CTR pistons in an N/A ls motor
  61. Could someone regrind my cams?
  62. jdm 4-1 header
  63. soch vtech head on a D16A6 i need help
  64. FASTEST B18B MOTOR SETUP
  65. 2nd gen lsvtec teg...i want 13's how can i get there?
  66. Need help
  67. where should i post my dyno results?
  68. fluidamper work at all rpm?
  69. How to make AEM GSR intake fit skunk2 manifold
  70. EnGine
  71. dyno tune when instaling a new header??
  72. b18c R set up question
  73. my first baseline, FINALLY
  74. b18 toda belt diffrent from b16 toda belt?
  75. What header to get?
  76. Value of a B17 Engine
  77. do you work on your own car?
  78. 1st LSVTEC....(omniman chime in)
  79. too much igniton timing= loss of power?please troubleshoot!
  80. camshaft assembly questions
  81. do crower cams break???
  82. Headgames article in Modified Magazine "February" ..head porting
  83. What should I be running?
  84. Best LSD to use in a drag race?
  85. K port Vs B port
  86. ideal compression for toda spec B's
  87. b18c1+blockguard ???'s...did search...
  88. LS cam options ::help::
  89. B16 or gsr
  90. Short Block and Long Block- What is the difference
  91. N/A b18b build up
  92. your personal experience with chip programs....
  93. Good resource for an LS/VTEC build up???
  94. best place to get crower cams???
  95. Highest octane to run on...
  96. What all is involved in changing pistons out
  97. all motor setup???
  98. ARP rod bolts
  99. which size throttle body?
  100. where in the powerband does high compression play?
  101. what size throttle body do you recommend for my set up if any...
  102. will a OBD I ecu work w/ an OBD 2 dizzy?????
  103. b20 vtec
  104. Please help me out.
  105. b20/vtec
  106. b20 build
  107. cam choices
  108. 4-1 HEADER SHIELD????
  109. b18c1 crank and rods in b17 block?
  110. Rod bolts and high rpm?
  111. All-Motor STREET SOHCs, lets see your complete set-ups, dyno #s, and 1/4 times.
  112. Hondata Intake Manifold Gasket
  113. Splifire spark plugs any good??
  114. what do u think im hitting
  115. what compression do you need for toda d's
  116. Need Roller Rockers
  117. all motor HB
  118. LS crank in GS-R block?
  119. Who you recomend me to make me a Road racing Engine
  120. anyone seen a 2k prelude automatic run 14s NA...need details
  121. how much is a bare block worth? gsr
  122. ebay p28 chips
  123. 5 gen running 14's all motor
  124. Toyota gearbox???
  125. Falls on its face when I nail the throttle??
  126. max bore on stock throttle bodies? where to buy larger butter fly?
  127. K-Series question
  128. aftermarket Intake Manidfold only good with aftermarket throttle body?
  129. JUN II intake cam with JUN III exhaust cam anyone done this?
  130. B18c1 butterfly problems? (SK2 IM)
  131. AEM ems any of you N/A guys running it?
  132. Where do I go in the LA/Orange County area to get LS rods rebushed to run in a D motor?
  133. Engine Shaking when getting on or off throttle. Any thoughts?
  134. VTEC ?
  135. valve adjustment specs on toda spec c's? "I can't search , it is disabled"
  136. Titan Motorsports Port and Polish Dyno Test
  137. p&p with 3 angle valve job...cost estimate
  138. Please help with headwork. Cam choices
  139. Rethinking my set-up, CTR vs. ITR pistons and S2S2's.
  140. Sk2 stg 1 or 2 cams?
  141. quick question:Adj. Timing belt tension posible with engine in car?
  142. quick question
  143. Need some help on what to buy with $2000
  144. ef-1 cams
  145. GSR Tranny with ITR LSD
  146. quick answer needed, will GSR head studs work on my C5?
  147. B18c5 with 2 layer head gasket & jun3's cam gear adjustments & CR? Searched!
  148. B18a/vtec Crower 402's vs Crower 403's??
  149. No power to get up a hill.
  150. Does port work help low end?
  151. how many HP and TORQUE does an 97 ls motor have????
  152. Valve Guides, and Seals
  153. New to all motor...piston blow by = air wooshing out dipstick hole?
  154. So.Cal Meet & BBQ...nature lovers invited!!
  155. Having head rebuild... Question
  156. resizing rods
  157. Odd problem with timing belt and cam gears
  158. I need tips to swap a chevy v8 and RWD into a del sol
  159. LS motor, with a b20 crank? or b16 crank?
  160. Boring and then de-stroking...has anyone heard of this?
  161. 200whp on b18c1
  162. Chipping ECU
  163. clutches
  164. The Great Valve Spring Test
  165. Ratios
  166. 11:8:1 compression je in b18c1
  167. b18/ls rod differences?
  168. N/A is best stickers
  169. a lil vid of my gs-r and friends
  170. all motor b20 vtec build
  171. AEBS studs
  172. POWER PLUS INTAKE???
  173. Anyone want to see a dyno chart of AUTOMATIC B16A cams?
  174. B18 ITB set ups?
  175. posting a block
  176. ::block girdles:: lets discuss
  177. CTR intake cam on stock B20b4, b16 head....Reliefs?
  178. So How many 19mm do you go through for a crank pulley?
  179. Mod
  180. I want to build a motor, Need opinions.
  181. what's a good setup for a daily driver low 13's in a CRX with a B16?
  182. What's better, ITR IM or Skunk2?
  183. S2000 cams & valve train compatible with K series?
  184. help me out jdm r motor or rebuild?
  185. Bore and Stroke
  186. Thoughts on zex/compcams 57200?
  187. Which motor?
  188. p&p question
  189. b16 bore
  190. Expected Power Outpute on Stage 3 setup
  191. p72 head vs. p72-1
  192. na dyno tuning needed in az.
  193. Dart cylinder heads
  194. Compression Calculation Questions.
  195. ITR pistons/rods in d16y8
  196. dumb question, what bolt pattern is the b20 head?
  197. Type-r pistons
  198. b20 vtec What crank
  199. 2.5 MANDREL bent B pipe w/ resonator VS. ITR B pipe (mated to SMSP header/maybe cat/SPOON n1)
  200. single cam motor mounts fit on b- series motor????
  201. sohc vtec d series who loves them
  202. best cams for my ls/vtec set up...
  203. lacking power
  204. bored and stroked 2.2 liter ls vtec
  205. B18c1 INtake Manifold
  206. GUESS MY WHP ....j/k b20 valve reliefs?
  207. obdII to obdI
  208. Compression ratio
  209. Which is better?
  210. P30 pistons with P72 head
  211. CEL 21... WTF mate?
  212. anyone have the receipt to their AEM CAI?
  213. Slippage
  214. y8 into the 13's N/A anyone heard and what is a good setup
  215. 2000 Civic LX 4DR with LS/VTEC questions
  216. ------Choice of Spark Plugs----------
  217. b16a2 with what head? (91 integra ls)
  218. 3500 to spend on rebuild
  219. advanced my distrubter
  220. do you advacing ignition timing with a chipped ecu?
  221. type r cams
  222. the right type
  223. str throttle body users
  224. b18b parts to swap on b20
  225. b16a lsd tranny where can I get one what is a good place.
  226. chipped d16y8
  227. $$$ Worth of a CTR Tranny?
  228. Is it Possible to use a GSR Crank, Rods, and Pistons in a B16A
  229. planning to put a h-22 on ek, got some minor questions?
  230. just installed new piston rings
  231. how do i identify bearing color??
  232. Motor
  233. the right clutch
  234. GSR and type r cams?
  235. cam gears in b20 v-tec
  236. AEBS Head Stud Question
  237. Anyone know of any Machine shops in NJ?
  238. carb setup on d16y8
  239. Rebuilding my jdm B18C
  240. What's the most you can mill off of a b series head?
  241. Cams
  242. Propane Injection for gas 12:1
  243. Endyn or Z10 Breather Kit?
  244. victor x manifold on 200h.p car?
  245. decipher head casting numbers
  246. Oil pump gear
  247. When having your block built...
  248. what crank would you use?
  249. Revs drop below idle when clutch in or putting in neutral...
  250. idle air screw adjustment, other probs
